Date/Time: Sun, 04 Oct 2026 09:40:50 +0000
basic trading setup - set target and stop
View Count: 1913
| [2015-04-30 22:42:35] |
| User43999 - Posts: 3 |
I've read so much SC documentation but can't seem to figure out exactly how to set up a trade with a profit target of 5 points and a stop of 4 points. I have been able to set the stop OR the target, but not both. Would someone kindly share exactly what to put where in the trade console to accomplish this? Many thanks!
| [2015-05-01 19:31:51] |
Refer to the Simple Bracket example here for instructions: Attached Orders: Simple Bracket Example There is a screenshot of the Targets tab of the Trade Window that shows the basic settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
