Date/Time: Sun, 22 Dec 2024 13:28:14 +0000
Re: attatching detatched windows
View Count: 956
[2015-05-04 09:33:23]
ripsdips - Posts: 143
I have multiple windows that are detached on one of my systems using multiple screens. I copied and pasted the SC files to an external drive and have loaded them onto another system that is now using 1 screen vs. the 4 screens prior. I cant see the dethatched charts and am trying to find the solution where I can attach them all back?
[2015-05-04 09:55:43]
We need to think about this. Normally our understanding is that Windows will automatically bring them into view if they are offscreen.
[2015-05-04 10:07:21]
Right-click on the Windows taskbar away from any icons on that taskbar, in a blank space, and then select the command "Show Windows Stacked". This should bring all of the windows into view.
