Date/Time: Sun, 22 Dec 2024 13:17:25 +0000
DOM problem
View Count: 913
[2015-05-01 01:04:01]
User595685 - Posts: 14
(a) Can you tell me how to sync with the trading issue(CL/GC/6E) ? I have CLM15 in the replay so the quantity should be 1,2,..10 why 10.0k or 20.0k ?
(b)What is the symbol for /6E in your future menu. I can't find 6E or any forex-futures like 6C or 6A etc... ?
Screenshot attached.
imageErrorDOM.JPG / V - Attached On 2015-05-01 01:02:36 UTC - Size: 34.75 KB - 335 views
[2015-05-01 01:58:12]
To correct the quantities go to the Set tab on the Trade Window and press the Default Quantities button.
This symbol is going to be listed as E6.
[2015-05-01 03:06:51]
Sweet. Both answers worked out. Thanks for the prompt reply
