Date/Time: Sun, 22 Dec 2024 13:51:03 +0000
miss historical datas on MX series
View Count: 926
[2015-05-05 06:03:23] |
vice&virtu - Posts: 43 |
Good morning, I can't find out a solution to fill the missing datas on MX( cac40 future contract on euronext) between 2014-11-20 and 2015-04-15 ( historical and intra-day)even using your different technical recommandations. Thanks for helping rv |
[2015-05-05 09:12:05] |
toc toc toc is there somebody here ??
[2015-05-05 10:44:26] |
Follow the instructions here for a Continuous Futures Contract chart: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
