Date/Time: Sun, 22 Dec 2024 13:18:52 +0000
Old data
View Count: 885
[2015-05-04 18:45:10] |
User87794 - Posts: 10 |
Hi i Have connected to a new data source Rithmic. When I open a chart it is limited by the date of the data. In the Date Range in File it is saying dates like 2004-12-17 to 2005-06017..... I cant get the chart to read past 2005-06-17. I have never struck this problem. I have been using currency charts and they go to current date. I am now using ES charts - what am I missing?? Thx R |
[2015-05-04 18:48:32] |
Please tell us the exact Symbol of the chart.
[2015-05-04 18:50:57] |
Hi The symbol is ESM5-CME, ESH5-CME thx |
[2015-05-04 22:00:40] |
This does not make much sense. Go to one of those charts and select Edit >> Delete All Data and Download. If the chart is not up to date, provide a copy of the Message Log: https://www.sierrachart.com/index.php?page=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
