Date/Time: Sun, 22 Dec 2024 13:16:34 +0000
TPO Question
View Count: 1086
[2015-05-05 18:18:53]
infpz - Posts: 826
I am trying to create the profile charts the way I need them. I want the ability to to look at an individual 30 minute profile to see the volume count per TPO in that bar. What I did (see screen shot lower right) I created a profile that starts at 9:30 ends at 10:00, then a second one that starts at 10:00 and ends at 10:30. This works, but every hour I have to go into the chart settings and change the times to the next hours two time periods. Perhaps there is an easier way?
image1234.png / V - Attached On 2015-05-05 18:18:51 UTC - Size: 23.01 KB - 337 views
[2015-05-05 18:24:34]
It sounds like they want to use the Numbers Bars feature instead:
https://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php
And set the chart bars to be 30 minutes per bar.
Date Time Of Last Edit: 2015-05-05 18:24:55
