Date/Time: Sun, 22 Dec 2024 13:17:39 +0000
copying Sierra on to second computer
View Count: 929
[2015-04-30 06:41:56] |
User41288 - Posts: 13 |
Hi there,Can I copy Sierra folder on to my second computer & start using straightway or there are other things to do also, thanks
[2015-04-30 06:51:14] |
Refer to help topic 15: Http://www.sierrachart.com/index.php?page=doc/helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
