Date/Time: Sat, 12 Sep 2026 13:02:26 +0000
TPO and footprint data not displaying for Shatz and Buxl
View Count: 1360
| [2015-05-05 04:31:15] |
| olambeth - Posts: 30 |
Hi My TPO and footprint charts are not displaying the correct data for the Shatzl even though OEC has the data available on the s5 trader platform. My chart/data settings are all correct. As you can see from the TPO and intraday chart, I only have data from 30th April. On the footprint chart there is NO data of any trades. Please kindly offer some advice from looking at the screenshot below. Thanks Oliver |
| [2015-05-05 05:25:24] |
This is now solved. Restart Sierra Chart and wait about 10 seconds. After that you can open those charts. Go to one of them and select Edit >>Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-05-05 06:22:44] |
Ok got the footprint working now for Shatz but not the TPO. You can see here that I have 30 days to load on the setting with only a few appearing. Any help please? Date Time Of Last Edit: 2015-05-05 06:26:52
| [2015-05-06 03:56:04] |
Follow the instructions here to download more data: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data The data starts at: 2015-01-30 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
