Date/Time: Sun, 22 Dec 2024 13:27:20 +0000
package upgrade 3 to 5 Effect on present charts setups
View Count: 890
[2015-04-29 10:21:49] |
User41288 - Posts: 13 |
Hi there, Would my present charts would be affected when I evaluate or upgrade from pkg 3 to pkg 5. Thanks
[2015-04-29 16:10:22] |
No. Not at all. Everything will remain the same. Other than having access to Numbers Bars and the TPO Profile Chart study.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-29 16:10:47
