Date/Time: Sun, 22 Dec 2024 13:24:00 +0000
[User Discussion] - jsyd's delta divergence cpp - incompatible with current Sierra compiler ?
View Count: 1131
[2015-04-30 12:34:41] |
Acro - Posts: 441 |
Hi, I was trying to edit this vintage code that is included in the user studies installed with Sierra but it cannot be compiled as is (out of the box without any amendments by me), because Sierra's compiler seems to have changed over the years. Is there any way I could get feedback on the errors that appear when one tries to compile the original code in Sierra. The DLL provided by Sierra still works so I'm hoping this can be overcome. Any pointers would be appreciated Thanks |
DeltaDivergence_v5.cpp - Attached On 2015-04-30 12:31:51 UTC - Size: 12.28 KB - 517 views Attachment Deleted. |
[2015-04-30 18:38:13] |
mkata - Posts: 103 |
Acro, I'm not a programmer but know just enough to get it to compile. Beyond this I can't be of much help. The attached file will compile though. |
DeltaDivergence_v5.cpp - Attached On 2015-04-30 18:37:25 UTC - Size: 12.24 KB - 451 views |
[2015-05-01 00:47:12] |
Acro - Posts: 441 |
Many thanks mkata. I'll try it out today |
