Date/Time: Sun, 22 Dec 2024 13:26:51 +0000
April 30 Daily Candle wrong
View Count: 972
[2015-05-01 08:45:20] |
User56783 - Posts: 9 |
Hi. My daily candle for yesterday in ES.20150600 is incorrect. It is showing a low of 2093.5 and a close of 2094.25 when the actual low yesterday was 2070.25 or so. I've tried deleting and downloading data and opening a new chart, but neither worked. I've attached a screenshot. It's probably something simple, but please advise. I don't see any postings on the board about this. Thanks. http://www.sierrachart.com/image.php?l=1430469836223.png |
[2015-05-01 09:54:37] |
This is unusual. Right-click before that bar and select Delete and Download Data and then post a copy of the Message Log by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-05-01 10:01:12] |
This time, when I Deleted and Downloaded it loaded the bar properly. The first few times it did not. I had also quit and restarted Sierra Chart and that didn't work either. It is correct now, but I'll post the Message Log in case you want to take a look. Thank you. Software version: 1239 | 2015-05-01 04:15:19 Uses New Spreadsheets | 2015-05-01 04:15:19 Usage end date: 2015-05-23 | 2015-05-01 04:15:19 Enabled for: Advanced Features. | 2015-05-01 04:15:19 Enabled for: Advanced Features 2. | 2015-05-01 04:15:19 Enabled for: Sierra Chart Historical Data Service. | 2015-05-01 04:15:19 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-05-01 04:15:19 Active service: CTS T4 FIX | 2015-05-01 04:15:19 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-05-01 04:15:19 2015-05-01 04:15:19 Local computer clock time | 2015-05-01 04:15:19 2015-05-01 08:15:19 GMT time | 2015-05-01 04:15:19 2015-05-01 04:15:19 Time zone adjusted time | 2015-05-01 04:15:19 Time difference to server time: 0 seconds. | 2015-05-01 04:15:19 Program path: C:\SierraChart\ | 2015-05-01 04:15:19 Data Files path: C:\SierraChart\Data\ | 2015-05-01 04:15:19 OS Version Number: 6.1 | 2015-05-01 04:15:19 Locale Information: C | 2015-05-01 04:15:19 Checking for new symbol settings for cts | 2015-05-01 04:15:19 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-05-01 04:15:19 HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-05-01 04:15:19 Symbol settings are up-to-date for cts | 2015-05-01 04:15:19 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2015-05-01 04:15:24 CTS FIX - Firm: adv | 2015-05-01 04:15:24 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102 | 2015-05-01 04:15:24 CTS FIX socket (2) | Connected. | 2015-05-01 04:15:24 CTS FIX socket (2) | Starting SSL connection. | 2015-05-01 04:15:24 HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-05-01 04:15:25 HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-05-01 04:15:25 CTS FIX socket (2) | SSL connection established. | 2015-05-01 04:15:25 CTS FIX: Sending the Logon message. | 2015-05-01 04:15:26 CTS FIX: Connected to data and trade server. FIX version: 4.3.31.0 | 2015-05-01 04:15:26 CTS T4 FIX | Starting real-time market data updates for: 3YT46T RGFCV YYYYYYYYYYYYYYY T TGHNMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMKKKKKKK KKKKKKLOP000 999999999 NK;.. ID: 1 | 2015-05-01 04:15:26 Symbol Error - 3YT46T RGFCV YYYYYYYYYYYYYYY T TGHNMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMKKKKKKK KKKKKKLOP000 999999999 NK;. is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-01 04:15:26 Intraday data recording state for symbol 3YT46T RGFCV YYYYYYYYYYYYYYY T TGHNMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMKKKKKKK KKKKKKLOP000 999999999 NK;. is set to download pending. | 2015-05-01 04:15:26 HD Request # 2 | Downloading Intraday chart data for 3YT46T RGFCV YYYYYYYYYYYYYYY T TGHNMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMKKKKKKK KKKKKKLOP000 999999999 NK;. to the file 3YT46T RGFCV YYYYYYYYYYYYYYY T TGHNMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMKKKKKKK KKKKKKLOP000 999999999 NK;..scid. Service: cts | 2015-05-01 04:15:26 HD Request # 2 | Download start Date-Time: 2015-04-01 04:15:26.0 | 2015-05-01 04:15:26 HD Request # 2 | Error downloading historical Intraday data for 3YT46T RGFCV YYYYYYYYYYYYYYY T TGHNMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMKKKKKKK KKKKKKLOP000 999999999 NK;.. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2015-05-01 04:15:26 * HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 3YT46T RGFCV YYYYYYYYYYYYYYY T TGHNMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMKKKKKKK KKKKKKLOP000 999999999 NK;. | 2015-05-01 04:15:26 HD Request # 2 | Intraday download COMPLETE for 3YT46T RGFCV YYYYYYYYYYYYYYY T TGHNMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMKKKKKKK KKKKKKLOP000 999999999 NK;.. Completion time: 0s. Unique request ID: 1 | 2015-05-01 04:15:26 Removed historical data download ID 1 | 2015-05-01 04:15:26 Real-time Intraday chart data file updates started for 3YT46T RGFCV YYYYYYYYYYYYYYY T TGHNMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMKKKKKKK KKKKKKLOP000 999999999 NK;. | 2015-05-01 04:15:26 CTS FIX: Received Account List collateral report. | 2015-05-01 04:15:26 CTS FIX: Subscribing to account: 73* | 2015-05-01 04:15:26 Supported exchange: CME_HoOp (CME Housing Options) | 2015-05-01 04:15:26 Supported exchange: E_CUR (Eurex Currency Futures) | 2015-05-01 04:15:26 Supported exchange: ICE_CO (ICE US Commodity Futures) | 2015-05-01 04:15:26 Supported exchange: ICE_IN (ICE US Index Futures) | 2015-05-01 04:15:26 Supported exchange: ICE_COOp (ICE US Commodity Options) | 2015-05-01 04:15:26 Supported exchange: CME_COALOp (NYMEX Coal Options) | 2015-05-01 04:15:26 Supported exchange: CME_REF (NYMEX Refined Products Futures) | 2015-05-01 04:15:26 Supported exchange: ICE_WOp (ICE Canada Options) | 2015-05-01 04:15:26 Supported exchange: ICE_ICOp (ICE EU Options) | 2015-05-01 04:15:26 Supported exchange: CME_COOp (COMEX Options) | 2015-05-01 04:15:26 Supported exchange: ICE_IC (ICE EU Futures) | 2015-05-01 04:15:26 Supported exchange: CME_InOp (CME Interest Rate Options) | 2015-05-01 04:15:26 Supported exchange: CME_OOp (MGEX Options) | 2015-05-01 04:15:26 Supported exchange: CME_COp (CBOT Commodity Options) | 2015-05-01 04:15:26 Supported exchange: LME_ME (LME Metal Futures) | 2015-05-01 04:15:26 Supported exchange: E_INXOp (Eurex Index Options) | 2015-05-01 04:15:26 Supported exchange: CME_PETOp (NYMEX NGL/Petrochemicals Options) | 2015-05-01 04:15:26 Supported exchange: CME_TR (CME TRAKRS Futures) | 2015-05-01 04:15:26 Supported exchange: CME_Eq (CME Equity Futures) | 2015-05-01 04:15:26 Supported exchange: CME_ELE (NYMEX Power Futures) | 2015-05-01 04:15:26 Supported exchange: E_CUROp (Eurex Currency Options) | 2015-05-01 04:15:26 Supported exchange: CME_COAL (NYMEX Coal Futures) | 2015-05-01 04:15:26 Supported exchange: L_J (Euronext Paris Index Futures) | 2015-05-01 04:15:26 Supported exchange: CME_EOp (CBOT Equity Options) | 2015-05-01 04:15:26 Supported exchange: ICE_MOp (ICE US Metals Options) | 2015-05-01 04:15:26 Supported exchange: L_Y (Euronext Paris Commodity Futures) | 2015-05-01 04:15:26 Supported exchange: CME_EqOp (CME Equity Options) | 2015-05-01 04:15:26 Supported exchange: E_INX (Eurex Index Futures) | 2015-05-01 04:15:26 Supported exchange: CME_FOp (CBOT Financial Options) | 2015-05-01 04:15:26 Supported exchange: E_INT (Eurex Interest Rate Futures) | 2015-05-01 04:15:26 Supported exchange: CME_CLOp (NYMEX CrudeOil Options) | 2015-05-01 04:15:26 Supported exchange: CME_REFOp (NYMEX Refined Products Options) | 2015-05-01 04:15:26 Supported exchange: CME_Ag (CME Agricultural Futures) | 2015-05-01 04:15:26 Supported exchange: ICE_COp (ICE EU Commodity Options) | 2015-05-01 04:15:26 Supported exchange: CME_NG (NYMEX NatGas Futures) | 2015-05-01 04:15:26 Supported exchange: CME_AgOp (CME Agricultural Options) | 2015-05-01 04:15:26 Supported exchange: E_VOL (Eurex Volatility Futures) | 2015-05-01 04:15:26 Supported exchange: E_FBDOp (Eurex Fixed Income Options) | 2015-05-01 04:15:26 Supported exchange: CME_NYOp (NYMEX Options) | 2015-05-01 04:15:26 Supported exchange: CME_NY (NYMEX Futures) | 2015-05-01 04:15:26 Supported exchange: LME_PL (LME Plastic Futures) | 2015-05-01 04:15:26 Supported exchange: LME_IN (LME Index Futures) | 2015-05-01 04:15:26 Supported exchange: CBOE_CFE (CFE) | 2015-05-01 04:15:26 Supported exchange: L_YOp (Euronext Paris Commodity Options) | 2015-05-01 04:15:26 Supported exchange: CME_ELEOp (NYMEX Power Options) | 2015-05-01 04:15:26 Supported exchange: CME_NGOp (NYMEX NatGas Options) | 2015-05-01 04:15:26 Supported exchange: ICE_M (ICE US Metals Futures) | 2015-05-01 04:15:26 Supported exchange: CME_We (CME Weather Futures) | 2015-05-01 04:15:26 Supported exchange: ICE_C (ICE EU Commodity Futures) | 2015-05-01 04:15:26 Supported exchange: ICE_CU (ICE US Currency Futures) | 2015-05-01 04:15:26 Supported exchange: ICE_F (ICE EU Financial Futures) | 2015-05-01 04:15:26 Supported exchange: ICE_FOp (ICE EU Financial Options) | 2015-05-01 04:15:26 Supported exchange: CME_Fo (CME Foreign Exchange Futures) | 2015-05-01 04:15:26 Supported exchange: ICE_W (ICE Canada Futures) | 2015-05-01 04:15:26 Supported exchange: ICE_INOp (ICE US Index Options) | 2015-05-01 04:15:26 Supported exchange: CME_Ho (CME Housing Futures) | 2015-05-01 04:15:26 Supported exchange: E_BND (Eurex Fixed Income Futures) | 2015-05-01 04:15:26 Supported exchange: CME_C (CBOT Commodity Futures) | 2015-05-01 04:15:26 Supported exchange: CME_FoOp (CME Foreign Exchange Options) | 2015-05-01 04:15:26 Supported exchange: CME_F (CBOT Financial Futures) | 2015-05-01 04:15:26 Supported exchange: CME_KOp (KCBT Options) | 2015-05-01 04:15:26 Supported exchange: CME_E (CBOT Equity Futures) | 2015-05-01 04:15:26 Supported exchange: CME_CO (COMEX Futures) | 2015-05-01 04:15:26 Supported exchange: CME_K (KCBT Futures) | 2015-05-01 04:15:26 Supported exchange: CME_O (MGEX Futures) | 2015-05-01 04:15:26 Supported exchange: E_FITOp (Eurex Interest Rate Options) | 2015-05-01 04:15:26 Supported exchange: CME_CL (NYMEX CrudeOil Futures) | 2015-05-01 04:15:26 Supported exchange: CME_PET (NYMEX NGL/Petrochemicals Futures) | 2015-05-01 04:15:26 Supported exchange: CME_In (CME Interest Rate Futures) | 2015-05-01 04:15:26 CTS FIX: Received Account Update collateral report. | 2015-05-01 04:15:28 CTS FIX: Requesting Open Orders for account: 73* | 2015-05-01 04:15:31 CTS FIX: Received Account List collateral report. | 2015-05-01 04:15:31 CTS T4 FIX | Starting real-time market data updates for: ES.20141200.CME_Eq. ID: 2 | 2015-05-01 04:15:36 Intraday data recording state for symbol ES.20141200.CME_Eq is set to download pending. | 2015-05-01 04:15:36 HD Request # 3 | Downloading Intraday chart data for ES.20141200.CME_Eq to the file ES.20141200.CME_Eq.scid. Service: cme | 2015-05-01 04:15:36 HD Request # 3 | Download start Date-Time: 2014-12-19 09:29:59.0 | 2015-05-01 04:15:36 CTS T4 FIX | Starting real-time market data updates for: ES.20150600.CME_Eq. ID: 3 | 2015-05-01 04:15:36 HD Request # 3 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-01 04:15:36 HD Request # 4 | Downloading Historical Daily chart data for ES.20150600.CME_Eq. Starting date: 2015-04-29. Service: cts | 2015-05-01 04:15:36 HD Request # 4 | Requesting historical Daily data for ESM15 starting at 2015-04-28 | 2015-05-01 04:15:36 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-01 04:15:36 Socket (3) | Connected. | 2015-05-01 04:15:36 HD Request # 3 | Sending historical data logon request message. | 2015-05-01 04:15:36 Intraday data recording state for symbol ES.20150600.CME_Eq is set to download pending. | 2015-05-01 04:15:36 HD Request # 3 | Requesting Intraday data. Start Date-Time: 2014-12-19 09:29:59. Record interval: 0. Symbol: ESZ14 | 2015-05-01 04:15:36 CTS T4 FIX | Starting real-time market data updates for: ES.20140900.CME_Eq. ID: 4 | 2015-05-01 04:15:36 Intraday data recording state for symbol ES.20140900.CME_Eq is set to download pending. | 2015-05-01 04:15:36 CTS T4 FIX | Starting real-time market data updates for: CL.20150600.CME_NY. ID: 5 | 2015-05-01 04:15:36 Intraday data recording state for symbol CL.20150600.CME_NY is set to download pending. | 2015-05-01 04:15:36 HD Request # 4 | Error downloading historical Daily data for ES.20150600.CME_Eq. <hr><p>HTTP Error 503. The service is unavailable.</p> | 2015-05-01 04:15:36 * HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES.20150600.CME_Eq | 2015-05-01 04:15:36 HD Request # 4 | Daily download COMPLETE for ES.20150600.CME_Eq. Completion time: 0s. Unique request ID: 3 | 2015-05-01 04:15:36 Removed historical data download ID 3 | 2015-05-01 04:15:36 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-05-01 04:15:36 HD Request # 5 | Downloading Historical Daily chart data for CL.20150600.CME_NY. Starting date: 2015-04-29. Service: cts | 2015-05-01 04:15:36 HD Request # 5 | Requesting historical Daily data for CLM15 starting at 2015-04-28 | 2015-05-01 04:15:36 CTS T4 FIX | Starting real-time market data updates for: CL.20150100.CME_NY. ID: 6 | 2015-05-01 04:15:36 Intraday data recording state for symbol CL.20150100.CME_NY is set to download pending. | 2015-05-01 04:15:36 HD Request # 3 | Decompressing data. | 2015-05-01 04:15:36 HD Request # 3 | Receiving Intraday data for ES.20141200.CME_Eq starting at 2014-12-19 09:29:59 | 2015-05-01 04:15:36 Socket (3) | Shutdown and closed. | 2015-05-01 04:15:36 The network socket for historical data has been closed. | 2015-05-01 04:15:36 HD Request # 3 | Received 1 record from 2014-12-19 09:29:59 to 2014-12-19 09:29:59 (0.0 seconds) and wrote 0 records for ES.20141200.CME_Eq | 2015-05-01 04:15:36 HD Request # 3 | Intraday download COMPLETE for ES.20141200.CME_Eq. Completion time: 0s. Unique request ID: 2 | 2015-05-01 04:15:36 Removed historical data download ID 2 | 2015-05-01 04:15:36 Real-time Intraday chart data file updates started for ES.20141200.CME_Eq | 2015-05-01 04:15:36 HD Request # 6 | Downloading Intraday chart data for ES.20150600.CME_Eq to the file ES.20150600.CME_Eq.scid. Service: cme | 2015-05-01 04:15:36 HD Request # 6 | Download start Date-Time: 2015-05-01 04:14:57.0 | 2015-05-01 04:15:36 HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CL.20150600.CME_NY | 2015-05-01 04:15:36 HD Request # 6 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-01 04:15:36 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-01 04:15:36 HD Request # 5 | Daily download COMPLETE for CL.20150600.CME_NY. Completion time: 0s. Unique request ID: 6 | 2015-05-01 04:15:36 Removed historical data download ID 6 | 2015-05-01 04:15:36 CTS T4 FIX | Starting real-time market data updates for: CL.20150300.CME_NY. ID: 7 | 2015-05-01 04:15:36 Intraday data recording state for symbol CL.20150300.CME_NY is set to download pending. | 2015-05-01 04:15:36 Socket (4) | Connected. | 2015-05-01 04:15:36 HD Request # 6 | Sending historical data logon request message. | 2015-05-01 04:15:36 CTS T4 FIX | Starting real-time market data updates for: ZB.20150600.CME_F. ID: 8 | 2015-05-01 04:15:37 Intraday data recording state for symbol ZB.20150600.CME_F is set to download pending. | 2015-05-01 04:15:37 HD Request # 6 | Requesting Intraday data. Start Date-Time: 2015-05-01 04:14:57. Record interval: 0. Symbol: ESM15 | 2015-05-01 04:15:37 CTS T4 FIX | Starting real-time market data updates for: ZN.20150600.CME_F. ID: 9 | 2015-05-01 04:15:37 Intraday data recording state for symbol ZN.20150600.CME_F is set to download pending. | 2015-05-01 04:15:37 HD Request # 6 | Decompressing data. | 2015-05-01 04:15:37 Socket (4) | Shutdown and closed. | 2015-05-01 04:15:37 The network socket for historical data has been closed. | 2015-05-01 04:15:37 HD Request # 6 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES.20150600.CME_Eq | 2015-05-01 04:15:37 HD Request # 6 | Intraday download COMPLETE for ES.20150600.CME_Eq. Completion time: 0s. Unique request ID: 4 | 2015-05-01 04:15:37 Removed historical data download ID 4 | 2015-05-01 04:15:37 Real-time Intraday chart data file updates started for ES.20150600.CME_Eq | 2015-05-01 04:15:37 Intraday data recording state for symbol ES.20150600.CME_Eq is set to download pending. | 2015-05-01 04:15:37 HD Request # 7 | Downloading Intraday chart data for ES.20150600.CME_Eq to the file ES.20150600.CME_Eq.scid. Service: cts | 2015-05-01 04:15:37 HD Request # 7 | Download start Date-Time: 2015-05-01 04:14:57.0 | 2015-05-01 04:15:37 CTS FIX Historical Data - Connecting to Historical data server fix-chart.t4login.com:10443 | 2015-05-01 04:15:37 HD Request # 8 | Downloading Intraday chart data for ES.20140900.CME_Eq to the file ES.20140900.CME_Eq.scid. Service: cme | 2015-05-01 04:15:37 HD Request # 8 | Download start Date-Time: 2014-09-19 09:29:59.0 | 2015-05-01 04:15:37 HD Request # 8 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-01 04:15:37 CTS T4 FIX | Sending security definition request for symbol CL.20150100.CME_NY | 2015-05-01 04:15:37 HD Request # 9 | Downloading Historical Daily chart data for ZB.20150600.CME_F. Starting date: 2015-04-29. Service: cts | 2015-05-01 04:15:37 HD Request # 9 | Requesting historical Daily data for ZBM15 starting at 2015-04-28 | 2015-05-01 04:15:37 CTS T4 FIX | Starting real-time market data updates for: TF.20141200.ICE_IN. ID: 10 | 2015-05-01 04:15:37 Intraday data recording state for symbol TF.20141200.ICE_IN is set to download pending. | 2015-05-01 04:15:37 CTS T4 FIX | Starting real-time market data updates for: F.US.GCEM15. ID: 11 | 2015-05-01 04:15:37 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-01 04:15:37 Socket (5) | Connected. | 2015-05-01 04:15:37 HD Request # 8 | Sending historical data logon request message. | 2015-05-01 04:15:37 CTS FIX Historical Data socket (0) | Resolved address fix-chart.t4login.com to IP 69.44.110.227 | 2015-05-01 04:15:37 Symbol Error - CL.20150100.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2015-05-01 04:15:37 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2015-05-01 04:15:37 HD Request # 9 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZB.20150600.CME_F | 2015-05-01 04:15:37 HD Request # 9 | Daily download COMPLETE for ZB.20150600.CME_F. Completion time: 0s. Unique request ID: 13 | 2015-05-01 04:15:37 Removed historical data download ID 13 | 2015-05-01 04:15:37 Symbol Error - F.US.GCEM15 is unknown, unavailable, or improperly formatted. CTS FIX: Received market data reject: (3) Exchange is not allowed for User | 2015-05-01 04:15:37 HD Request # 10 | Downloading Historical Daily chart data for F.US.GCEM15. Starting date: 2015-04-29. Service: cts | 2015-05-01 04:15:37 HD Request # 10 | Requesting historical Daily data for GCM15 starting at 2015-04-28 | 2015-05-01 04:15:37 HD Request # 8 | Requesting Intraday data. Start Date-Time: 2014-09-19 09:29:59. Record interval: 0. Symbol: ESU14 | 2015-05-01 04:15:37 CTS FIX Historical Data socket (6) | Connected. | 2015-05-01 04:15:37 CTS FIX Historical Data socket (6) | Starting SSL connection. | 2015-05-01 04:15:37 HD Request # 10 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.GCEM15 | 2015-05-01 04:15:37 HD Request # 10 | Daily download COMPLETE for F.US.GCEM15. Completion time: 0s. Unique request ID: 15 | 2015-05-01 04:15:37 Removed historical data download ID 15 | 2015-05-01 04:15:37 CTS FIX Historical Data socket (6) | SSL connection established. | 2015-05-01 04:15:37 HD Request # 8 | Decompressing data. | 2015-05-01 04:15:37 HD Request # 8 | Receiving Intraday data for ES.20140900.CME_Eq starting at 2014-09-19 09:29:59 | 2015-05-01 04:15:37 Socket (5) | Shutdown and closed. | 2015-05-01 04:15:37 The network socket for historical data has been closed. | 2015-05-01 04:15:37 HD Request # 8 | Received 1 record from 2014-09-19 09:29:59 to 2014-09-19 09:29:59 (0.0 seconds) and wrote 0 records for ES.20140900.CME_Eq | 2015-05-01 04:15:37 HD Request # 8 | Intraday download COMPLETE for ES.20140900.CME_Eq. Completion time: 0s. Unique request ID: 5 | 2015-05-01 04:15:37 Removed historical data download ID 5 | 2015-05-01 04:15:37 Real-time Intraday chart data file updates started for ES.20140900.CME_Eq | 2015-05-01 04:15:37 HD Request # 11 | Downloading Intraday chart data for CL.20150600.CME_NY to the file CL.20150600.CME_NY.scid. Service: nymex | 2015-05-01 04:15:37 HD Request # 11 | Download start Date-Time: 2015-05-01 04:15:04.0 | 2015-05-01 04:15:37 HD Request # 11 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-01 04:15:37 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-01 04:15:37 Socket (7) | Connected. | 2015-05-01 04:15:37 HD Request # 11 | Sending historical data logon request message. | 2015-05-01 04:15:37 HD Request # 11 | Requesting Intraday data. Start Date-Time: 2015-05-01 04:15:04. Record interval: 0. Symbol: CLM15 | 2015-05-01 04:15:37 HD Request # 11 | Decompressing data. | 2015-05-01 04:15:37 Socket (7) | Shutdown and closed. | 2015-05-01 04:15:37 The network socket for historical data has been closed. | 2015-05-01 04:15:37 HD Request # 11 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CL.20150600.CME_NY | 2015-05-01 04:15:37 HD Request # 11 | Intraday download COMPLETE for CL.20150600.CME_NY. Completion time: 0s. Unique request ID: 7 | 2015-05-01 04:15:37 Removed historical data download ID 7 | 2015-05-01 04:15:37 Real-time Intraday chart data file updates started for CL.20150600.CME_NY | 2015-05-01 04:15:37 Intraday data recording state for symbol CL.20150600.CME_NY is set to download pending. | 2015-05-01 04:15:37 HD Request # 12 | Downloading Intraday chart data for CL.20150100.CME_NY to the file CL.20150100.CME_NY.scid. Service: nymex | 2015-05-01 04:15:37 HD Request # 12 | Download start Date-Time: 2015-01-01 18:59:59.0 | 2015-05-01 04:15:37 HD Request # 12 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-01 04:15:37 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-01 04:15:37 Socket (8) | Connected. | 2015-05-01 04:15:37 HD Request # 12 | Sending historical data logon request message. | 2015-05-01 04:15:37 HD Request # 12 | Requesting Intraday data. Start Date-Time: 2015-01-01 18:59:59. Record interval: 0. Symbol: CLF15 | 2015-05-01 04:15:38 HD Request # 12 | Decompressing data. | 2015-05-01 04:15:38 HD Request # 12 | Receiving Intraday data for CL.20150100.CME_NY starting at 2014-08-22 15:58:34 | 2015-05-01 04:15:38 CTS FIX Historical Data: Sending the Logon message. | 2015-05-01 04:15:38 CTS T4 FIX | Sending security definition request for symbol CL.20150300.CME_NY | 2015-05-01 04:15:38 CTS FIX Historical Data: Connected to Historical data server. | 2015-05-01 04:15:38 Symbol Error - CL.20150300.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2015-05-01 04:15:38 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2015-05-01 04:15:38 CTS T4 FIX | Sending security definition request for symbol CL.20150600.CME_NY | 2015-05-01 04:15:39 CTS T4 FIX | Received matching security definition for symbol CL.20150600.CME_NY. Subscribing to data. | 2015-05-01 04:15:39 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2015-05-01 04:15:39 CTS T4 FIX | Sending security definition request for symbol ES.20140900.CME_Eq | 2015-05-01 04:15:41 Symbol Error - ES.20140900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2015-05-01 04:15:41 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2015-05-01 04:15:41 CTS FIX: Received Account List collateral report. | 2015-05-01 04:15:41 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Strategies Testing.cht | 2015-05-01 04:15:41 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Strategies Testing.cht | 2015-05-01 04:15:41 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Strategies Testing.cht | 2015-05-01 04:15:41 Chart #1 is performing a full recalculation because it has been tagged. Chartbook: Strategies Testing.cht | 2015-05-01 04:15:41 CTS T4 FIX | Sending security definition request for symbol ES.20141200.CME_Eq | 2015-05-01 04:15:42 Symbol Error - ES.20141200.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2015-05-01 04:15:42 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2015-05-01 04:15:42 CTS T4 FIX | Sending security definition request for symbol ES.20150600.CME_Eq | 2015-05-01 04:15:44 CTS T4 FIX | Received matching security definition for symbol ES.20150600.CME_Eq. Subscribing to data. | 2015-05-01 04:15:44 CTS T4 FIX | Received matching security definition for symbol ES.20150600.CME_Eq. Requesting historical data. | 2015-05-01 04:15:44 HD Request # 7 | Requesting historical Tick data for ES.20150600.CME_Eq from 2015-05-01 00:00:00 to 2015-05-01 00:00:00 (US Central Time). | 2015-05-01 04:15:44 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2015-05-01 04:15:44 HD Request # 7 | Receiving Intraday data for ES.20150600.CME_Eq starting at 2015-04-30 18:00:00 | 2015-05-01 04:15:44 HD Request # 7 | Timestamp of first Intraday data file record written: 2015-05-01 04:15:13 | 2015-05-01 04:15:44 HD Request # 7 | Total records received: 17908 | 2015-05-01 04:15:44 HD Request # 7 | Requesting historical Tick data for ES.20150600.CME_Eq from 2015-05-02 00:00:00 to 2015-05-02 00:00:00 (US Central Time). | 2015-05-01 04:15:44 HD Request # 7 | Total records received: 17908 | 2015-05-01 04:15:44 HD Request # 7 | Requesting historical Tick data for ES.20150600.CME_Eq from 2015-05-03 00:00:00 to 2015-05-03 00:00:00 (US Central Time). | 2015-05-01 04:15:44 HD Request # 7 | Received 17908 records from 2015-04-30 18:00:00 to 2015-05-01 04:15:37 (10.3 hours) and wrote 3 records for ES.20150600.CME_Eq | 2015-05-01 04:15:44 HD Request # 7 | Intraday download COMPLETE for ES.20150600.CME_Eq. Completion time: 7s. Unique request ID: 12 | 2015-05-01 04:15:44 Removed historical data download ID 12 | 2015-05-01 04:15:44 Real-time Intraday chart data file updates started for ES.20150600.CME_Eq | 2015-05-01 04:15:44 HD Request # 13 | Downloading Intraday chart data for CL.20150600.CME_NY to the file CL.20150600.CME_NY.scid. Service: cts | 2015-05-01 04:15:44 HD Request # 13 | Download start Date-Time: 2015-05-01 04:15:04.0 | 2015-05-01 04:15:44 HD Request # 13 | Requesting historical Tick data for CL.20150600.CME_NY from 2015-05-01 00:00:00 to 2015-05-01 00:00:00 (US Central Time). | 2015-05-01 04:15:44 HD Request # 13 | Receiving Intraday data for CL.20150600.CME_NY starting at 2015-04-30 18:00:00 | 2015-05-01 04:15:45 HD Request # 13 | Timestamp of first Intraday data file record written: 2015-05-01 04:15:06 | 2015-05-01 04:15:45 HD Request # 13 | Total records received: 10519 | 2015-05-01 04:15:45 HD Request # 13 | Requesting historical Tick data for CL.20150600.CME_NY from 2015-05-02 00:00:00 to 2015-05-02 00:00:00 (US Central Time). | 2015-05-01 04:15:45 HD Request # 13 | Total records received: 10519 | 2015-05-01 04:15:45 HD Request # 13 | Requesting historical Tick data for CL.20150600.CME_NY from 2015-05-03 00:00:00 to 2015-05-03 00:00:00 (US Central Time). | 2015-05-01 04:15:45 HD Request # 13 | Received 10519 records from 2015-04-30 18:00:00 to 2015-05-01 04:15:40 (10.3 hours) and wrote 39 records for CL.20150600.CME_NY | 2015-05-01 04:15:45 HD Request # 13 | Intraday download COMPLETE for CL.20150600.CME_NY. Completion time: 0s. Unique request ID: 16 | 2015-05-01 04:15:45 Removed historical data download ID 16 | 2015-05-01 04:15:45 Real-time Intraday chart data file updates started for CL.20150600.CME_NY | 2015-05-01 04:15:45 CTS T4 FIX | Sending security definition request for symbol TF.20141200.ICE_IN | 2015-05-01 04:15:45 Symbol Error - TF.20141200.ICE_IN is unknown, unavailable, or improperly formatted. Security definition not found | 2015-05-01 04:15:45 CTS T4 FIX | Received 0 security definitions for underlying symbol TF | 2015-05-01 04:15:45 Socket (8) | Shutdown and closed. | 2015-05-01 04:15:45 The network socket for historical data has been closed. | 2015-05-01 04:15:45 HD Request # 12 | Received 5010121 records from 2014-08-22 15:58:34 to 2014-12-19 14:29:55 (119.0 days) and wrote 0 records for CL.20150100.CME_NY | 2015-05-01 04:15:45 HD Request # 12 | Intraday download COMPLETE for CL.20150100.CME_NY. Completion time: 8s. Unique request ID: 8 | 2015-05-01 04:15:45 Removed historical data download ID 8 | 2015-05-01 04:15:45 Real-time Intraday chart data file updates started for CL.20150100.CME_NY | 2015-05-01 04:15:45 HD Request # 14 | Downloading Intraday chart data for CL.20150300.CME_NY to the file CL.20150300.CME_NY.scid. Service: nymex | 2015-05-01 04:15:46 HD Request # 14 | Download start Date-Time: 2015-03-01 18:59:59.0 | 2015-05-01 04:15:46 HD Request # 14 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-01 04:15:46 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-01 04:15:46 Socket (9) | Connected. | 2015-05-01 04:15:46 HD Request # 14 | Sending historical data logon request message. | 2015-05-01 04:15:46 HD Request # 14 | Requesting Intraday data. Start Date-Time: 2015-03-01 18:59:59. Record interval: 0. Symbol: CLH15 | 2015-05-01 04:15:46 HD Request # 14 | Decompressing data. | 2015-05-01 04:15:46 HD Request # 14 | Receiving Intraday data for CL.20150300.CME_NY starting at 2014-12-22 14:29:59 | 2015-05-01 04:15:46 CTS T4 FIX | Sending security definition request for symbol ZB.20150600.CME_F | 2015-05-01 04:15:47 CTS T4 FIX | Received matching security definition for symbol ZB.20150600.CME_F. Subscribing to data. | 2015-05-01 04:15:47 CTS T4 FIX | Received 1 security definitions for underlying symbol ZB | 2015-05-01 04:15:47 CTS T4 FIX | Sending security definition request for symbol ZN.20150600.CME_F | 2015-05-01 04:15:48 CTS T4 FIX | Received matching security definition for symbol ZN.20150600.CME_F. Subscribing to data. | 2015-05-01 04:15:48 CTS T4 FIX | Received 1 security definitions for underlying symbol ZN | 2015-05-01 04:15:48 Socket (9) | Shutdown and closed. | 2015-05-01 04:15:56 The network socket for historical data has been closed. | 2015-05-01 04:15:56 HD Request # 14 | Received 6412608 records from 2014-12-22 14:29:59 to 2015-02-20 14:29:59 (60.0 days) and wrote 0 records for CL.20150300.CME_NY | 2015-05-01 04:15:56 HD Request # 14 | Intraday download COMPLETE for CL.20150300.CME_NY. Completion time: 10s. Unique request ID: 9 | 2015-05-01 04:15:56 Removed historical data download ID 9 | 2015-05-01 04:15:56 Real-time Intraday chart data file updates started for CL.20150300.CME_NY | 2015-05-01 04:15:56 HD Request # 15 | Downloading Intraday chart data for ZB.20150600.CME_F to the file ZB.20150600.CME_F.scid. Service: cbot | 2015-05-01 04:15:56 HD Request # 15 | Download start Date-Time: 2015-05-01 04:14:20.0 | 2015-05-01 04:15:56 HD Request # 15 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-01 04:15:56 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-01 04:15:56 Socket (10) | Connected. | 2015-05-01 04:15:56 HD Request # 15 | Sending historical data logon request message. | 2015-05-01 04:15:56 HD Request # 15 | Requesting Intraday data. Start Date-Time: 2015-05-01 04:14:20. Record interval: 0. Symbol: ZBM15 | 2015-05-01 04:15:56 HD Request # 15 | Decompressing data. | 2015-05-01 04:15:56 Socket (10) | Shutdown and closed. | 2015-05-01 04:15:56 The network socket for historical data has been closed. | 2015-05-01 04:15:56 HD Request # 15 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZB.20150600.CME_F | 2015-05-01 04:15:56 HD Request # 15 | Intraday download COMPLETE for ZB.20150600.CME_F. Completion time: 0s. Unique request ID: 10 | 2015-05-01 04:15:56 Removed historical data download ID 10 | 2015-05-01 04:15:56 Real-time Intraday chart data file updates started for ZB.20150600.CME_F | 2015-05-01 04:15:56 Intraday data recording state for symbol ZB.20150600.CME_F is set to download pending. | 2015-05-01 04:15:56 HD Request # 16 | Downloading Intraday chart data for ZB.20150600.CME_F to the file ZB.20150600.CME_F.scid. Service: cts | 2015-05-01 04:15:56 HD Request # 16 | Download start Date-Time: 2015-05-01 04:14:20.0 | 2015-05-01 04:15:56 HD Request # 16 | Requesting historical Tick data for ZB.20150600.CME_F from 2015-05-01 00:00:00 to 2015-05-01 00:00:00 (US Central Time). | 2015-05-01 04:15:56 HD Request # 17 | Downloading Intraday chart data for ZN.20150600.CME_F to the file ZN.20150600.CME_F.scid. Service: cbot | 2015-05-01 04:15:56 HD Request # 17 | Download start Date-Time: 2015-05-01 04:14:44.0 | 2015-05-01 04:15:56 HD Request # 17 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-01 04:15:56 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-01 04:15:56 Socket (11) | Connected. | 2015-05-01 04:15:56 HD Request # 17 | Sending historical data logon request message. | 2015-05-01 04:15:56 HD Request # 17 | Requesting Intraday data. Start Date-Time: 2015-05-01 04:14:44. Record interval: 0. Symbol: ZNM15 | 2015-05-01 04:15:56 HD Request # 17 | Decompressing data. | 2015-05-01 04:15:56 Socket (11) | Shutdown and closed. | 2015-05-01 04:15:56 The network socket for historical data has been closed. | 2015-05-01 04:15:56 HD Request # 17 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZN.20150600.CME_F | 2015-05-01 04:15:56 HD Request # 17 | Intraday download COMPLETE for ZN.20150600.CME_F. Completion time: 0s. Unique request ID: 11 | 2015-05-01 04:15:56 Removed historical data download ID 11 | 2015-05-01 04:15:56 Real-time Intraday chart data file updates started for ZN.20150600.CME_F | 2015-05-01 04:15:56 Intraday data recording state for symbol ZN.20150600.CME_F is set to download pending. | 2015-05-01 04:15:56 HD Request # 18 | Downloading Intraday chart data for TF.20141200.ICE_IN to the file TF.20141200.ICE_IN.scid. Service: ice.us | 2015-05-01 04:15:56 HD Request # 18 | Download start Date-Time: 2014-12-19 09:28:24.0 | 2015-05-01 04:15:56 HD Request # 18 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-01 04:15:56 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-01 04:15:56 Socket (12) | Connected. | 2015-05-01 04:15:56 HD Request # 18 | Sending historical data logon request message. | 2015-05-01 04:15:56 HD Request # 18 | Requesting Intraday data. Start Date-Time: 2014-12-19 09:28:24. Record interval: 0. Symbol: RJZ14 | 2015-05-01 04:15:56 HD Request # 16 | Receiving Intraday data for ZB.20150600.CME_F starting at 2015-04-30 18:00:00 | 2015-05-01 04:15:57 HD Request # 16 | Total records received: 2035 | 2015-05-01 04:15:57 HD Request # 16 | Requesting historical Tick data for ZB.20150600.CME_F from 2015-05-02 00:00:00 to 2015-05-02 00:00:00 (US Central Time). | 2015-05-01 04:15:57 HD Request # 16 | Total records received: 2035 | 2015-05-01 04:15:57 HD Request # 16 | Requesting historical Tick data for ZB.20150600.CME_F from 2015-05-03 00:00:00 to 2015-05-03 00:00:00 (US Central Time). | 2015-05-01 04:15:57 HD Request # 18 | Decompressing data. | 2015-05-01 04:15:57 HD Request # 18 | Receiving Intraday data for TF.20141200.ICE_IN starting at 2014-12-19 09:28:24 | 2015-05-01 04:15:57 Socket (12) | Shutdown and closed. | 2015-05-01 04:15:57 The network socket for historical data has been closed. | 2015-05-01 04:15:57 HD Request # 18 | Received 1 record from 2014-12-19 09:28:24 to 2014-12-19 09:28:24 (0.0 seconds) and wrote 0 records for TF.20141200.ICE_IN | 2015-05-01 04:15:57 HD Request # 18 | Intraday download COMPLETE for TF.20141200.ICE_IN. Completion time: 1s. Unique request ID: 14 | 2015-05-01 04:15:57 Removed historical data download ID 14 | 2015-05-01 04:15:57 Real-time Intraday chart data file updates started for TF.20141200.ICE_IN | 2015-05-01 04:15:57 HD Request # 16 | Received 2035 records from 2015-04-30 18:00:00 to 2015-05-01 04:14:20 (10.2 hours) and wrote 0 records for ZB.20150600.CME_F | 2015-05-01 04:15:57 HD Request # 16 | Intraday download COMPLETE for ZB.20150600.CME_F. Completion time: 1s. Unique request ID: 17 | 2015-05-01 04:15:57 Removed historical data download ID 17 | 2015-05-01 04:15:57 Real-time Intraday chart data file updates started for ZB.20150600.CME_F | 2015-05-01 04:15:57 HD Request # 19 | Downloading Intraday chart data for ZN.20150600.CME_F to the file ZN.20150600.CME_F.scid. Service: cts | 2015-05-01 04:15:57 HD Request # 19 | Download start Date-Time: 2015-05-01 04:14:44.0 | 2015-05-01 04:15:57 HD Request # 19 | Requesting historical Tick data for ZN.20150600.CME_F from 2015-05-01 00:00:00 to 2015-05-01 00:00:00 (US Central Time). | 2015-05-01 04:15:57 HD Request # 19 | Receiving Intraday data for ZN.20150600.CME_F starting at 2015-04-30 18:00:00 | 2015-05-01 04:15:57 HD Request # 19 | Timestamp of first Intraday data file record written: 2015-05-01 04:15:11 | 2015-05-01 04:15:57 HD Request # 19 | Total records received: 7164 | 2015-05-01 04:15:57 HD Request # 19 | Requesting historical Tick data for ZN.20150600.CME_F from 2015-05-02 00:00:00 to 2015-05-02 00:00:00 (US Central Time). | 2015-05-01 04:15:57 HD Request # 19 | Total records received: 7164 | 2015-05-01 04:15:57 HD Request # 19 | Requesting historical Tick data for ZN.20150600.CME_F from 2015-05-03 00:00:00 to 2015-05-03 00:00:00 (US Central Time). | 2015-05-01 04:15:57 HD Request # 19 | Received 7164 records from 2015-04-30 18:00:00 to 2015-05-01 04:15:48 (10.3 hours) and wrote 3 records for ZN.20150600.CME_F | 2015-05-01 04:15:57 HD Request # 19 | Intraday download COMPLETE for ZN.20150600.CME_F. Completion time: 0s. Unique request ID: 18 | 2015-05-01 04:15:57 Removed historical data download ID 18 | 2015-05-01 04:15:57 Real-time Intraday chart data file updates started for ZN.20150600.CME_F | 2015-05-01 04:15:57 CTS FIX Historical Data: Received a Logout message. Text = Chart Data Timeout. No valid chart data requests were received within the chart data interval of 60 seconds | 2015-05-01 04:16:57 CTS FIX Historical Data: Sending a Logout message. Text = Received Logout message. | 2015-05-01 04:16:57 CTS FIX Historical Data socket (6) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-01 04:16:57 CTS FIX Historical Data socket (6) | SSL has been shut down. | 2015-05-01 04:16:57 CTS FIX Historical Data socket (6) | SSL object has been freed. SSL state is now disconnected. | 2015-05-01 04:16:57 CTS FIX Historical Data socket (6) | Shutdown and closed. | 2015-05-01 04:16:57 CTS FIX Historical Data: Logged out and disconnected. | 2015-05-01 04:16:57 CTS FIX Historical Data: Disconnected. | 2015-05-01 04:16:57 HD Request # 20 | Downloading Historical Daily chart data for ES.20150600.CME_Eq. Starting date: 2015-04-30. Service: cts | 2015-05-01 04:17:50 HD Request # 20 | Requesting historical Daily data for ESM15 starting at 2015-04-29 | 2015-05-01 04:17:50 HD Request # 20 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES.20150600.CME_Eq | 2015-05-01 04:17:50 HD Request # 20 | Daily download COMPLETE for ES.20150600.CME_Eq. Completion time: 0s. Unique request ID: 19 | 2015-05-01 04:17:50 Removed historical data download ID 19 | 2015-05-01 04:17:50 CTS T4 FIX | Starting real-time market data updates for: ESM15. ID: 24 | 2015-05-01 04:26:09 Symbol Error - ESM15 is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-01 04:26:09 HD Request # 21 | Downloading Historical Daily chart data for ESM15. Starting date: 2015-03-11. Service: cts | 2015-05-01 04:26:09 HD Request # 21 | Error downloading historical Daily data for ESM15. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2015-05-01 04:26:09 * HD Request # 21 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM15 | 2015-05-01 04:26:09 HD Request # 21 | Daily download COMPLETE for ESM15. Completion time: 0s. Unique request ID: 20 | 2015-05-01 04:26:09 Removed historical data download ID 20 | 2015-05-01 04:26:09 Uploaded an image to the server. Request ID: 1 | 2015-05-01 04:31:04 Uploaded an image to the server. Request ID: 2 | 2015-05-01 04:43:55 CTS FIX socket (2) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2015-05-01 05:31:19 CTS FIX socket (2) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-01 05:31:19 CTS FIX socket (2) | SSL has been shut down. | 2015-05-01 05:31:19 CTS FIX socket (2) | SSL object has been freed. SSL state is now disconnected. | 2015-05-01 05:31:19 CTS FIX socket (2) | Shutdown and closed. | 2015-05-01 05:31:19 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2015-05-01 05:31:19 Connection to the external service has been lost. | 2015-05-01 05:31:19 CTS FIX: DisconnectFIX called. | 2015-05-01 05:31:19 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-01 05:31:19 CTS FIX: Disconnected. | 2015-05-01 05:31:19 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-01 05:31:19 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2015-05-01 05:31:22 CTS FIX - Firm: adv | 2015-05-01 05:31:22 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102 | 2015-05-01 05:31:22 CTS FIX socket (13) | Connected. | 2015-05-01 05:31:22 CTS FIX socket (13) | Starting SSL connection. | 2015-05-01 05:31:22 CTS FIX socket (13) | SSL connection established. | 2015-05-01 05:31:22 CTS FIX: Sending the Logon message. | 2015-05-01 05:31:23 CTS FIX: Connected to data and trade server. FIX version: 4.3.31.0 | 2015-05-01 05:31:23 CTS T4 FIX | Starting real-time market data updates for: 3YT46T RGFCV YYYYYYYYYYYYYYY T TGHNMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMKKKKKKK KKKKKKLOP000 999999999 NK;.. ID: 1 | 2015-05-01 05:31:23 Symbol Error - 3YT46T RGFCV YYYYYYYYYYYYYYY T TGHNMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMKKKKKKK KKKKKKLOP000 999999999 NK;. is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-01 05:31:23 Intraday data recording state for symbol 3YT46T RGFCV YYYYYYYYYYYYYYY T TGHNMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMKKKKKKK KKKKKKLOP000 999999999 NK;. is set to download pending. | 2015-05-01 05:31:23 HD Request # 22 | Downloading Intraday chart data for 3YT46T RGFCV YYYYYYYYYYYYYYY T TGHNMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMKKKKKKK KKKKKKLOP000 999999999 NK;. to the file 3YT46T RGFCV YYYYYYYYYYYYYYY T TGHNMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMKKKKKKK KKKKKKLOP000 999999999 NK;..scid. Service: cts | 2015-05-01 05:31:23 HD Request # 22 | Download start Date-Time: 2015-04-01 05:31:23.0 | 2015-05-01 05:31:23 HD Request # 22 | Error downloading historical Intraday data for 3YT46T RGFCV YYYYYYYYYYYYYYY T TGHNMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMKKKKKKK KKKKKKLOP000 999999999 NK;.. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2015-05-01 05:31:23 * HD Request # 22 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 3YT46T RGFCV YYYYYYYYYYYYYYY T TGHNMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMKKKKKKK KKKKKKLOP000 999999999 NK;. | 2015-05-01 05:31:23 HD Request # 22 | Intraday download COMPLETE for 3YT46T RGFCV YYYYYYYYYYYYYYY T TGHNMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMKKKKKKK KKKKKKLOP000 999999999 NK;.. Completion time: 0s. Unique request ID: 21 | 2015-05-01 05:31:23 Removed historical data download ID 21 | 2015-05-01 05:31:23 Real-time Intraday chart data file updates started for 3YT46T RGFCV YYYYYYYYYYYYYYY T TGHNMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMKKKKKKK KKKKKKLOP000 999999999 NK;. | 2015-05-01 05:31:23 CTS FIX: Received Account List collateral report. | 2015-05-01 05:31:23 CTS FIX: Subscribing to account: 73* | 2015-05-01 05:31:23 Supported exchange: CME_HoOp (CME Housing Options) | 2015-05-01 05:31:23 Supported exchange: E_CUR (Eurex Currency Futures) | 2015-05-01 05:31:23 Supported exchange: ICE_CO (ICE US Commodity Futures) | 2015-05-01 05:31:23 Supported exchange: ICE_IN (ICE US Index Futures) | 2015-05-01 05:31:23 Supported exchange: ICE_COOp (ICE US Commodity Options) | 2015-05-01 05:31:23 Supported exchange: CME_COALOp (NYMEX Coal Options) | 2015-05-01 05:31:23 Supported exchange: CME_REF (NYMEX Refined Products Futures) | 2015-05-01 05:31:23 Supported exchange: ICE_WOp (ICE Canada Options) | 2015-05-01 05:31:23 Supported exchange: ICE_ICOp (ICE EU Options) | 2015-05-01 05:31:23 Supported exchange: CME_COOp (COMEX Options) | 2015-05-01 05:31:23 Supported exchange: ICE_IC (ICE EU Futures) | 2015-05-01 05:31:23 Supported exchange: CME_InOp (CME Interest Rate Options) | 2015-05-01 05:31:23 Supported exchange: CME_OOp (MGEX Options) | 2015-05-01 05:31:23 Supported exchange: CME_COp (CBOT Commodity Options) | 2015-05-01 05:31:23 Supported exchange: LME_ME (LME Metal Futures) | 2015-05-01 05:31:23 Supported exchange: E_INXOp (Eurex Index Options) | 2015-05-01 05:31:23 Supported exchange: CME_PETOp (NYMEX NGL/Petrochemicals Options) | 2015-05-01 05:31:23 Supported exchange: CME_TR (CME TRAKRS Futures) | 2015-05-01 05:31:23 Supported exchange: CME_Eq (CME Equity Futures) | 2015-05-01 05:31:23 Supported exchange: CME_ELE (NYMEX Power Futures) | 2015-05-01 05:31:23 Supported exchange: E_CUROp (Eurex Currency Options) | 2015-05-01 05:31:23 Supported exchange: CME_COAL (NYMEX Coal Futures) | 2015-05-01 05:31:23 Supported exchange: L_J (Euronext Paris Index Futures) | 2015-05-01 05:31:23 Supported exchange: CME_EOp (CBOT Equity Options) | 2015-05-01 05:31:23 Supported exchange: ICE_MOp (ICE US Metals Options) | 2015-05-01 05:31:23 Supported exchange: L_Y (Euronext Paris Commodity Futures) | 2015-05-01 05:31:23 Supported exchange: CME_EqOp (CME Equity Options) | 2015-05-01 05:31:23 Supported exchange: E_INX (Eurex Index Futures) | 2015-05-01 05:31:23 Supported exchange: CME_FOp (CBOT Financial Options) | 2015-05-01 05:31:23 Supported exchange: E_INT (Eurex Interest Rate Futures) | 2015-05-01 05:31:23 Supported exchange: CME_CLOp (NYMEX CrudeOil Options) | 2015-05-01 05:31:23 Supported exchange: CME_REFOp (NYMEX Refined Products Options) | 2015-05-01 05:31:23 Supported exchange: CME_Ag (CME Agricultural Futures) | 2015-05-01 05:31:23 Supported exchange: ICE_COp (ICE EU Commodity Options) | 2015-05-01 05:31:23 Supported exchange: CME_NG (NYMEX NatGas Futures) | 2015-05-01 05:31:23 Supported exchange: CME_AgOp (CME Agricultural Options) | 2015-05-01 05:31:23 Supported exchange: E_VOL (Eurex Volatility Futures) | 2015-05-01 05:31:23 Supported exchange: E_FBDOp (Eurex Fixed Income Options) | 2015-05-01 05:31:23 Supported exchange: CME_NYOp (NYMEX Options) | 2015-05-01 05:31:23 Supported exchange: CME_NY (NYMEX Futures) | 2015-05-01 05:31:23 Supported exchange: LME_PL (LME Plastic Futures) | 2015-05-01 05:31:23 Supported exchange: LME_IN (LME Index Futures) | 2015-05-01 05:31:23 Supported exchange: CBOE_CFE (CFE) | 2015-05-01 05:31:23 Supported exchange: L_YOp (Euronext Paris Commodity Options) | 2015-05-01 05:31:23 Supported exchange: CME_ELEOp (NYMEX Power Options) | 2015-05-01 05:31:23 Supported exchange: CME_NGOp (NYMEX NatGas Options) | 2015-05-01 05:31:23 Supported exchange: ICE_M (ICE US Metals Futures) | 2015-05-01 05:31:23 Supported exchange: CME_We (CME Weather Futures) | 2015-05-01 05:31:23 Supported exchange: ICE_C (ICE EU Commodity Futures) | 2015-05-01 05:31:23 Supported exchange: ICE_CU (ICE US Currency Futures) | 2015-05-01 05:31:23 Supported exchange: ICE_F (ICE EU Financial Futures) | 2015-05-01 05:31:23 Supported exchange: ICE_FOp (ICE EU Financial Options) | 2015-05-01 05:31:23 Supported exchange: CME_Fo (CME Foreign Exchange Futures) | 2015-05-01 05:31:23 Supported exchange: ICE_W (ICE Canada Futures) | 2015-05-01 05:31:23 Supported exchange: ICE_INOp (ICE US Index Options) | 2015-05-01 05:31:23 Supported exchange: CME_Ho (CME Housing Futures) | 2015-05-01 05:31:23 Supported exchange: E_BND (Eurex Fixed Income Futures) | 2015-05-01 05:31:23 Supported exchange: CME_C (CBOT Commodity Futures) | 2015-05-01 05:31:23 Supported exchange: CME_FoOp (CME Foreign Exchange Options) | 2015-05-01 05:31:23 Supported exchange: CME_F (CBOT Financial Futures) | 2015-05-01 05:31:23 Supported exchange: CME_KOp (KCBT Options) | 2015-05-01 05:31:23 Supported exchange: CME_E (CBOT Equity Futures) | 2015-05-01 05:31:23 Supported exchange: CME_CO (COMEX Futures) | 2015-05-01 05:31:23 Supported exchange: CME_K (KCBT Futures) | 2015-05-01 05:31:23 Supported exchange: CME_O (MGEX Futures) | 2015-05-01 05:31:23 Supported exchange: E_FITOp (Eurex Interest Rate Options) | 2015-05-01 05:31:23 Supported exchange: CME_CL (NYMEX CrudeOil Futures) | 2015-05-01 05:31:23 Supported exchange: CME_PET (NYMEX NGL/Petrochemicals Futures) | 2015-05-01 05:31:23 Supported exchange: CME_In (CME Interest Rate Futures) | 2015-05-01 05:31:23 CTS T4 FIX | Starting real-time market data updates for: ZB.20150600.CME_F. ID: 2 | 2015-05-01 05:31:23 CTS T4 FIX | Starting real-time market data updates for: ES.20150600.CME_Eq. ID: 3 | 2015-05-01 05:31:23 Intraday data recording state for symbol ES.20150600.CME_Eq is set to download pending. | 2015-05-01 05:31:23 HD Request # 23 | Downloading Intraday chart data for ES.20150600.CME_Eq to the file ES.20150600.CME_Eq.scid. Service: cme | 2015-05-01 05:31:23 HD Request # 23 | Download start Date-Time: 2015-05-01 05:30:10.0 | 2015-05-01 05:31:23 HD Request # 23 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-01 05:31:23 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-01 05:31:23 Socket (14) | Connected. | 2015-05-01 05:31:23 HD Request # 23 | Sending historical data logon request message. | 2015-05-01 05:31:23 HD Request # 23 | Requesting Intraday data. Start Date-Time: 2015-05-01 05:30:10. Record interval: 0. Symbol: ESM15 | 2015-05-01 05:31:23 CTS T4 FIX | Starting real-time market data updates for: ES.20140900.CME_Eq. ID: 4 | 2015-05-01 05:31:23 Intraday data recording state for symbol ES.20140900.CME_Eq is set to download pending. | 2015-05-01 05:31:23 CTS T4 FIX | Starting real-time market data updates for: TF.20141200.ICE_IN. ID: 5 | 2015-05-01 05:31:23 Intraday data recording state for symbol TF.20141200.ICE_IN is set to download pending. | 2015-05-01 05:31:23 CTS T4 FIX | Starting real-time market data updates for: CL.20150600.CME_NY. ID: 6 | 2015-05-01 05:31:23 CTS T4 FIX | Starting real-time market data updates for: F.US.GCEM15. ID: 7 | 2015-05-01 05:31:23 CTS T4 FIX | Starting real-time market data updates for: ES.20141200.CME_Eq. ID: 8 | 2015-05-01 05:31:23 Intraday data recording state for symbol ES.20141200.CME_Eq is set to download pending. | 2015-05-01 05:31:23 Intraday data recording state for symbol CL.20150600.CME_NY is set to download pending. | 2015-05-01 05:31:23 CTS T4 FIX | Starting real-time market data updates for: CL.20150100.CME_NY. ID: 9 | 2015-05-01 05:31:23 Intraday data recording state for symbol CL.20150100.CME_NY is set to download pending. | 2015-05-01 05:31:23 Symbol Error - F.US.GCEM15 is unknown, unavailable, or improperly formatted. CTS FIX: Received market data reject: (3) Exchange is not allowed for User | 2015-05-01 05:31:23 HD Request # 23 | Decompressing data. | 2015-05-01 05:31:23 Socket (14) | Shutdown and closed. | 2015-05-01 05:31:23 The network socket for historical data has been closed. | 2015-05-01 05:31:23 HD Request # 23 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES.20150600.CME_Eq | 2015-05-01 05:31:23 HD Request # 23 | Intraday download COMPLETE for ES.20150600.CME_Eq. Completion time: 0s. Unique request ID: 22 | 2015-05-01 05:31:23 Removed historical data download ID 22 | 2015-05-01 05:31:23 Real-time Intraday chart data file updates started for ES.20150600.CME_Eq | 2015-05-01 05:31:23 Intraday data recording state for symbol ES.20150600.CME_Eq is set to download pending. | 2015-05-01 05:31:23 HD Request # 24 | Downloading Intraday chart data for ES.20150600.CME_Eq to the file ES.20150600.CME_Eq.scid. Service: cts | 2015-05-01 05:31:23 HD Request # 24 | Download start Date-Time: 2015-05-01 05:30:10.0 | 2015-05-01 05:31:23 CTS FIX Historical Data - Connecting to Historical data server fix-chart.t4login.com:10443 | 2015-05-01 05:31:23 HD Request # 25 | Downloading Intraday chart data for ES.20140900.CME_Eq to the file ES.20140900.CME_Eq.scid. Service: cme | 2015-05-01 05:31:23 HD Request # 25 | Download start Date-Time: 2014-09-19 09:29:59.0 | 2015-05-01 05:31:23 HD Request # 25 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-01 05:31:23 CTS T4 FIX | Starting real-time market data updates for: CL.20150300.CME_NY. ID: 10 | 2015-05-01 05:31:23 Intraday data recording state for symbol CL.20150300.CME_NY is set to download pending. | 2015-05-01 05:31:23 Intraday data recording state for symbol ZB.20150600.CME_F is set to download pending. | 2015-05-01 05:31:23 CTS T4 FIX | Starting real-time market data updates for: ZN.20150600.CME_F. ID: 11 | 2015-05-01 05:31:23 Intraday data recording state for symbol ZN.20150600.CME_F is set to download pending. | 2015-05-01 05:31:23 CTS FIX Historical Data socket (0) | Resolved address fix-chart.t4login.com to IP 69.44.110.227 | 2015-05-01 05:31:23 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-01 05:31:23 Socket (15) | Connected. | 2015-05-01 05:31:23 HD Request # 25 | Sending historical data logon request message. | 2015-05-01 05:31:23 CTS FIX Historical Data socket (16) | Connected. | 2015-05-01 05:31:23 CTS FIX Historical Data socket (16) | Starting SSL connection. | 2015-05-01 05:31:23 HD Request # 25 | Requesting Intraday data. Start Date-Time: 2014-09-19 09:29:59. Record interval: 0. Symbol: ESU14 | 2015-05-01 05:31:24 CTS FIX Historical Data socket (16) | SSL connection established. | 2015-05-01 05:31:24 HD Request # 25 | Decompressing data. | 2015-05-01 05:31:24 HD Request # 25 | Receiving Intraday data for ES.20140900.CME_Eq starting at 2014-09-19 09:29:59 | 2015-05-01 05:31:24 Socket (15) | Shutdown and closed. | 2015-05-01 05:31:24 The network socket for historical data has been closed. | 2015-05-01 05:31:24 HD Request # 25 | Received 1 record from 2014-09-19 09:29:59 to 2014-09-19 09:29:59 (0.0 seconds) and wrote 0 records for ES.20140900.CME_Eq | 2015-05-01 05:31:24 HD Request # 25 | Intraday download COMPLETE for ES.20140900.CME_Eq. Completion time: 0s. Unique request ID: 23 | 2015-05-01 05:31:24 Removed historical data download ID 23 | 2015-05-01 05:31:24 Real-time Intraday chart data file updates started for ES.20140900.CME_Eq | 2015-05-01 05:31:24 HD Request # 26 | Downloading Intraday chart data for TF.20141200.ICE_IN to the file TF.20141200.ICE_IN.scid. Service: ice.us | 2015-05-01 05:31:24 HD Request # 26 | Download start Date-Time: 2014-12-19 09:28:24.0 | 2015-05-01 05:31:24 HD Request # 26 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-01 05:31:24 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-01 05:31:24 Socket (17) | Connected. | 2015-05-01 05:31:24 HD Request # 26 | Sending historical data logon request message. | 2015-05-01 05:31:24 CTS T4 FIX | Sending security definition request for symbol CL.20150100.CME_NY | 2015-05-01 05:31:24 HD Request # 26 | Requesting Intraday data. Start Date-Time: 2014-12-19 09:28:24. Record interval: 0. Symbol: RJZ14 | 2015-05-01 05:31:24 CTS FIX Historical Data: Sending the Logon message. | 2015-05-01 05:31:24 Symbol Error - CL.20150100.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2015-05-01 05:31:24 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2015-05-01 05:31:24 CTS FIX Historical Data: Connected to Historical data server. | 2015-05-01 05:31:24 HD Request # 26 | Decompressing data. | 2015-05-01 05:31:24 HD Request # 26 | Receiving Intraday data for TF.20141200.ICE_IN starting at 2014-12-19 09:28:24 | 2015-05-01 05:31:24 Socket (17) | Shutdown and closed. | 2015-05-01 05:31:24 The network socket for historical data has been closed. | 2015-05-01 05:31:24 HD Request # 26 | Received 1 record from 2014-12-19 09:28:24 to 2014-12-19 09:28:24 (0.0 seconds) and wrote 0 records for TF.20141200.ICE_IN | 2015-05-01 05:31:24 HD Request # 26 | Intraday download COMPLETE for TF.20141200.ICE_IN. Completion time: 0s. Unique request ID: 24 | 2015-05-01 05:31:24 Removed historical data download ID 24 | 2015-05-01 05:31:24 Real-time Intraday chart data file updates started for TF.20141200.ICE_IN | 2015-05-01 05:31:24 HD Request # 27 | Downloading Intraday chart data for ES.20141200.CME_Eq to the file ES.20141200.CME_Eq.scid. Service: cme | 2015-05-01 05:31:24 HD Request # 27 | Download start Date-Time: 2014-12-19 09:29:59.0 | 2015-05-01 05:31:24 HD Request # 27 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-01 05:31:24 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-01 05:31:24 Socket (18) | Connected. | 2015-05-01 05:31:24 HD Request # 27 | Sending historical data logon request message. | 2015-05-01 05:31:24 HD Request # 27 | Requesting Intraday data. Start Date-Time: 2014-12-19 09:29:59. Record interval: 0. Symbol: ESZ14 | 2015-05-01 05:31:24 HD Request # 27 | Decompressing data. | 2015-05-01 05:31:24 HD Request # 27 | Receiving Intraday data for ES.20141200.CME_Eq starting at 2014-12-19 09:29:59 | 2015-05-01 05:31:24 Socket (18) | Shutdown and closed. | 2015-05-01 05:31:24 The network socket for historical data has been closed. | 2015-05-01 05:31:24 HD Request # 27 | Received 1 record from 2014-12-19 09:29:59 to 2014-12-19 09:29:59 (0.0 seconds) and wrote 0 records for ES.20141200.CME_Eq | 2015-05-01 05:31:24 HD Request # 27 | Intraday download COMPLETE for ES.20141200.CME_Eq. Completion time: 0s. Unique request ID: 25 | 2015-05-01 05:31:24 Removed historical data download ID 25 | 2015-05-01 05:31:24 Real-time Intraday chart data file updates started for ES.20141200.CME_Eq | 2015-05-01 05:31:24 HD Request # 28 | Downloading Intraday chart data for CL.20150600.CME_NY to the file CL.20150600.CME_NY.scid. Service: nymex | 2015-05-01 05:31:24 HD Request # 28 | Download start Date-Time: 2015-05-01 05:30:28.0 | 2015-05-01 05:31:24 HD Request # 28 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-01 05:31:24 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-01 05:31:24 Socket (19) | Connected. | 2015-05-01 05:31:24 HD Request # 28 | Sending historical data logon request message. | 2015-05-01 05:31:24 HD Request # 28 | Requesting Intraday data. Start Date-Time: 2015-05-01 05:30:28. Record interval: 0. Symbol: CLM15 | 2015-05-01 05:31:24 HD Request # 28 | Decompressing data. | 2015-05-01 05:31:24 Socket (19) | Shutdown and closed. | 2015-05-01 05:31:24 The network socket for historical data has been closed. | 2015-05-01 05:31:24 HD Request # 28 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CL.20150600.CME_NY | 2015-05-01 05:31:24 HD Request # 28 | Intraday download COMPLETE for CL.20150600.CME_NY. Completion time: 0s. Unique request ID: 26 | 2015-05-01 05:31:24 Removed historical data download ID 26 | 2015-05-01 05:31:24 Real-time Intraday chart data file updates started for CL.20150600.CME_NY | 2015-05-01 05:31:24 Intraday data recording state for symbol CL.20150600.CME_NY is set to download pending. | 2015-05-01 05:31:24 HD Request # 29 | Downloading Intraday chart data for CL.20150100.CME_NY to the file CL.20150100.CME_NY.scid. Service: nymex | 2015-05-01 05:31:24 HD Request # 29 | Download start Date-Time: 2015-01-01 18:59:59.0 | 2015-05-01 05:31:24 HD Request # 29 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-01 05:31:24 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-01 05:31:24 Chart #2 has tagged chart #1 for full recalculation. Chartbook: Strategies Testing.cht | 2015-05-01 05:31:24 Socket (20) | Connected. | 2015-05-01 05:31:24 HD Request # 29 | Sending historical data logon request message. | 2015-05-01 05:31:24 HD Request # 29 | Requesting Intraday data. Start Date-Time: 2015-01-01 18:59:59. Record interval: 0. Symbol: CLF15 | 2015-05-01 05:31:24 HD Request # 29 | Decompressing data. | 2015-05-01 05:31:25 HD Request # 29 | Receiving Intraday data for CL.20150100.CME_NY starting at 2014-08-22 15:58:34 | 2015-05-01 05:31:25 Chart #1 is performing a full recalculation because it has been tagged. Chartbook: Strategies Testing.cht | 2015-05-01 05:31:25 CTS T4 FIX | Sending security definition request for symbol CL.20150300.CME_NY | 2015-05-01 05:31:25 Symbol Error - CL.20150300.CME_NY is unknown, unavailable, or improperly formatted. Security definition not found | 2015-05-01 05:31:25 CTS T4 FIX | Received 0 security definitions for underlying symbol CL | 2015-05-01 05:31:25 CTS FIX: Received Account Update collateral report. | 2015-05-01 05:31:26 CTS T4 FIX | Sending security definition request for symbol CL.20150600.CME_NY | 2015-05-01 05:31:26 CTS T4 FIX | Received matching security definition for symbol CL.20150600.CME_NY. Subscribing to data. | 2015-05-01 05:31:27 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2015-05-01 05:31:27 CTS FIX: Requesting Open Orders for account: 73* | 2015-05-01 05:31:28 CTS FIX: Received Account List collateral report. | 2015-05-01 05:31:28 CTS T4 FIX | Sending security definition request for symbol ES.20140900.CME_Eq | 2015-05-01 05:31:28 Symbol Error - ES.20140900.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2015-05-01 05:31:28 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2015-05-01 05:31:28 CTS T4 FIX | Sending security definition request for symbol ES.20141200.CME_Eq | 2015-05-01 05:31:29 Symbol Error - ES.20141200.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2015-05-01 05:31:30 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2015-05-01 05:31:30 CTS T4 FIX | Sending security definition request for symbol ES.20150600.CME_Eq | 2015-05-01 05:31:31 CTS T4 FIX | Received matching security definition for symbol ES.20150600.CME_Eq. Subscribing to data. | 2015-05-01 05:31:31 CTS T4 FIX | Received matching security definition for symbol ES.20150600.CME_Eq. Requesting historical data. | 2015-05-01 05:31:31 HD Request # 24 | Requesting historical Tick data for ES.20150600.CME_Eq from 2015-05-01 00:00:00 to 2015-05-01 00:00:00 (US Central Time). | 2015-05-01 05:31:31 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2015-05-01 05:31:31 HD Request # 24 | Receiving Intraday data for ES.20150600.CME_Eq starting at 2015-04-30 18:00:00 | 2015-05-01 05:31:32 HD Request # 24 | Timestamp of first Intraday data file record written: 2015-05-01 05:30:48 | 2015-05-01 05:31:32 HD Request # 24 | Total records received: 18981 | 2015-05-01 05:31:32 HD Request # 24 | Requesting historical Tick data for ES.20150600.CME_Eq from 2015-05-02 00:00:00 to 2015-05-02 00:00:00 (US Central Time). | 2015-05-01 05:31:32 HD Request # 24 | Total records received: 18981 | 2015-05-01 05:31:32 HD Request # 24 | Requesting historical Tick data for ES.20150600.CME_Eq from 2015-05-03 00:00:00 to 2015-05-03 00:00:00 (US Central Time). | 2015-05-01 05:31:32 HD Request # 24 | Received 18981 records from 2015-04-30 18:00:00 to 2015-05-01 05:31:23 (11.5 hours) and wrote 19 records for ES.20150600.CME_Eq | 2015-05-01 05:31:32 HD Request # 24 | Intraday download COMPLETE for ES.20150600.CME_Eq. Completion time: 9s. Unique request ID: 28 | 2015-05-01 05:31:32 Removed historical data download ID 28 | 2015-05-01 05:31:32 Real-time Intraday chart data file updates started for ES.20150600.CME_Eq | 2015-05-01 05:31:32 HD Request # 30 | Downloading Intraday chart data for CL.20150600.CME_NY to the file CL.20150600.CME_NY.scid. Service: cts | 2015-05-01 05:31:32 HD Request # 30 | Download start Date-Time: 2015-05-01 05:30:28.0 | 2015-05-01 05:31:32 HD Request # 30 | Requesting historical Tick data for CL.20150600.CME_NY from 2015-05-01 00:00:00 to 2015-05-01 00:00:00 (US Central Time). | 2015-05-01 05:31:32 HD Request # 30 | Receiving Intraday data for CL.20150600.CME_NY starting at 2015-04-30 18:00:00 | 2015-05-01 05:31:32 HD Request # 30 | Timestamp of first Intraday data file record written: 2015-05-01 05:30:34 | 2015-05-01 05:31:32 HD Request # 30 | Total records received: 13711 | 2015-05-01 05:31:32 HD Request # 30 | Requesting historical Tick data for CL.20150600.CME_NY from 2015-05-02 00:00:00 to 2015-05-02 00:00:00 (US Central Time). | 2015-05-01 05:31:32 HD Request # 30 | Total records received: 13711 | 2015-05-01 05:31:32 HD Request # 30 | Requesting historical Tick data for CL.20150600.CME_NY from 2015-05-03 00:00:00 to 2015-05-03 00:00:00 (US Central Time). | 2015-05-01 05:31:32 HD Request # 30 | Received 13711 records from 2015-04-30 18:00:00 to 2015-05-01 05:31:31 (11.5 hours) and wrote 13 records for CL.20150600.CME_NY | 2015-05-01 05:31:32 HD Request # 30 | Intraday download COMPLETE for CL.20150600.CME_NY. Completion time: 0s. Unique request ID: 32 | 2015-05-01 05:31:32 Removed historical data download ID 32 | 2015-05-01 05:31:32 Real-time Intraday chart data file updates started for CL.20150600.CME_NY | 2015-05-01 05:31:32 CTS T4 FIX | Sending security definition request for symbol TF.20141200.ICE_IN | 2015-05-01 05:31:33 Symbol Error - TF.20141200.ICE_IN is unknown, unavailable, or improperly formatted. Security definition not found | 2015-05-01 05:31:33 CTS T4 FIX | Received 0 security definitions for underlying symbol TF | 2015-05-01 05:31:33 Socket (20) | Shutdown and closed. | 2015-05-01 05:31:33 The network socket for historical data has been closed. | 2015-05-01 05:31:33 HD Request # 29 | Received 5010121 records from 2014-08-22 15:58:34 to 2014-12-19 14:29:55 (119.0 days) and wrote 0 records for CL.20150100.CME_NY | 2015-05-01 05:31:33 HD Request # 29 | Intraday download COMPLETE for CL.20150100.CME_NY. Completion time: 9s. Unique request ID: 27 | 2015-05-01 05:31:33 Removed historical data download ID 27 | 2015-05-01 05:31:33 Real-time Intraday chart data file updates started for CL.20150100.CME_NY | 2015-05-01 05:31:33 HD Request # 31 | Downloading Intraday chart data for CL.20150300.CME_NY to the file CL.20150300.CME_NY.scid. Service: nymex | 2015-05-01 05:31:33 HD Request # 31 | Download start Date-Time: 2015-03-01 18:59:59.0 | 2015-05-01 05:31:33 HD Request # 31 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-01 05:31:33 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-01 05:31:33 Socket (21) | Connected. | 2015-05-01 05:31:33 HD Request # 31 | Sending historical data logon request message. | 2015-05-01 05:31:33 HD Request # 31 | Requesting Intraday data. Start Date-Time: 2015-03-01 18:59:59. Record interval: 0. Symbol: CLH15 | 2015-05-01 05:31:33 HD Request # 31 | Decompressing data. | 2015-05-01 05:31:33 HD Request # 31 | Receiving Intraday data for CL.20150300.CME_NY starting at 2014-12-22 14:29:59 | 2015-05-01 05:31:33 CTS T4 FIX | Sending security definition request for symbol ZB.20150600.CME_F | 2015-05-01 05:31:34 CTS T4 FIX | Received matching security definition for symbol ZB.20150600.CME_F. Subscribing to data. | 2015-05-01 05:31:34 CTS T4 FIX | Received 1 security definitions for underlying symbol ZB | 2015-05-01 05:31:34 CTS T4 FIX | Sending security definition request for symbol ZN.20150600.CME_F | 2015-05-01 05:31:36 CTS T4 FIX | Received matching security definition for symbol ZN.20150600.CME_F. Subscribing to data. | 2015-05-01 05:31:36 CTS T4 FIX | Received 1 security definitions for underlying symbol ZN | 2015-05-01 05:31:36 CTS FIX: Received Account List collateral report. | 2015-05-01 05:31:38 Socket (21) | Shutdown and closed. | 2015-05-01 05:31:43 The network socket for historical data has been closed. | 2015-05-01 05:31:43 HD Request # 31 | Received 6412608 records from 2014-12-22 14:29:59 to 2015-02-20 14:29:59 (60.0 days) and wrote 0 records for CL.20150300.CME_NY | 2015-05-01 05:31:43 HD Request # 31 | Intraday download COMPLETE for CL.20150300.CME_NY. Completion time: 10s. Unique request ID: 29 | 2015-05-01 05:31:43 Removed historical data download ID 29 | 2015-05-01 05:31:43 Real-time Intraday chart data file updates started for CL.20150300.CME_NY | 2015-05-01 05:31:43 HD Request # 32 | Downloading Intraday chart data for ZB.20150600.CME_F to the file ZB.20150600.CME_F.scid. Service: cbot | 2015-05-01 05:31:43 HD Request # 32 | Download start Date-Time: 2015-05-01 05:29:55.0 | 2015-05-01 05:31:43 HD Request # 32 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-01 05:31:43 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-01 05:31:43 Socket (22) | Connected. | 2015-05-01 05:31:43 HD Request # 32 | Sending historical data logon request message. | 2015-05-01 05:31:43 HD Request # 32 | Requesting Intraday data. Start Date-Time: 2015-05-01 05:29:55. Record interval: 0. Symbol: ZBM15 | 2015-05-01 05:31:43 HD Request # 32 | Decompressing data. | 2015-05-01 05:31:43 Socket (22) | Shutdown and closed. | 2015-05-01 05:31:43 The network socket for historical data has been closed. | 2015-05-01 05:31:43 HD Request # 32 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZB.20150600.CME_F | 2015-05-01 05:31:43 HD Request # 32 | Intraday download COMPLETE for ZB.20150600.CME_F. Completion time: 0s. Unique request ID: 30 | 2015-05-01 05:31:43 Removed historical data download ID 30 | 2015-05-01 05:31:43 Real-time Intraday chart data file updates started for ZB.20150600.CME_F | 2015-05-01 05:31:43 Intraday data recording state for symbol ZB.20150600.CME_F is set to download pending. | 2015-05-01 05:31:43 HD Request # 33 | Downloading Intraday chart data for ZB.20150600.CME_F to the file ZB.20150600.CME_F.scid. Service: cts | 2015-05-01 05:31:43 HD Request # 33 | Download start Date-Time: 2015-05-01 05:29:55.0 | 2015-05-01 05:31:43 HD Request # 33 | Requesting historical Tick data for ZB.20150600.CME_F from 2015-05-01 00:00:00 to 2015-05-01 00:00:00 (US Central Time). | 2015-05-01 05:31:43 HD Request # 34 | Downloading Intraday chart data for ZN.20150600.CME_F to the file ZN.20150600.CME_F.scid. Service: cbot | 2015-05-01 05:31:43 HD Request # 34 | Download start Date-Time: 2015-05-01 05:30:29.0 | 2015-05-01 05:31:43 HD Request # 34 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-01 05:31:43 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-01 05:31:43 HD Request # 33 | Receiving Intraday data for ZB.20150600.CME_F starting at 2015-04-30 18:00:00 | 2015-05-01 05:31:43 Socket (23) | Connected. | 2015-05-01 05:31:43 HD Request # 34 | Sending historical data logon request message. | 2015-05-01 05:31:43 HD Request # 33 | Timestamp of first Intraday data file record written: 2015-05-01 05:30:58 | 2015-05-01 05:31:43 HD Request # 33 | Total records received: 2432 | 2015-05-01 05:31:43 HD Request # 33 | Requesting historical Tick data for ZB.20150600.CME_F from 2015-05-02 00:00:00 to 2015-05-02 00:00:00 (US Central Time). | 2015-05-01 05:31:43 HD Request # 33 | Total records received: 2432 | 2015-05-01 05:31:43 HD Request # 33 | Requesting historical Tick data for ZB.20150600.CME_F from 2015-05-03 00:00:00 to 2015-05-03 00:00:00 (US Central Time). | 2015-05-01 05:31:43 HD Request # 34 | Requesting Intraday data. Start Date-Time: 2015-05-01 05:30:29. Record interval: 0. Symbol: ZNM15 | 2015-05-01 05:31:43 HD Request # 34 | Decompressing data. | 2015-05-01 05:31:43 Socket (23) | Shutdown and closed. | 2015-05-01 05:31:43 The network socket for historical data has been closed. | 2015-05-01 05:31:43 HD Request # 34 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZN.20150600.CME_F | 2015-05-01 05:31:43 HD Request # 34 | Intraday download COMPLETE for ZN.20150600.CME_F. Completion time: 0s. Unique request ID: 31 | 2015-05-01 05:31:43 Removed historical data download ID 31 | 2015-05-01 05:31:43 Real-time Intraday chart data file updates started for ZN.20150600.CME_F | 2015-05-01 05:31:43 Intraday data recording state for symbol ZN.20150600.CME_F is set to download pending. | 2015-05-01 05:31:43 HD Request # 33 | Received 2432 records from 2015-04-30 18:00:00 to 2015-05-01 05:30:58 (11.5 hours) and wrote 1 record for ZB.20150600.CME_F | 2015-05-01 05:31:43 HD Request # 33 | Intraday download COMPLETE for ZB.20150600.CME_F. Completion time: 0s. Unique request ID: 33 | 2015-05-01 05:31:43 Removed historical data download ID 33 | 2015-05-01 05:31:43 Real-time Intraday chart data file updates started for ZB.20150600.CME_F | 2015-05-01 05:31:43 HD Request # 35 | Downloading Intraday chart data for ZN.20150600.CME_F to the file ZN.20150600.CME_F.scid. Service: cts | 2015-05-01 05:31:43 HD Request # 35 | Download start Date-Time: 2015-05-01 05:30:29.0 | 2015-05-01 05:31:43 HD Request # 35 | Requesting historical Tick data for ZN.20150600.CME_F from 2015-05-01 00:00:00 to 2015-05-01 00:00:00 (US Central Time). | 2015-05-01 05:31:43 HD Request # 35 | Receiving Intraday data for ZN.20150600.CME_F starting at 2015-04-30 18:00:00 | 2015-05-01 05:31:43 HD Request # 35 | Timestamp of first Intraday data file record written: 2015-05-01 05:30:37 | 2015-05-01 05:31:43 HD Request # 35 | Total records received: 8412 | 2015-05-01 05:31:43 HD Request # 35 | Requesting historical Tick data for ZN.20150600.CME_F from 2015-05-02 00:00:00 to 2015-05-02 00:00:00 (US Central Time). | 2015-05-01 05:31:43 HD Request # 35 | Total records received: 8412 | 2015-05-01 05:31:43 HD Request # 35 | Requesting historical Tick data for ZN.20150600.CME_F from 2015-05-03 00:00:00 to 2015-05-03 00:00:00 (US Central Time). | 2015-05-01 05:31:43 HD Request # 35 | Received 8412 records from 2015-04-30 18:00:00 to 2015-05-01 05:31:39 (11.5 hours) and wrote 14 records for ZN.20150600.CME_F | 2015-05-01 05:31:43 HD Request # 35 | Intraday download COMPLETE for ZN.20150600.CME_F. Completion time: 0s. Unique request ID: 34 | 2015-05-01 05:31:43 Removed historical data download ID 34 | 2015-05-01 05:31:43 Real-time Intraday chart data file updates started for ZN.20150600.CME_F | 2015-05-01 05:31:43 CTS FIX Historical Data socket (16) | Closed. No error. | 2015-05-01 05:32:43 CTS FIX Historical Data socket (16) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-01 05:32:43 CTS FIX Historical Data socket (16) | SSL has been shut down. | 2015-05-01 05:32:43 CTS FIX Historical Data socket (16) | SSL object has been freed. SSL state is now disconnected. | 2015-05-01 05:32:43 CTS FIX Historical Data socket (16) | Shutdown and closed. | 2015-05-01 05:32:43 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2015-05-01 05:32:43 CTS FIX Historical Data: Disconnected. | 2015-05-01 05:32:43 HD Request # 36 | Downloading Historical Daily chart data for ES.20150600.CME_Eq. Starting date: 2015-04-27. Service: cts | 2015-05-01 05:56:34 HD Request # 36 | Requesting historical Daily data for ESM15 starting at 2015-04-26 | 2015-05-01 05:56:34 HD Request # 36 | Receiving historical Daily data for ES.20150600.CME_Eq starting at 2015-04-27 | 2015-05-01 05:56:34 Writing historical Daily data for ES.20150600.CME_Eq to the file ES.20150600.CME_Eq.dly | 2015-05-01 05:56:34 HD Request # 36 | Received 5 records from 2015-04-27 00:00:00 to 2015-05-01 00:00:00 (5.0 days) and wrote 5 records for ES.20150600.CME_Eq | 2015-05-01 05:56:34 HD Request # 36 | Daily download COMPLETE for ES.20150600.CME_Eq. Completion time: 0s. Unique request ID: 35 | 2015-05-01 05:56:34 Removed historical data download ID 35 | 2015-05-01 05:56:34 |
