Date/Time: Sun, 22 Dec 2024 13:12:46 +0000
Annoying Trade confirmation window
View Count: 1132
[2015-05-01 05:12:54] |
User595685 - Posts: 14 |
Hello , Can you tell how to turn off the "Annoying trade confirmation Window " ? Screenshot attached. Thanks |
TurnOffAnnoying.JPG / V - Attached On 2015-05-01 05:09:29 UTC - Size: 101.8 KB - 342 views |
[2015-05-01 10:30:09] |
Yes. This is documented here: http://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#OrderConfirmations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
