Date/Time: Sun, 22 Dec 2024 13:07:37 +0000
volume by price, how to get a longer term profile on a shorter term chart
View Count: 987
[2015-05-03 23:27:19] |
User48557 - Posts: 138 |
In the image attached i have a 6 tick renko chart with ''volume by price'' study set at default. The problem with this is i am only getting about 2 days of volume by price data. How can i get 10 days of volume by price data with the exact same chart?
volume profile.PNG / V - Attached On 2015-05-03 23:20:44 UTC - Size: 133.5 KB - 357 views Attachment Deleted. |
[2015-05-06 04:05:00] |
You need to set the Volume Graph Period Type input with the Volume by Price study to what you require: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.html#Settings You may also want set the Always Display Last Profile Within View input to Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
