Date/Time: Tue, 29 Sep 2026 15:59:28 +0000
triangles shifted
View Count: 1309
| [2015-05-05 18:16:06] |
| User52247 - Posts: 26 |
Hello, How do you explain that the yellows triangles that indicate my inputs and outputs are shifted ? version 1251 et 1252 is same. Thank you for your answer alaindua |
| [2015-05-05 18:19:04] |
We do not understand the question.
| [2015-05-05 19:41:51] |
The triangles do not correspond to the exact value of my trading entries and exits. The triangles next to the candles (see screenshot) |
| [2015-05-06 04:58:07] |
This can be caused by time stamping differences between order fills and the chart bars. Make sure your computer's clock is set accurately. Refer to help topic 38 here: Incorrect Date and/or Time Display, Missing Historical Intraday Data, Chart Not Updating Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
