Date/Time: Sun, 22 Dec 2024 13:13:02 +0000
SBUX stock split 2:1
View Count: 2138
[2015-05-04 17:33:21] |
User39772 - Posts: 311 |
Hello how does the SC data feed for US equities handle stock splits, e.g. in SBUX there is a big Gap due to the split visible in the charts.
[2015-05-04 17:55:28] |
We will have to check on this. Stock split adjustments are done but they are done manually.
[2015-05-06 02:48:10] |
Sierra Chart - Max - Posts: 5756 |
You will need to delete and refresh the data in your chart by selecting Edit >> Delete All Data and Download.
Sierra Chart Support |
