Date/Time: Sun, 22 Dec 2024 13:44:30 +0000
Two ETFs with two Chart Windows
View Count: 933
[2015-05-04 18:44:20] |
klemmeri - Posts: 2 |
Hi sorry for a question with probably an obvious answer, but can't find it. Trying to open two chart windowswith two intraday ETFS.
[2015-05-04 22:01:23] |
You just need to open another chart. Here are instructions: https://www.sierrachart.com/index.php?page=doc/doc_GettingStarted.php#Step3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
