Date/Time: Sun, 22 Dec 2024 13:08:55 +0000
Alert for when a background changes color
View Count: 1291
[2015-05-04 01:48:13] |
User20214 - Posts: 24 |
Hello, I have a rather simple request, probably child's play to many on this board. I'm seeking to create an alert for when the Color Bar Based On Above/Below Study(Draw Style set to Background)changes color. Why you may ask do I need an alert when the change in background color is enough? I'm using two chart regions using different analysis and trying to sync up the same condition. I searched the forum for any such request and have found none. Any help would be appreciated. |
[2015-05-04 18:03:50] |
You have to write an Alert Formula which compares the main price graph and Subgraph values which are used to color the background. Here is the documentation: https://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html There are examples at the bottom of that page which should be helpful. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
