Date/Time: Sun, 22 Dec 2024 13:49:31 +0000
Intraday charts
View Count: 969
[2015-05-04 08:47:08] |
User742670 - Posts: 43 |
Hello, I wanted to ask you how can I load intraday chart that the price will be from the beginning of the future contract opening hour. I have experience that when I open SC for example 8:35 the graph opening price starts at that price at 8:35...but the futures contract opening is at 8:00 and the price is different. So my question is ho can I load intraday chart with opening price at 8:00 and not on the time I am opening the graph? I also tried historical chart..but it loads only in day time frame.. Many thanks David |
[2015-05-04 09:02:21] |
It sounds like there is a problem downloading the historical Intraday data. Refer to this section here for help with this: https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#MissingOrIncompleteIntradayChartData If you still have a problem post a copy of the Message Log by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-05-04 12:46:04] |
Hello, Thanks a lot for the info..the first mentioned solution solved it for me..I would have another question regarding historical data. When I chose FDAX historical data graph to be loaded it automatically set the period back 4380 days but the historical data are only till October last Year...How can i download more then that? Many thanks David |
[2015-05-04 17:38:07] |
You need to use the Continuous Futures Contract chart feature: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
