Date/Time: Sun, 22 Dec 2024 13:45:55 +0000
myTrack changed to Quodd 5/1/15
View Count: 1017
[2015-05-04 19:17:08] |
User339369 - Posts: 7 |
myTrack has changed to Quodd, and now my charts do not update. I have both Quodd running and Sierra Chart running on my computer, but Sierra does not connect. Both myTrack and Quodd say that I need to contact Sierra Chart. Please tell me how to get my live-feed to update Sierra charts. Thanks, Bob
[2015-05-04 21:58:55] |
We do not see how this would work because almost certainly the protocol is different with Quodd . You will need to use the Sierra Chart Real-time and Historical Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
