Date/Time: Sun, 13 Sep 2026 21:31:05 +0000
Numeric Information Graph Draw help
View Count: 1779
[2015-05-01 13:31:38]
User66746 - Posts: 15
Hello everybody i'm novice in language C++ and I don't find in ACSIL Interface Members the functions for display Ask volume, Bid volume, Delta volume,... in NumericInformationGraphDraw. My code source is based on the study 7 - NumericInformationGraphDrawTypeConfig in attachment.
Thank you, best regards.
imageScan.JPG / V - Attached On 2015-05-01 13:30:03 UTC - Size: 169.37 KB - 513 views
attachmentNumericInformationGraphDrawTypeConfig.txt - Attached On 2015-05-01 13:30:23 UTC - Size: 2.72 KB - 642 views
[2015-05-01 18:20:45]
Ask Volume and Bid Volume are sc.BaseData members:
ACSIL Interface Members - Variables and Arrays: sc.BaseDataIn[][] / sc.BaseData[][]
You can easily calculate the difference between the two.
[2015-05-01 18:25:29]
ok I try thanks you
[2015-05-04 14:12:21]
Hello, it doesn't work, my line Ask is empty, I don't understand my error, could you help me help please.
imagescan1.JPG / V - Attached On 2015-05-04 14:12:07 UTC - Size: 150.61 KB - 534 views
attachmentSource Code.txt - Attached On 2015-05-04 14:12:12 UTC - Size: 2.21 KB - 514 views
[2015-05-04 17:11:09]
This is because the Ask Subgraph is not set to anything. You need a line like this:
Ask[sc.Index]= Value;
[2015-05-04 17:16:55]
thank for answer but when build sierra write:
" A:\SierraChart\ACS_Source\aTestcode.cpp: In function 'void scsf_NumericNumber(SCStudyInterfaceRef)':
A:\SierraChart\ACS_Source\aTestcode.cpp:67:18: error: 'Value' was not declared in this scope
Ask[sc.Index]= Value; "
best regards
[2015-05-04 17:32:32]
Yes, this is expected. The Value variable we specified is just an example variable. You will have to assign the value that you want.
[2015-05-04 17:40:55]
OK but which value?, I'm sorry I'm hopeless ^_^
[2015-05-04 18:10:36]
We would not know the answer to this because we do not know what you want to do exactly.
[2015-05-04 18:12:28]
I want just display the ask volume for the moment.
[2015-05-04 21:50:17]
Therefore, use this:
Ask[sc.Index]= sc.BaseData[SC_ASKVOL][sc.Index]
[2015-05-05 07:22:29]
Thank it's Almost ready but I have a différence between the 2 value in my scan. Best regards
Date Time Of Last Edit: 2015-05-05 07:23:02
imagescan.JPG / V - Attached On 2015-05-05 07:22:56 UTC - Size: 82.1 KB - 492 views
[2015-05-05 14:45:02]
ok i'm sorry is find my error thank you so much!
[2015-05-05 16:29:13]
Just last question, how do you calculted 2 variable?
I want to subtract Down tick volume - Bid volume in example:
Deltaupdowntick[sc.index]= (DownTickVolume[sc.Index] - Bid[sc.Index]); is correct??
thank you best regards
[2015-05-05 18:06:45]
Deltaupdowntick[sc.Index]= (DownTickVolume[sc.Index] - sc.BaseData[SC_BIDVOL][sc.Index] )
Date Time Of Last Edit: 2015-05-05 18:07:19
[2015-05-05 18:14:06]
A:\SierraChart\ACS_Source\aTestcode.cpp:95:22: error: 'struct s_sc' has no member named 'index'
Deltaupdowntick[sc.index]= (DownTickVolume[sc.Index] - sc.BaseData[SC_BIDVOL][sc.Index] )
A:\SierraChart\ACS_Source\aTestcode.cpp:100:2: error: expected ';' before 'if'
if (Close[sc.Index] > Close[sc.Index-1])
A:\SierraChart\ACS_Source\aTestcode.cpp:102:2: error: 'else' without a previous 'if'
else
and I try " Deltaupdowntick[sc.index]= (sc.BaseData[SC_DOWNVOL][sc.Index] - sc.BaseData[SC_BIDVOL][sc.Index] )"
but it's not correct.
sorry and thank you for your help.
[2015-05-06 04:56:57]
You need to use sc.Index
This is case sensitive.
[2015-05-06 13:41:32]
Thank you it's perfect ! byebye.
