Date/Time: Sun, 22 Dec 2024 13:41:55 +0000
Cell format in New Spreadsheet
View Count: 1139
[2015-05-05 13:22:03] |
klemmeri - Posts: 2 |
Hi - Try as I might I don't seem to be able get the cell 'numbers' produced by a formula into any other format that a general number. For example, to change a number into a price e.g. 16.5 -> $16.5 using spreadsheet -> Format - > $0.01 I get some strange date-like format. What am I doing wrong here? Tx. klemmeri |
[2015-05-05 18:27:19] |
We will check on this.
[2015-05-05 18:56:20] |
Jeffrey - Posts: 2187 |
I see the problem you are describing. This should be fixed in the next release.
