Date/Time: Sun, 22 Dec 2024 12:57:08 +0000
frequent historical download
View Count: 993
[2015-04-29 08:52:38]
Neo - Posts: 198
My chart books keep redownload historical data. This only started happening today, and is the same chart books I've been using for the last couple of weeks. I downloaded the latest version today to see if that would fix the issue, but no luck.
Software version: 1251 | 2015-04-29 03:39:12
Uses New Spreadsheets | 2015-04-29 03:39:12
Usage end date: 2015-04-30 | 2015-04-29 03:39:12
Enabled for: Advanced Features. | 2015-04-29 03:39:12
Enabled for: Advanced Features 2. | 2015-04-29 03:39:12
Enabled for: Sierra Chart Historical Data Service. | 2015-04-29 03:39:12
Allow Support for Sierra Chart Data Feeds is enabled. | 2015-04-29 03:39:12
Active service: IQFeed | 2015-04-29 03:39:12
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-04-29 03:39:12
2015-04-29 03:39:12 Local computer clock time | 2015-04-29 03:39:12
2015-04-29 07:39:12 GMT time | 2015-04-29 03:39:12
2015-04-29 03:39:12 Time zone adjusted time | 2015-04-29 03:39:12
Time difference to server time: 2 seconds. | 2015-04-29 03:39:12
Program path: A:\S Chart\ | 2015-04-29 03:39:12
Data Files path: A:\S Chart\Data\ | 2015-04-29 03:39:12
OS Version Number: 6.2 | 2015-04-29 03:39:12
Locale Information: C | 2015-04-29 03:39:12
Checking for new symbol settings for dtn | 2015-04-29 03:39:12
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-04-29 03:39:12
HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-04-29 03:39:12
Requesting symbol settings for dtn. Overwrite = on. | 2015-04-29 03:39:12
Notice: 1 days of full use remaining. To continue full use the software and services, | 2015-04-29 03:39:12
purchase more usage time by selecting 'Help >> Add Usage Credit' on the menu. | 2015-04-29 03:39:12 *
Symbol settings received. | 2015-04-29 03:39:14
Processed received symbol settings | 2015-04-29 03:39:14
IQFeed | Connecting. | 2015-04-29 03:39:17
Starting DTN IQ Feed interface software. | 2015-04-29 03:39:17
IQFeed | Connecting to Admin port 9300 | 2015-04-29 03:39:17
Socket (2) | Connected. | 2015-04-29 03:39:17
IQFeed | Connected to Admin port. | 2015-04-29 03:39:17
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2015-04-29 03:39:17
AdminMessage: S,STATS,66.112.148.110,60007,500,0,10,0,13,0,Apr 29 3:39AM,Apr 29 3:39AM,Connected,5.1.1.3,423970,117.88,0.02,39.29,216.42,0.00,72.14, | 2015-04-29 03:39:17
IQFeed | Connecting to Level 1 port 5009 | 2015-04-29 03:39:17
Socket (3) | Connected. | 2015-04-29 03:39:17
IQFeed | Connected to Level 1 port. | 2015-04-29 03:39:17
IQFeed | Connecting to Lookup port 9100 | 2015-04-29 03:39:17
IQFeed | Connecting to Level 2 port (9200)... | 2015-04-29 03:39:17
Socket (4) | Connected. | 2015-04-29 03:39:17
IQFeed | Connected to Historical Data port. | 2015-04-29 03:39:17
IQFeed | Fully connected. | 2015-04-29 03:39:17
Socket (5) | Connected. | 2015-04-29 03:39:17
IQFeed | Connected to Level 2 port. | 2015-04-29 03:39:17
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:39:17
IQFeed | Level 2 protocol is 5.0. | 2015-04-29 03:39:17
IQFeed | Level 1 system message: KEY | 2015-04-29 03:39:17
IQFeed | Level 1 system message: SERVER CONNECTED | 2015-04-29 03:39:17
IQFeed | Level 1 system message: IP | 2015-04-29 03:39:17
IQFeed | Level 1 system message: CUST | 2015-04-29 03:39:17
HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-04-29 03:39:19
HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-04-29 03:39:19
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:39:19
VXX 2 Min #6 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-03-31 10:30:00. Next Bar Date Time: 2015-03-31 09:30:00. Filename: VXX.scid | 2015-04-29 03:39:31
XOm 2 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-03-31 10:30:00. Next Bar Date Time: 2015-03-31 09:30:00. Filename: XOm.scid | 2015-04-29 03:39:31
QQQ 2 Min #10 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-03-31 10:30:00. Next Bar Date Time: 2015-03-31 09:30:00. Filename: QQQ.scid | 2015-04-29 03:39:32
BABA 2 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-03-31 10:30:00. Next Bar Date Time: 2015-03-31 09:30:00. Filename: BABA.scid | 2015-04-29 03:39:32
TSLA 2 Min #9 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-03-31 10:30:00. Next Bar Date Time: 2015-03-31 09:30:00. Filename: TSLA.scid | 2015-04-29 03:39:32
BRK.B 2 Min #4 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-03-31 10:30:00. Next Bar Date Time: 2015-03-31 09:30:00. Filename: BRK.B.scid | 2015-04-29 03:39:33
XOm 2 Min #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-03-31 10:30:00. Next Bar Date Time: 2015-03-31 09:30:00. Filename: XOm.scid | 2015-04-29 03:39:33
AAPL 2 Min #12 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-03-31 10:30:00. Next Bar Date Time: 2015-03-31 09:30:00. Filename: AAPL.scid | 2015-04-29 03:39:33
IQFeed | Starting real-time market data updates for: TWTR. ID: 1 | 2015-04-29 03:39:35
Intraday data recording state for symbol TWTR is set to download pending. | 2015-04-29 03:39:35
HD Request # 2 | Downloading Intraday chart data for TWTR to the file TWTR.scid. Service: dtn | 2015-04-29 03:39:35
HD Request # 2 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:39:35
HD Request # 2 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:39:35
IQFeed | Starting real-time market data updates for: BABA. ID: 2 | 2015-04-29 03:39:35
Intraday data recording state for symbol BABA is set to download pending. | 2015-04-29 03:39:35
IQFeed | Starting real-time market data updates for: UAL. ID: 3 | 2015-04-29 03:39:35
Intraday data recording state for symbol UAL is set to download pending. | 2015-04-29 03:39:35
IQFeed | Starting real-time market data updates for: VXX. ID: 4 | 2015-04-29 03:39:35
Intraday data recording state for symbol VXX is set to download pending. | 2015-04-29 03:39:35
IQFeed | Starting real-time market data updates for: FB. ID: 5 | 2015-04-29 03:39:35
Intraday data recording state for symbol FB is set to download pending. | 2015-04-29 03:39:35
IQFeed | Starting real-time market data updates for: XOm. ID: 6 | 2015-04-29 03:39:35
Intraday data recording state for symbol XOm is set to download pending. | 2015-04-29 03:39:35
IQFeed | Starting real-time market data updates for: QQQ. ID: 7 | 2015-04-29 03:39:35
Intraday data recording state for symbol QQQ is set to download pending. | 2015-04-29 03:39:35
IQFeed | Starting real-time market data updates for: TSLA. ID: 8 | 2015-04-29 03:39:35
Intraday data recording state for symbol TSLA is set to download pending. | 2015-04-29 03:39:35
IQFeed | Starting real-time market data updates for: AMZN. ID: 9 | 2015-04-29 03:39:35
Intraday data recording state for symbol AMZN is set to download pending. | 2015-04-29 03:39:35
IQFeed | Starting real-time market data updates for: V. ID: 10 | 2015-04-29 03:39:35
Intraday data recording state for symbol V is set to download pending. | 2015-04-29 03:39:35
HD Request # 2 | Receiving historical Intraday Tick data for TWTR | 2015-04-29 03:39:35
HD Request # 2 | Receiving Intraday data for TWTR starting at 2015-04-28 19:59:58 | 2015-04-29 03:39:35
HD Request # 2 | Received 3 records from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for TWTR | 2015-04-29 03:39:35
HD Request # 2 | Intraday download COMPLETE for TWTR. Completion time: 0s. Unique request ID: 1 | 2015-04-29 03:39:35
Removed historical data download ID 1 | 2015-04-29 03:39:35
Real-time Intraday chart data file updates started for TWTR | 2015-04-29 03:39:35
HD Request # 3 | Downloading Intraday chart data for BABA to the file BABA.scid. Service: dtn | 2015-04-29 03:39:35
HD Request # 3 | Download start Date-Time: 2015-04-28 19:58:41.0 | 2015-04-29 03:39:35
HD Request # 3 | Requesting Tick data beginning at 2015-04-28 19:58:41 US Eastern Time. | 2015-04-29 03:39:35
IQFeed | Starting real-time market data updates for: BRK.B. ID: 11 | 2015-04-29 03:39:35
Intraday data recording state for symbol BRK.B is set to download pending. | 2015-04-29 03:39:35
IQFeed | Starting real-time market data updates for: LNKD. ID: 12 | 2015-04-29 03:39:35
Intraday data recording state for symbol LNKD is set to download pending. | 2015-04-29 03:39:36
IQFeed | Starting real-time market data updates for: NKE. ID: 13 | 2015-04-29 03:39:36
Intraday data recording state for symbol NKE is set to download pending. | 2015-04-29 03:39:36
IQFeed | Starting real-time market data updates for: AAPL. ID: 14 | 2015-04-29 03:39:36
Intraday data recording state for symbol AAPL is set to download pending. | 2015-04-29 03:39:36
HD Request # 3 | Receiving historical Intraday Tick data for BABA | 2015-04-29 03:39:36
HD Request # 3 | Receiving Intraday data for BABA starting at 2015-04-28 19:58:41 | 2015-04-29 03:39:36
HD Request # 3 | Received 1 record from 2015-04-28 19:58:41 to 2015-04-28 19:58:41 (0.0 seconds) and wrote 0 records for BABA | 2015-04-29 03:39:36
HD Request # 3 | Intraday download COMPLETE for BABA. Completion time: 1s. Unique request ID: 2 | 2015-04-29 03:39:36
Removed historical data download ID 2 | 2015-04-29 03:39:36
Real-time Intraday chart data file updates started for BABA | 2015-04-29 03:39:36
HD Request # 4 | Downloading Intraday chart data for UAL to the file UAL.scid. Service: dtn | 2015-04-29 03:39:36
HD Request # 4 | Download start Date-Time: 2015-04-28 17:14:23.0 | 2015-04-29 03:39:36
HD Request # 4 | Requesting Tick data beginning at 2015-04-28 17:14:23 US Eastern Time. | 2015-04-29 03:39:36
HD Request # 4 | Receiving historical Intraday Tick data for UAL | 2015-04-29 03:39:36
HD Request # 4 | Receiving Intraday data for UAL starting at 2015-04-28 17:14:23 | 2015-04-29 03:39:36
HD Request # 4 | Received 1 record from 2015-04-28 17:14:23 to 2015-04-28 17:14:23 (0.0 seconds) and wrote 0 records for UAL | 2015-04-29 03:39:36
HD Request # 4 | Intraday download COMPLETE for UAL. Completion time: 0s. Unique request ID: 3 | 2015-04-29 03:39:36
Removed historical data download ID 3 | 2015-04-29 03:39:36
Real-time Intraday chart data file updates started for UAL | 2015-04-29 03:39:36
HD Request # 5 | Downloading Intraday chart data for VXX to the file VXX.scid. Service: dtn | 2015-04-29 03:39:36
HD Request # 5 | Download start Date-Time: 2015-04-28 19:59:39.0 | 2015-04-29 03:39:36
HD Request # 5 | Requesting Tick data beginning at 2015-04-28 19:59:39 US Eastern Time. | 2015-04-29 03:39:36
HD Request # 5 | Receiving historical Intraday Tick data for VXX | 2015-04-29 03:39:38
QQQ 0.10 Range #8 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-03-31 19:53:42. Next Bar Date Time: 2015-03-31 10:30:58. Filename: QQQ.scid | 2015-04-29 03:39:38
QQQ 0.10 Range #8 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-03-31 10:30:58. Next Bar Date Time: 2015-03-31 09:31:00. Filename: QQQ.scid | 2015-04-29 03:39:38
HD Request # 5 | Receiving Intraday data for VXX starting at 2015-04-28 19:59:39 | 2015-04-29 03:39:38
HD Request # 5 | Received 2 records from 2015-04-28 19:59:39 to 2015-04-28 19:59:39 (0.0 seconds) and wrote 0 records for VXX | 2015-04-29 03:39:38
HD Request # 5 | Intraday download COMPLETE for VXX. Completion time: 2s. Unique request ID: 4 | 2015-04-29 03:39:38
Removed historical data download ID 4 | 2015-04-29 03:39:38
Real-time Intraday chart data file updates started for VXX | 2015-04-29 03:39:38
HD Request # 6 | Downloading Intraday chart data for FB to the file FB.scid. Service: dtn | 2015-04-29 03:39:38
HD Request # 6 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:39:38
HD Request # 6 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:39:38
IQFeed | Starting real-time market data updates for: SPY. ID: 15 | 2015-04-29 03:39:38
Intraday data recording state for symbol SPY is set to download pending. | 2015-04-29 03:39:38
IQFeed | Starting real-time market data updates for: @ES#C. ID: 16 | 2015-04-29 03:39:38
Intraday data recording state for symbol @ES#C is set to download pending. | 2015-04-29 03:39:38
IQFeed | Starting real-time market data updates for: @NQ#C. ID: 17 | 2015-04-29 03:39:38
Intraday data recording state for symbol @NQ#C is set to download pending. | 2015-04-29 03:39:38
IQFeed | Starting real-time market data updates for: @ym#C. ID: 18 | 2015-04-29 03:39:38
Intraday data recording state for symbol @ym#C is set to download pending. | 2015-04-29 03:39:38
HD Request # 6 | Receiving historical Intraday Tick data for FB | 2015-04-29 03:39:38
HD Request # 6 | Receiving Intraday data for FB starting at 2015-04-28 19:59:58 | 2015-04-29 03:39:38
HD Request # 6 | Received 1 record from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for FB | 2015-04-29 03:39:38
HD Request # 6 | Intraday download COMPLETE for FB. Completion time: 0s. Unique request ID: 5 | 2015-04-29 03:39:38
Removed historical data download ID 5 | 2015-04-29 03:39:38
Real-time Intraday chart data file updates started for FB | 2015-04-29 03:39:38
HD Request # 7 | Downloading Intraday chart data for XOm to the file XOm.scid. Service: dtn | 2015-04-29 03:39:38
HD Request # 7 | Download start Date-Time: 2015-04-28 19:59:49.0 | 2015-04-29 03:39:38
HD Request # 7 | Requesting Tick data beginning at 2015-04-28 19:59:49 US Eastern Time. | 2015-04-29 03:39:38
HD Request # 7 | Receiving historical Intraday Tick data for XOM | 2015-04-29 03:39:38
HD Request # 7 | Receiving Intraday data for XOm starting at 2015-04-28 19:59:49 | 2015-04-29 03:39:38
HD Request # 7 | Received 1 record from 2015-04-28 19:59:49 to 2015-04-28 19:59:49 (0.0 seconds) and wrote 0 records for XOm | 2015-04-29 03:39:38
HD Request # 7 | Intraday download COMPLETE for XOm. Completion time: 0s. Unique request ID: 6 | 2015-04-29 03:39:38
Removed historical data download ID 6 | 2015-04-29 03:39:38
Real-time Intraday chart data file updates started for XOm | 2015-04-29 03:39:38
HD Request # 8 | Downloading Intraday chart data for QQQ to the file QQQ.scid. Service: dtn | 2015-04-29 03:39:38
HD Request # 8 | Download start Date-Time: 2015-04-28 19:44:40.0 | 2015-04-29 03:39:39
HD Request # 8 | Requesting Tick data beginning at 2015-04-28 19:44:40 US Eastern Time. | 2015-04-29 03:39:39
HD Request # 8 | Receiving historical Intraday Tick data for QQQ | 2015-04-29 03:39:39
HD Request # 8 | Receiving Intraday data for QQQ starting at 2015-04-28 19:44:40 | 2015-04-29 03:39:39
HD Request # 8 | Received 4 records from 2015-04-28 19:44:40 to 2015-04-28 19:44:40 (0.0 seconds) and wrote 0 records for QQQ | 2015-04-29 03:39:39
HD Request # 8 | Intraday download COMPLETE for QQQ. Completion time: 1s. Unique request ID: 7 | 2015-04-29 03:39:39
Removed historical data download ID 7 | 2015-04-29 03:39:39
Real-time Intraday chart data file updates started for QQQ | 2015-04-29 03:39:39
HD Request # 9 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: dtn | 2015-04-29 03:39:39
HD Request # 9 | Download start Date-Time: 2015-04-28 19:59:10.0 | 2015-04-29 03:39:39
HD Request # 9 | Requesting Tick data beginning at 2015-04-28 19:59:10 US Eastern Time. | 2015-04-29 03:39:39
HD Request # 9 | Receiving historical Intraday Tick data for TSLA | 2015-04-29 03:39:40
HD Request # 9 | Receiving Intraday data for TSLA starting at 2015-04-28 19:59:10 | 2015-04-29 03:39:40
HD Request # 9 | Received 1 record from 2015-04-28 19:59:10 to 2015-04-28 19:59:10 (0.0 seconds) and wrote 0 records for TSLA | 2015-04-29 03:39:40
HD Request # 9 | Intraday download COMPLETE for TSLA. Completion time: 0s. Unique request ID: 8 | 2015-04-29 03:39:40
Removed historical data download ID 8 | 2015-04-29 03:39:40
Real-time Intraday chart data file updates started for TSLA | 2015-04-29 03:39:40
HD Request # 10 | Downloading Intraday chart data for AMZN to the file AMZN.scid. Service: dtn | 2015-04-29 03:39:40
HD Request # 10 | Download start Date-Time: 2015-04-28 19:29:10.0 | 2015-04-29 03:39:40
HD Request # 10 | Requesting Tick data beginning at 2015-04-28 19:29:10 US Eastern Time. | 2015-04-29 03:39:40
HD Request # 10 | Receiving historical Intraday Tick data for AMZN | 2015-04-29 03:39:41
HD Request # 10 | Receiving Intraday data for AMZN starting at 2015-04-28 19:29:10 | 2015-04-29 03:39:41
HD Request # 10 | Received 1 record from 2015-04-28 19:29:10 to 2015-04-28 19:29:10 (0.0 seconds) and wrote 0 records for AMZN | 2015-04-29 03:39:41
HD Request # 10 | Intraday download COMPLETE for AMZN. Completion time: 1s. Unique request ID: 9 | 2015-04-29 03:39:41
Removed historical data download ID 9 | 2015-04-29 03:39:41
Real-time Intraday chart data file updates started for AMZN | 2015-04-29 03:39:41
HD Request # 11 | Downloading Intraday chart data for V to the file V.scid. Service: dtn | 2015-04-29 03:39:41
HD Request # 11 | Download start Date-Time: 2015-04-28 19:57:15.0 | 2015-04-29 03:39:41
HD Request # 11 | Requesting Tick data beginning at 2015-04-28 19:57:15 US Eastern Time. | 2015-04-29 03:39:41
HD Request # 11 | Receiving historical Intraday Tick data for V | 2015-04-29 03:39:41
HD Request # 11 | Receiving Intraday data for V starting at 2015-04-28 19:57:15 | 2015-04-29 03:39:41
HD Request # 11 | Received 1 record from 2015-04-28 19:57:15 to 2015-04-28 19:57:15 (0.0 seconds) and wrote 0 records for V | 2015-04-29 03:39:41
HD Request # 11 | Intraday download COMPLETE for V. Completion time: 0s. Unique request ID: 10 | 2015-04-29 03:39:41
Removed historical data download ID 10 | 2015-04-29 03:39:41
Real-time Intraday chart data file updates started for V | 2015-04-29 03:39:41
HD Request # 12 | Downloading Intraday chart data for BRK.B to the file BRK.B.scid. Service: dtn | 2015-04-29 03:39:41
HD Request # 12 | Download start Date-Time: 2015-04-28 17:01:29.0 | 2015-04-29 03:39:41
HD Request # 12 | Requesting Tick data beginning at 2015-04-28 17:01:29 US Eastern Time. | 2015-04-29 03:39:41
HD Request # 12 | Receiving historical Intraday Tick data for BRK.B | 2015-04-29 03:39:42
HD Request # 12 | Receiving Intraday data for BRK.B starting at 2015-04-28 17:01:29 | 2015-04-29 03:39:42
HD Request # 12 | Received 1 record from 2015-04-28 17:01:29 to 2015-04-28 17:01:29 (0.0 seconds) and wrote 0 records for BRK.B | 2015-04-29 03:39:42
HD Request # 12 | Intraday download COMPLETE for BRK.B. Completion time: 1s. Unique request ID: 11 | 2015-04-29 03:39:42
Removed historical data download ID 11 | 2015-04-29 03:39:42
Real-time Intraday chart data file updates started for BRK.B | 2015-04-29 03:39:42
HD Request # 13 | Downloading Intraday chart data for LNKD to the file LNKD.scid. Service: dtn | 2015-04-29 03:39:42
HD Request # 13 | Download start Date-Time: 2015-04-28 19:46:00.0 | 2015-04-29 03:39:42
HD Request # 13 | Requesting Tick data beginning at 2015-04-28 19:46:00 US Eastern Time. | 2015-04-29 03:39:42
HD Request # 13 | Receiving historical Intraday Tick data for LNKD | 2015-04-29 03:39:42
HD Request # 13 | Receiving Intraday data for LNKD starting at 2015-04-28 19:46:00 | 2015-04-29 03:39:42
HD Request # 13 | Received 1 record from 2015-04-28 19:46:00 to 2015-04-28 19:46:00 (0.0 seconds) and wrote 0 records for LNKD | 2015-04-29 03:39:42
HD Request # 13 | Intraday download COMPLETE for LNKD. Completion time: 0s. Unique request ID: 12 | 2015-04-29 03:39:42
Removed historical data download ID 12 | 2015-04-29 03:39:42
Real-time Intraday chart data file updates started for LNKD | 2015-04-29 03:39:42
HD Request # 14 | Downloading Intraday chart data for NKE to the file NKE.scid. Service: dtn | 2015-04-29 03:39:42
HD Request # 14 | Download start Date-Time: 2015-04-28 16:32:54.0 | 2015-04-29 03:39:42
HD Request # 14 | Requesting Tick data beginning at 2015-04-28 16:32:54 US Eastern Time. | 2015-04-29 03:39:42
HD Request # 14 | Receiving historical Intraday Tick data for NKE | 2015-04-29 03:39:43
HD Request # 14 | Receiving Intraday data for NKE starting at 2015-04-28 16:32:54 | 2015-04-29 03:39:43
HD Request # 14 | Received 1 record from 2015-04-28 16:32:54 to 2015-04-28 16:32:54 (0.0 seconds) and wrote 0 records for NKE | 2015-04-29 03:39:43
HD Request # 14 | Intraday download COMPLETE for NKE. Completion time: 0s. Unique request ID: 13 | 2015-04-29 03:39:43
Removed historical data download ID 13 | 2015-04-29 03:39:43
Real-time Intraday chart data file updates started for NKE | 2015-04-29 03:39:43
HD Request # 15 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: dtn | 2015-04-29 03:39:43
HD Request # 15 | Download start Date-Time: 2015-04-28 19:59:48.0 | 2015-04-29 03:39:43
HD Request # 15 | Requesting Tick data beginning at 2015-04-28 19:59:48 US Eastern Time. | 2015-04-29 03:39:43
HD Request # 15 | Receiving historical Intraday Tick data for AAPL | 2015-04-29 03:39:43
HD Request # 15 | Receiving Intraday data for AAPL starting at 2015-04-28 19:59:48 | 2015-04-29 03:39:43
HD Request # 15 | Received 1 record from 2015-04-28 19:59:48 to 2015-04-28 19:59:48 (0.0 seconds) and wrote 0 records for AAPL | 2015-04-29 03:39:43
HD Request # 15 | Intraday download COMPLETE for AAPL. Completion time: 0s. Unique request ID: 14 | 2015-04-29 03:39:43
Removed historical data download ID 14 | 2015-04-29 03:39:43
Real-time Intraday chart data file updates started for AAPL | 2015-04-29 03:39:43
HD Request # 16 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: dtn | 2015-04-29 03:39:43
HD Request # 16 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:39:43
HD Request # 16 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:39:43
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2015-04-29 03:39:50
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2015-04-29 03:39:50
Connection to the external service has been lost. | 2015-04-29 03:39:50
Removed historical data download ID 16 | 2015-04-29 03:39:50
Removed historical data download ID 17 | 2015-04-29 03:39:50
Removed historical data download ID 18 | 2015-04-29 03:39:50
HD Request # 16 | Download canceled. | 2015-04-29 03:39:50
HD Request # 16 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for SPY | 2015-04-29 03:39:50
HD Request # 16 | Intraday download COMPLETE for SPY. Completion time: 7s. Unique request ID: 15 | 2015-04-29 03:39:50
Removed historical data download ID 15 | 2015-04-29 03:39:50
Socket (5) | Shutdown and closed. | 2015-04-29 03:39:50
IQFeed | Disconnected from Level 2 port. | 2015-04-29 03:39:50
Socket (4) | Shutdown and closed. | 2015-04-29 03:39:50
IQFeed | Disconnected from Lookup port. | 2015-04-29 03:39:50
Socket (3) | Shutdown and closed. | 2015-04-29 03:39:50
IQFeed | Disconnected from Level 1 port. | 2015-04-29 03:39:50
Socket (2) | Shutdown and closed. | 2015-04-29 03:39:50
IQFeed | Disconnected from Admin port. | 2015-04-29 03:39:50
IQFeed | Fully disconnected. | 2015-04-29 03:39:50
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-29 03:39:50
IQFeed | Connecting. | 2015-04-29 03:39:55
Starting DTN IQ Feed interface software. | 2015-04-29 03:39:55
IQFeed | Connecting to Admin port 9300 | 2015-04-29 03:39:55
Socket (6) | Connected. | 2015-04-29 03:39:55
IQFeed | Connected to Admin port. | 2015-04-29 03:39:55
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2015-04-29 03:39:55
AdminMessage: S,STATS,66.112.156.226,60006,500,0,11,0,14,0,Apr 29 3:39AM,Apr 29 3:39AM,Connected,5.1.1.3,423970,127.24,0.02,63.62,258.86,0.04,129.43, | 2015-04-29 03:39:56
IQFeed | Connecting to Level 1 port 5009 | 2015-04-29 03:39:56
Socket (7) | Connected. | 2015-04-29 03:39:56
IQFeed | Connected to Level 1 port. | 2015-04-29 03:39:56
IQFeed | Connecting to Lookup port 9100 | 2015-04-29 03:39:56
IQFeed | Connecting to Level 2 port (9200)... | 2015-04-29 03:39:56
IQFeed | Level 1 system message: KEY | 2015-04-29 03:39:56
IQFeed | Level 1 system message: SERVER CONNECTED | 2015-04-29 03:39:56
IQFeed | Level 1 system message: IP | 2015-04-29 03:39:56
IQFeed | Level 1 system message: CUST | 2015-04-29 03:39:56
Socket (8) | Connected. | 2015-04-29 03:39:56
IQFeed | Connected to Historical Data port. | 2015-04-29 03:39:56
IQFeed | Fully connected. | 2015-04-29 03:39:56
Socket (9) | Connected. | 2015-04-29 03:39:56
IQFeed | Connected to Level 2 port. | 2015-04-29 03:39:56
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:39:56
IQFeed | Level 2 protocol is 5.0. | 2015-04-29 03:39:56
IQFeed | Starting real-time market data updates for: AAPL. ID: 1 | 2015-04-29 03:39:56
Intraday data recording state for symbol AAPL is set to download pending. | 2015-04-29 03:39:56
HD Request # 17 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: dtn | 2015-04-29 03:39:56
HD Request # 17 | Download start Date-Time: 2015-04-28 19:59:48.0 | 2015-04-29 03:39:56
HD Request # 17 | Requesting Tick data beginning at 2015-04-28 19:59:48 US Eastern Time. | 2015-04-29 03:39:56
IQFeed | Starting real-time market data updates for: AMZN. ID: 2 | 2015-04-29 03:39:56
Intraday data recording state for symbol AMZN is set to download pending. | 2015-04-29 03:39:56
IQFeed | Starting real-time market data updates for: @ES#C. ID: 3 | 2015-04-29 03:39:56
Intraday data recording state for symbol @ES#C is set to download pending. | 2015-04-29 03:39:56
IQFeed | Starting real-time market data updates for: XOm. ID: 4 | 2015-04-29 03:39:56
Intraday data recording state for symbol XOm is set to download pending. | 2015-04-29 03:39:56
IQFeed | Starting real-time market data updates for: QQQ. ID: 5 | 2015-04-29 03:39:56
Intraday data recording state for symbol QQQ is set to download pending. | 2015-04-29 03:39:56
IQFeed | Starting real-time market data updates for: @ym#C. ID: 6 | 2015-04-29 03:39:56
Intraday data recording state for symbol @ym#C is set to download pending. | 2015-04-29 03:39:56
IQFeed | Starting real-time market data updates for: BRK.B. ID: 7 | 2015-04-29 03:39:56
Intraday data recording state for symbol BRK.B is set to download pending. | 2015-04-29 03:39:56
IQFeed | Starting real-time market data updates for: V. ID: 8 | 2015-04-29 03:39:56
Intraday data recording state for symbol V is set to download pending. | 2015-04-29 03:39:56
IQFeed | Starting real-time market data updates for: TSLA. ID: 9 | 2015-04-29 03:39:56
Intraday data recording state for symbol TSLA is set to download pending. | 2015-04-29 03:39:56
IQFeed | Starting real-time market data updates for: LNKD. ID: 10 | 2015-04-29 03:39:56
Intraday data recording state for symbol LNKD is set to download pending. | 2015-04-29 03:39:56
IQFeed | Starting real-time market data updates for: NKE. ID: 11 | 2015-04-29 03:39:56
Intraday data recording state for symbol NKE is set to download pending. | 2015-04-29 03:39:56
IQFeed | Starting real-time market data updates for: @NQ#C. ID: 12 | 2015-04-29 03:39:56
Intraday data recording state for symbol @NQ#C is set to download pending. | 2015-04-29 03:39:56
IQFeed | Starting real-time market data updates for: TWTR. ID: 13 | 2015-04-29 03:39:56
Intraday data recording state for symbol TWTR is set to download pending. | 2015-04-29 03:39:56
IQFeed | Starting real-time market data updates for: BABA. ID: 14 | 2015-04-29 03:39:56
Intraday data recording state for symbol BABA is set to download pending. | 2015-04-29 03:39:56
IQFeed | Starting real-time market data updates for: SPY. ID: 15 | 2015-04-29 03:39:56
Intraday data recording state for symbol SPY is set to download pending. | 2015-04-29 03:39:56
IQFeed | Starting real-time market data updates for: UAL. ID: 16 | 2015-04-29 03:39:56
Intraday data recording state for symbol UAL is set to download pending. | 2015-04-29 03:39:56
IQFeed | Starting real-time market data updates for: VXX. ID: 17 | 2015-04-29 03:39:56
Intraday data recording state for symbol VXX is set to download pending. | 2015-04-29 03:39:56
IQFeed | Starting real-time market data updates for: FB. ID: 18 | 2015-04-29 03:39:56
Intraday data recording state for symbol FB is set to download pending. | 2015-04-29 03:39:56
HD Request # 17 | Receiving historical Intraday Tick data for AAPL | 2015-04-29 03:39:56
HD Request # 17 | Receiving Intraday data for AAPL starting at 2015-04-28 19:59:48 | 2015-04-29 03:39:56
HD Request # 17 | Received 1 record from 2015-04-28 19:59:48 to 2015-04-28 19:59:48 (0.0 seconds) and wrote 0 records for AAPL | 2015-04-29 03:39:56
HD Request # 17 | Intraday download COMPLETE for AAPL. Completion time: 0s. Unique request ID: 19 | 2015-04-29 03:39:56
Removed historical data download ID 19 | 2015-04-29 03:39:56
Real-time Intraday chart data file updates started for AAPL | 2015-04-29 03:39:56
HD Request # 18 | Downloading Intraday chart data for AMZN to the file AMZN.scid. Service: dtn | 2015-04-29 03:39:56
HD Request # 18 | Download start Date-Time: 2015-04-28 19:29:10.0 | 2015-04-29 03:39:56
HD Request # 18 | Requesting Tick data beginning at 2015-04-28 19:29:10 US Eastern Time. | 2015-04-29 03:39:56
HD Request # 18 | Receiving historical Intraday Tick data for AMZN | 2015-04-29 03:39:57
HD Request # 18 | Receiving Intraday data for AMZN starting at 2015-04-28 19:29:10 | 2015-04-29 03:39:57
HD Request # 18 | Received 1 record from 2015-04-28 19:29:10 to 2015-04-28 19:29:10 (0.0 seconds) and wrote 0 records for AMZN | 2015-04-29 03:39:57
HD Request # 18 | Intraday download COMPLETE for AMZN. Completion time: 1s. Unique request ID: 20 | 2015-04-29 03:39:57
Removed historical data download ID 20 | 2015-04-29 03:39:57
Real-time Intraday chart data file updates started for AMZN | 2015-04-29 03:39:57
HD Request # 19 | Downloading Intraday chart data for @ES#C to the file @ES#C.scid. Service: dtn | 2015-04-29 03:39:57
HD Request # 19 | Download start Date-Time: 2015-04-29 03:00:14.0 | 2015-04-29 03:39:57
HD Request # 19 | Requesting Tick data beginning at 2015-04-29 03:00:14 US Eastern Time. | 2015-04-29 03:39:57
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:39:57
HD Request # 19 | Receiving historical Intraday Tick data for @ES#C | 2015-04-29 03:39:58
HD Request # 19 | Receiving Intraday data for @ES#C starting at 2015-04-29 03:00:14 | 2015-04-29 03:39:58
HD Request # 19 | Timestamp of first Intraday data file record written: 2015-04-29 03:00:16 | 2015-04-29 03:39:58
HD Request # 19 | Received 5850 records from 2015-04-29 03:00:14 to 2015-04-29 03:29:58 (29.7 minutes) and wrote 5849 records for @ES#C | 2015-04-29 03:39:58
HD Request # 19 | Intraday download COMPLETE for @ES#C. Completion time: 1s. Unique request ID: 21 | 2015-04-29 03:39:58
Removed historical data download ID 21 | 2015-04-29 03:39:58
Real-time Intraday chart data file updates started for @ES#C | 2015-04-29 03:39:58
HD Request # 20 | Downloading Intraday chart data for XOm to the file XOm.scid. Service: dtn | 2015-04-29 03:39:58
HD Request # 20 | Download start Date-Time: 2015-04-28 19:59:49.0 | 2015-04-29 03:39:58
HD Request # 20 | Requesting Tick data beginning at 2015-04-28 19:59:49 US Eastern Time. | 2015-04-29 03:39:58
HD Request # 20 | Receiving historical Intraday Tick data for XOM | 2015-04-29 03:39:58
HD Request # 20 | Receiving Intraday data for XOm starting at 2015-04-28 19:59:49 | 2015-04-29 03:39:58
HD Request # 20 | Received 1 record from 2015-04-28 19:59:49 to 2015-04-28 19:59:49 (0.0 seconds) and wrote 0 records for XOm | 2015-04-29 03:39:58
HD Request # 20 | Intraday download COMPLETE for XOm. Completion time: 0s. Unique request ID: 22 | 2015-04-29 03:39:58
Removed historical data download ID 22 | 2015-04-29 03:39:58
Real-time Intraday chart data file updates started for XOm | 2015-04-29 03:39:58
HD Request # 21 | Downloading Intraday chart data for QQQ to the file QQQ.scid. Service: dtn | 2015-04-29 03:39:59
HD Request # 21 | Download start Date-Time: 2015-04-28 19:44:40.0 | 2015-04-29 03:39:59
HD Request # 21 | Requesting Tick data beginning at 2015-04-28 19:44:40 US Eastern Time. | 2015-04-29 03:39:59
HD Request # 21 | Receiving historical Intraday Tick data for QQQ | 2015-04-29 03:39:59
HD Request # 21 | Receiving Intraday data for QQQ starting at 2015-04-28 19:44:40 | 2015-04-29 03:39:59
HD Request # 21 | Received 4 records from 2015-04-28 19:44:40 to 2015-04-28 19:44:40 (0.0 seconds) and wrote 0 records for QQQ | 2015-04-29 03:39:59
HD Request # 21 | Intraday download COMPLETE for QQQ. Completion time: 0s. Unique request ID: 23 | 2015-04-29 03:39:59
Removed historical data download ID 23 | 2015-04-29 03:39:59
Real-time Intraday chart data file updates started for QQQ | 2015-04-29 03:39:59
HD Request # 22 | Downloading Intraday chart data for @ym#C to the file @ym#C.scid. Service: dtn | 2015-04-29 03:39:59
HD Request # 22 | Download start Date-Time: 2015-04-29 03:00:14.0 | 2015-04-29 03:39:59
HD Request # 22 | Requesting Tick data beginning at 2015-04-29 03:00:14 US Eastern Time. | 2015-04-29 03:39:59
HD Request # 22 | Receiving historical Intraday Tick data for @YM#C | 2015-04-29 03:40:00
HD Request # 22 | Receiving Intraday data for @ym#C starting at 2015-04-29 03:00:14 | 2015-04-29 03:40:00
HD Request # 22 | Timestamp of first Intraday data file record written: 2015-04-29 03:00:15 | 2015-04-29 03:40:00
HD Request # 22 | Received 1691 records from 2015-04-29 03:00:14 to 2015-04-29 03:29:58 (29.7 minutes) and wrote 1690 records for @ym#C | 2015-04-29 03:40:00
HD Request # 22 | Intraday download COMPLETE for @ym#C. Completion time: 1s. Unique request ID: 24 | 2015-04-29 03:40:00
Removed historical data download ID 24 | 2015-04-29 03:40:00
Real-time Intraday chart data file updates started for @ym#C | 2015-04-29 03:40:00
HD Request # 23 | Downloading Intraday chart data for BRK.B to the file BRK.B.scid. Service: dtn | 2015-04-29 03:40:00
HD Request # 23 | Download start Date-Time: 2015-04-28 17:01:29.0 | 2015-04-29 03:40:00
HD Request # 23 | Requesting Tick data beginning at 2015-04-28 17:01:29 US Eastern Time. | 2015-04-29 03:40:00
HD Request # 23 | Receiving historical Intraday Tick data for BRK.B | 2015-04-29 03:40:00
HD Request # 23 | Receiving Intraday data for BRK.B starting at 2015-04-28 17:01:29 | 2015-04-29 03:40:00
HD Request # 23 | Received 1 record from 2015-04-28 17:01:29 to 2015-04-28 17:01:29 (0.0 seconds) and wrote 0 records for BRK.B | 2015-04-29 03:40:00
HD Request # 23 | Intraday download COMPLETE for BRK.B. Completion time: 0s. Unique request ID: 25 | 2015-04-29 03:40:00
Removed historical data download ID 25 | 2015-04-29 03:40:00
Real-time Intraday chart data file updates started for BRK.B | 2015-04-29 03:40:00
HD Request # 24 | Downloading Intraday chart data for V to the file V.scid. Service: dtn | 2015-04-29 03:40:00
HD Request # 24 | Download start Date-Time: 2015-04-28 19:57:15.0 | 2015-04-29 03:40:00
HD Request # 24 | Requesting Tick data beginning at 2015-04-28 19:57:15 US Eastern Time. | 2015-04-29 03:40:00
HD Request # 24 | Receiving historical Intraday Tick data for V | 2015-04-29 03:40:01
HD Request # 24 | Receiving Intraday data for V starting at 2015-04-28 19:57:15 | 2015-04-29 03:40:01
HD Request # 24 | Received 1 record from 2015-04-28 19:57:15 to 2015-04-28 19:57:15 (0.0 seconds) and wrote 0 records for V | 2015-04-29 03:40:01
HD Request # 24 | Intraday download COMPLETE for V. Completion time: 1s. Unique request ID: 26 | 2015-04-29 03:40:01
Removed historical data download ID 26 | 2015-04-29 03:40:01
Real-time Intraday chart data file updates started for V | 2015-04-29 03:40:01
HD Request # 25 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: dtn | 2015-04-29 03:40:01
HD Request # 25 | Download start Date-Time: 2015-04-28 19:59:10.0 | 2015-04-29 03:40:01
HD Request # 25 | Requesting Tick data beginning at 2015-04-28 19:59:10 US Eastern Time. | 2015-04-29 03:40:01
HD Request # 25 | Receiving historical Intraday Tick data for TSLA | 2015-04-29 03:40:01
HD Request # 25 | Receiving Intraday data for TSLA starting at 2015-04-28 19:59:10 | 2015-04-29 03:40:01
HD Request # 25 | Received 1 record from 2015-04-28 19:59:10 to 2015-04-28 19:59:10 (0.0 seconds) and wrote 0 records for TSLA | 2015-04-29 03:40:01
HD Request # 25 | Intraday download COMPLETE for TSLA. Completion time: 0s. Unique request ID: 27 | 2015-04-29 03:40:01
Removed historical data download ID 27 | 2015-04-29 03:40:01
Real-time Intraday chart data file updates started for TSLA | 2015-04-29 03:40:01
HD Request # 26 | Downloading Intraday chart data for LNKD to the file LNKD.scid. Service: dtn | 2015-04-29 03:40:01
HD Request # 26 | Download start Date-Time: 2015-04-28 19:46:00.0 | 2015-04-29 03:40:01
HD Request # 26 | Requesting Tick data beginning at 2015-04-28 19:46:00 US Eastern Time. | 2015-04-29 03:40:01
HD Request # 26 | Receiving historical Intraday Tick data for LNKD | 2015-04-29 03:40:02
HD Request # 26 | Receiving Intraday data for LNKD starting at 2015-04-28 19:46:00 | 2015-04-29 03:40:02
HD Request # 26 | Received 1 record from 2015-04-28 19:46:00 to 2015-04-28 19:46:00 (0.0 seconds) and wrote 0 records for LNKD | 2015-04-29 03:40:02
HD Request # 26 | Intraday download COMPLETE for LNKD. Completion time: 0s. Unique request ID: 28 | 2015-04-29 03:40:02
Removed historical data download ID 28 | 2015-04-29 03:40:02
Real-time Intraday chart data file updates started for LNKD | 2015-04-29 03:40:02
HD Request # 27 | Downloading Intraday chart data for NKE to the file NKE.scid. Service: dtn | 2015-04-29 03:40:02
HD Request # 27 | Download start Date-Time: 2015-04-28 16:32:54.0 | 2015-04-29 03:40:02
HD Request # 27 | Requesting Tick data beginning at 2015-04-28 16:32:54 US Eastern Time. | 2015-04-29 03:40:02
HD Request # 27 | Receiving historical Intraday Tick data for NKE | 2015-04-29 03:40:02
HD Request # 27 | Receiving Intraday data for NKE starting at 2015-04-28 16:32:54 | 2015-04-29 03:40:02
HD Request # 27 | Received 1 record from 2015-04-28 16:32:54 to 2015-04-28 16:32:54 (0.0 seconds) and wrote 0 records for NKE | 2015-04-29 03:40:02
HD Request # 27 | Intraday download COMPLETE for NKE. Completion time: 0s. Unique request ID: 29 | 2015-04-29 03:40:02
Removed historical data download ID 29 | 2015-04-29 03:40:02
Real-time Intraday chart data file updates started for NKE | 2015-04-29 03:40:02
HD Request # 28 | Downloading Intraday chart data for @NQ#C to the file @NQ#C.scid. Service: dtn | 2015-04-29 03:40:02
HD Request # 28 | Download start Date-Time: 2015-04-29 03:00:14.0 | 2015-04-29 03:40:02
HD Request # 28 | Requesting Tick data beginning at 2015-04-29 03:00:14 US Eastern Time. | 2015-04-29 03:40:02
HD Request # 28 | Receiving historical Intraday Tick data for @NQ#C | 2015-04-29 03:40:03
HD Request # 28 | Receiving Intraday data for @NQ#C starting at 2015-04-29 03:00:14 | 2015-04-29 03:40:03
HD Request # 28 | Timestamp of first Intraday data file record written: 2015-04-29 03:00:15 | 2015-04-29 03:40:03
HD Request # 28 | Received 1732 records from 2015-04-29 03:00:14 to 2015-04-29 03:29:58 (29.7 minutes) and wrote 1728 records for @NQ#C | 2015-04-29 03:40:03
HD Request # 28 | Intraday download COMPLETE for @NQ#C. Completion time: 1s. Unique request ID: 30 | 2015-04-29 03:40:03
Removed historical data download ID 30 | 2015-04-29 03:40:03
Real-time Intraday chart data file updates started for @NQ#C | 2015-04-29 03:40:03
HD Request # 29 | Downloading Intraday chart data for TWTR to the file TWTR.scid. Service: dtn | 2015-04-29 03:40:03
HD Request # 29 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:40:03
HD Request # 29 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:40:03
HD Request # 29 | Receiving historical Intraday Tick data for TWTR | 2015-04-29 03:40:03
HD Request # 29 | Receiving Intraday data for TWTR starting at 2015-04-28 19:59:58 | 2015-04-29 03:40:03
HD Request # 29 | Received 3 records from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for TWTR | 2015-04-29 03:40:03
HD Request # 29 | Intraday download COMPLETE for TWTR. Completion time: 0s. Unique request ID: 31 | 2015-04-29 03:40:03
Removed historical data download ID 31 | 2015-04-29 03:40:03
Real-time Intraday chart data file updates started for TWTR | 2015-04-29 03:40:03
HD Request # 30 | Downloading Intraday chart data for BABA to the file BABA.scid. Service: dtn | 2015-04-29 03:40:03
HD Request # 30 | Download start Date-Time: 2015-04-28 19:58:41.0 | 2015-04-29 03:40:03
HD Request # 30 | Requesting Tick data beginning at 2015-04-28 19:58:41 US Eastern Time. | 2015-04-29 03:40:03
HD Request # 30 | Receiving historical Intraday Tick data for BABA | 2015-04-29 03:40:04
HD Request # 30 | Receiving Intraday data for BABA starting at 2015-04-28 19:58:41 | 2015-04-29 03:40:04
HD Request # 30 | Received 1 record from 2015-04-28 19:58:41 to 2015-04-28 19:58:41 (0.0 seconds) and wrote 0 records for BABA | 2015-04-29 03:40:04
HD Request # 30 | Intraday download COMPLETE for BABA. Completion time: 0s. Unique request ID: 32 | 2015-04-29 03:40:04
Removed historical data download ID 32 | 2015-04-29 03:40:04
Real-time Intraday chart data file updates started for BABA | 2015-04-29 03:40:04
HD Request # 31 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: dtn | 2015-04-29 03:40:04
HD Request # 31 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:40:04
HD Request # 31 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:40:04
HD Request # 31 | Receiving historical Intraday Tick data for SPY | 2015-04-29 03:40:04
HD Request # 31 | Receiving Intraday data for SPY starting at 2015-04-28 19:59:58 | 2015-04-29 03:40:04
HD Request # 31 | Received 1 record from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for SPY | 2015-04-29 03:40:04
HD Request # 31 | Intraday download COMPLETE for SPY. Completion time: 0s. Unique request ID: 33 | 2015-04-29 03:40:04
Removed historical data download ID 33 | 2015-04-29 03:40:04
Real-time Intraday chart data file updates started for SPY | 2015-04-29 03:40:04
HD Request # 32 | Downloading Intraday chart data for UAL to the file UAL.scid. Service: dtn | 2015-04-29 03:40:04
HD Request # 32 | Download start Date-Time: 2015-04-28 17:14:23.0 | 2015-04-29 03:40:04
HD Request # 32 | Requesting Tick data beginning at 2015-04-28 17:14:23 US Eastern Time. | 2015-04-29 03:40:04
HD Request # 32 | Receiving historical Intraday Tick data for UAL | 2015-04-29 03:40:05
HD Request # 32 | Receiving Intraday data for UAL starting at 2015-04-28 17:14:23 | 2015-04-29 03:40:05
HD Request # 32 | Received 1 record from 2015-04-28 17:14:23 to 2015-04-28 17:14:23 (0.0 seconds) and wrote 0 records for UAL | 2015-04-29 03:40:05
HD Request # 32 | Intraday download COMPLETE for UAL. Completion time: 1s. Unique request ID: 34 | 2015-04-29 03:40:05
Removed historical data download ID 34 | 2015-04-29 03:40:05
Real-time Intraday chart data file updates started for UAL | 2015-04-29 03:40:05
HD Request # 33 | Downloading Intraday chart data for VXX to the file VXX.scid. Service: dtn | 2015-04-29 03:40:05
HD Request # 33 | Download start Date-Time: 2015-04-28 19:59:39.0 | 2015-04-29 03:40:05
HD Request # 33 | Requesting Tick data beginning at 2015-04-28 19:59:39 US Eastern Time. | 2015-04-29 03:40:05
HD Request # 33 | Receiving historical Intraday Tick data for VXX | 2015-04-29 03:40:05
HD Request # 33 | Receiving Intraday data for VXX starting at 2015-04-28 19:59:39 | 2015-04-29 03:40:05
HD Request # 33 | Received 2 records from 2015-04-28 19:59:39 to 2015-04-28 19:59:39 (0.0 seconds) and wrote 0 records for VXX | 2015-04-29 03:40:05
HD Request # 33 | Intraday download COMPLETE for VXX. Completion time: 0s. Unique request ID: 35 | 2015-04-29 03:40:05
Removed historical data download ID 35 | 2015-04-29 03:40:05
Real-time Intraday chart data file updates started for VXX | 2015-04-29 03:40:05
HD Request # 34 | Downloading Intraday chart data for FB to the file FB.scid. Service: dtn | 2015-04-29 03:40:05
HD Request # 34 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:40:05
HD Request # 34 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:40:05
HD Request # 34 | Receiving historical Intraday Tick data for FB | 2015-04-29 03:40:06
HD Request # 34 | Receiving Intraday data for FB starting at 2015-04-28 19:59:58 | 2015-04-29 03:40:06
HD Request # 34 | Received 1 record from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for FB | 2015-04-29 03:40:06
HD Request # 34 | Intraday download COMPLETE for FB. Completion time: 1s. Unique request ID: 36 | 2015-04-29 03:40:06
Removed historical data download ID 36 | 2015-04-29 03:40:06
Real-time Intraday chart data file updates started for FB | 2015-04-29 03:40:06
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2015-04-29 03:41:16
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2015-04-29 03:41:16
Connection to the external service has been lost. | 2015-04-29 03:41:16
Socket (9) | Shutdown and closed. | 2015-04-29 03:41:16
IQFeed | Disconnected from Level 2 port. | 2015-04-29 03:41:16
Socket (8) | Shutdown and closed. | 2015-04-29 03:41:16
IQFeed | Disconnected from Lookup port. | 2015-04-29 03:41:16
Socket (7) | Shutdown and closed. | 2015-04-29 03:41:16
IQFeed | Disconnected from Level 1 port. | 2015-04-29 03:41:16
Socket (6) | Shutdown and closed. | 2015-04-29 03:41:16
IQFeed | Disconnected from Admin port. | 2015-04-29 03:41:16
IQFeed | Fully disconnected. | 2015-04-29 03:41:16
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-29 03:41:16
IQFeed | Connecting. | 2015-04-29 03:41:21
Starting DTN IQ Feed interface software. | 2015-04-29 03:41:21
IQFeed | Connecting to Admin port 9300 | 2015-04-29 03:41:21
Socket (10) | Connected. | 2015-04-29 03:41:21
IQFeed | Connected to Admin port. | 2015-04-29 03:41:21
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2015-04-29 03:41:21
AdminMessage: S,STATS,66.112.156.226,60006,500,0,12,0,15,0,Apr 29 3:41AM,Apr 29 3:41AM,Connected,5.1.1.3,423970,174.52,0.02,87.26,1367.67,0.04,683.83, | 2015-04-29 03:41:22
IQFeed | Connecting to Level 1 port 5009 | 2015-04-29 03:41:22
Socket (11) | Connected. | 2015-04-29 03:41:22
IQFeed | Connected to Level 1 port. | 2015-04-29 03:41:22
IQFeed | Connecting to Lookup port 9100 | 2015-04-29 03:41:22
IQFeed | Connecting to Level 2 port (9200)... | 2015-04-29 03:41:22
Socket (12) | Connected. | 2015-04-29 03:41:22
IQFeed | Connected to Historical Data port. | 2015-04-29 03:41:22
IQFeed | Fully connected. | 2015-04-29 03:41:22
Socket (13) | Connected. | 2015-04-29 03:41:22
IQFeed | Connected to Level 2 port. | 2015-04-29 03:41:22
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:41:22
IQFeed | Level 2 protocol is 5.0. | 2015-04-29 03:41:22
IQFeed | Level 1 system message: KEY | 2015-04-29 03:41:22
IQFeed | Level 1 system message: SERVER CONNECTED | 2015-04-29 03:41:22
IQFeed | Level 1 system message: IP | 2015-04-29 03:41:22
IQFeed | Level 1 system message: CUST | 2015-04-29 03:41:22
IQFeed | Starting real-time market data updates for: AAPL. ID: 1 | 2015-04-29 03:41:22
Intraday data recording state for symbol AAPL is set to download pending. | 2015-04-29 03:41:22
HD Request # 35 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: dtn | 2015-04-29 03:41:22
HD Request # 35 | Download start Date-Time: 2015-04-28 19:59:48.0 | 2015-04-29 03:41:22
HD Request # 35 | Requesting Tick data beginning at 2015-04-28 19:59:48 US Eastern Time. | 2015-04-29 03:41:22
IQFeed | Starting real-time market data updates for: AMZN. ID: 2 | 2015-04-29 03:41:22
Intraday data recording state for symbol AMZN is set to download pending. | 2015-04-29 03:41:22
IQFeed | Starting real-time market data updates for: @ES#C. ID: 3 | 2015-04-29 03:41:22
Intraday data recording state for symbol @ES#C is set to download pending. | 2015-04-29 03:41:22
IQFeed | Starting real-time market data updates for: XOm. ID: 4 | 2015-04-29 03:41:22
Intraday data recording state for symbol XOm is set to download pending. | 2015-04-29 03:41:22
IQFeed | Starting real-time market data updates for: QQQ. ID: 5 | 2015-04-29 03:41:22
Intraday data recording state for symbol QQQ is set to download pending. | 2015-04-29 03:41:22
IQFeed | Starting real-time market data updates for: @ym#C. ID: 6 | 2015-04-29 03:41:22
Intraday data recording state for symbol @ym#C is set to download pending. | 2015-04-29 03:41:22
IQFeed | Starting real-time market data updates for: BRK.B. ID: 7 | 2015-04-29 03:41:22
Intraday data recording state for symbol BRK.B is set to download pending. | 2015-04-29 03:41:22
IQFeed | Starting real-time market data updates for: V. ID: 8 | 2015-04-29 03:41:22
Intraday data recording state for symbol V is set to download pending. | 2015-04-29 03:41:22
IQFeed | Starting real-time market data updates for: TSLA. ID: 9 | 2015-04-29 03:41:22
Intraday data recording state for symbol TSLA is set to download pending. | 2015-04-29 03:41:22
IQFeed | Starting real-time market data updates for: LNKD. ID: 10 | 2015-04-29 03:41:22
Intraday data recording state for symbol LNKD is set to download pending. | 2015-04-29 03:41:22
IQFeed | Starting real-time market data updates for: NKE. ID: 11 | 2015-04-29 03:41:22
Intraday data recording state for symbol NKE is set to download pending. | 2015-04-29 03:41:22
IQFeed | Starting real-time market data updates for: @NQ#C. ID: 12 | 2015-04-29 03:41:22
Intraday data recording state for symbol @NQ#C is set to download pending. | 2015-04-29 03:41:22
IQFeed | Starting real-time market data updates for: TWTR. ID: 13 | 2015-04-29 03:41:22
Intraday data recording state for symbol TWTR is set to download pending. | 2015-04-29 03:41:22
IQFeed | Starting real-time market data updates for: BABA. ID: 14 | 2015-04-29 03:41:23
Intraday data recording state for symbol BABA is set to download pending. | 2015-04-29 03:41:23
IQFeed | Starting real-time market data updates for: SPY. ID: 15 | 2015-04-29 03:41:23
Intraday data recording state for symbol SPY is set to download pending. | 2015-04-29 03:41:23
IQFeed | Starting real-time market data updates for: UAL. ID: 16 | 2015-04-29 03:41:23
Intraday data recording state for symbol UAL is set to download pending. | 2015-04-29 03:41:23
IQFeed | Starting real-time market data updates for: VXX. ID: 17 | 2015-04-29 03:41:23
Intraday data recording state for symbol VXX is set to download pending. | 2015-04-29 03:41:23
IQFeed | Starting real-time market data updates for: FB. ID: 18 | 2015-04-29 03:41:23
Intraday data recording state for symbol FB is set to download pending. | 2015-04-29 03:41:23
HD Request # 35 | Receiving historical Intraday Tick data for AAPL | 2015-04-29 03:41:27
HD Request # 35 | Receiving Intraday data for AAPL starting at 2015-04-28 19:59:48 | 2015-04-29 03:41:27
HD Request # 35 | Received 1 record from 2015-04-28 19:59:48 to 2015-04-28 19:59:48 (0.0 seconds) and wrote 0 records for AAPL | 2015-04-29 03:41:27
HD Request # 35 | Intraday download COMPLETE for AAPL. Completion time: 5s. Unique request ID: 37 | 2015-04-29 03:41:27
Removed historical data download ID 37 | 2015-04-29 03:41:27
Real-time Intraday chart data file updates started for AAPL | 2015-04-29 03:41:27
HD Request # 36 | Downloading Intraday chart data for AMZN to the file AMZN.scid. Service: dtn | 2015-04-29 03:41:27
HD Request # 36 | Download start Date-Time: 2015-04-28 19:29:10.0 | 2015-04-29 03:41:27
HD Request # 36 | Requesting Tick data beginning at 2015-04-28 19:29:10 US Eastern Time. | 2015-04-29 03:41:27
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:41:27
HD Request # 36 | Receiving historical Intraday Tick data for AMZN | 2015-04-29 03:41:27
HD Request # 36 | Receiving Intraday data for AMZN starting at 2015-04-28 19:29:10 | 2015-04-29 03:41:27
HD Request # 36 | Received 1 record from 2015-04-28 19:29:10 to 2015-04-28 19:29:10 (0.0 seconds) and wrote 0 records for AMZN | 2015-04-29 03:41:27
HD Request # 36 | Intraday download COMPLETE for AMZN. Completion time: 0s. Unique request ID: 38 | 2015-04-29 03:41:27
Removed historical data download ID 38 | 2015-04-29 03:41:27
Real-time Intraday chart data file updates started for AMZN | 2015-04-29 03:41:27
HD Request # 37 | Downloading Intraday chart data for @ES#C to the file @ES#C.scid. Service: dtn | 2015-04-29 03:41:27
HD Request # 37 | Download start Date-Time: 2015-04-29 03:31:09.0 | 2015-04-29 03:41:27
HD Request # 37 | Requesting Tick data beginning at 2015-04-29 03:31:09 US Eastern Time. | 2015-04-29 03:41:27
HD Request # 37 | Receiving historical Intraday Tick data for @ES#C | 2015-04-29 03:41:28
HD Request # 37 | Receiving Intraday data for @ES#C starting at 2015-04-29 03:31:09 | 2015-04-29 03:41:28
HD Request # 37 | Timestamp of first Intraday data file record written: 2015-04-29 03:31:16 | 2015-04-29 03:41:28
HD Request # 37 | Received 20 records from 2015-04-29 03:31:09 to 2015-04-29 03:31:28 (19.0 seconds) and wrote 19 records for @ES#C | 2015-04-29 03:41:28
HD Request # 37 | Intraday download COMPLETE for @ES#C. Completion time: 0s. Unique request ID: 39 | 2015-04-29 03:41:28
Removed historical data download ID 39 | 2015-04-29 03:41:28
Real-time Intraday chart data file updates started for @ES#C | 2015-04-29 03:41:28
HD Request # 38 | Downloading Intraday chart data for XOm to the file XOm.scid. Service: dtn | 2015-04-29 03:41:28
HD Request # 38 | Download start Date-Time: 2015-04-28 19:59:49.0 | 2015-04-29 03:41:28
HD Request # 38 | Requesting Tick data beginning at 2015-04-28 19:59:49 US Eastern Time. | 2015-04-29 03:41:28
HD Request # 38 | Receiving historical Intraday Tick data for XOM | 2015-04-29 03:41:28
HD Request # 38 | Receiving Intraday data for XOm starting at 2015-04-28 19:59:49 | 2015-04-29 03:41:28
HD Request # 38 | Received 1 record from 2015-04-28 19:59:49 to 2015-04-28 19:59:49 (0.0 seconds) and wrote 0 records for XOm | 2015-04-29 03:41:28
HD Request # 38 | Intraday download COMPLETE for XOm. Completion time: 0s. Unique request ID: 40 | 2015-04-29 03:41:28
Removed historical data download ID 40 | 2015-04-29 03:41:28
Real-time Intraday chart data file updates started for XOm | 2015-04-29 03:41:28
HD Request # 39 | Downloading Intraday chart data for QQQ to the file QQQ.scid. Service: dtn | 2015-04-29 03:41:28
HD Request # 39 | Download start Date-Time: 2015-04-28 19:44:40.0 | 2015-04-29 03:41:28
HD Request # 39 | Requesting Tick data beginning at 2015-04-28 19:44:40 US Eastern Time. | 2015-04-29 03:41:28
HD Request # 39 | Receiving historical Intraday Tick data for QQQ | 2015-04-29 03:41:29
HD Request # 39 | Receiving Intraday data for QQQ starting at 2015-04-28 19:44:40 | 2015-04-29 03:41:29
HD Request # 39 | Received 4 records from 2015-04-28 19:44:40 to 2015-04-28 19:44:40 (0.0 seconds) and wrote 0 records for QQQ | 2015-04-29 03:41:29
HD Request # 39 | Intraday download COMPLETE for QQQ. Completion time: 1s. Unique request ID: 41 | 2015-04-29 03:41:29
Removed historical data download ID 41 | 2015-04-29 03:41:29
Real-time Intraday chart data file updates started for QQQ | 2015-04-29 03:41:29
HD Request # 40 | Downloading Intraday chart data for @ym#C to the file @ym#C.scid. Service: dtn | 2015-04-29 03:41:29
HD Request # 40 | Download start Date-Time: 2015-04-29 03:31:09.0 | 2015-04-29 03:41:29
HD Request # 40 | Requesting Tick data beginning at 2015-04-29 03:31:09 US Eastern Time. | 2015-04-29 03:41:29
HD Request # 40 | Receiving historical Intraday Tick data for @YM#C | 2015-04-29 03:41:29
HD Request # 40 | Receiving Intraday data for @ym#C starting at 2015-04-29 03:31:09 | 2015-04-29 03:41:29
HD Request # 40 | Timestamp of first Intraday data file record written: 2015-04-29 03:31:14 | 2015-04-29 03:41:29
HD Request # 40 | Received 8 records from 2015-04-29 03:31:09 to 2015-04-29 03:31:21 (12.0 seconds) and wrote 7 records for @ym#C | 2015-04-29 03:41:29
HD Request # 40 | Intraday download COMPLETE for @ym#C. Completion time: 0s. Unique request ID: 42 | 2015-04-29 03:41:29
Removed historical data download ID 42 | 2015-04-29 03:41:29
Real-time Intraday chart data file updates started for @ym#C | 2015-04-29 03:41:29
HD Request # 41 | Downloading Intraday chart data for BRK.B to the file BRK.B.scid. Service: dtn | 2015-04-29 03:41:29
HD Request # 41 | Download start Date-Time: 2015-04-28 17:01:29.0 | 2015-04-29 03:41:29
HD Request # 41 | Requesting Tick data beginning at 2015-04-28 17:01:29 US Eastern Time. | 2015-04-29 03:41:29
HD Request # 41 | Receiving historical Intraday Tick data for BRK.B | 2015-04-29 03:41:30
HD Request # 41 | Receiving Intraday data for BRK.B starting at 2015-04-28 17:01:29 | 2015-04-29 03:41:30
HD Request # 41 | Received 1 record from 2015-04-28 17:01:29 to 2015-04-28 17:01:29 (0.0 seconds) and wrote 0 records for BRK.B | 2015-04-29 03:41:30
HD Request # 41 | Intraday download COMPLETE for BRK.B. Completion time: 0s. Unique request ID: 43 | 2015-04-29 03:41:30
Removed historical data download ID 43 | 2015-04-29 03:41:30
Real-time Intraday chart data file updates started for BRK.B | 2015-04-29 03:41:30
HD Request # 42 | Downloading Intraday chart data for V to the file V.scid. Service: dtn | 2015-04-29 03:41:30
HD Request # 42 | Download start Date-Time: 2015-04-28 19:57:15.0 | 2015-04-29 03:41:30
HD Request # 42 | Requesting Tick data beginning at 2015-04-28 19:57:15 US Eastern Time. | 2015-04-29 03:41:30
HD Request # 42 | Receiving historical Intraday Tick data for V | 2015-04-29 03:41:31
HD Request # 42 | Receiving Intraday data for V starting at 2015-04-28 19:57:15 | 2015-04-29 03:41:31
HD Request # 42 | Received 1 record from 2015-04-28 19:57:15 to 2015-04-28 19:57:15 (0.0 seconds) and wrote 0 records for V | 2015-04-29 03:41:31
HD Request # 42 | Intraday download COMPLETE for V. Completion time: 1s. Unique request ID: 44 | 2015-04-29 03:41:31
Removed historical data download ID 44 | 2015-04-29 03:41:31
Real-time Intraday chart data file updates started for V | 2015-04-29 03:41:31
HD Request # 43 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: dtn | 2015-04-29 03:41:31
HD Request # 43 | Download start Date-Time: 2015-04-28 19:59:10.0 | 2015-04-29 03:41:31
HD Request # 43 | Requesting Tick data beginning at 2015-04-28 19:59:10 US Eastern Time. | 2015-04-29 03:41:31
HD Request # 43 | Receiving historical Intraday Tick data for TSLA | 2015-04-29 03:41:31
HD Request # 43 | Receiving Intraday data for TSLA starting at 2015-04-28 19:59:10 | 2015-04-29 03:41:31
HD Request # 43 | Received 1 record from 2015-04-28 19:59:10 to 2015-04-28 19:59:10 (0.0 seconds) and wrote 0 records for TSLA | 2015-04-29 03:41:31
HD Request # 43 | Intraday download COMPLETE for TSLA. Completion time: 0s. Unique request ID: 45 | 2015-04-29 03:41:31
Removed historical data download ID 45 | 2015-04-29 03:41:31
Real-time Intraday chart data file updates started for TSLA | 2015-04-29 03:41:31
HD Request # 44 | Downloading Intraday chart data for LNKD to the file LNKD.scid. Service: dtn | 2015-04-29 03:41:31
HD Request # 44 | Download start Date-Time: 2015-04-28 19:46:00.0 | 2015-04-29 03:41:31
HD Request # 44 | Requesting Tick data beginning at 2015-04-28 19:46:00 US Eastern Time. | 2015-04-29 03:41:31
HD Request # 44 | Receiving historical Intraday Tick data for LNKD | 2015-04-29 03:41:32
HD Request # 44 | Receiving Intraday data for LNKD starting at 2015-04-28 19:46:00 | 2015-04-29 03:41:32
HD Request # 44 | Received 1 record from 2015-04-28 19:46:00 to 2015-04-28 19:46:00 (0.0 seconds) and wrote 0 records for LNKD | 2015-04-29 03:41:32
HD Request # 44 | Intraday download COMPLETE for LNKD. Completion time: 1s. Unique request ID: 46 | 2015-04-29 03:41:32
Removed historical data download ID 46 | 2015-04-29 03:41:32
Real-time Intraday chart data file updates started for LNKD | 2015-04-29 03:41:32
HD Request # 45 | Downloading Intraday chart data for NKE to the file NKE.scid. Service: dtn | 2015-04-29 03:41:32
HD Request # 45 | Download start Date-Time: 2015-04-28 16:32:54.0 | 2015-04-29 03:41:32
HD Request # 45 | Requesting Tick data beginning at 2015-04-28 16:32:54 US Eastern Time. | 2015-04-29 03:41:32
HD Request # 45 | Receiving historical Intraday Tick data for NKE | 2015-04-29 03:41:32
HD Request # 45 | Receiving Intraday data for NKE starting at 2015-04-28 16:32:54 | 2015-04-29 03:41:32
HD Request # 45 | Received 1 record from 2015-04-28 16:32:54 to 2015-04-28 16:32:54 (0.0 seconds) and wrote 0 records for NKE | 2015-04-29 03:41:32
HD Request # 45 | Intraday download COMPLETE for NKE. Completion time: 0s. Unique request ID: 47 | 2015-04-29 03:41:32
Removed historical data download ID 47 | 2015-04-29 03:41:32
Real-time Intraday chart data file updates started for NKE | 2015-04-29 03:41:32
HD Request # 46 | Downloading Intraday chart data for @NQ#C to the file @NQ#C.scid. Service: dtn | 2015-04-29 03:41:32
HD Request # 46 | Download start Date-Time: 2015-04-29 03:30:39.0 | 2015-04-29 03:41:32
HD Request # 46 | Requesting Tick data beginning at 2015-04-29 03:30:39 US Eastern Time. | 2015-04-29 03:41:32
HD Request # 46 | Receiving historical Intraday Tick data for @NQ#C | 2015-04-29 03:41:33
HD Request # 46 | Receiving Intraday data for @NQ#C starting at 2015-04-29 03:30:39 | 2015-04-29 03:41:33
HD Request # 46 | Timestamp of first Intraday data file record written: 2015-04-29 03:31:17 | 2015-04-29 03:41:33
HD Request # 46 | Received 8 records from 2015-04-29 03:30:39 to 2015-04-29 03:31:35 (56.0 seconds) and wrote 7 records for @NQ#C | 2015-04-29 03:41:33
HD Request # 46 | Intraday download COMPLETE for @NQ#C. Completion time: 0s. Unique request ID: 48 | 2015-04-29 03:41:33
Removed historical data download ID 48 | 2015-04-29 03:41:33
Real-time Intraday chart data file updates started for @NQ#C | 2015-04-29 03:41:33
HD Request # 47 | Downloading Intraday chart data for TWTR to the file TWTR.scid. Service: dtn | 2015-04-29 03:41:33
HD Request # 47 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:41:33
HD Request # 47 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:41:33
HD Request # 47 | Receiving historical Intraday Tick data for TWTR | 2015-04-29 03:41:34
HD Request # 47 | Receiving Intraday data for TWTR starting at 2015-04-28 19:59:58 | 2015-04-29 03:41:34
HD Request # 47 | Received 3 records from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for TWTR | 2015-04-29 03:41:34
HD Request # 47 | Intraday download COMPLETE for TWTR. Completion time: 1s. Unique request ID: 49 | 2015-04-29 03:41:34
Removed historical data download ID 49 | 2015-04-29 03:41:34
Real-time Intraday chart data file updates started for TWTR | 2015-04-29 03:41:34
HD Request # 48 | Downloading Intraday chart data for BABA to the file BABA.scid. Service: dtn | 2015-04-29 03:41:34
HD Request # 48 | Download start Date-Time: 2015-04-28 19:58:41.0 | 2015-04-29 03:41:34
HD Request # 48 | Requesting Tick data beginning at 2015-04-28 19:58:41 US Eastern Time. | 2015-04-29 03:41:34
HD Request # 48 | Receiving historical Intraday Tick data for BABA | 2015-04-29 03:41:34
HD Request # 48 | Receiving Intraday data for BABA starting at 2015-04-28 19:58:41 | 2015-04-29 03:41:34
HD Request # 48 | Received 1 record from 2015-04-28 19:58:41 to 2015-04-28 19:58:41 (0.0 seconds) and wrote 0 records for BABA | 2015-04-29 03:41:34
HD Request # 48 | Intraday download COMPLETE for BABA. Completion time: 0s. Unique request ID: 50 | 2015-04-29 03:41:34
Removed historical data download ID 50 | 2015-04-29 03:41:34
Real-time Intraday chart data file updates started for BABA | 2015-04-29 03:41:34
HD Request # 49 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: dtn | 2015-04-29 03:41:34
HD Request # 49 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:41:34
HD Request # 49 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:41:34
HD Request # 49 | Receiving historical Intraday Tick data for SPY | 2015-04-29 03:41:35
HD Request # 49 | Receiving Intraday data for SPY starting at 2015-04-28 19:59:58 | 2015-04-29 03:41:35
HD Request # 49 | Received 1 record from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for SPY | 2015-04-29 03:41:35
HD Request # 49 | Intraday download COMPLETE for SPY. Completion time: 1s. Unique request ID: 51 | 2015-04-29 03:41:35
Removed historical data download ID 51 | 2015-04-29 03:41:35
Real-time Intraday chart data file updates started for SPY | 2015-04-29 03:41:35
HD Request # 50 | Downloading Intraday chart data for UAL to the file UAL.scid. Service: dtn | 2015-04-29 03:41:35
HD Request # 50 | Download start Date-Time: 2015-04-28 17:14:23.0 | 2015-04-29 03:41:35
HD Request # 50 | Requesting Tick data beginning at 2015-04-28 17:14:23 US Eastern Time. | 2015-04-29 03:41:35
HD Request # 50 | Receiving historical Intraday Tick data for UAL | 2015-04-29 03:41:35
HD Request # 50 | Receiving Intraday data for UAL starting at 2015-04-28 17:14:23 | 2015-04-29 03:41:35
HD Request # 50 | Received 1 record from 2015-04-28 17:14:23 to 2015-04-28 17:14:23 (0.0 seconds) and wrote 0 records for UAL | 2015-04-29 03:41:35
HD Request # 50 | Intraday download COMPLETE for UAL. Completion time: 0s. Unique request ID: 52 | 2015-04-29 03:41:35
Removed historical data download ID 52 | 2015-04-29 03:41:35
Real-time Intraday chart data file updates started for UAL | 2015-04-29 03:41:35
HD Request # 51 | Downloading Intraday chart data for VXX to the file VXX.scid. Service: dtn | 2015-04-29 03:41:35
HD Request # 51 | Download start Date-Time: 2015-04-28 19:59:39.0 | 2015-04-29 03:41:35
HD Request # 51 | Requesting Tick data beginning at 2015-04-28 19:59:39 US Eastern Time. | 2015-04-29 03:41:35
HD Request # 51 | Receiving historical Intraday Tick data for VXX | 2015-04-29 03:41:36
HD Request # 51 | Receiving Intraday data for VXX starting at 2015-04-28 19:59:39 | 2015-04-29 03:41:36
HD Request # 51 | Received 2 records from 2015-04-28 19:59:39 to 2015-04-28 19:59:39 (0.0 seconds) and wrote 0 records for VXX | 2015-04-29 03:41:36
HD Request # 51 | Intraday download COMPLETE for VXX. Completion time: 0s. Unique request ID: 53 | 2015-04-29 03:41:36
Removed historical data download ID 53 | 2015-04-29 03:41:36
Real-time Intraday chart data file updates started for VXX | 2015-04-29 03:41:36
HD Request # 52 | Downloading Intraday chart data for FB to the file FB.scid. Service: dtn | 2015-04-29 03:41:36
HD Request # 52 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:41:36
HD Request # 52 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:41:36
HD Request # 52 | Receiving historical Intraday Tick data for FB | 2015-04-29 03:41:36
HD Request # 52 | Receiving Intraday data for FB starting at 2015-04-28 19:59:58 | 2015-04-29 03:41:36
HD Request # 52 | Received 1 record from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for FB | 2015-04-29 03:41:36
HD Request # 52 | Intraday download COMPLETE for FB. Completion time: 0s. Unique request ID: 54 | 2015-04-29 03:41:36
Removed historical data download ID 54 | 2015-04-29 03:41:36
Real-time Intraday chart data file updates started for FB | 2015-04-29 03:41:36
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2015-04-29 03:41:57
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2015-04-29 03:41:57
Connection to the external service has been lost. | 2015-04-29 03:41:57
Socket (13) | Shutdown and closed. | 2015-04-29 03:41:57
IQFeed | Disconnected from Level 2 port. | 2015-04-29 03:41:57
Socket (12) | Shutdown and closed. | 2015-04-29 03:41:57
IQFeed | Disconnected from Lookup port. | 2015-04-29 03:41:57
Socket (11) | Shutdown and closed. | 2015-04-29 03:41:57
IQFeed | Disconnected from Level 1 port. | 2015-04-29 03:41:57
Socket (10) | Shutdown and closed. | 2015-04-29 03:41:57
IQFeed | Disconnected from Admin port. | 2015-04-29 03:41:57
IQFeed | Fully disconnected. | 2015-04-29 03:41:57
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-29 03:41:57
IQFeed | Connecting. | 2015-04-29 03:42:02
Starting DTN IQ Feed interface software. | 2015-04-29 03:42:02
IQFeed | Connecting to Admin port 9300 | 2015-04-29 03:42:02
Socket (14) | Connected. | 2015-04-29 03:42:02
IQFeed | Connected to Admin port. | 2015-04-29 03:42:02
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2015-04-29 03:42:02
AdminMessage: S,STATS,66.112.156.223,60005,500,0,13,1,16,0,Apr 29 3:42AM,Apr 29 3:42AM,Connected,5.1.1.3,423970,198.38,0.02,99.19,1553.00,0.04,776.50, | 2015-04-29 03:42:03
IQFeed | Connecting to Level 1 port 5009 | 2015-04-29 03:42:03
Socket (15) | Connected. | 2015-04-29 03:42:03
IQFeed | Connected to Level 1 port. | 2015-04-29 03:42:03
IQFeed | Connecting to Lookup port 9100 | 2015-04-29 03:42:03
IQFeed | Connecting to Level 2 port (9200)... | 2015-04-29 03:42:03
Socket (16) | Connected. | 2015-04-29 03:42:03
IQFeed | Connected to Historical Data port. | 2015-04-29 03:42:03
IQFeed | Fully connected. | 2015-04-29 03:42:03
Socket (17) | Connected. | 2015-04-29 03:42:03
IQFeed | Connected to Level 2 port. | 2015-04-29 03:42:03
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:42:03
IQFeed | Level 2 protocol is 5.0. | 2015-04-29 03:42:03
IQFeed | Level 1 system message: KEY | 2015-04-29 03:42:03
IQFeed | Level 1 system message: SERVER CONNECTED | 2015-04-29 03:42:03
IQFeed | Level 1 system message: IP | 2015-04-29 03:42:03
IQFeed | Level 1 system message: CUST | 2015-04-29 03:42:03
IQFeed | Starting real-time market data updates for: TSLA. ID: 1 | 2015-04-29 03:42:03
Intraday data recording state for symbol TSLA is set to download pending. | 2015-04-29 03:42:03
HD Request # 53 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: dtn | 2015-04-29 03:42:03
HD Request # 53 | Download start Date-Time: 2015-04-28 19:59:10.0 | 2015-04-29 03:42:03
HD Request # 53 | Requesting Tick data beginning at 2015-04-28 19:59:10 US Eastern Time. | 2015-04-29 03:42:03
IQFeed | Starting real-time market data updates for: LNKD. ID: 2 | 2015-04-29 03:42:03
Intraday data recording state for symbol LNKD is set to download pending. | 2015-04-29 03:42:03
IQFeed | Starting real-time market data updates for: @ES#C. ID: 3 | 2015-04-29 03:42:03
Intraday data recording state for symbol @ES#C is set to download pending. | 2015-04-29 03:42:03
IQFeed | Starting real-time market data updates for: NKE. ID: 4 | 2015-04-29 03:42:03
Intraday data recording state for symbol NKE is set to download pending. | 2015-04-29 03:42:03
IQFeed | Starting real-time market data updates for: @NQ#C. ID: 5 | 2015-04-29 03:42:03
Intraday data recording state for symbol @NQ#C is set to download pending. | 2015-04-29 03:42:03
IQFeed | Starting real-time market data updates for: QQQ. ID: 6 | 2015-04-29 03:42:03
Intraday data recording state for symbol QQQ is set to download pending. | 2015-04-29 03:42:03
IQFeed | Starting real-time market data updates for: TWTR. ID: 7 | 2015-04-29 03:42:03
Intraday data recording state for symbol TWTR is set to download pending. | 2015-04-29 03:42:03
IQFeed | Starting real-time market data updates for: BABA. ID: 8 | 2015-04-29 03:42:03
Intraday data recording state for symbol BABA is set to download pending. | 2015-04-29 03:42:03
IQFeed | Starting real-time market data updates for: SPY. ID: 9 | 2015-04-29 03:42:03
Intraday data recording state for symbol SPY is set to download pending. | 2015-04-29 03:42:03
IQFeed | Starting real-time market data updates for: UAL. ID: 10 | 2015-04-29 03:42:03
Intraday data recording state for symbol UAL is set to download pending. | 2015-04-29 03:42:03
IQFeed | Starting real-time market data updates for: VXX. ID: 11 | 2015-04-29 03:42:03
Intraday data recording state for symbol VXX is set to download pending. | 2015-04-29 03:42:03
IQFeed | Starting real-time market data updates for: FB. ID: 12 | 2015-04-29 03:42:03
Intraday data recording state for symbol FB is set to download pending. | 2015-04-29 03:42:03
IQFeed | Starting real-time market data updates for: AMZN. ID: 13 | 2015-04-29 03:42:03
Intraday data recording state for symbol AMZN is set to download pending. | 2015-04-29 03:42:03
HD Request # 53 | Receiving historical Intraday Tick data for TSLA | 2015-04-29 03:42:03
HD Request # 53 | Receiving Intraday data for TSLA starting at 2015-04-28 19:59:10 | 2015-04-29 03:42:03
HD Request # 53 | Received 1 record from 2015-04-28 19:59:10 to 2015-04-28 19:59:10 (0.0 seconds) and wrote 0 records for TSLA | 2015-04-29 03:42:03
HD Request # 53 | Intraday download COMPLETE for TSLA. Completion time: 0s. Unique request ID: 55 | 2015-04-29 03:42:03
Removed historical data download ID 55 | 2015-04-29 03:42:03
Real-time Intraday chart data file updates started for TSLA | 2015-04-29 03:42:03
HD Request # 54 | Downloading Intraday chart data for LNKD to the file LNKD.scid. Service: dtn | 2015-04-29 03:42:03
HD Request # 54 | Download start Date-Time: 2015-04-28 19:46:00.0 | 2015-04-29 03:42:03
HD Request # 54 | Requesting Tick data beginning at 2015-04-28 19:46:00 US Eastern Time. | 2015-04-29 03:42:03
IQFeed | Starting real-time market data updates for: AAPL. ID: 14 | 2015-04-29 03:42:03
Intraday data recording state for symbol AAPL is set to download pending. | 2015-04-29 03:42:03
IQFeed | Starting real-time market data updates for: XOm. ID: 15 | 2015-04-29 03:42:03
Intraday data recording state for symbol XOm is set to download pending. | 2015-04-29 03:42:03
IQFeed | Starting real-time market data updates for: @ym#C. ID: 16 | 2015-04-29 03:42:03
Intraday data recording state for symbol @ym#C is set to download pending. | 2015-04-29 03:42:03
IQFeed | Starting real-time market data updates for: BRK.B. ID: 17 | 2015-04-29 03:42:03
Intraday data recording state for symbol BRK.B is set to download pending. | 2015-04-29 03:42:03
IQFeed | Starting real-time market data updates for: V. ID: 18 | 2015-04-29 03:42:03
Intraday data recording state for symbol V is set to download pending. | 2015-04-29 03:42:04
HD Request # 54 | Receiving historical Intraday Tick data for LNKD | 2015-04-29 03:42:04
HD Request # 54 | Receiving Intraday data for LNKD starting at 2015-04-28 19:46:00 | 2015-04-29 03:42:04
HD Request # 54 | Received 1 record from 2015-04-28 19:46:00 to 2015-04-28 19:46:00 (0.0 seconds) and wrote 0 records for LNKD | 2015-04-29 03:42:04
HD Request # 54 | Intraday download COMPLETE for LNKD. Completion time: 1s. Unique request ID: 56 | 2015-04-29 03:42:04
Removed historical data download ID 56 | 2015-04-29 03:42:04
Real-time Intraday chart data file updates started for LNKD | 2015-04-29 03:42:04
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:42:04
HD Request # 55 | Downloading Intraday chart data for @ES#C to the file @ES#C.scid. Service: dtn | 2015-04-29 03:42:04
HD Request # 55 | Download start Date-Time: 2015-04-29 03:31:50.0 | 2015-04-29 03:42:04
HD Request # 55 | Requesting Tick data beginning at 2015-04-29 03:31:50 US Eastern Time. | 2015-04-29 03:42:04
HD Request # 55 | Receiving historical Intraday Tick data for @ES#C | 2015-04-29 03:42:04
HD Request # 55 | Receiving Intraday data for @ES#C starting at 2015-04-29 03:31:50 | 2015-04-29 03:42:04
HD Request # 55 | Timestamp of first Intraday data file record written: 2015-04-29 03:31:54 | 2015-04-29 03:42:04
HD Request # 55 | Received 144 records from 2015-04-29 03:31:50 to 2015-04-29 03:32:06 (16.0 seconds) and wrote 135 records for @ES#C | 2015-04-29 03:42:04
HD Request # 55 | Intraday download COMPLETE for @ES#C. Completion time: 0s. Unique request ID: 57 | 2015-04-29 03:42:04
Removed historical data download ID 57 | 2015-04-29 03:42:04
Real-time Intraday chart data file updates started for @ES#C | 2015-04-29 03:42:04
HD Request # 56 | Downloading Intraday chart data for NKE to the file NKE.scid. Service: dtn | 2015-04-29 03:42:04
HD Request # 56 | Download start Date-Time: 2015-04-28 16:32:54.0 | 2015-04-29 03:42:04
HD Request # 56 | Requesting Tick data beginning at 2015-04-28 16:32:54 US Eastern Time. | 2015-04-29 03:42:04
HD Request # 56 | Receiving historical Intraday Tick data for NKE | 2015-04-29 03:42:05
HD Request # 56 | Receiving Intraday data for NKE starting at 2015-04-28 16:32:54 | 2015-04-29 03:42:05
HD Request # 56 | Received 1 record from 2015-04-28 16:32:54 to 2015-04-28 16:32:54 (0.0 seconds) and wrote 0 records for NKE | 2015-04-29 03:42:05
HD Request # 56 | Intraday download COMPLETE for NKE. Completion time: 0s. Unique request ID: 58 | 2015-04-29 03:42:05
Removed historical data download ID 58 | 2015-04-29 03:42:05
Real-time Intraday chart data file updates started for NKE | 2015-04-29 03:42:05
HD Request # 57 | Downloading Intraday chart data for @NQ#C to the file @NQ#C.scid. Service: dtn | 2015-04-29 03:42:05
HD Request # 57 | Download start Date-Time: 2015-04-29 03:31:50.0 | 2015-04-29 03:42:05
HD Request # 57 | Requesting Tick data beginning at 2015-04-29 03:31:50 US Eastern Time. | 2015-04-29 03:42:05
HD Request # 57 | Receiving historical Intraday Tick data for @NQ#C | 2015-04-29 03:42:05
HD Request # 57 | Receiving Intraday data for @NQ#C starting at 2015-04-29 03:31:50 | 2015-04-29 03:42:05
HD Request # 57 | Timestamp of first Intraday data file record written: 2015-04-29 03:31:54 | 2015-04-29 03:42:05
HD Request # 57 | Received 32 records from 2015-04-29 03:31:50 to 2015-04-29 03:32:07 (17.0 seconds) and wrote 29 records for @NQ#C | 2015-04-29 03:42:05
HD Request # 57 | Intraday download COMPLETE for @NQ#C. Completion time: 0s. Unique request ID: 59 | 2015-04-29 03:42:05
Removed historical data download ID 59 | 2015-04-29 03:42:05
Real-time Intraday chart data file updates started for @NQ#C | 2015-04-29 03:42:05
HD Request # 58 | Downloading Intraday chart data for QQQ to the file QQQ.scid. Service: dtn | 2015-04-29 03:42:06
HD Request # 58 | Download start Date-Time: 2015-04-28 19:44:40.0 | 2015-04-29 03:42:06
HD Request # 58 | Requesting Tick data beginning at 2015-04-28 19:44:40 US Eastern Time. | 2015-04-29 03:42:06
HD Request # 58 | Receiving historical Intraday Tick data for QQQ | 2015-04-29 03:42:06
HD Request # 58 | Receiving Intraday data for QQQ starting at 2015-04-28 19:44:40 | 2015-04-29 03:42:06
HD Request # 58 | Received 4 records from 2015-04-28 19:44:40 to 2015-04-28 19:44:40 (0.0 seconds) and wrote 0 records for QQQ | 2015-04-29 03:42:06
HD Request # 58 | Intraday download COMPLETE for QQQ. Completion time: 0s. Unique request ID: 60 | 2015-04-29 03:42:06
Removed historical data download ID 60 | 2015-04-29 03:42:06
Real-time Intraday chart data file updates started for QQQ | 2015-04-29 03:42:06
HD Request # 59 | Downloading Intraday chart data for TWTR to the file TWTR.scid. Service: dtn | 2015-04-29 03:42:06
HD Request # 59 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:42:06
HD Request # 59 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:42:06
HD Request # 59 | Receiving historical Intraday Tick data for TWTR | 2015-04-29 03:42:07
HD Request # 59 | Receiving Intraday data for TWTR starting at 2015-04-28 19:59:58 | 2015-04-29 03:42:07
HD Request # 59 | Received 3 records from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for TWTR | 2015-04-29 03:42:07
HD Request # 59 | Intraday download COMPLETE for TWTR. Completion time: 1s. Unique request ID: 61 | 2015-04-29 03:42:07
Removed historical data download ID 61 | 2015-04-29 03:42:07
Real-time Intraday chart data file updates started for TWTR | 2015-04-29 03:42:07
HD Request # 60 | Downloading Intraday chart data for BABA to the file BABA.scid. Service: dtn | 2015-04-29 03:42:07
HD Request # 60 | Download start Date-Time: 2015-04-28 19:58:41.0 | 2015-04-29 03:42:07
HD Request # 60 | Requesting Tick data beginning at 2015-04-28 19:58:41 US Eastern Time. | 2015-04-29 03:42:07
HD Request # 60 | Receiving historical Intraday Tick data for BABA | 2015-04-29 03:42:07
HD Request # 60 | Receiving Intraday data for BABA starting at 2015-04-28 19:58:41 | 2015-04-29 03:42:07
HD Request # 60 | Received 1 record from 2015-04-28 19:58:41 to 2015-04-28 19:58:41 (0.0 seconds) and wrote 0 records for BABA | 2015-04-29 03:42:07
HD Request # 60 | Intraday download COMPLETE for BABA. Completion time: 0s. Unique request ID: 62 | 2015-04-29 03:42:07
Removed historical data download ID 62 | 2015-04-29 03:42:07
Real-time Intraday chart data file updates started for BABA | 2015-04-29 03:42:07
HD Request # 61 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: dtn | 2015-04-29 03:42:07
HD Request # 61 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:42:07
HD Request # 61 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:42:07
HD Request # 61 | Receiving historical Intraday Tick data for SPY | 2015-04-29 03:42:08
HD Request # 61 | Receiving Intraday data for SPY starting at 2015-04-28 19:59:58 | 2015-04-29 03:42:08
HD Request # 61 | Received 1 record from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for SPY | 2015-04-29 03:42:08
HD Request # 61 | Intraday download COMPLETE for SPY. Completion time: 0s. Unique request ID: 63 | 2015-04-29 03:42:08
Removed historical data download ID 63 | 2015-04-29 03:42:08
Real-time Intraday chart data file updates started for SPY | 2015-04-29 03:42:08
HD Request # 62 | Downloading Intraday chart data for UAL to the file UAL.scid. Service: dtn | 2015-04-29 03:42:08
HD Request # 62 | Download start Date-Time: 2015-04-28 17:14:23.0 | 2015-04-29 03:42:08
HD Request # 62 | Requesting Tick data beginning at 2015-04-28 17:14:23 US Eastern Time. | 2015-04-29 03:42:08
HD Request # 62 | Receiving historical Intraday Tick data for UAL | 2015-04-29 03:42:08
HD Request # 62 | Receiving Intraday data for UAL starting at 2015-04-28 17:14:23 | 2015-04-29 03:42:08
HD Request # 62 | Received 1 record from 2015-04-28 17:14:23 to 2015-04-28 17:14:23 (0.0 seconds) and wrote 0 records for UAL | 2015-04-29 03:42:08
HD Request # 62 | Intraday download COMPLETE for UAL. Completion time: 0s. Unique request ID: 64 | 2015-04-29 03:42:08
Removed historical data download ID 64 | 2015-04-29 03:42:08
Real-time Intraday chart data file updates started for UAL | 2015-04-29 03:42:08
HD Request # 63 | Downloading Intraday chart data for VXX to the file VXX.scid. Service: dtn | 2015-04-29 03:42:08
HD Request # 63 | Download start Date-Time: 2015-04-28 19:59:39.0 | 2015-04-29 03:42:08
HD Request # 63 | Requesting Tick data beginning at 2015-04-28 19:59:39 US Eastern Time. | 2015-04-29 03:42:08
HD Request # 63 | Receiving historical Intraday Tick data for VXX | 2015-04-29 03:42:09
HD Request # 63 | Receiving Intraday data for VXX starting at 2015-04-28 19:59:39 | 2015-04-29 03:42:09
HD Request # 63 | Received 2 records from 2015-04-28 19:59:39 to 2015-04-28 19:59:39 (0.0 seconds) and wrote 0 records for VXX | 2015-04-29 03:42:09
HD Request # 63 | Intraday download COMPLETE for VXX. Completion time: 1s. Unique request ID: 65 | 2015-04-29 03:42:09
Removed historical data download ID 65 | 2015-04-29 03:42:09
Real-time Intraday chart data file updates started for VXX | 2015-04-29 03:42:09
HD Request # 64 | Downloading Intraday chart data for FB to the file FB.scid. Service: dtn | 2015-04-29 03:42:09
HD Request # 64 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:42:09
HD Request # 64 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:42:09
HD Request # 64 | Receiving historical Intraday Tick data for FB | 2015-04-29 03:42:09
HD Request # 64 | Receiving Intraday data for FB starting at 2015-04-28 19:59:58 | 2015-04-29 03:42:09
HD Request # 64 | Received 1 record from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for FB | 2015-04-29 03:42:09
HD Request # 64 | Intraday download COMPLETE for FB. Completion time: 0s. Unique request ID: 66 | 2015-04-29 03:42:09
Removed historical data download ID 66 | 2015-04-29 03:42:09
Real-time Intraday chart data file updates started for FB | 2015-04-29 03:42:09
HD Request # 65 | Downloading Intraday chart data for AMZN to the file AMZN.scid. Service: dtn | 2015-04-29 03:42:09
HD Request # 65 | Download start Date-Time: 2015-04-28 19:29:10.0 | 2015-04-29 03:42:09
HD Request # 65 | Requesting Tick data beginning at 2015-04-28 19:29:10 US Eastern Time. | 2015-04-29 03:42:09
HD Request # 65 | Receiving historical Intraday Tick data for AMZN | 2015-04-29 03:42:10
HD Request # 65 | Receiving Intraday data for AMZN starting at 2015-04-28 19:29:10 | 2015-04-29 03:42:10
HD Request # 65 | Received 1 record from 2015-04-28 19:29:10 to 2015-04-28 19:29:10 (0.0 seconds) and wrote 0 records for AMZN | 2015-04-29 03:42:10
HD Request # 65 | Intraday download COMPLETE for AMZN. Completion time: 1s. Unique request ID: 67 | 2015-04-29 03:42:10
Removed historical data download ID 67 | 2015-04-29 03:42:10
Real-time Intraday chart data file updates started for AMZN | 2015-04-29 03:42:10
HD Request # 66 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: dtn | 2015-04-29 03:42:10
HD Request # 66 | Download start Date-Time: 2015-04-28 19:59:48.0 | 2015-04-29 03:42:10
HD Request # 66 | Requesting Tick data beginning at 2015-04-28 19:59:48 US Eastern Time. | 2015-04-29 03:42:10
HD Request # 66 | Receiving historical Intraday Tick data for AAPL | 2015-04-29 03:42:10
HD Request # 66 | Receiving Intraday data for AAPL starting at 2015-04-28 19:59:48 | 2015-04-29 03:42:10
HD Request # 66 | Received 1 record from 2015-04-28 19:59:48 to 2015-04-28 19:59:48 (0.0 seconds) and wrote 0 records for AAPL | 2015-04-29 03:42:10
HD Request # 66 | Intraday download COMPLETE for AAPL. Completion time: 0s. Unique request ID: 68 | 2015-04-29 03:42:10
Removed historical data download ID 68 | 2015-04-29 03:42:10
Real-time Intraday chart data file updates started for AAPL | 2015-04-29 03:42:10
HD Request # 67 | Downloading Intraday chart data for XOm to the file XOm.scid. Service: dtn | 2015-04-29 03:42:10
HD Request # 67 | Download start Date-Time: 2015-04-28 19:59:49.0 | 2015-04-29 03:42:10
HD Request # 67 | Requesting Tick data beginning at 2015-04-28 19:59:49 US Eastern Time. | 2015-04-29 03:42:10
HD Request # 67 | Receiving historical Intraday Tick data for XOM | 2015-04-29 03:42:11
HD Request # 67 | Receiving Intraday data for XOm starting at 2015-04-28 19:59:49 | 2015-04-29 03:42:11
HD Request # 67 | Received 1 record from 2015-04-28 19:59:49 to 2015-04-28 19:59:49 (0.0 seconds) and wrote 0 records for XOm | 2015-04-29 03:42:11
HD Request # 67 | Intraday download COMPLETE for XOm. Completion time: 0s. Unique request ID: 69 | 2015-04-29 03:42:11
Removed historical data download ID 69 | 2015-04-29 03:42:11
Real-time Intraday chart data file updates started for XOm | 2015-04-29 03:42:11
HD Request # 68 | Downloading Intraday chart data for @ym#C to the file @ym#C.scid. Service: dtn | 2015-04-29 03:42:11
HD Request # 68 | Download start Date-Time: 2015-04-29 03:31:50.0 | 2015-04-29 03:42:11
HD Request # 68 | Requesting Tick data beginning at 2015-04-29 03:31:50 US Eastern Time. | 2015-04-29 03:42:11
HD Request # 68 | Receiving historical Intraday Tick data for @YM#C | 2015-04-29 03:42:11
HD Request # 68 | Receiving Intraday data for @ym#C starting at 2015-04-29 03:31:50 | 2015-04-29 03:42:11
HD Request # 68 | Timestamp of first Intraday data file record written: 2015-04-29 03:31:53 | 2015-04-29 03:42:11
HD Request # 68 | Received 58 records from 2015-04-29 03:31:50 to 2015-04-29 03:32:13 (23.0 seconds) and wrote 57 records for @ym#C | 2015-04-29 03:42:11
HD Request # 68 | Intraday download COMPLETE for @ym#C. Completion time: 0s. Unique request ID: 70 | 2015-04-29 03:42:11
Removed historical data download ID 70 | 2015-04-29 03:42:11
Real-time Intraday chart data file updates started for @ym#C | 2015-04-29 03:42:11
HD Request # 69 | Downloading Intraday chart data for BRK.B to the file BRK.B.scid. Service: dtn | 2015-04-29 03:42:11
HD Request # 69 | Download start Date-Time: 2015-04-28 17:01:29.0 | 2015-04-29 03:42:11
HD Request # 69 | Requesting Tick data beginning at 2015-04-28 17:01:29 US Eastern Time. | 2015-04-29 03:42:11
HD Request # 69 | Receiving historical Intraday Tick data for BRK.B | 2015-04-29 03:42:12
HD Request # 69 | Receiving Intraday data for BRK.B starting at 2015-04-28 17:01:29 | 2015-04-29 03:42:12
HD Request # 69 | Received 1 record from 2015-04-28 17:01:29 to 2015-04-28 17:01:29 (0.0 seconds) and wrote 0 records for BRK.B | 2015-04-29 03:42:12
HD Request # 69 | Intraday download COMPLETE for BRK.B. Completion time: 1s. Unique request ID: 71 | 2015-04-29 03:42:12
Removed historical data download ID 71 | 2015-04-29 03:42:12
Real-time Intraday chart data file updates started for BRK.B | 2015-04-29 03:42:12
HD Request # 70 | Downloading Intraday chart data for V to the file V.scid. Service: dtn | 2015-04-29 03:42:12
HD Request # 70 | Download start Date-Time: 2015-04-28 19:57:15.0 | 2015-04-29 03:42:12
HD Request # 70 | Requesting Tick data beginning at 2015-04-28 19:57:15 US Eastern Time. | 2015-04-29 03:42:12
HD Request # 70 | Receiving historical Intraday Tick data for V | 2015-04-29 03:42:12
HD Request # 70 | Receiving Intraday data for V starting at 2015-04-28 19:57:15 | 2015-04-29 03:42:12
HD Request # 70 | Received 1 record from 2015-04-28 19:57:15 to 2015-04-28 19:57:15 (0.0 seconds) and wrote 0 records for V | 2015-04-29 03:42:12
HD Request # 70 | Intraday download COMPLETE for V. Completion time: 0s. Unique request ID: 72 | 2015-04-29 03:42:13
Removed historical data download ID 72 | 2015-04-29 03:42:13
Real-time Intraday chart data file updates started for V | 2015-04-29 03:42:13
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2015-04-29 03:42:38
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2015-04-29 03:42:38
Connection to the external service has been lost. | 2015-04-29 03:42:38
Socket (17) | Shutdown and closed. | 2015-04-29 03:42:38
IQFeed | Disconnected from Level 2 port. | 2015-04-29 03:42:38
Socket (16) | Shutdown and closed. | 2015-04-29 03:42:38
IQFeed | Disconnected from Lookup port. | 2015-04-29 03:42:38
Socket (15) | Shutdown and closed. | 2015-04-29 03:42:38
IQFeed | Disconnected from Level 1 port. | 2015-04-29 03:42:38
Socket (14) | Shutdown and closed. | 2015-04-29 03:42:38
IQFeed | Disconnected from Admin port. | 2015-04-29 03:42:38
IQFeed | Fully disconnected. | 2015-04-29 03:42:38
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-29 03:42:38
IQFeed | Connecting. | 2015-04-29 03:42:43
Starting DTN IQ Feed interface software. | 2015-04-29 03:42:43
IQFeed | Connecting to Admin port 9300 | 2015-04-29 03:42:43
Socket (18) | Connected. | 2015-04-29 03:42:43
IQFeed | Connected to Admin port. | 2015-04-29 03:42:43
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2015-04-29 03:42:43
AdminMessage: S,STATS,66.112.148.229,60002,500,0,14,1,17,0,Apr 29 3:42AM,Apr 29 3:42AM,Connected,5.1.1.3,423970,231.84,0.02,115.92,1885.86,0.04,942.93, | 2015-04-29 03:42:44
IQFeed | Connecting to Level 1 port 5009 | 2015-04-29 03:42:44
Socket (19) | Connected. | 2015-04-29 03:42:44
IQFeed | Connected to Level 1 port. | 2015-04-29 03:42:44
IQFeed | Connecting to Lookup port 9100 | 2015-04-29 03:42:44
IQFeed | Connecting to Level 2 port (9200)... | 2015-04-29 03:42:44
Socket (20) | Connected. | 2015-04-29 03:42:44
IQFeed | Connected to Historical Data port. | 2015-04-29 03:42:44
IQFeed | Fully connected. | 2015-04-29 03:42:44
Socket (21) | Connected. | 2015-04-29 03:42:44
IQFeed | Connected to Level 2 port. | 2015-04-29 03:42:44
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:42:44
IQFeed | Level 2 protocol is 5.0. | 2015-04-29 03:42:44
IQFeed | Level 1 system message: KEY | 2015-04-29 03:42:44
IQFeed | Level 1 system message: SERVER CONNECTED | 2015-04-29 03:42:44
IQFeed | Level 1 system message: IP | 2015-04-29 03:42:44
IQFeed | Level 1 system message: CUST | 2015-04-29 03:42:44
IQFeed | Starting real-time market data updates for: TSLA. ID: 1 | 2015-04-29 03:42:44
Intraday data recording state for symbol TSLA is set to download pending. | 2015-04-29 03:42:44
HD Request # 71 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: dtn | 2015-04-29 03:42:44
HD Request # 71 | Download start Date-Time: 2015-04-28 19:59:10.0 | 2015-04-29 03:42:44
HD Request # 71 | Requesting Tick data beginning at 2015-04-28 19:59:10 US Eastern Time. | 2015-04-29 03:42:44
IQFeed | Starting real-time market data updates for: LNKD. ID: 2 | 2015-04-29 03:42:44
Intraday data recording state for symbol LNKD is set to download pending. | 2015-04-29 03:42:44
IQFeed | Starting real-time market data updates for: @ES#C. ID: 3 | 2015-04-29 03:42:44
Intraday data recording state for symbol @ES#C is set to download pending. | 2015-04-29 03:42:44
IQFeed | Starting real-time market data updates for: TWTR. ID: 4 | 2015-04-29 03:42:44
Intraday data recording state for symbol TWTR is set to download pending. | 2015-04-29 03:42:44
IQFeed | Starting real-time market data updates for: BABA. ID: 5 | 2015-04-29 03:42:44
Intraday data recording state for symbol BABA is set to download pending. | 2015-04-29 03:42:44
IQFeed | Starting real-time market data updates for: SPY. ID: 6 | 2015-04-29 03:42:44
Intraday data recording state for symbol SPY is set to download pending. | 2015-04-29 03:42:44
IQFeed | Starting real-time market data updates for: NKE. ID: 7 | 2015-04-29 03:42:44
Intraday data recording state for symbol NKE is set to download pending. | 2015-04-29 03:42:44
IQFeed | Starting real-time market data updates for: @NQ#C. ID: 8 | 2015-04-29 03:42:44
Intraday data recording state for symbol @NQ#C is set to download pending. | 2015-04-29 03:42:44
IQFeed | Starting real-time market data updates for: QQQ. ID: 9 | 2015-04-29 03:42:44
Intraday data recording state for symbol QQQ is set to download pending. | 2015-04-29 03:42:44
IQFeed | Starting real-time market data updates for: UAL. ID: 10 | 2015-04-29 03:42:44
Intraday data recording state for symbol UAL is set to download pending. | 2015-04-29 03:42:44
IQFeed | Starting real-time market data updates for: VXX. ID: 11 | 2015-04-29 03:42:44
Intraday data recording state for symbol VXX is set to download pending. | 2015-04-29 03:42:44
IQFeed | Starting real-time market data updates for: FB. ID: 12 | 2015-04-29 03:42:44
Intraday data recording state for symbol FB is set to download pending. | 2015-04-29 03:42:44
IQFeed | Starting real-time market data updates for: AMZN. ID: 13 | 2015-04-29 03:42:44
Intraday data recording state for symbol AMZN is set to download pending. | 2015-04-29 03:42:44
HD Request # 71 | Receiving historical Intraday Tick data for TSLA | 2015-04-29 03:42:44
HD Request # 71 | Receiving Intraday data for TSLA starting at 2015-04-28 19:59:10 | 2015-04-29 03:42:44
HD Request # 71 | Received 1 record from 2015-04-28 19:59:10 to 2015-04-28 19:59:10 (0.0 seconds) and wrote 0 records for TSLA | 2015-04-29 03:42:44
HD Request # 71 | Intraday download COMPLETE for TSLA. Completion time: 0s. Unique request ID: 73 | 2015-04-29 03:42:44
Removed historical data download ID 73 | 2015-04-29 03:42:44
Real-time Intraday chart data file updates started for TSLA | 2015-04-29 03:42:44
HD Request # 72 | Downloading Intraday chart data for LNKD to the file LNKD.scid. Service: dtn | 2015-04-29 03:42:44
HD Request # 72 | Download start Date-Time: 2015-04-28 19:46:00.0 | 2015-04-29 03:42:44
HD Request # 72 | Requesting Tick data beginning at 2015-04-28 19:46:00 US Eastern Time. | 2015-04-29 03:42:44
IQFeed | Starting real-time market data updates for: AAPL. ID: 14 | 2015-04-29 03:42:44
Intraday data recording state for symbol AAPL is set to download pending. | 2015-04-29 03:42:44
IQFeed | Starting real-time market data updates for: XOm. ID: 15 | 2015-04-29 03:42:44
Intraday data recording state for symbol XOm is set to download pending. | 2015-04-29 03:42:45
IQFeed | Starting real-time market data updates for: @ym#C. ID: 16 | 2015-04-29 03:42:45
Intraday data recording state for symbol @ym#C is set to download pending. | 2015-04-29 03:42:45
IQFeed | Starting real-time market data updates for: BRK.B. ID: 17 | 2015-04-29 03:42:45
Intraday data recording state for symbol BRK.B is set to download pending. | 2015-04-29 03:42:45
IQFeed | Starting real-time market data updates for: V. ID: 18 | 2015-04-29 03:42:45
Intraday data recording state for symbol V is set to download pending. | 2015-04-29 03:42:45
HD Request # 72 | Receiving historical Intraday Tick data for LNKD | 2015-04-29 03:42:48
HD Request # 72 | Receiving Intraday data for LNKD starting at 2015-04-28 19:46:00 | 2015-04-29 03:42:48
HD Request # 72 | Received 1 record from 2015-04-28 19:46:00 to 2015-04-28 19:46:00 (0.0 seconds) and wrote 0 records for LNKD | 2015-04-29 03:42:48
HD Request # 72 | Intraday download COMPLETE for LNKD. Completion time: 4s. Unique request ID: 74 | 2015-04-29 03:42:48
Removed historical data download ID 74 | 2015-04-29 03:42:48
Real-time Intraday chart data file updates started for LNKD | 2015-04-29 03:42:48
HD Request # 73 | Downloading Intraday chart data for @ES#C to the file @ES#C.scid. Service: dtn | 2015-04-29 03:42:48
HD Request # 73 | Download start Date-Time: 2015-04-29 03:32:28.0 | 2015-04-29 03:42:48
HD Request # 73 | Requesting Tick data beginning at 2015-04-29 03:32:28 US Eastern Time. | 2015-04-29 03:42:48
HD Request # 73 | Receiving historical Intraday Tick data for @ES#C | 2015-04-29 03:42:48
HD Request # 73 | Receiving Intraday data for @ES#C starting at 2015-04-29 03:32:28 | 2015-04-29 03:42:48
HD Request # 73 | Timestamp of first Intraday data file record written: 2015-04-29 03:32:36 | 2015-04-29 03:42:48
HD Request # 73 | Received 41 records from 2015-04-29 03:32:28 to 2015-04-29 03:32:50 (22.0 seconds) and wrote 40 records for @ES#C | 2015-04-29 03:42:48
HD Request # 73 | Intraday download COMPLETE for @ES#C. Completion time: 0s. Unique request ID: 75 | 2015-04-29 03:42:48
Removed historical data download ID 75 | 2015-04-29 03:42:48
Real-time Intraday chart data file updates started for @ES#C | 2015-04-29 03:42:48
HD Request # 74 | Downloading Intraday chart data for TWTR to the file TWTR.scid. Service: dtn | 2015-04-29 03:42:48
HD Request # 74 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:42:48
HD Request # 74 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:42:48
HD Request # 74 | Receiving historical Intraday Tick data for TWTR | 2015-04-29 03:42:49
HD Request # 74 | Receiving Intraday data for TWTR starting at 2015-04-28 19:59:58 | 2015-04-29 03:42:49
HD Request # 74 | Received 3 records from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for TWTR | 2015-04-29 03:42:49
HD Request # 74 | Intraday download COMPLETE for TWTR. Completion time: 1s. Unique request ID: 76 | 2015-04-29 03:42:49
Removed historical data download ID 76 | 2015-04-29 03:42:49
Real-time Intraday chart data file updates started for TWTR | 2015-04-29 03:42:49
HD Request # 75 | Downloading Intraday chart data for BABA to the file BABA.scid. Service: dtn | 2015-04-29 03:42:49
HD Request # 75 | Download start Date-Time: 2015-04-28 19:58:41.0 | 2015-04-29 03:42:49
HD Request # 75 | Requesting Tick data beginning at 2015-04-28 19:58:41 US Eastern Time. | 2015-04-29 03:42:49
HD Request # 75 | Receiving historical Intraday Tick data for BABA | 2015-04-29 03:42:49
HD Request # 75 | Receiving Intraday data for BABA starting at 2015-04-28 19:58:41 | 2015-04-29 03:42:49
HD Request # 75 | Received 1 record from 2015-04-28 19:58:41 to 2015-04-28 19:58:41 (0.0 seconds) and wrote 0 records for BABA | 2015-04-29 03:42:49
HD Request # 75 | Intraday download COMPLETE for BABA. Completion time: 0s. Unique request ID: 77 | 2015-04-29 03:42:49
Removed historical data download ID 77 | 2015-04-29 03:42:49
Real-time Intraday chart data file updates started for BABA | 2015-04-29 03:42:49
HD Request # 76 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: dtn | 2015-04-29 03:42:49
HD Request # 76 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:42:49
HD Request # 76 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:42:49
HD Request # 76 | Receiving historical Intraday Tick data for SPY | 2015-04-29 03:42:50
HD Request # 76 | Receiving Intraday data for SPY starting at 2015-04-28 19:59:58 | 2015-04-29 03:42:50
HD Request # 76 | Received 1 record from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for SPY | 2015-04-29 03:42:50
HD Request # 76 | Intraday download COMPLETE for SPY. Completion time: 1s. Unique request ID: 78 | 2015-04-29 03:42:50
Removed historical data download ID 78 | 2015-04-29 03:42:50
Real-time Intraday chart data file updates started for SPY | 2015-04-29 03:42:50
HD Request # 77 | Downloading Intraday chart data for NKE to the file NKE.scid. Service: dtn | 2015-04-29 03:42:50
HD Request # 77 | Download start Date-Time: 2015-04-28 16:32:54.0 | 2015-04-29 03:42:50
HD Request # 77 | Requesting Tick data beginning at 2015-04-28 16:32:54 US Eastern Time. | 2015-04-29 03:42:50
HD Request # 77 | Receiving historical Intraday Tick data for NKE | 2015-04-29 03:42:50
HD Request # 77 | Receiving Intraday data for NKE starting at 2015-04-28 16:32:54 | 2015-04-29 03:42:50
HD Request # 77 | Received 1 record from 2015-04-28 16:32:54 to 2015-04-28 16:32:54 (0.0 seconds) and wrote 0 records for NKE | 2015-04-29 03:42:50
HD Request # 77 | Intraday download COMPLETE for NKE. Completion time: 0s. Unique request ID: 79 | 2015-04-29 03:42:50
Removed historical data download ID 79 | 2015-04-29 03:42:50
Real-time Intraday chart data file updates started for NKE | 2015-04-29 03:42:50
HD Request # 78 | Downloading Intraday chart data for @NQ#C to the file @NQ#C.scid. Service: dtn | 2015-04-29 03:42:50
HD Request # 78 | Download start Date-Time: 2015-04-29 03:32:21.0 | 2015-04-29 03:42:50
HD Request # 78 | Requesting Tick data beginning at 2015-04-29 03:32:21 US Eastern Time. | 2015-04-29 03:42:50
HD Request # 78 | Receiving historical Intraday Tick data for @NQ#C | 2015-04-29 03:42:51
HD Request # 78 | Receiving Intraday data for @NQ#C starting at 2015-04-29 03:32:21 | 2015-04-29 03:42:51
HD Request # 78 | Timestamp of first Intraday data file record written: 2015-04-29 03:32:49 | 2015-04-29 03:42:51
HD Request # 78 | Received 31 records from 2015-04-29 03:32:21 to 2015-04-29 03:32:50 (29.0 seconds) and wrote 28 records for @NQ#C | 2015-04-29 03:42:51
HD Request # 78 | Intraday download COMPLETE for @NQ#C. Completion time: 0s. Unique request ID: 80 | 2015-04-29 03:42:51
Removed historical data download ID 80 | 2015-04-29 03:42:51
Real-time Intraday chart data file updates started for @NQ#C | 2015-04-29 03:42:51
HD Request # 79 | Downloading Intraday chart data for QQQ to the file QQQ.scid. Service: dtn | 2015-04-29 03:42:51
HD Request # 79 | Download start Date-Time: 2015-04-28 19:44:40.0 | 2015-04-29 03:42:51
HD Request # 79 | Requesting Tick data beginning at 2015-04-28 19:44:40 US Eastern Time. | 2015-04-29 03:42:51
HD Request # 79 | Receiving historical Intraday Tick data for QQQ | 2015-04-29 03:42:51
HD Request # 79 | Receiving Intraday data for QQQ starting at 2015-04-28 19:44:40 | 2015-04-29 03:42:51
HD Request # 79 | Received 4 records from 2015-04-28 19:44:40 to 2015-04-28 19:44:40 (0.0 seconds) and wrote 0 records for QQQ | 2015-04-29 03:42:51
HD Request # 79 | Intraday download COMPLETE for QQQ. Completion time: 0s. Unique request ID: 81 | 2015-04-29 03:42:51
Removed historical data download ID 81 | 2015-04-29 03:42:51
Real-time Intraday chart data file updates started for QQQ | 2015-04-29 03:42:51
HD Request # 80 | Downloading Intraday chart data for UAL to the file UAL.scid. Service: dtn | 2015-04-29 03:42:51
HD Request # 80 | Download start Date-Time: 2015-04-28 17:14:23.0 | 2015-04-29 03:42:51
HD Request # 80 | Requesting Tick data beginning at 2015-04-28 17:14:23 US Eastern Time. | 2015-04-29 03:42:51
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:42:52
HD Request # 80 | Receiving historical Intraday Tick data for UAL | 2015-04-29 03:42:52
HD Request # 80 | Receiving Intraday data for UAL starting at 2015-04-28 17:14:23 | 2015-04-29 03:42:52
HD Request # 80 | Received 1 record from 2015-04-28 17:14:23 to 2015-04-28 17:14:23 (0.0 seconds) and wrote 0 records for UAL | 2015-04-29 03:42:52
HD Request # 80 | Intraday download COMPLETE for UAL. Completion time: 1s. Unique request ID: 82 | 2015-04-29 03:42:52
Removed historical data download ID 82 | 2015-04-29 03:42:52
Real-time Intraday chart data file updates started for UAL | 2015-04-29 03:42:52
HD Request # 81 | Downloading Intraday chart data for VXX to the file VXX.scid. Service: dtn | 2015-04-29 03:42:52
HD Request # 81 | Download start Date-Time: 2015-04-28 19:59:39.0 | 2015-04-29 03:42:52
HD Request # 81 | Requesting Tick data beginning at 2015-04-28 19:59:39 US Eastern Time. | 2015-04-29 03:42:52
HD Request # 81 | Receiving historical Intraday Tick data for VXX | 2015-04-29 03:42:52
HD Request # 81 | Receiving Intraday data for VXX starting at 2015-04-28 19:59:39 | 2015-04-29 03:42:52
HD Request # 81 | Received 2 records from 2015-04-28 19:59:39 to 2015-04-28 19:59:39 (0.0 seconds) and wrote 0 records for VXX | 2015-04-29 03:42:52
HD Request # 81 | Intraday download COMPLETE for VXX. Completion time: 0s. Unique request ID: 83 | 2015-04-29 03:42:52
Removed historical data download ID 83 | 2015-04-29 03:42:52
Real-time Intraday chart data file updates started for VXX | 2015-04-29 03:42:52
HD Request # 82 | Downloading Intraday chart data for FB to the file FB.scid. Service: dtn | 2015-04-29 03:42:52
HD Request # 82 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:42:52
HD Request # 82 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:42:52
HD Request # 82 | Receiving historical Intraday Tick data for FB | 2015-04-29 03:42:53
HD Request # 82 | Receiving Intraday data for FB starting at 2015-04-28 19:59:58 | 2015-04-29 03:42:53
HD Request # 82 | Received 1 record from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for FB | 2015-04-29 03:42:53
HD Request # 82 | Intraday download COMPLETE for FB. Completion time: 1s. Unique request ID: 84 | 2015-04-29 03:42:53
Removed historical data download ID 84 | 2015-04-29 03:42:53
Real-time Intraday chart data file updates started for FB | 2015-04-29 03:42:53
HD Request # 83 | Downloading Intraday chart data for AMZN to the file AMZN.scid. Service: dtn | 2015-04-29 03:42:53
HD Request # 83 | Download start Date-Time: 2015-04-28 19:29:10.0 | 2015-04-29 03:42:53
HD Request # 83 | Requesting Tick data beginning at 2015-04-28 19:29:10 US Eastern Time. | 2015-04-29 03:42:53
HD Request # 83 | Receiving historical Intraday Tick data for AMZN | 2015-04-29 03:42:53
HD Request # 83 | Receiving Intraday data for AMZN starting at 2015-04-28 19:29:10 | 2015-04-29 03:42:53
HD Request # 83 | Received 1 record from 2015-04-28 19:29:10 to 2015-04-28 19:29:10 (0.0 seconds) and wrote 0 records for AMZN | 2015-04-29 03:42:53
HD Request # 83 | Intraday download COMPLETE for AMZN. Completion time: 0s. Unique request ID: 85 | 2015-04-29 03:42:53
Removed historical data download ID 85 | 2015-04-29 03:42:53
Real-time Intraday chart data file updates started for AMZN | 2015-04-29 03:42:53
HD Request # 84 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: dtn | 2015-04-29 03:42:53
HD Request # 84 | Download start Date-Time: 2015-04-28 19:59:48.0 | 2015-04-29 03:42:53
HD Request # 84 | Requesting Tick data beginning at 2015-04-28 19:59:48 US Eastern Time. | 2015-04-29 03:42:53
HD Request # 84 | Receiving historical Intraday Tick data for AAPL | 2015-04-29 03:42:54
HD Request # 84 | Receiving Intraday data for AAPL starting at 2015-04-28 19:59:48 | 2015-04-29 03:42:54
HD Request # 84 | Received 1 record from 2015-04-28 19:59:48 to 2015-04-28 19:59:48 (0.0 seconds) and wrote 0 records for AAPL | 2015-04-29 03:42:54
HD Request # 84 | Intraday download COMPLETE for AAPL. Completion time: 0s. Unique request ID: 86 | 2015-04-29 03:42:54
Removed historical data download ID 86 | 2015-04-29 03:42:54
Real-time Intraday chart data file updates started for AAPL | 2015-04-29 03:42:54
HD Request # 85 | Downloading Intraday chart data for XOm to the file XOm.scid. Service: dtn | 2015-04-29 03:42:54
HD Request # 85 | Download start Date-Time: 2015-04-28 19:59:49.0 | 2015-04-29 03:42:54
HD Request # 85 | Requesting Tick data beginning at 2015-04-28 19:59:49 US Eastern Time. | 2015-04-29 03:42:54
HD Request # 85 | Receiving historical Intraday Tick data for XOM | 2015-04-29 03:42:54
HD Request # 85 | Receiving Intraday data for XOm starting at 2015-04-28 19:59:49 | 2015-04-29 03:42:54
HD Request # 85 | Received 1 record from 2015-04-28 19:59:49 to 2015-04-28 19:59:49 (0.0 seconds) and wrote 0 records for XOm | 2015-04-29 03:42:54
HD Request # 85 | Intraday download COMPLETE for XOm. Completion time: 0s. Unique request ID: 87 | 2015-04-29 03:42:54
Removed historical data download ID 87 | 2015-04-29 03:42:54
Real-time Intraday chart data file updates started for XOm | 2015-04-29 03:42:54
HD Request # 86 | Downloading Intraday chart data for @ym#C to the file @ym#C.scid. Service: dtn | 2015-04-29 03:42:54
HD Request # 86 | Download start Date-Time: 2015-04-29 03:32:32.0 | 2015-04-29 03:42:54
HD Request # 86 | Requesting Tick data beginning at 2015-04-29 03:32:32 US Eastern Time. | 2015-04-29 03:42:54
HD Request # 86 | Receiving historical Intraday Tick data for @YM#C | 2015-04-29 03:42:55
HD Request # 86 | Receiving Intraday data for @ym#C starting at 2015-04-29 03:32:32 | 2015-04-29 03:42:55
HD Request # 86 | Timestamp of first Intraday data file record written: 2015-04-29 03:32:36 | 2015-04-29 03:42:55
HD Request # 86 | Received 21 records from 2015-04-29 03:32:32 to 2015-04-29 03:32:54 (22.0 seconds) and wrote 20 records for @ym#C | 2015-04-29 03:42:55
HD Request # 86 | Intraday download COMPLETE for @ym#C. Completion time: 1s. Unique request ID: 88 | 2015-04-29 03:42:55
Removed historical data download ID 88 | 2015-04-29 03:42:55
Real-time Intraday chart data file updates started for @ym#C | 2015-04-29 03:42:55
HD Request # 87 | Downloading Intraday chart data for BRK.B to the file BRK.B.scid. Service: dtn | 2015-04-29 03:42:55
HD Request # 87 | Download start Date-Time: 2015-04-28 17:01:29.0 | 2015-04-29 03:42:55
HD Request # 87 | Requesting Tick data beginning at 2015-04-28 17:01:29 US Eastern Time. | 2015-04-29 03:42:55
HD Request # 87 | Receiving historical Intraday Tick data for BRK.B | 2015-04-29 03:42:55
HD Request # 87 | Receiving Intraday data for BRK.B starting at 2015-04-28 17:01:29 | 2015-04-29 03:42:55
HD Request # 87 | Received 1 record from 2015-04-28 17:01:29 to 2015-04-28 17:01:29 (0.0 seconds) and wrote 0 records for BRK.B | 2015-04-29 03:42:55
HD Request # 87 | Intraday download COMPLETE for BRK.B. Completion time: 0s. Unique request ID: 89 | 2015-04-29 03:42:55
Removed historical data download ID 89 | 2015-04-29 03:42:55
Real-time Intraday chart data file updates started for BRK.B | 2015-04-29 03:42:55
HD Request # 88 | Downloading Intraday chart data for V to the file V.scid. Service: dtn | 2015-04-29 03:42:55
HD Request # 88 | Download start Date-Time: 2015-04-28 19:57:15.0 | 2015-04-29 03:42:55
HD Request # 88 | Requesting Tick data beginning at 2015-04-28 19:57:15 US Eastern Time. | 2015-04-29 03:42:55
HD Request # 88 | Receiving historical Intraday Tick data for V | 2015-04-29 03:42:56
HD Request # 88 | Receiving Intraday data for V starting at 2015-04-28 19:57:15 | 2015-04-29 03:42:56
HD Request # 88 | Received 1 record from 2015-04-28 19:57:15 to 2015-04-28 19:57:15 (0.0 seconds) and wrote 0 records for V | 2015-04-29 03:42:56
HD Request # 88 | Intraday download COMPLETE for V. Completion time: 0s. Unique request ID: 90 | 2015-04-29 03:42:56
Removed historical data download ID 90 | 2015-04-29 03:42:56
Real-time Intraday chart data file updates started for V | 2015-04-29 03:42:56
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2015-04-29 03:43:18
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2015-04-29 03:43:18
Connection to the external service has been lost. | 2015-04-29 03:43:18
Socket (21) | Shutdown and closed. | 2015-04-29 03:43:18
IQFeed | Disconnected from Level 2 port. | 2015-04-29 03:43:18
Socket (20) | Shutdown and closed. | 2015-04-29 03:43:18
IQFeed | Disconnected from Lookup port. | 2015-04-29 03:43:18
Socket (19) | Shutdown and closed. | 2015-04-29 03:43:18
IQFeed | Disconnected from Level 1 port. | 2015-04-29 03:43:18
Socket (18) | Shutdown and closed. | 2015-04-29 03:43:18
IQFeed | Disconnected from Admin port. | 2015-04-29 03:43:18
IQFeed | Fully disconnected. | 2015-04-29 03:43:18
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-29 03:43:18
IQFeed | Connecting. | 2015-04-29 03:43:23
Starting DTN IQ Feed interface software. | 2015-04-29 03:43:23
IQFeed | Connecting to Admin port 9300 | 2015-04-29 03:43:23
Socket (22) | Connected. | 2015-04-29 03:43:23
IQFeed | Connected to Admin port. | 2015-04-29 03:43:23
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2015-04-29 03:43:23
AdminMessage: S,STATS,66.112.148.229,60002,500,0,15,1,18,0,Apr 29 3:43AM,Apr 29 3:43AM,Connected,5.1.1.3,423970,292.90,0.02,146.45,2364.21,0.04,1182.11, | 2015-04-29 03:43:24
IQFeed | Connecting to Level 1 port 5009 | 2015-04-29 03:43:24
Socket (23) | Connected. | 2015-04-29 03:43:24
IQFeed | Connected to Level 1 port. | 2015-04-29 03:43:24
IQFeed | Connecting to Lookup port 9100 | 2015-04-29 03:43:24
IQFeed | Connecting to Level 2 port (9200)... | 2015-04-29 03:43:24
Socket (24) | Connected. | 2015-04-29 03:43:24
IQFeed | Connected to Historical Data port. | 2015-04-29 03:43:24
IQFeed | Fully connected. | 2015-04-29 03:43:24
Socket (25) | Connected. | 2015-04-29 03:43:24
IQFeed | Connected to Level 2 port. | 2015-04-29 03:43:24
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:43:24
IQFeed | Level 2 protocol is 5.0. | 2015-04-29 03:43:24
IQFeed | Level 1 system message: KEY | 2015-04-29 03:43:24
IQFeed | Level 1 system message: SERVER CONNECTED | 2015-04-29 03:43:24
IQFeed | Level 1 system message: IP | 2015-04-29 03:43:24
IQFeed | Level 1 system message: CUST | 2015-04-29 03:43:24
IQFeed | Starting real-time market data updates for: QQQ. ID: 1 | 2015-04-29 03:43:24
Intraday data recording state for symbol QQQ is set to download pending. | 2015-04-29 03:43:24
HD Request # 89 | Downloading Intraday chart data for QQQ to the file QQQ.scid. Service: dtn | 2015-04-29 03:43:24
HD Request # 89 | Download start Date-Time: 2015-04-28 19:44:40.0 | 2015-04-29 03:43:24
HD Request # 89 | Requesting Tick data beginning at 2015-04-28 19:44:40 US Eastern Time. | 2015-04-29 03:43:24
IQFeed | Starting real-time market data updates for: TSLA. ID: 2 | 2015-04-29 03:43:24
Intraday data recording state for symbol TSLA is set to download pending. | 2015-04-29 03:43:24
IQFeed | Starting real-time market data updates for: LNKD. ID: 3 | 2015-04-29 03:43:24
Intraday data recording state for symbol LNKD is set to download pending. | 2015-04-29 03:43:24
IQFeed | Starting real-time market data updates for: @ES#C. ID: 4 | 2015-04-29 03:43:24
Intraday data recording state for symbol @ES#C is set to download pending. | 2015-04-29 03:43:24
IQFeed | Starting real-time market data updates for: TWTR. ID: 5 | 2015-04-29 03:43:24
Intraday data recording state for symbol TWTR is set to download pending. | 2015-04-29 03:43:24
HD Request # 89 | Receiving historical Intraday Tick data for QQQ | 2015-04-29 03:43:24
HD Request # 89 | Receiving Intraday data for QQQ starting at 2015-04-28 19:44:40 | 2015-04-29 03:43:24
HD Request # 89 | Received 4 records from 2015-04-28 19:44:40 to 2015-04-28 19:44:40 (0.0 seconds) and wrote 0 records for QQQ | 2015-04-29 03:43:24
HD Request # 89 | Intraday download COMPLETE for QQQ. Completion time: 0s. Unique request ID: 91 | 2015-04-29 03:43:24
Removed historical data download ID 91 | 2015-04-29 03:43:24
Real-time Intraday chart data file updates started for QQQ | 2015-04-29 03:43:24
HD Request # 90 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: dtn | 2015-04-29 03:43:24
HD Request # 90 | Download start Date-Time: 2015-04-28 19:59:10.0 | 2015-04-29 03:43:24
HD Request # 90 | Requesting Tick data beginning at 2015-04-28 19:59:10 US Eastern Time. | 2015-04-29 03:43:24
IQFeed | Starting real-time market data updates for: BABA. ID: 6 | 2015-04-29 03:43:24
Intraday data recording state for symbol BABA is set to download pending. | 2015-04-29 03:43:24
IQFeed | Starting real-time market data updates for: SPY. ID: 7 | 2015-04-29 03:43:24
Intraday data recording state for symbol SPY is set to download pending. | 2015-04-29 03:43:24
IQFeed | Starting real-time market data updates for: NKE. ID: 8 | 2015-04-29 03:43:24
Intraday data recording state for symbol NKE is set to download pending. | 2015-04-29 03:43:24
IQFeed | Starting real-time market data updates for: @NQ#C. ID: 9 | 2015-04-29 03:43:24
Intraday data recording state for symbol @NQ#C is set to download pending. | 2015-04-29 03:43:24
IQFeed | Starting real-time market data updates for: UAL. ID: 10 | 2015-04-29 03:43:24
Intraday data recording state for symbol UAL is set to download pending. | 2015-04-29 03:43:24
IQFeed | Starting real-time market data updates for: VXX. ID: 11 | 2015-04-29 03:43:24
Intraday data recording state for symbol VXX is set to download pending. | 2015-04-29 03:43:24
IQFeed | Starting real-time market data updates for: FB. ID: 12 | 2015-04-29 03:43:24
Intraday data recording state for symbol FB is set to download pending. | 2015-04-29 03:43:24
IQFeed | Starting real-time market data updates for: AMZN. ID: 13 | 2015-04-29 03:43:24
Intraday data recording state for symbol AMZN is set to download pending. | 2015-04-29 03:43:24
IQFeed | Starting real-time market data updates for: AAPL. ID: 14 | 2015-04-29 03:43:24
Intraday data recording state for symbol AAPL is set to download pending. | 2015-04-29 03:43:24
IQFeed | Starting real-time market data updates for: XOm. ID: 15 | 2015-04-29 03:43:24
Intraday data recording state for symbol XOm is set to download pending. | 2015-04-29 03:43:24
IQFeed | Starting real-time market data updates for: @ym#C. ID: 16 | 2015-04-29 03:43:25
Intraday data recording state for symbol @ym#C is set to download pending. | 2015-04-29 03:43:25
IQFeed | Starting real-time market data updates for: BRK.B. ID: 17 | 2015-04-29 03:43:25
Intraday data recording state for symbol BRK.B is set to download pending. | 2015-04-29 03:43:25
HD Request # 90 | Receiving historical Intraday Tick data for TSLA | 2015-04-29 03:43:25
HD Request # 90 | Receiving Intraday data for TSLA starting at 2015-04-28 19:59:10 | 2015-04-29 03:43:25
HD Request # 90 | Received 1 record from 2015-04-28 19:59:10 to 2015-04-28 19:59:10 (0.0 seconds) and wrote 0 records for TSLA | 2015-04-29 03:43:25
HD Request # 90 | Intraday download COMPLETE for TSLA. Completion time: 1s. Unique request ID: 92 | 2015-04-29 03:43:25
Removed historical data download ID 92 | 2015-04-29 03:43:25
Real-time Intraday chart data file updates started for TSLA | 2015-04-29 03:43:25
HD Request # 91 | Downloading Intraday chart data for LNKD to the file LNKD.scid. Service: dtn | 2015-04-29 03:43:25
HD Request # 91 | Download start Date-Time: 2015-04-28 19:46:00.0 | 2015-04-29 03:43:25
HD Request # 91 | Requesting Tick data beginning at 2015-04-28 19:46:00 US Eastern Time. | 2015-04-29 03:43:25
IQFeed | Starting real-time market data updates for: V. ID: 18 | 2015-04-29 03:43:25
Intraday data recording state for symbol V is set to download pending. | 2015-04-29 03:43:25
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:43:25
HD Request # 91 | Receiving historical Intraday Tick data for LNKD | 2015-04-29 03:43:25
HD Request # 91 | Receiving Intraday data for LNKD starting at 2015-04-28 19:46:00 | 2015-04-29 03:43:25
HD Request # 91 | Received 1 record from 2015-04-28 19:46:00 to 2015-04-28 19:46:00 (0.0 seconds) and wrote 0 records for LNKD | 2015-04-29 03:43:25
HD Request # 91 | Intraday download COMPLETE for LNKD. Completion time: 0s. Unique request ID: 93 | 2015-04-29 03:43:25
Removed historical data download ID 93 | 2015-04-29 03:43:25
Real-time Intraday chart data file updates started for LNKD | 2015-04-29 03:43:25
HD Request # 92 | Downloading Intraday chart data for @ES#C to the file @ES#C.scid. Service: dtn | 2015-04-29 03:43:25
HD Request # 92 | Download start Date-Time: 2015-04-29 03:33:11.0 | 2015-04-29 03:43:25
HD Request # 92 | Requesting Tick data beginning at 2015-04-29 03:33:11 US Eastern Time. | 2015-04-29 03:43:25
HD Request # 92 | Receiving historical Intraday Tick data for @ES#C | 2015-04-29 03:43:26
HD Request # 92 | Receiving Intraday data for @ES#C starting at 2015-04-29 03:33:11 | 2015-04-29 03:43:26
HD Request # 92 | Timestamp of first Intraday data file record written: 2015-04-29 03:33:15 | 2015-04-29 03:43:26
HD Request # 92 | Received 132 records from 2015-04-29 03:33:11 to 2015-04-29 03:33:27 (16.0 seconds) and wrote 113 records for @ES#C | 2015-04-29 03:43:26
HD Request # 92 | Intraday download COMPLETE for @ES#C. Completion time: 0s. Unique request ID: 94 | 2015-04-29 03:43:26
Removed historical data download ID 94 | 2015-04-29 03:43:26
Real-time Intraday chart data file updates started for @ES#C | 2015-04-29 03:43:26
HD Request # 93 | Downloading Intraday chart data for TWTR to the file TWTR.scid. Service: dtn | 2015-04-29 03:43:26
HD Request # 93 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:43:26
HD Request # 93 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:43:26
HD Request # 93 | Receiving historical Intraday Tick data for TWTR | 2015-04-29 03:43:26
HD Request # 93 | Receiving Intraday data for TWTR starting at 2015-04-28 19:59:58 | 2015-04-29 03:43:26
HD Request # 93 | Received 3 records from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for TWTR | 2015-04-29 03:43:26
HD Request # 93 | Intraday download COMPLETE for TWTR. Completion time: 0s. Unique request ID: 95 | 2015-04-29 03:43:26
Removed historical data download ID 95 | 2015-04-29 03:43:26
Real-time Intraday chart data file updates started for TWTR | 2015-04-29 03:43:26
HD Request # 94 | Downloading Intraday chart data for BABA to the file BABA.scid. Service: dtn | 2015-04-29 03:43:26
HD Request # 94 | Download start Date-Time: 2015-04-28 19:58:41.0 | 2015-04-29 03:43:26
HD Request # 94 | Requesting Tick data beginning at 2015-04-28 19:58:41 US Eastern Time. | 2015-04-29 03:43:26
HD Request # 94 | Receiving historical Intraday Tick data for BABA | 2015-04-29 03:43:27
HD Request # 94 | Receiving Intraday data for BABA starting at 2015-04-28 19:58:41 | 2015-04-29 03:43:27
HD Request # 94 | Received 1 record from 2015-04-28 19:58:41 to 2015-04-28 19:58:41 (0.0 seconds) and wrote 0 records for BABA | 2015-04-29 03:43:27
HD Request # 94 | Intraday download COMPLETE for BABA. Completion time: 1s. Unique request ID: 96 | 2015-04-29 03:43:27
Removed historical data download ID 96 | 2015-04-29 03:43:27
Real-time Intraday chart data file updates started for BABA | 2015-04-29 03:43:27
HD Request # 95 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: dtn | 2015-04-29 03:43:27
HD Request # 95 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:43:27
HD Request # 95 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:43:27
HD Request # 95 | Receiving historical Intraday Tick data for SPY | 2015-04-29 03:43:27
HD Request # 95 | Receiving Intraday data for SPY starting at 2015-04-28 19:59:58 | 2015-04-29 03:43:27
HD Request # 95 | Received 1 record from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for SPY | 2015-04-29 03:43:27
HD Request # 95 | Intraday download COMPLETE for SPY. Completion time: 0s. Unique request ID: 97 | 2015-04-29 03:43:27
Removed historical data download ID 97 | 2015-04-29 03:43:27
Real-time Intraday chart data file updates started for SPY | 2015-04-29 03:43:27
HD Request # 96 | Downloading Intraday chart data for NKE to the file NKE.scid. Service: dtn | 2015-04-29 03:43:27
HD Request # 96 | Download start Date-Time: 2015-04-28 16:32:54.0 | 2015-04-29 03:43:27
HD Request # 96 | Requesting Tick data beginning at 2015-04-28 16:32:54 US Eastern Time. | 2015-04-29 03:43:27
HD Request # 96 | Receiving historical Intraday Tick data for NKE | 2015-04-29 03:43:28
HD Request # 96 | Receiving Intraday data for NKE starting at 2015-04-28 16:32:54 | 2015-04-29 03:43:28
HD Request # 96 | Received 1 record from 2015-04-28 16:32:54 to 2015-04-28 16:32:54 (0.0 seconds) and wrote 0 records for NKE | 2015-04-29 03:43:28
HD Request # 96 | Intraday download COMPLETE for NKE. Completion time: 1s. Unique request ID: 98 | 2015-04-29 03:43:28
Removed historical data download ID 98 | 2015-04-29 03:43:28
Real-time Intraday chart data file updates started for NKE | 2015-04-29 03:43:28
HD Request # 97 | Downloading Intraday chart data for @NQ#C to the file @NQ#C.scid. Service: dtn | 2015-04-29 03:43:28
HD Request # 97 | Download start Date-Time: 2015-04-29 03:33:11.0 | 2015-04-29 03:43:28
HD Request # 97 | Requesting Tick data beginning at 2015-04-29 03:33:11 US Eastern Time. | 2015-04-29 03:43:28
HD Request # 97 | Receiving historical Intraday Tick data for @NQ#C | 2015-04-29 03:43:29
HD Request # 97 | Receiving Intraday data for @NQ#C starting at 2015-04-29 03:33:11 | 2015-04-29 03:43:29
HD Request # 97 | Timestamp of first Intraday data file record written: 2015-04-29 03:33:14 | 2015-04-29 03:43:29
HD Request # 97 | Received 49 records from 2015-04-29 03:33:11 to 2015-04-29 03:33:27 (16.0 seconds) and wrote 35 records for @NQ#C | 2015-04-29 03:43:29
HD Request # 97 | Intraday download COMPLETE for @NQ#C. Completion time: 0s. Unique request ID: 99 | 2015-04-29 03:43:29
Removed historical data download ID 99 | 2015-04-29 03:43:29
Real-time Intraday chart data file updates started for @NQ#C | 2015-04-29 03:43:29
HD Request # 98 | Downloading Intraday chart data for UAL to the file UAL.scid. Service: dtn | 2015-04-29 03:43:29
HD Request # 98 | Download start Date-Time: 2015-04-28 17:14:23.0 | 2015-04-29 03:43:29
HD Request # 98 | Requesting Tick data beginning at 2015-04-28 17:14:23 US Eastern Time. | 2015-04-29 03:43:29
HD Request # 98 | Receiving historical Intraday Tick data for UAL | 2015-04-29 03:43:33
HD Request # 98 | Receiving Intraday data for UAL starting at 2015-04-28 17:14:23 | 2015-04-29 03:43:33
HD Request # 98 | Received 1 record from 2015-04-28 17:14:23 to 2015-04-28 17:14:23 (0.0 seconds) and wrote 0 records for UAL | 2015-04-29 03:43:33
HD Request # 98 | Intraday download COMPLETE for UAL. Completion time: 4s. Unique request ID: 100 | 2015-04-29 03:43:33
Removed historical data download ID 100 | 2015-04-29 03:43:33
Real-time Intraday chart data file updates started for UAL | 2015-04-29 03:43:33
HD Request # 99 | Downloading Intraday chart data for VXX to the file VXX.scid. Service: dtn | 2015-04-29 03:43:33
HD Request # 99 | Download start Date-Time: 2015-04-28 19:59:39.0 | 2015-04-29 03:43:33
HD Request # 99 | Requesting Tick data beginning at 2015-04-28 19:59:39 US Eastern Time. | 2015-04-29 03:43:33
HD Request # 99 | Receiving historical Intraday Tick data for VXX | 2015-04-29 03:43:33
HD Request # 99 | Receiving Intraday data for VXX starting at 2015-04-28 19:59:39 | 2015-04-29 03:43:33
HD Request # 99 | Received 2 records from 2015-04-28 19:59:39 to 2015-04-28 19:59:39 (0.0 seconds) and wrote 0 records for VXX | 2015-04-29 03:43:33
HD Request # 99 | Intraday download COMPLETE for VXX. Completion time: 0s. Unique request ID: 101 | 2015-04-29 03:43:33
Removed historical data download ID 101 | 2015-04-29 03:43:33
Real-time Intraday chart data file updates started for VXX | 2015-04-29 03:43:33
HD Request # 100 | Downloading Intraday chart data for FB to the file FB.scid. Service: dtn | 2015-04-29 03:43:33
HD Request # 100 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:43:33
HD Request # 100 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:43:33
HD Request # 100 | Receiving historical Intraday Tick data for FB | 2015-04-29 03:43:33
HD Request # 100 | Receiving Intraday data for FB starting at 2015-04-28 19:59:58 | 2015-04-29 03:43:33
HD Request # 100 | Received 1 record from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for FB | 2015-04-29 03:43:33
HD Request # 100 | Intraday download COMPLETE for FB. Completion time: 0s. Unique request ID: 102 | 2015-04-29 03:43:33
Removed historical data download ID 102 | 2015-04-29 03:43:33
Real-time Intraday chart data file updates started for FB | 2015-04-29 03:43:33
HD Request # 101 | Downloading Intraday chart data for AMZN to the file AMZN.scid. Service: dtn | 2015-04-29 03:43:33
HD Request # 101 | Download start Date-Time: 2015-04-28 19:29:10.0 | 2015-04-29 03:43:33
HD Request # 101 | Requesting Tick data beginning at 2015-04-28 19:29:10 US Eastern Time. | 2015-04-29 03:43:33
HD Request # 101 | Receiving historical Intraday Tick data for AMZN | 2015-04-29 03:43:34
HD Request # 101 | Receiving Intraday data for AMZN starting at 2015-04-28 19:29:10 | 2015-04-29 03:43:34
HD Request # 101 | Received 1 record from 2015-04-28 19:29:10 to 2015-04-28 19:29:10 (0.0 seconds) and wrote 0 records for AMZN | 2015-04-29 03:43:34
HD Request # 101 | Intraday download COMPLETE for AMZN. Completion time: 0s. Unique request ID: 103 | 2015-04-29 03:43:34
Removed historical data download ID 103 | 2015-04-29 03:43:34
Real-time Intraday chart data file updates started for AMZN | 2015-04-29 03:43:34
HD Request # 102 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: dtn | 2015-04-29 03:43:34
HD Request # 102 | Download start Date-Time: 2015-04-28 19:59:48.0 | 2015-04-29 03:43:34
HD Request # 102 | Requesting Tick data beginning at 2015-04-28 19:59:48 US Eastern Time. | 2015-04-29 03:43:34
HD Request # 102 | Receiving historical Intraday Tick data for AAPL | 2015-04-29 03:43:35
HD Request # 102 | Receiving Intraday data for AAPL starting at 2015-04-28 19:59:48 | 2015-04-29 03:43:35
HD Request # 102 | Received 1 record from 2015-04-28 19:59:48 to 2015-04-28 19:59:48 (0.0 seconds) and wrote 0 records for AAPL | 2015-04-29 03:43:35
HD Request # 102 | Intraday download COMPLETE for AAPL. Completion time: 1s. Unique request ID: 104 | 2015-04-29 03:43:35
Removed historical data download ID 104 | 2015-04-29 03:43:35
Real-time Intraday chart data file updates started for AAPL | 2015-04-29 03:43:35
HD Request # 103 | Downloading Intraday chart data for XOm to the file XOm.scid. Service: dtn | 2015-04-29 03:43:35
HD Request # 103 | Download start Date-Time: 2015-04-28 19:59:49.0 | 2015-04-29 03:43:35
HD Request # 103 | Requesting Tick data beginning at 2015-04-28 19:59:49 US Eastern Time. | 2015-04-29 03:43:35
HD Request # 103 | Receiving historical Intraday Tick data for XOM | 2015-04-29 03:43:35
HD Request # 103 | Receiving Intraday data for XOm starting at 2015-04-28 19:59:49 | 2015-04-29 03:43:35
HD Request # 103 | Received 1 record from 2015-04-28 19:59:49 to 2015-04-28 19:59:49 (0.0 seconds) and wrote 0 records for XOm | 2015-04-29 03:43:35
HD Request # 103 | Intraday download COMPLETE for XOm. Completion time: 0s. Unique request ID: 105 | 2015-04-29 03:43:35
Removed historical data download ID 105 | 2015-04-29 03:43:35
Real-time Intraday chart data file updates started for XOm | 2015-04-29 03:43:35
HD Request # 104 | Downloading Intraday chart data for @ym#C to the file @ym#C.scid. Service: dtn | 2015-04-29 03:43:35
HD Request # 104 | Download start Date-Time: 2015-04-29 03:33:11.0 | 2015-04-29 03:43:35
HD Request # 104 | Requesting Tick data beginning at 2015-04-29 03:33:11 US Eastern Time. | 2015-04-29 03:43:35
HD Request # 104 | Receiving historical Intraday Tick data for @YM#C | 2015-04-29 03:43:35
HD Request # 104 | Receiving Intraday data for @ym#C starting at 2015-04-29 03:33:11 | 2015-04-29 03:43:35
HD Request # 104 | Timestamp of first Intraday data file record written: 2015-04-29 03:33:14 | 2015-04-29 03:43:35
HD Request # 104 | Received 57 records from 2015-04-29 03:33:11 to 2015-04-29 03:33:35 (24.0 seconds) and wrote 50 records for @ym#C | 2015-04-29 03:43:35
HD Request # 104 | Intraday download COMPLETE for @ym#C. Completion time: 0s. Unique request ID: 106 | 2015-04-29 03:43:35
Removed historical data download ID 106 | 2015-04-29 03:43:35
Real-time Intraday chart data file updates started for @ym#C | 2015-04-29 03:43:35
HD Request # 105 | Downloading Intraday chart data for BRK.B to the file BRK.B.scid. Service: dtn | 2015-04-29 03:43:36
HD Request # 105 | Download start Date-Time: 2015-04-28 17:01:29.0 | 2015-04-29 03:43:36
HD Request # 105 | Requesting Tick data beginning at 2015-04-28 17:01:29 US Eastern Time. | 2015-04-29 03:43:36
HD Request # 105 | Receiving historical Intraday Tick data for BRK.B | 2015-04-29 03:43:36
HD Request # 105 | Receiving Intraday data for BRK.B starting at 2015-04-28 17:01:29 | 2015-04-29 03:43:36
HD Request # 105 | Received 1 record from 2015-04-28 17:01:29 to 2015-04-28 17:01:29 (0.0 seconds) and wrote 0 records for BRK.B | 2015-04-29 03:43:36
HD Request # 105 | Intraday download COMPLETE for BRK.B. Completion time: 0s. Unique request ID: 107 | 2015-04-29 03:43:36
Removed historical data download ID 107 | 2015-04-29 03:43:36
Real-time Intraday chart data file updates started for BRK.B | 2015-04-29 03:43:36
HD Request # 106 | Downloading Intraday chart data for V to the file V.scid. Service: dtn | 2015-04-29 03:43:36
HD Request # 106 | Download start Date-Time: 2015-04-28 19:57:15.0 | 2015-04-29 03:43:36
HD Request # 106 | Requesting Tick data beginning at 2015-04-28 19:57:15 US Eastern Time. | 2015-04-29 03:43:36
HD Request # 106 | Receiving historical Intraday Tick data for V | 2015-04-29 03:43:36
HD Request # 106 | Receiving Intraday data for V starting at 2015-04-28 19:57:15 | 2015-04-29 03:43:36
HD Request # 106 | Received 1 record from 2015-04-28 19:57:15 to 2015-04-28 19:57:15 (0.0 seconds) and wrote 0 records for V | 2015-04-29 03:43:36
HD Request # 106 | Intraday download COMPLETE for V. Completion time: 0s. Unique request ID: 108 | 2015-04-29 03:43:37
Removed historical data download ID 108 | 2015-04-29 03:43:37
Real-time Intraday chart data file updates started for V | 2015-04-29 03:43:37
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2015-04-29 03:44:02
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2015-04-29 03:44:02
Connection to the external service has been lost. | 2015-04-29 03:44:02
Socket (25) | Shutdown and closed. | 2015-04-29 03:44:02
IQFeed | Disconnected from Level 2 port. | 2015-04-29 03:44:02
Socket (24) | Shutdown and closed. | 2015-04-29 03:44:02
IQFeed | Disconnected from Lookup port. | 2015-04-29 03:44:02
Socket (23) | Shutdown and closed. | 2015-04-29 03:44:02
IQFeed | Disconnected from Level 1 port. | 2015-04-29 03:44:02
Socket (22) | Shutdown and closed. | 2015-04-29 03:44:02
IQFeed | Disconnected from Admin port. | 2015-04-29 03:44:02
IQFeed | Fully disconnected. | 2015-04-29 03:44:02
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-29 03:44:02
Intraday data recording state for symbol TSLA is set to download pending. | 2015-04-29 03:44:06
Reloading all charts with filename: TSLA.scid | 2015-04-29 03:44:06
IQFeed | Connecting. | 2015-04-29 03:44:07
Starting DTN IQ Feed interface software. | 2015-04-29 03:44:07
IQFeed | Connecting to Admin port 9300 | 2015-04-29 03:44:07
Socket (26) | Connected. | 2015-04-29 03:44:07
IQFeed | Connected to Admin port. | 2015-04-29 03:44:07
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2015-04-29 03:44:07
TSLA 2 Min #9 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2015-03-31 10:30:00. Next Bar Date Time: 2015-03-31 09:30:00. Filename: TSLA.scid | 2015-04-29 03:44:07
AdminMessage: S,STATS,66.112.148.229,60002,500,0,16,1,19,0,Apr 29 3:44AM,Apr 29 3:44AM,Connected,5.1.1.3,423970,319.49,0.02,159.74,2685.62,0.04,1342.81, | 2015-04-29 03:44:08
IQFeed | Connecting to Level 1 port 5009 | 2015-04-29 03:44:08
Socket (27) | Connected. | 2015-04-29 03:44:08
IQFeed | Connected to Level 1 port. | 2015-04-29 03:44:08
IQFeed | Connecting to Lookup port 9100 | 2015-04-29 03:44:08
IQFeed | Connecting to Level 2 port (9200)... | 2015-04-29 03:44:08
Socket (28) | Connected. | 2015-04-29 03:44:08
IQFeed | Connected to Historical Data port. | 2015-04-29 03:44:08
IQFeed | Fully connected. | 2015-04-29 03:44:08
Socket (29) | Connected. | 2015-04-29 03:44:08
IQFeed | Connected to Level 2 port. | 2015-04-29 03:44:08
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:44:08
IQFeed | Level 2 protocol is 5.0. | 2015-04-29 03:44:08
IQFeed | Level 1 system message: KEY | 2015-04-29 03:44:08
IQFeed | Level 1 system message: SERVER CONNECTED | 2015-04-29 03:44:08
IQFeed | Level 1 system message: IP | 2015-04-29 03:44:08
IQFeed | Level 1 system message: CUST | 2015-04-29 03:44:08
HD Request # 107 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: dtn | 2015-04-29 03:44:08
HD Request # 107 | Download start Date-Time: 2015-04-28 15:49:59.0 | 2015-04-29 03:44:08
HD Request # 107 | Requesting Tick data beginning at 2015-04-28 15:49:59 US Eastern Time. | 2015-04-29 03:44:08
IQFeed | Starting real-time market data updates for: QQQ. ID: 2 | 2015-04-29 03:44:08
Intraday data recording state for symbol QQQ is set to download pending. | 2015-04-29 03:44:08
IQFeed | Starting real-time market data updates for: TSLA. ID: 1 | 2015-04-29 03:44:08
IQFeed | Starting real-time market data updates for: LNKD. ID: 3 | 2015-04-29 03:44:08
Intraday data recording state for symbol LNKD is set to download pending. | 2015-04-29 03:44:08
IQFeed | Starting real-time market data updates for: @ES#C. ID: 4 | 2015-04-29 03:44:08
Intraday data recording state for symbol @ES#C is set to download pending. | 2015-04-29 03:44:08
IQFeed | Starting real-time market data updates for: TWTR. ID: 5 | 2015-04-29 03:44:08
Intraday data recording state for symbol TWTR is set to download pending. | 2015-04-29 03:44:08
IQFeed | Starting real-time market data updates for: BABA. ID: 6 | 2015-04-29 03:44:08
Intraday data recording state for symbol BABA is set to download pending. | 2015-04-29 03:44:08
IQFeed | Starting real-time market data updates for: SPY. ID: 7 | 2015-04-29 03:44:08
Intraday data recording state for symbol SPY is set to download pending. | 2015-04-29 03:44:08
IQFeed | Starting real-time market data updates for: NKE. ID: 8 | 2015-04-29 03:44:08
Intraday data recording state for symbol NKE is set to download pending. | 2015-04-29 03:44:08
IQFeed | Starting real-time market data updates for: @NQ#C. ID: 9 | 2015-04-29 03:44:08
Intraday data recording state for symbol @NQ#C is set to download pending. | 2015-04-29 03:44:08
IQFeed | Starting real-time market data updates for: UAL. ID: 10 | 2015-04-29 03:44:08
Intraday data recording state for symbol UAL is set to download pending. | 2015-04-29 03:44:08
IQFeed | Starting real-time market data updates for: VXX. ID: 11 | 2015-04-29 03:44:08
Intraday data recording state for symbol VXX is set to download pending. | 2015-04-29 03:44:08
IQFeed | Starting real-time market data updates for: FB. ID: 12 | 2015-04-29 03:44:08
Intraday data recording state for symbol FB is set to download pending. | 2015-04-29 03:44:08
IQFeed | Starting real-time market data updates for: AMZN. ID: 13 | 2015-04-29 03:44:08
Intraday data recording state for symbol AMZN is set to download pending. | 2015-04-29 03:44:08
IQFeed | Starting real-time market data updates for: AAPL. ID: 14 | 2015-04-29 03:44:08
Intraday data recording state for symbol AAPL is set to download pending. | 2015-04-29 03:44:08
IQFeed | Starting real-time market data updates for: XOm. ID: 15 | 2015-04-29 03:44:08
Intraday data recording state for symbol XOm is set to download pending. | 2015-04-29 03:44:08
IQFeed | Starting real-time market data updates for: @ym#C. ID: 16 | 2015-04-29 03:44:08
Intraday data recording state for symbol @ym#C is set to download pending. | 2015-04-29 03:44:08
IQFeed | Starting real-time market data updates for: BRK.B. ID: 17 | 2015-04-29 03:44:08
Intraday data recording state for symbol BRK.B is set to download pending. | 2015-04-29 03:44:08
HD Request # 107 | Receiving historical Intraday Tick data for TSLA | 2015-04-29 03:44:08
HD Request # 107 | Receiving Intraday data for TSLA starting at 2015-04-28 15:50:00 | 2015-04-29 03:44:08
HD Request # 107 | Timestamp of first Intraday data file record written: 2015-04-28 15:50:00 | 2015-04-29 03:44:08
HD Request # 107 | Received 1425 records from 2015-04-28 15:50:00 to 2015-04-28 19:59:10 (4.2 hours) and wrote 1425 records for TSLA | 2015-04-29 03:44:08
HD Request # 107 | Intraday download COMPLETE for TSLA. Completion time: 0s. Unique request ID: 109 | 2015-04-29 03:44:08
Removed historical data download ID 109 | 2015-04-29 03:44:08
Real-time Intraday chart data file updates started for TSLA | 2015-04-29 03:44:08
HD Request # 108 | Downloading Intraday chart data for QQQ to the file QQQ.scid. Service: dtn | 2015-04-29 03:44:08
HD Request # 108 | Download start Date-Time: 2015-04-28 19:44:40.0 | 2015-04-29 03:44:08
HD Request # 108 | Requesting Tick data beginning at 2015-04-28 19:44:40 US Eastern Time. | 2015-04-29 03:44:08
IQFeed | Starting real-time market data updates for: V. ID: 18 | 2015-04-29 03:44:08
Intraday data recording state for symbol V is set to download pending. | 2015-04-29 03:44:08
HD Request # 108 | Receiving historical Intraday Tick data for QQQ | 2015-04-29 03:44:09
HD Request # 108 | Receiving Intraday data for QQQ starting at 2015-04-28 19:44:40 | 2015-04-29 03:44:09
HD Request # 108 | Received 4 records from 2015-04-28 19:44:40 to 2015-04-28 19:44:40 (0.0 seconds) and wrote 0 records for QQQ | 2015-04-29 03:44:09
HD Request # 108 | Intraday download COMPLETE for QQQ. Completion time: 0s. Unique request ID: 110 | 2015-04-29 03:44:09
Removed historical data download ID 110 | 2015-04-29 03:44:09
Real-time Intraday chart data file updates started for QQQ | 2015-04-29 03:44:09
HD Request # 109 | Downloading Intraday chart data for LNKD to the file LNKD.scid. Service: dtn | 2015-04-29 03:44:09
HD Request # 109 | Download start Date-Time: 2015-04-28 19:46:00.0 | 2015-04-29 03:44:09
HD Request # 109 | Requesting Tick data beginning at 2015-04-28 19:46:00 US Eastern Time. | 2015-04-29 03:44:09
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:44:09
HD Request # 109 | Receiving historical Intraday Tick data for LNKD | 2015-04-29 03:44:09
HD Request # 109 | Receiving Intraday data for LNKD starting at 2015-04-28 19:46:00 | 2015-04-29 03:44:09
HD Request # 109 | Received 1 record from 2015-04-28 19:46:00 to 2015-04-28 19:46:00 (0.0 seconds) and wrote 0 records for LNKD | 2015-04-29 03:44:09
HD Request # 109 | Intraday download COMPLETE for LNKD. Completion time: 0s. Unique request ID: 111 | 2015-04-29 03:44:09
Removed historical data download ID 111 | 2015-04-29 03:44:09
Real-time Intraday chart data file updates started for LNKD | 2015-04-29 03:44:09
HD Request # 110 | Downloading Intraday chart data for @ES#C to the file @ES#C.scid. Service: dtn | 2015-04-29 03:44:09
HD Request # 110 | Download start Date-Time: 2015-04-29 03:33:57.0 | 2015-04-29 03:44:09
HD Request # 110 | Requesting Tick data beginning at 2015-04-29 03:33:57 US Eastern Time. | 2015-04-29 03:44:09
HD Request # 110 | Receiving historical Intraday Tick data for @ES#C | 2015-04-29 03:44:10
HD Request # 110 | Receiving Intraday data for @ES#C starting at 2015-04-29 03:33:57 | 2015-04-29 03:44:10
HD Request # 110 | Timestamp of first Intraday data file record written: 2015-04-29 03:33:59 | 2015-04-29 03:44:10
HD Request # 110 | Received 68 records from 2015-04-29 03:33:57 to 2015-04-29 03:34:10 (13.0 seconds) and wrote 63 records for @ES#C | 2015-04-29 03:44:10
HD Request # 110 | Intraday download COMPLETE for @ES#C. Completion time: 1s. Unique request ID: 112 | 2015-04-29 03:44:10
Removed historical data download ID 112 | 2015-04-29 03:44:10
Real-time Intraday chart data file updates started for @ES#C | 2015-04-29 03:44:10
HD Request # 111 | Downloading Intraday chart data for TWTR to the file TWTR.scid. Service: dtn | 2015-04-29 03:44:10
HD Request # 111 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:44:10
HD Request # 111 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:44:10
HD Request # 111 | Receiving historical Intraday Tick data for TWTR | 2015-04-29 03:44:10
HD Request # 111 | Receiving Intraday data for TWTR starting at 2015-04-28 19:59:58 | 2015-04-29 03:44:10
HD Request # 111 | Received 3 records from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for TWTR | 2015-04-29 03:44:10
HD Request # 111 | Intraday download COMPLETE for TWTR. Completion time: 0s. Unique request ID: 113 | 2015-04-29 03:44:10
Removed historical data download ID 113 | 2015-04-29 03:44:10
Real-time Intraday chart data file updates started for TWTR | 2015-04-29 03:44:10
HD Request # 112 | Downloading Intraday chart data for BABA to the file BABA.scid. Service: dtn | 2015-04-29 03:44:10
HD Request # 112 | Download start Date-Time: 2015-04-28 19:58:41.0 | 2015-04-29 03:44:10
HD Request # 112 | Requesting Tick data beginning at 2015-04-28 19:58:41 US Eastern Time. | 2015-04-29 03:44:10
HD Request # 112 | Receiving historical Intraday Tick data for BABA | 2015-04-29 03:44:11
HD Request # 112 | Receiving Intraday data for BABA starting at 2015-04-28 19:58:41 | 2015-04-29 03:44:11
HD Request # 112 | Received 1 record from 2015-04-28 19:58:41 to 2015-04-28 19:58:41 (0.0 seconds) and wrote 0 records for BABA | 2015-04-29 03:44:11
HD Request # 112 | Intraday download COMPLETE for BABA. Completion time: 1s. Unique request ID: 114 | 2015-04-29 03:44:11
Removed historical data download ID 114 | 2015-04-29 03:44:11
Real-time Intraday chart data file updates started for BABA | 2015-04-29 03:44:11
HD Request # 113 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: dtn | 2015-04-29 03:44:11
HD Request # 113 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:44:11
HD Request # 113 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:44:11
HD Request # 113 | Receiving historical Intraday Tick data for SPY | 2015-04-29 03:44:11
HD Request # 113 | Receiving Intraday data for SPY starting at 2015-04-28 19:59:58 | 2015-04-29 03:44:11
HD Request # 113 | Received 1 record from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for SPY | 2015-04-29 03:44:11
HD Request # 113 | Intraday download COMPLETE for SPY. Completion time: 0s. Unique request ID: 115 | 2015-04-29 03:44:11
Removed historical data download ID 115 | 2015-04-29 03:44:11
Real-time Intraday chart data file updates started for SPY | 2015-04-29 03:44:11
HD Request # 114 | Downloading Intraday chart data for NKE to the file NKE.scid. Service: dtn | 2015-04-29 03:44:11
HD Request # 114 | Download start Date-Time: 2015-04-28 16:32:54.0 | 2015-04-29 03:44:11
HD Request # 114 | Requesting Tick data beginning at 2015-04-28 16:32:54 US Eastern Time. | 2015-04-29 03:44:11
HD Request # 114 | Receiving historical Intraday Tick data for NKE | 2015-04-29 03:44:12
HD Request # 114 | Receiving Intraday data for NKE starting at 2015-04-28 16:32:54 | 2015-04-29 03:44:12
HD Request # 114 | Received 1 record from 2015-04-28 16:32:54 to 2015-04-28 16:32:54 (0.0 seconds) and wrote 0 records for NKE | 2015-04-29 03:44:12
HD Request # 114 | Intraday download COMPLETE for NKE. Completion time: 0s. Unique request ID: 116 | 2015-04-29 03:44:12
Removed historical data download ID 116 | 2015-04-29 03:44:12
Real-time Intraday chart data file updates started for NKE | 2015-04-29 03:44:12
HD Request # 115 | Downloading Intraday chart data for @NQ#C to the file @NQ#C.scid. Service: dtn | 2015-04-29 03:44:12
HD Request # 115 | Download start Date-Time: 2015-04-29 03:33:57.0 | 2015-04-29 03:44:12
HD Request # 115 | Requesting Tick data beginning at 2015-04-29 03:33:57 US Eastern Time. | 2015-04-29 03:44:12
HD Request # 115 | Receiving historical Intraday Tick data for @NQ#C | 2015-04-29 03:44:12
HD Request # 115 | Receiving Intraday data for @NQ#C starting at 2015-04-29 03:33:57 | 2015-04-29 03:44:12
HD Request # 115 | Timestamp of first Intraday data file record written: 2015-04-29 03:34:02 | 2015-04-29 03:44:12
HD Request # 115 | Received 11 records from 2015-04-29 03:33:57 to 2015-04-29 03:34:08 (11.0 seconds) and wrote 10 records for @NQ#C | 2015-04-29 03:44:12
HD Request # 115 | Intraday download COMPLETE for @NQ#C. Completion time: 0s. Unique request ID: 117 | 2015-04-29 03:44:12
Removed historical data download ID 117 | 2015-04-29 03:44:12
Real-time Intraday chart data file updates started for @NQ#C | 2015-04-29 03:44:12
HD Request # 116 | Downloading Intraday chart data for UAL to the file UAL.scid. Service: dtn | 2015-04-29 03:44:12
HD Request # 116 | Download start Date-Time: 2015-04-28 17:14:23.0 | 2015-04-29 03:44:12
HD Request # 116 | Requesting Tick data beginning at 2015-04-28 17:14:23 US Eastern Time. | 2015-04-29 03:44:12
HD Request # 116 | Receiving historical Intraday Tick data for UAL | 2015-04-29 03:44:13
HD Request # 116 | Receiving Intraday data for UAL starting at 2015-04-28 17:14:23 | 2015-04-29 03:44:13
HD Request # 116 | Received 1 record from 2015-04-28 17:14:23 to 2015-04-28 17:14:23 (0.0 seconds) and wrote 0 records for UAL | 2015-04-29 03:44:13
HD Request # 116 | Intraday download COMPLETE for UAL. Completion time: 1s. Unique request ID: 118 | 2015-04-29 03:44:13
Removed historical data download ID 118 | 2015-04-29 03:44:13
Real-time Intraday chart data file updates started for UAL | 2015-04-29 03:44:13
HD Request # 117 | Downloading Intraday chart data for VXX to the file VXX.scid. Service: dtn | 2015-04-29 03:44:13
HD Request # 117 | Download start Date-Time: 2015-04-28 19:59:39.0 | 2015-04-29 03:44:13
HD Request # 117 | Requesting Tick data beginning at 2015-04-28 19:59:39 US Eastern Time. | 2015-04-29 03:44:13
HD Request # 117 | Receiving historical Intraday Tick data for VXX | 2015-04-29 03:44:13
HD Request # 117 | Receiving Intraday data for VXX starting at 2015-04-28 19:59:39 | 2015-04-29 03:44:13
HD Request # 117 | Received 2 records from 2015-04-28 19:59:39 to 2015-04-28 19:59:39 (0.0 seconds) and wrote 0 records for VXX | 2015-04-29 03:44:13
HD Request # 117 | Intraday download COMPLETE for VXX. Completion time: 0s. Unique request ID: 119 | 2015-04-29 03:44:13
Removed historical data download ID 119 | 2015-04-29 03:44:13
Real-time Intraday chart data file updates started for VXX | 2015-04-29 03:44:13
HD Request # 118 | Downloading Intraday chart data for FB to the file FB.scid. Service: dtn | 2015-04-29 03:44:13
HD Request # 118 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:44:13
HD Request # 118 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:44:13
HD Request # 118 | Receiving historical Intraday Tick data for FB | 2015-04-29 03:44:14
HD Request # 118 | Receiving Intraday data for FB starting at 2015-04-28 19:59:58 | 2015-04-29 03:44:14
HD Request # 118 | Received 1 record from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for FB | 2015-04-29 03:44:14
HD Request # 118 | Intraday download COMPLETE for FB. Completion time: 0s. Unique request ID: 120 | 2015-04-29 03:44:14
Removed historical data download ID 120 | 2015-04-29 03:44:14
Real-time Intraday chart data file updates started for FB | 2015-04-29 03:44:14
HD Request # 119 | Downloading Intraday chart data for AMZN to the file AMZN.scid. Service: dtn | 2015-04-29 03:44:14
HD Request # 119 | Download start Date-Time: 2015-04-28 19:29:10.0 | 2015-04-29 03:44:14
HD Request # 119 | Requesting Tick data beginning at 2015-04-28 19:29:10 US Eastern Time. | 2015-04-29 03:44:14
HD Request # 119 | Receiving historical Intraday Tick data for AMZN | 2015-04-29 03:44:14
HD Request # 119 | Receiving Intraday data for AMZN starting at 2015-04-28 19:29:10 | 2015-04-29 03:44:14
HD Request # 119 | Received 1 record from 2015-04-28 19:29:10 to 2015-04-28 19:29:10 (0.0 seconds) and wrote 0 records for AMZN | 2015-04-29 03:44:14
HD Request # 119 | Intraday download COMPLETE for AMZN. Completion time: 0s. Unique request ID: 121 | 2015-04-29 03:44:14
Removed historical data download ID 121 | 2015-04-29 03:44:14
Real-time Intraday chart data file updates started for AMZN | 2015-04-29 03:44:14
HD Request # 120 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: dtn | 2015-04-29 03:44:14
HD Request # 120 | Download start Date-Time: 2015-04-28 19:59:48.0 | 2015-04-29 03:44:14
HD Request # 120 | Requesting Tick data beginning at 2015-04-28 19:59:48 US Eastern Time. | 2015-04-29 03:44:14
HD Request # 120 | Receiving historical Intraday Tick data for AAPL | 2015-04-29 03:44:15
HD Request # 120 | Receiving Intraday data for AAPL starting at 2015-04-28 19:59:48 | 2015-04-29 03:44:15
HD Request # 120 | Received 1 record from 2015-04-28 19:59:48 to 2015-04-28 19:59:48 (0.0 seconds) and wrote 0 records for AAPL | 2015-04-29 03:44:15
HD Request # 120 | Intraday download COMPLETE for AAPL. Completion time: 1s. Unique request ID: 122 | 2015-04-29 03:44:15
Removed historical data download ID 122 | 2015-04-29 03:44:15
Real-time Intraday chart data file updates started for AAPL | 2015-04-29 03:44:15
HD Request # 121 | Downloading Intraday chart data for XOm to the file XOm.scid. Service: dtn | 2015-04-29 03:44:15
HD Request # 121 | Download start Date-Time: 2015-04-28 19:59:49.0 | 2015-04-29 03:44:15
HD Request # 121 | Requesting Tick data beginning at 2015-04-28 19:59:49 US Eastern Time. | 2015-04-29 03:44:15
HD Request # 121 | Receiving historical Intraday Tick data for XOM | 2015-04-29 03:44:15
HD Request # 121 | Receiving Intraday data for XOm starting at 2015-04-28 19:59:49 | 2015-04-29 03:44:15
HD Request # 121 | Received 1 record from 2015-04-28 19:59:49 to 2015-04-28 19:59:49 (0.0 seconds) and wrote 0 records for XOm | 2015-04-29 03:44:15
HD Request # 121 | Intraday download COMPLETE for XOm. Completion time: 0s. Unique request ID: 123 | 2015-04-29 03:44:15
Removed historical data download ID 123 | 2015-04-29 03:44:15
Real-time Intraday chart data file updates started for XOm | 2015-04-29 03:44:15
HD Request # 122 | Downloading Intraday chart data for @ym#C to the file @ym#C.scid. Service: dtn | 2015-04-29 03:44:15
HD Request # 122 | Download start Date-Time: 2015-04-29 03:33:54.0 | 2015-04-29 03:44:15
HD Request # 122 | Requesting Tick data beginning at 2015-04-29 03:33:54 US Eastern Time. | 2015-04-29 03:44:15
HD Request # 122 | Receiving historical Intraday Tick data for @YM#C | 2015-04-29 03:44:16
HD Request # 122 | Receiving Intraday data for @ym#C starting at 2015-04-29 03:33:54 | 2015-04-29 03:44:16
HD Request # 122 | Timestamp of first Intraday data file record written: 2015-04-29 03:34:02 | 2015-04-29 03:44:16
HD Request # 122 | Received 12 records from 2015-04-29 03:33:54 to 2015-04-29 03:34:10 (16.0 seconds) and wrote 10 records for @ym#C | 2015-04-29 03:44:16
HD Request # 122 | Intraday download COMPLETE for @ym#C. Completion time: 1s. Unique request ID: 124 | 2015-04-29 03:44:16
Removed historical data download ID 124 | 2015-04-29 03:44:16
Real-time Intraday chart data file updates started for @ym#C | 2015-04-29 03:44:16
HD Request # 123 | Downloading Intraday chart data for BRK.B to the file BRK.B.scid. Service: dtn | 2015-04-29 03:44:16
HD Request # 123 | Download start Date-Time: 2015-04-28 17:01:29.0 | 2015-04-29 03:44:16
HD Request # 123 | Requesting Tick data beginning at 2015-04-28 17:01:29 US Eastern Time. | 2015-04-29 03:44:16
HD Request # 123 | Receiving historical Intraday Tick data for BRK.B | 2015-04-29 03:44:16
HD Request # 123 | Receiving Intraday data for BRK.B starting at 2015-04-28 17:01:29 | 2015-04-29 03:44:16
HD Request # 123 | Received 1 record from 2015-04-28 17:01:29 to 2015-04-28 17:01:29 (0.0 seconds) and wrote 0 records for BRK.B | 2015-04-29 03:44:16
HD Request # 123 | Intraday download COMPLETE for BRK.B. Completion time: 0s. Unique request ID: 125 | 2015-04-29 03:44:16
Removed historical data download ID 125 | 2015-04-29 03:44:16
Real-time Intraday chart data file updates started for BRK.B | 2015-04-29 03:44:16
HD Request # 124 | Downloading Intraday chart data for V to the file V.scid. Service: dtn | 2015-04-29 03:44:16
HD Request # 124 | Download start Date-Time: 2015-04-28 19:57:15.0 | 2015-04-29 03:44:16
HD Request # 124 | Requesting Tick data beginning at 2015-04-28 19:57:15 US Eastern Time. | 2015-04-29 03:44:16
HD Request # 124 | Receiving historical Intraday Tick data for V | 2015-04-29 03:44:17
HD Request # 124 | Receiving Intraday data for V starting at 2015-04-28 19:57:15 | 2015-04-29 03:44:17
HD Request # 124 | Received 1 record from 2015-04-28 19:57:15 to 2015-04-28 19:57:15 (0.0 seconds) and wrote 0 records for V | 2015-04-29 03:44:17
HD Request # 124 | Intraday download COMPLETE for V. Completion time: 0s. Unique request ID: 126 | 2015-04-29 03:44:17
Removed historical data download ID 126 | 2015-04-29 03:44:17
Real-time Intraday chart data file updates started for V | 2015-04-29 03:44:17
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2015-04-29 03:45:24
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2015-04-29 03:45:24
Connection to the external service has been lost. | 2015-04-29 03:45:24
Socket (29) | Shutdown and closed. | 2015-04-29 03:45:24
IQFeed | Disconnected from Level 2 port. | 2015-04-29 03:45:24
Socket (28) | Shutdown and closed. | 2015-04-29 03:45:24
IQFeed | Disconnected from Lookup port. | 2015-04-29 03:45:24
Socket (27) | Shutdown and closed. | 2015-04-29 03:45:24
IQFeed | Disconnected from Level 1 port. | 2015-04-29 03:45:24
Socket (26) | Shutdown and closed. | 2015-04-29 03:45:24
IQFeed | Disconnected from Admin port. | 2015-04-29 03:45:24
IQFeed | Fully disconnected. | 2015-04-29 03:45:24
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-29 03:45:24
IQFeed | Connecting. | 2015-04-29 03:45:29
Starting DTN IQ Feed interface software. | 2015-04-29 03:45:29
IQFeed | Connecting to Admin port 9300 | 2015-04-29 03:45:29
Socket (30) | Connected. | 2015-04-29 03:45:29
IQFeed | Connected to Admin port. | 2015-04-29 03:45:29
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2015-04-29 03:45:29
AdminMessage: S,STATS,66.112.156.223,60005,500,0,17,0,20,0,Apr 29 3:45AM,Apr 29 3:45AM,Connected,5.1.1.3,423970,386.39,0.22,38.64,3571.01,0.01,357.10, | 2015-04-29 03:45:38
IQFeed | Connecting to Level 1 port 5009 | 2015-04-29 03:45:38
Socket (31) | Connected. | 2015-04-29 03:45:38
IQFeed | Connected to Level 1 port. | 2015-04-29 03:45:38
IQFeed | Connecting to Lookup port 9100 | 2015-04-29 03:45:38
IQFeed | Connecting to Level 2 port (9200)... | 2015-04-29 03:45:38
Socket (32) | Connected. | 2015-04-29 03:45:38
IQFeed | Connected to Historical Data port. | 2015-04-29 03:45:38
IQFeed | Fully connected. | 2015-04-29 03:45:38
Socket (33) | Connected. | 2015-04-29 03:45:38
IQFeed | Connected to Level 2 port. | 2015-04-29 03:45:38
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:45:38
IQFeed | Level 1 system message: KEY | 2015-04-29 03:45:38
IQFeed | Level 1 system message: SERVER CONNECTED | 2015-04-29 03:45:38
IQFeed | Level 1 system message: IP | 2015-04-29 03:45:38
IQFeed | Level 1 system message: CUST | 2015-04-29 03:45:38
IQFeed | Level 2 protocol is 5.0. | 2015-04-29 03:45:38
IQFeed | Starting real-time market data updates for: AMZN. ID: 1 | 2015-04-29 03:45:38
Intraday data recording state for symbol AMZN is set to download pending. | 2015-04-29 03:45:38
HD Request # 125 | Downloading Intraday chart data for AMZN to the file AMZN.scid. Service: dtn | 2015-04-29 03:45:38
HD Request # 125 | Download start Date-Time: 2015-04-28 19:29:10.0 | 2015-04-29 03:45:38
HD Request # 125 | Requesting Tick data beginning at 2015-04-28 19:29:10 US Eastern Time. | 2015-04-29 03:45:38
IQFeed | Starting real-time market data updates for: AAPL. ID: 2 | 2015-04-29 03:45:38
Intraday data recording state for symbol AAPL is set to download pending. | 2015-04-29 03:45:38
IQFeed | Starting real-time market data updates for: @ES#C. ID: 3 | 2015-04-29 03:45:38
Intraday data recording state for symbol @ES#C is set to download pending. | 2015-04-29 03:45:38
IQFeed | Starting real-time market data updates for: XOm. ID: 4 | 2015-04-29 03:45:38
Intraday data recording state for symbol XOm is set to download pending. | 2015-04-29 03:45:38
IQFeed | Starting real-time market data updates for: QQQ. ID: 5 | 2015-04-29 03:45:38
Intraday data recording state for symbol QQQ is set to download pending. | 2015-04-29 03:45:38
IQFeed | Starting real-time market data updates for: @ym#C. ID: 6 | 2015-04-29 03:45:38
Intraday data recording state for symbol @ym#C is set to download pending. | 2015-04-29 03:45:38
IQFeed | Starting real-time market data updates for: BRK.B. ID: 7 | 2015-04-29 03:45:38
Intraday data recording state for symbol BRK.B is set to download pending. | 2015-04-29 03:45:38
IQFeed | Starting real-time market data updates for: V. ID: 8 | 2015-04-29 03:45:38
Intraday data recording state for symbol V is set to download pending. | 2015-04-29 03:45:38
IQFeed | Starting real-time market data updates for: LNKD. ID: 9 | 2015-04-29 03:45:38
Intraday data recording state for symbol LNKD is set to download pending. | 2015-04-29 03:45:38
IQFeed | Starting real-time market data updates for: TSLA. ID: 10 | 2015-04-29 03:45:38
Intraday data recording state for symbol TSLA is set to download pending. | 2015-04-29 03:45:38
HD Request # 125 | Receiving historical Intraday Tick data for AMZN | 2015-04-29 03:45:38
HD Request # 125 | Receiving Intraday data for AMZN starting at 2015-04-28 19:29:10 | 2015-04-29 03:45:38
HD Request # 125 | Received 1 record from 2015-04-28 19:29:10 to 2015-04-28 19:29:10 (0.0 seconds) and wrote 0 records for AMZN | 2015-04-29 03:45:38
HD Request # 125 | Intraday download COMPLETE for AMZN. Completion time: 0s. Unique request ID: 127 | 2015-04-29 03:45:38
Removed historical data download ID 127 | 2015-04-29 03:45:38
Real-time Intraday chart data file updates started for AMZN | 2015-04-29 03:45:38
HD Request # 126 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: dtn | 2015-04-29 03:45:38
HD Request # 126 | Download start Date-Time: 2015-04-28 19:59:48.0 | 2015-04-29 03:45:38
HD Request # 126 | Requesting Tick data beginning at 2015-04-28 19:59:48 US Eastern Time. | 2015-04-29 03:45:38
IQFeed | Starting real-time market data updates for: TWTR. ID: 11 | 2015-04-29 03:45:38
Intraday data recording state for symbol TWTR is set to download pending. | 2015-04-29 03:45:39
IQFeed | Starting real-time market data updates for: BABA. ID: 12 | 2015-04-29 03:45:39
Intraday data recording state for symbol BABA is set to download pending. | 2015-04-29 03:45:39
IQFeed | Starting real-time market data updates for: SPY. ID: 13 | 2015-04-29 03:45:39
Intraday data recording state for symbol SPY is set to download pending. | 2015-04-29 03:45:39
IQFeed | Starting real-time market data updates for: NKE. ID: 14 | 2015-04-29 03:45:39
Intraday data recording state for symbol NKE is set to download pending. | 2015-04-29 03:45:39
IQFeed | Starting real-time market data updates for: @NQ#C. ID: 15 | 2015-04-29 03:45:39
Intraday data recording state for symbol @NQ#C is set to download pending. | 2015-04-29 03:45:39
IQFeed | Starting real-time market data updates for: UAL. ID: 16 | 2015-04-29 03:45:39
Intraday data recording state for symbol UAL is set to download pending. | 2015-04-29 03:45:39
IQFeed | Starting real-time market data updates for: VXX. ID: 17 | 2015-04-29 03:45:39
Intraday data recording state for symbol VXX is set to download pending. | 2015-04-29 03:45:39
IQFeed | Starting real-time market data updates for: FB. ID: 18 | 2015-04-29 03:45:39
Intraday data recording state for symbol FB is set to download pending. | 2015-04-29 03:45:39
HD Request # 126 | Receiving historical Intraday Tick data for AAPL | 2015-04-29 03:45:39
HD Request # 126 | Receiving Intraday data for AAPL starting at 2015-04-28 19:59:48 | 2015-04-29 03:45:39
HD Request # 126 | Received 1 record from 2015-04-28 19:59:48 to 2015-04-28 19:59:48 (0.0 seconds) and wrote 0 records for AAPL | 2015-04-29 03:45:39
HD Request # 126 | Intraday download COMPLETE for AAPL. Completion time: 1s. Unique request ID: 128 | 2015-04-29 03:45:39
Removed historical data download ID 128 | 2015-04-29 03:45:39
Real-time Intraday chart data file updates started for AAPL | 2015-04-29 03:45:39
HD Request # 127 | Downloading Intraday chart data for @ES#C to the file @ES#C.scid. Service: dtn | 2015-04-29 03:45:39
HD Request # 127 | Download start Date-Time: 2015-04-29 03:35:18.0 | 2015-04-29 03:45:39
HD Request # 127 | Requesting Tick data beginning at 2015-04-29 03:35:18 US Eastern Time. | 2015-04-29 03:45:39
HD Request # 127 | Receiving historical Intraday Tick data for @ES#C | 2015-04-29 03:45:39
HD Request # 127 | Receiving Intraday data for @ES#C starting at 2015-04-29 03:35:18 | 2015-04-29 03:45:39
HD Request # 127 | Timestamp of first Intraday data file record written: 2015-04-29 03:35:27 | 2015-04-29 03:45:39
HD Request # 127 | Received 64 records from 2015-04-29 03:35:18 to 2015-04-29 03:35:41 (23.0 seconds) and wrote 57 records for @ES#C | 2015-04-29 03:45:39
HD Request # 127 | Intraday download COMPLETE for @ES#C. Completion time: 0s. Unique request ID: 129 | 2015-04-29 03:45:39
Removed historical data download ID 129 | 2015-04-29 03:45:39
Real-time Intraday chart data file updates started for @ES#C | 2015-04-29 03:45:39
HD Request # 128 | Downloading Intraday chart data for XOm to the file XOm.scid. Service: dtn | 2015-04-29 03:45:40
HD Request # 128 | Download start Date-Time: 2015-04-28 19:59:49.0 | 2015-04-29 03:45:40
HD Request # 128 | Requesting Tick data beginning at 2015-04-28 19:59:49 US Eastern Time. | 2015-04-29 03:45:40
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:45:40
HD Request # 128 | Receiving historical Intraday Tick data for XOM | 2015-04-29 03:45:40
HD Request # 128 | Receiving Intraday data for XOm starting at 2015-04-28 19:59:49 | 2015-04-29 03:45:40
HD Request # 128 | Received 1 record from 2015-04-28 19:59:49 to 2015-04-28 19:59:49 (0.0 seconds) and wrote 0 records for XOm | 2015-04-29 03:45:40
HD Request # 128 | Intraday download COMPLETE for XOm. Completion time: 0s. Unique request ID: 130 | 2015-04-29 03:45:40
Removed historical data download ID 130 | 2015-04-29 03:45:40
Real-time Intraday chart data file updates started for XOm | 2015-04-29 03:45:40
HD Request # 129 | Downloading Intraday chart data for QQQ to the file QQQ.scid. Service: dtn | 2015-04-29 03:45:40
HD Request # 129 | Download start Date-Time: 2015-04-28 19:44:40.0 | 2015-04-29 03:45:40
HD Request # 129 | Requesting Tick data beginning at 2015-04-28 19:44:40 US Eastern Time. | 2015-04-29 03:45:40
HD Request # 129 | Receiving historical Intraday Tick data for QQQ | 2015-04-29 03:45:40
HD Request # 129 | Receiving Intraday data for QQQ starting at 2015-04-28 19:44:40 | 2015-04-29 03:45:40
HD Request # 129 | Received 4 records from 2015-04-28 19:44:40 to 2015-04-28 19:44:40 (0.0 seconds) and wrote 0 records for QQQ | 2015-04-29 03:45:40
HD Request # 129 | Intraday download COMPLETE for QQQ. Completion time: 1s. Unique request ID: 131 | 2015-04-29 03:45:41
Removed historical data download ID 131 | 2015-04-29 03:45:41
Real-time Intraday chart data file updates started for QQQ | 2015-04-29 03:45:41
HD Request # 130 | Downloading Intraday chart data for @ym#C to the file @ym#C.scid. Service: dtn | 2015-04-29 03:45:41
HD Request # 130 | Download start Date-Time: 2015-04-29 03:35:18.0 | 2015-04-29 03:45:41
HD Request # 130 | Requesting Tick data beginning at 2015-04-29 03:35:18 US Eastern Time. | 2015-04-29 03:45:41
HD Request # 130 | Receiving historical Intraday Tick data for @YM#C | 2015-04-29 03:45:41
HD Request # 130 | Receiving Intraday data for @ym#C starting at 2015-04-29 03:35:18 | 2015-04-29 03:45:41
HD Request # 130 | Timestamp of first Intraday data file record written: 2015-04-29 03:35:33 | 2015-04-29 03:45:41
HD Request # 130 | Received 25 records from 2015-04-29 03:35:18 to 2015-04-29 03:35:36 (18.0 seconds) and wrote 23 records for @ym#C | 2015-04-29 03:45:41
HD Request # 130 | Intraday download COMPLETE for @ym#C. Completion time: 0s. Unique request ID: 132 | 2015-04-29 03:45:41
Removed historical data download ID 132 | 2015-04-29 03:45:41
Real-time Intraday chart data file updates started for @ym#C | 2015-04-29 03:45:41
HD Request # 131 | Downloading Intraday chart data for BRK.B to the file BRK.B.scid. Service: dtn | 2015-04-29 03:45:41
HD Request # 131 | Download start Date-Time: 2015-04-28 17:01:29.0 | 2015-04-29 03:45:41
HD Request # 131 | Requesting Tick data beginning at 2015-04-28 17:01:29 US Eastern Time. | 2015-04-29 03:45:41
HD Request # 131 | Receiving historical Intraday Tick data for BRK.B | 2015-04-29 03:45:42
HD Request # 131 | Receiving Intraday data for BRK.B starting at 2015-04-28 17:01:29 | 2015-04-29 03:45:42
HD Request # 131 | Received 1 record from 2015-04-28 17:01:29 to 2015-04-28 17:01:29 (0.0 seconds) and wrote 0 records for BRK.B | 2015-04-29 03:45:42
HD Request # 131 | Intraday download COMPLETE for BRK.B. Completion time: 1s. Unique request ID: 133 | 2015-04-29 03:45:42
Removed historical data download ID 133 | 2015-04-29 03:45:42
Real-time Intraday chart data file updates started for BRK.B | 2015-04-29 03:45:42
HD Request # 132 | Downloading Intraday chart data for V to the file V.scid. Service: dtn | 2015-04-29 03:45:42
HD Request # 132 | Download start Date-Time: 2015-04-28 19:57:15.0 | 2015-04-29 03:45:42
HD Request # 132 | Requesting Tick data beginning at 2015-04-28 19:57:15 US Eastern Time. | 2015-04-29 03:45:42
HD Request # 132 | Receiving historical Intraday Tick data for V | 2015-04-29 03:45:42
HD Request # 132 | Receiving Intraday data for V starting at 2015-04-28 19:57:15 | 2015-04-29 03:45:42
HD Request # 132 | Received 1 record from 2015-04-28 19:57:15 to 2015-04-28 19:57:15 (0.0 seconds) and wrote 0 records for V | 2015-04-29 03:45:42
HD Request # 132 | Intraday download COMPLETE for V. Completion time: 0s. Unique request ID: 134 | 2015-04-29 03:45:42
Removed historical data download ID 134 | 2015-04-29 03:45:42
Real-time Intraday chart data file updates started for V | 2015-04-29 03:45:42
HD Request # 133 | Downloading Intraday chart data for LNKD to the file LNKD.scid. Service: dtn | 2015-04-29 03:45:42
HD Request # 133 | Download start Date-Time: 2015-04-28 19:46:00.0 | 2015-04-29 03:45:42
HD Request # 133 | Requesting Tick data beginning at 2015-04-28 19:46:00 US Eastern Time. | 2015-04-29 03:45:42
HD Request # 133 | Receiving historical Intraday Tick data for LNKD | 2015-04-29 03:45:43
HD Request # 133 | Receiving Intraday data for LNKD starting at 2015-04-28 19:46:00 | 2015-04-29 03:45:43
HD Request # 133 | Received 1 record from 2015-04-28 19:46:00 to 2015-04-28 19:46:00 (0.0 seconds) and wrote 0 records for LNKD | 2015-04-29 03:45:43
HD Request # 133 | Intraday download COMPLETE for LNKD. Completion time: 0s. Unique request ID: 135 | 2015-04-29 03:45:43
Removed historical data download ID 135 | 2015-04-29 03:45:43
Real-time Intraday chart data file updates started for LNKD | 2015-04-29 03:45:43
HD Request # 134 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: dtn | 2015-04-29 03:45:43
HD Request # 134 | Download start Date-Time: 2015-04-28 19:59:10.0 | 2015-04-29 03:45:43
HD Request # 134 | Requesting Tick data beginning at 2015-04-28 19:59:10 US Eastern Time. | 2015-04-29 03:45:43
HD Request # 134 | Receiving historical Intraday Tick data for TSLA | 2015-04-29 03:45:43
HD Request # 134 | Receiving Intraday data for TSLA starting at 2015-04-28 19:59:10 | 2015-04-29 03:45:43
HD Request # 134 | Received 1 record from 2015-04-28 19:59:10 to 2015-04-28 19:59:10 (0.0 seconds) and wrote 0 records for TSLA | 2015-04-29 03:45:43
HD Request # 134 | Intraday download COMPLETE for TSLA. Completion time: 0s. Unique request ID: 136 | 2015-04-29 03:45:43
Removed historical data download ID 136 | 2015-04-29 03:45:43
Real-time Intraday chart data file updates started for TSLA | 2015-04-29 03:45:43
HD Request # 135 | Downloading Intraday chart data for TWTR to the file TWTR.scid. Service: dtn | 2015-04-29 03:45:43
HD Request # 135 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:45:43
HD Request # 135 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:45:43
HD Request # 135 | Receiving historical Intraday Tick data for TWTR | 2015-04-29 03:45:44
HD Request # 135 | Receiving Intraday data for TWTR starting at 2015-04-28 19:59:58 | 2015-04-29 03:45:44
HD Request # 135 | Received 3 records from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for TWTR | 2015-04-29 03:45:44
HD Request # 135 | Intraday download COMPLETE for TWTR. Completion time: 1s. Unique request ID: 137 | 2015-04-29 03:45:44
Removed historical data download ID 137 | 2015-04-29 03:45:44
Real-time Intraday chart data file updates started for TWTR | 2015-04-29 03:45:44
HD Request # 136 | Downloading Intraday chart data for BABA to the file BABA.scid. Service: dtn | 2015-04-29 03:45:44
HD Request # 136 | Download start Date-Time: 2015-04-28 19:58:41.0 | 2015-04-29 03:45:44
HD Request # 136 | Requesting Tick data beginning at 2015-04-28 19:58:41 US Eastern Time. | 2015-04-29 03:45:44
HD Request # 136 | Receiving historical Intraday Tick data for BABA | 2015-04-29 03:45:44
HD Request # 136 | Receiving Intraday data for BABA starting at 2015-04-28 19:58:41 | 2015-04-29 03:45:44
HD Request # 136 | Received 1 record from 2015-04-28 19:58:41 to 2015-04-28 19:58:41 (0.0 seconds) and wrote 0 records for BABA | 2015-04-29 03:45:44
HD Request # 136 | Intraday download COMPLETE for BABA. Completion time: 0s. Unique request ID: 138 | 2015-04-29 03:45:44
Removed historical data download ID 138 | 2015-04-29 03:45:44
Real-time Intraday chart data file updates started for BABA | 2015-04-29 03:45:44
HD Request # 137 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: dtn | 2015-04-29 03:45:44
HD Request # 137 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:45:44
HD Request # 137 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:45:44
HD Request # 137 | Receiving historical Intraday Tick data for SPY | 2015-04-29 03:45:45
HD Request # 137 | Receiving Intraday data for SPY starting at 2015-04-28 19:59:58 | 2015-04-29 03:45:45
HD Request # 137 | Received 1 record from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for SPY | 2015-04-29 03:45:45
HD Request # 137 | Intraday download COMPLETE for SPY. Completion time: 1s. Unique request ID: 139 | 2015-04-29 03:45:45
Removed historical data download ID 139 | 2015-04-29 03:45:45
Real-time Intraday chart data file updates started for SPY | 2015-04-29 03:45:45
HD Request # 138 | Downloading Intraday chart data for NKE to the file NKE.scid. Service: dtn | 2015-04-29 03:45:45
HD Request # 138 | Download start Date-Time: 2015-04-28 16:32:54.0 | 2015-04-29 03:45:45
HD Request # 138 | Requesting Tick data beginning at 2015-04-28 16:32:54 US Eastern Time. | 2015-04-29 03:45:45
HD Request # 138 | Receiving historical Intraday Tick data for NKE | 2015-04-29 03:45:46
HD Request # 138 | Receiving Intraday data for NKE starting at 2015-04-28 16:32:54 | 2015-04-29 03:45:46
HD Request # 138 | Received 1 record from 2015-04-28 16:32:54 to 2015-04-28 16:32:54 (0.0 seconds) and wrote 0 records for NKE | 2015-04-29 03:45:46
HD Request # 138 | Intraday download COMPLETE for NKE. Completion time: 0s. Unique request ID: 140 | 2015-04-29 03:45:46
Removed historical data download ID 140 | 2015-04-29 03:45:46
Real-time Intraday chart data file updates started for NKE | 2015-04-29 03:45:46
HD Request # 139 | Downloading Intraday chart data for @NQ#C to the file @NQ#C.scid. Service: dtn | 2015-04-29 03:45:46
HD Request # 139 | Download start Date-Time: 2015-04-29 03:35:18.0 | 2015-04-29 03:45:46
HD Request # 139 | Requesting Tick data beginning at 2015-04-29 03:35:18 US Eastern Time. | 2015-04-29 03:45:46
HD Request # 139 | Receiving historical Intraday Tick data for @NQ#C | 2015-04-29 03:45:46
HD Request # 139 | Receiving Intraday data for @NQ#C starting at 2015-04-29 03:35:18 | 2015-04-29 03:45:46
HD Request # 139 | Timestamp of first Intraday data file record written: 2015-04-29 03:35:27 | 2015-04-29 03:45:46
HD Request # 139 | Received 17 records from 2015-04-29 03:35:18 to 2015-04-29 03:35:44 (26.0 seconds) and wrote 16 records for @NQ#C | 2015-04-29 03:45:46
HD Request # 139 | Intraday download COMPLETE for @NQ#C. Completion time: 0s. Unique request ID: 141 | 2015-04-29 03:45:46
Removed historical data download ID 141 | 2015-04-29 03:45:46
Real-time Intraday chart data file updates started for @NQ#C | 2015-04-29 03:45:46
HD Request # 140 | Downloading Intraday chart data for UAL to the file UAL.scid. Service: dtn | 2015-04-29 03:45:46
HD Request # 140 | Download start Date-Time: 2015-04-28 17:14:23.0 | 2015-04-29 03:45:46
HD Request # 140 | Requesting Tick data beginning at 2015-04-28 17:14:23 US Eastern Time. | 2015-04-29 03:45:46
HD Request # 140 | Receiving historical Intraday Tick data for UAL | 2015-04-29 03:45:47
HD Request # 140 | Receiving Intraday data for UAL starting at 2015-04-28 17:14:23 | 2015-04-29 03:45:47
HD Request # 140 | Received 1 record from 2015-04-28 17:14:23 to 2015-04-28 17:14:23 (0.0 seconds) and wrote 0 records for UAL | 2015-04-29 03:45:47
HD Request # 140 | Intraday download COMPLETE for UAL. Completion time: 1s. Unique request ID: 142 | 2015-04-29 03:45:47
Removed historical data download ID 142 | 2015-04-29 03:45:47
Real-time Intraday chart data file updates started for UAL | 2015-04-29 03:45:47
HD Request # 141 | Downloading Intraday chart data for VXX to the file VXX.scid. Service: dtn | 2015-04-29 03:45:47
HD Request # 141 | Download start Date-Time: 2015-04-28 19:59:39.0 | 2015-04-29 03:45:47
HD Request # 141 | Requesting Tick data beginning at 2015-04-28 19:59:39 US Eastern Time. | 2015-04-29 03:45:47
HD Request # 141 | Receiving historical Intraday Tick data for VXX | 2015-04-29 03:45:47
HD Request # 141 | Receiving Intraday data for VXX starting at 2015-04-28 19:59:39 | 2015-04-29 03:45:47
HD Request # 141 | Received 2 records from 2015-04-28 19:59:39 to 2015-04-28 19:59:39 (0.0 seconds) and wrote 0 records for VXX | 2015-04-29 03:45:47
HD Request # 141 | Intraday download COMPLETE for VXX. Completion time: 0s. Unique request ID: 143 | 2015-04-29 03:45:47
Removed historical data download ID 143 | 2015-04-29 03:45:47
Real-time Intraday chart data file updates started for VXX | 2015-04-29 03:45:47
HD Request # 142 | Downloading Intraday chart data for FB to the file FB.scid. Service: dtn | 2015-04-29 03:45:47
HD Request # 142 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:45:47
HD Request # 142 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:45:47
HD Request # 142 | Receiving historical Intraday Tick data for FB | 2015-04-29 03:45:48
HD Request # 142 | Receiving Intraday data for FB starting at 2015-04-28 19:59:58 | 2015-04-29 03:45:48
HD Request # 142 | Received 1 record from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for FB | 2015-04-29 03:45:48
HD Request # 142 | Intraday download COMPLETE for FB. Completion time: 0s. Unique request ID: 144 | 2015-04-29 03:45:48
Removed historical data download ID 144 | 2015-04-29 03:45:48
Real-time Intraday chart data file updates started for FB | 2015-04-29 03:45:48
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2015-04-29 03:46:06
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2015-04-29 03:46:06
Connection to the external service has been lost. | 2015-04-29 03:46:06
Socket (33) | Shutdown and closed. | 2015-04-29 03:46:06
IQFeed | Disconnected from Level 2 port. | 2015-04-29 03:46:06
Socket (32) | Shutdown and closed. | 2015-04-29 03:46:06
IQFeed | Disconnected from Lookup port. | 2015-04-29 03:46:06
Socket (31) | Shutdown and closed. | 2015-04-29 03:46:06
IQFeed | Disconnected from Level 1 port. | 2015-04-29 03:46:06
Socket (30) | Shutdown and closed. | 2015-04-29 03:46:06
IQFeed | Disconnected from Admin port. | 2015-04-29 03:46:06
IQFeed | Fully disconnected. | 2015-04-29 03:46:06
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-29 03:46:06
IQFeed | Connecting. | 2015-04-29 03:46:11
Starting DTN IQ Feed interface software. | 2015-04-29 03:46:11
IQFeed | Connecting to Admin port 9300 | 2015-04-29 03:46:11
Socket (34) | Connected. | 2015-04-29 03:46:11
IQFeed | Connected to Admin port. | 2015-04-29 03:46:11
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2015-04-29 03:46:11
AdminMessage: S,STATS,66.112.148.223,60003,500,0,18,1,21,0,Apr 29 3:46AM,Apr 29 3:46AM,Connected,5.1.1.3,423970,410.02,0.02,136.67,3842.25,0.04,1280.75, | 2015-04-29 03:46:12
IQFeed | Connecting to Level 1 port 5009 | 2015-04-29 03:46:12
Socket (35) | Connected. | 2015-04-29 03:46:12
IQFeed | Connected to Level 1 port. | 2015-04-29 03:46:12
IQFeed | Connecting to Lookup port 9100 | 2015-04-29 03:46:12
IQFeed | Connecting to Level 2 port (9200)... | 2015-04-29 03:46:12
Socket (36) | Connected. | 2015-04-29 03:46:12
IQFeed | Connected to Historical Data port. | 2015-04-29 03:46:12
IQFeed | Fully connected. | 2015-04-29 03:46:12
Socket (37) | Connected. | 2015-04-29 03:46:12
IQFeed | Connected to Level 2 port. | 2015-04-29 03:46:12
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:46:12
IQFeed | Level 2 protocol is 5.0. | 2015-04-29 03:46:12
IQFeed | Level 1 system message: KEY | 2015-04-29 03:46:12
IQFeed | Level 1 system message: SERVER CONNECTED | 2015-04-29 03:46:12
IQFeed | Level 1 system message: IP | 2015-04-29 03:46:12
IQFeed | Level 1 system message: CUST | 2015-04-29 03:46:12
IQFeed | Starting real-time market data updates for: QQQ. ID: 1 | 2015-04-29 03:46:12
Intraday data recording state for symbol QQQ is set to download pending. | 2015-04-29 03:46:12
HD Request # 143 | Downloading Intraday chart data for QQQ to the file QQQ.scid. Service: dtn | 2015-04-29 03:46:12
HD Request # 143 | Download start Date-Time: 2015-04-28 19:44:40.0 | 2015-04-29 03:46:12
HD Request # 143 | Requesting Tick data beginning at 2015-04-28 19:44:40 US Eastern Time. | 2015-04-29 03:46:12
IQFeed | Starting real-time market data updates for: LNKD. ID: 2 | 2015-04-29 03:46:12
Intraday data recording state for symbol LNKD is set to download pending. | 2015-04-29 03:46:12
IQFeed | Starting real-time market data updates for: TSLA. ID: 3 | 2015-04-29 03:46:12
Intraday data recording state for symbol TSLA is set to download pending. | 2015-04-29 03:46:12
IQFeed | Starting real-time market data updates for: @ES#C. ID: 4 | 2015-04-29 03:46:12
Intraday data recording state for symbol @ES#C is set to download pending. | 2015-04-29 03:46:12
IQFeed | Starting real-time market data updates for: TWTR. ID: 5 | 2015-04-29 03:46:12
Intraday data recording state for symbol TWTR is set to download pending. | 2015-04-29 03:46:12
IQFeed | Starting real-time market data updates for: BABA. ID: 6 | 2015-04-29 03:46:12
Intraday data recording state for symbol BABA is set to download pending. | 2015-04-29 03:46:12
IQFeed | Starting real-time market data updates for: SPY. ID: 7 | 2015-04-29 03:46:12
Intraday data recording state for symbol SPY is set to download pending. | 2015-04-29 03:46:12
IQFeed | Starting real-time market data updates for: NKE. ID: 8 | 2015-04-29 03:46:12
Intraday data recording state for symbol NKE is set to download pending. | 2015-04-29 03:46:12
HD Request # 143 | Receiving historical Intraday Tick data for QQQ | 2015-04-29 03:46:12
HD Request # 143 | Receiving Intraday data for QQQ starting at 2015-04-28 19:44:40 | 2015-04-29 03:46:12
HD Request # 143 | Received 4 records from 2015-04-28 19:44:40 to 2015-04-28 19:44:40 (0.0 seconds) and wrote 0 records for QQQ | 2015-04-29 03:46:12
HD Request # 143 | Intraday download COMPLETE for QQQ. Completion time: 0s. Unique request ID: 145 | 2015-04-29 03:46:12
Removed historical data download ID 145 | 2015-04-29 03:46:12
Real-time Intraday chart data file updates started for QQQ | 2015-04-29 03:46:12
HD Request # 144 | Downloading Intraday chart data for LNKD to the file LNKD.scid. Service: dtn | 2015-04-29 03:46:12
HD Request # 144 | Download start Date-Time: 2015-04-28 19:46:00.0 | 2015-04-29 03:46:12
HD Request # 144 | Requesting Tick data beginning at 2015-04-28 19:46:00 US Eastern Time. | 2015-04-29 03:46:12
IQFeed | Starting real-time market data updates for: @NQ#C. ID: 9 | 2015-04-29 03:46:12
Intraday data recording state for symbol @NQ#C is set to download pending. | 2015-04-29 03:46:12
IQFeed | Starting real-time market data updates for: UAL. ID: 10 | 2015-04-29 03:46:12
Intraday data recording state for symbol UAL is set to download pending. | 2015-04-29 03:46:12
IQFeed | Starting real-time market data updates for: VXX. ID: 11 | 2015-04-29 03:46:12
Intraday data recording state for symbol VXX is set to download pending. | 2015-04-29 03:46:12
IQFeed | Starting real-time market data updates for: FB. ID: 12 | 2015-04-29 03:46:12
Intraday data recording state for symbol FB is set to download pending. | 2015-04-29 03:46:12
IQFeed | Starting real-time market data updates for: AMZN. ID: 13 | 2015-04-29 03:46:12
Intraday data recording state for symbol AMZN is set to download pending. | 2015-04-29 03:46:12
IQFeed | Starting real-time market data updates for: AAPL. ID: 14 | 2015-04-29 03:46:12
Intraday data recording state for symbol AAPL is set to download pending. | 2015-04-29 03:46:12
IQFeed | Starting real-time market data updates for: XOm. ID: 15 | 2015-04-29 03:46:12
Intraday data recording state for symbol XOm is set to download pending. | 2015-04-29 03:46:12
IQFeed | Starting real-time market data updates for: @ym#C. ID: 16 | 2015-04-29 03:46:12
Intraday data recording state for symbol @ym#C is set to download pending. | 2015-04-29 03:46:12
IQFeed | Starting real-time market data updates for: BRK.B. ID: 17 | 2015-04-29 03:46:12
Intraday data recording state for symbol BRK.B is set to download pending. | 2015-04-29 03:46:12
IQFeed | Starting real-time market data updates for: V. ID: 18 | 2015-04-29 03:46:13
Intraday data recording state for symbol V is set to download pending. | 2015-04-29 03:46:13
HD Request # 144 | Receiving historical Intraday Tick data for LNKD | 2015-04-29 03:46:13
HD Request # 144 | Receiving Intraday data for LNKD starting at 2015-04-28 19:46:00 | 2015-04-29 03:46:13
HD Request # 144 | Received 1 record from 2015-04-28 19:46:00 to 2015-04-28 19:46:00 (0.0 seconds) and wrote 0 records for LNKD | 2015-04-29 03:46:13
HD Request # 144 | Intraday download COMPLETE for LNKD. Completion time: 0s. Unique request ID: 146 | 2015-04-29 03:46:13
Removed historical data download ID 146 | 2015-04-29 03:46:13
Real-time Intraday chart data file updates started for LNKD | 2015-04-29 03:46:13
HD Request # 145 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: dtn | 2015-04-29 03:46:13
HD Request # 145 | Download start Date-Time: 2015-04-28 19:59:10.0 | 2015-04-29 03:46:13
HD Request # 145 | Requesting Tick data beginning at 2015-04-28 19:59:10 US Eastern Time. | 2015-04-29 03:46:13
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:46:13
HD Request # 145 | Receiving historical Intraday Tick data for TSLA | 2015-04-29 03:46:13
HD Request # 145 | Receiving Intraday data for TSLA starting at 2015-04-28 19:59:10 | 2015-04-29 03:46:13
HD Request # 145 | Received 1 record from 2015-04-28 19:59:10 to 2015-04-28 19:59:10 (0.0 seconds) and wrote 0 records for TSLA | 2015-04-29 03:46:13
HD Request # 145 | Intraday download COMPLETE for TSLA. Completion time: 0s. Unique request ID: 147 | 2015-04-29 03:46:13
Removed historical data download ID 147 | 2015-04-29 03:46:13
Real-time Intraday chart data file updates started for TSLA | 2015-04-29 03:46:13
HD Request # 146 | Downloading Intraday chart data for @ES#C to the file @ES#C.scid. Service: dtn | 2015-04-29 03:46:13
HD Request # 146 | Download start Date-Time: 2015-04-29 03:36:02.0 | 2015-04-29 03:46:13
HD Request # 146 | Requesting Tick data beginning at 2015-04-29 03:36:02 US Eastern Time. | 2015-04-29 03:46:13
HD Request # 146 | Receiving historical Intraday Tick data for @ES#C | 2015-04-29 03:46:14
HD Request # 146 | Receiving Intraday data for @ES#C starting at 2015-04-29 03:36:02 | 2015-04-29 03:46:14
HD Request # 146 | Timestamp of first Intraday data file record written: 2015-04-29 03:36:09 | 2015-04-29 03:46:14
HD Request # 146 | Received 38 records from 2015-04-29 03:36:02 to 2015-04-29 03:36:16 (14.0 seconds) and wrote 37 records for @ES#C | 2015-04-29 03:46:14
HD Request # 146 | Intraday download COMPLETE for @ES#C. Completion time: 1s. Unique request ID: 148 | 2015-04-29 03:46:14
Removed historical data download ID 148 | 2015-04-29 03:46:14
Real-time Intraday chart data file updates started for @ES#C | 2015-04-29 03:46:14
HD Request # 147 | Downloading Intraday chart data for TWTR to the file TWTR.scid. Service: dtn | 2015-04-29 03:46:14
HD Request # 147 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:46:14
HD Request # 147 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:46:14
HD Request # 147 | Receiving historical Intraday Tick data for TWTR | 2015-04-29 03:46:14
HD Request # 147 | Receiving Intraday data for TWTR starting at 2015-04-28 19:59:58 | 2015-04-29 03:46:14
HD Request # 147 | Received 3 records from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for TWTR | 2015-04-29 03:46:14
HD Request # 147 | Intraday download COMPLETE for TWTR. Completion time: 0s. Unique request ID: 149 | 2015-04-29 03:46:14
Removed historical data download ID 149 | 2015-04-29 03:46:14
Real-time Intraday chart data file updates started for TWTR | 2015-04-29 03:46:14
HD Request # 148 | Downloading Intraday chart data for BABA to the file BABA.scid. Service: dtn | 2015-04-29 03:46:14
HD Request # 148 | Download start Date-Time: 2015-04-28 19:58:41.0 | 2015-04-29 03:46:14
HD Request # 148 | Requesting Tick data beginning at 2015-04-28 19:58:41 US Eastern Time. | 2015-04-29 03:46:14
HD Request # 148 | Receiving historical Intraday Tick data for BABA | 2015-04-29 03:46:15
HD Request # 148 | Receiving Intraday data for BABA starting at 2015-04-28 19:58:41 | 2015-04-29 03:46:15
HD Request # 148 | Received 1 record from 2015-04-28 19:58:41 to 2015-04-28 19:58:41 (0.0 seconds) and wrote 0 records for BABA | 2015-04-29 03:46:15
HD Request # 148 | Intraday download COMPLETE for BABA. Completion time: 0s. Unique request ID: 150 | 2015-04-29 03:46:15
Removed historical data download ID 150 | 2015-04-29 03:46:15
Real-time Intraday chart data file updates started for BABA | 2015-04-29 03:46:15
HD Request # 149 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: dtn | 2015-04-29 03:46:15
HD Request # 149 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:46:15
HD Request # 149 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:46:15
HD Request # 149 | Receiving historical Intraday Tick data for SPY | 2015-04-29 03:46:15
HD Request # 149 | Receiving Intraday data for SPY starting at 2015-04-28 19:59:58 | 2015-04-29 03:46:15
HD Request # 149 | Received 1 record from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for SPY | 2015-04-29 03:46:15
HD Request # 149 | Intraday download COMPLETE for SPY. Completion time: 0s. Unique request ID: 151 | 2015-04-29 03:46:15
Removed historical data download ID 151 | 2015-04-29 03:46:15
Real-time Intraday chart data file updates started for SPY | 2015-04-29 03:46:15
HD Request # 150 | Downloading Intraday chart data for NKE to the file NKE.scid. Service: dtn | 2015-04-29 03:46:15
HD Request # 150 | Download start Date-Time: 2015-04-28 16:32:54.0 | 2015-04-29 03:46:15
HD Request # 150 | Requesting Tick data beginning at 2015-04-28 16:32:54 US Eastern Time. | 2015-04-29 03:46:15
HD Request # 150 | Receiving historical Intraday Tick data for NKE | 2015-04-29 03:46:16
HD Request # 150 | Receiving Intraday data for NKE starting at 2015-04-28 16:32:54 | 2015-04-29 03:46:16
HD Request # 150 | Received 1 record from 2015-04-28 16:32:54 to 2015-04-28 16:32:54 (0.0 seconds) and wrote 0 records for NKE | 2015-04-29 03:46:16
HD Request # 150 | Intraday download COMPLETE for NKE. Completion time: 1s. Unique request ID: 152 | 2015-04-29 03:46:16
Removed historical data download ID 152 | 2015-04-29 03:46:16
Real-time Intraday chart data file updates started for NKE | 2015-04-29 03:46:16
HD Request # 151 | Downloading Intraday chart data for @NQ#C to the file @NQ#C.scid. Service: dtn | 2015-04-29 03:46:16
HD Request # 151 | Download start Date-Time: 2015-04-29 03:36:00.0 | 2015-04-29 03:46:16
HD Request # 151 | Requesting Tick data beginning at 2015-04-29 03:36:00 US Eastern Time. | 2015-04-29 03:46:16
HD Request # 151 | Receiving historical Intraday Tick data for @NQ#C | 2015-04-29 03:46:16
HD Request # 151 | Receiving Intraday data for @NQ#C starting at 2015-04-29 03:36:00 | 2015-04-29 03:46:16
HD Request # 151 | Timestamp of first Intraday data file record written: 2015-04-29 03:36:13 | 2015-04-29 03:46:16
HD Request # 151 | Received 12 records from 2015-04-29 03:36:00 to 2015-04-29 03:36:18 (18.0 seconds) and wrote 11 records for @NQ#C | 2015-04-29 03:46:16
HD Request # 151 | Intraday download COMPLETE for @NQ#C. Completion time: 0s. Unique request ID: 153 | 2015-04-29 03:46:16
Removed historical data download ID 153 | 2015-04-29 03:46:16
Real-time Intraday chart data file updates started for @NQ#C | 2015-04-29 03:46:16
HD Request # 152 | Downloading Intraday chart data for UAL to the file UAL.scid. Service: dtn | 2015-04-29 03:46:16
HD Request # 152 | Download start Date-Time: 2015-04-28 17:14:23.0 | 2015-04-29 03:46:16
HD Request # 152 | Requesting Tick data beginning at 2015-04-28 17:14:23 US Eastern Time. | 2015-04-29 03:46:16
HD Request # 152 | Receiving historical Intraday Tick data for UAL | 2015-04-29 03:46:17
HD Request # 152 | Receiving Intraday data for UAL starting at 2015-04-28 17:14:23 | 2015-04-29 03:46:17
HD Request # 152 | Received 1 record from 2015-04-28 17:14:23 to 2015-04-28 17:14:23 (0.0 seconds) and wrote 0 records for UAL | 2015-04-29 03:46:17
HD Request # 152 | Intraday download COMPLETE for UAL. Completion time: 1s. Unique request ID: 154 | 2015-04-29 03:46:17
Removed historical data download ID 154 | 2015-04-29 03:46:17
Real-time Intraday chart data file updates started for UAL | 2015-04-29 03:46:17
HD Request # 153 | Downloading Intraday chart data for VXX to the file VXX.scid. Service: dtn | 2015-04-29 03:46:17
HD Request # 153 | Download start Date-Time: 2015-04-28 19:59:39.0 | 2015-04-29 03:46:17
HD Request # 153 | Requesting Tick data beginning at 2015-04-28 19:59:39 US Eastern Time. | 2015-04-29 03:46:17
HD Request # 153 | Receiving historical Intraday Tick data for VXX | 2015-04-29 03:46:17
HD Request # 153 | Receiving Intraday data for VXX starting at 2015-04-28 19:59:39 | 2015-04-29 03:46:17
HD Request # 153 | Received 2 records from 2015-04-28 19:59:39 to 2015-04-28 19:59:39 (0.0 seconds) and wrote 0 records for VXX | 2015-04-29 03:46:17
HD Request # 153 | Intraday download COMPLETE for VXX. Completion time: 0s. Unique request ID: 155 | 2015-04-29 03:46:17
Removed historical data download ID 155 | 2015-04-29 03:46:17
Real-time Intraday chart data file updates started for VXX | 2015-04-29 03:46:17
HD Request # 154 | Downloading Intraday chart data for FB to the file FB.scid. Service: dtn | 2015-04-29 03:46:17
HD Request # 154 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:46:17
HD Request # 154 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:46:17
HD Request # 154 | Receiving historical Intraday Tick data for FB | 2015-04-29 03:46:18
HD Request # 154 | Receiving Intraday data for FB starting at 2015-04-28 19:59:58 | 2015-04-29 03:46:18
HD Request # 154 | Received 1 record from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for FB | 2015-04-29 03:46:18
HD Request # 154 | Intraday download COMPLETE for FB. Completion time: 0s. Unique request ID: 156 | 2015-04-29 03:46:18
Removed historical data download ID 156 | 2015-04-29 03:46:18
Real-time Intraday chart data file updates started for FB | 2015-04-29 03:46:18
HD Request # 155 | Downloading Intraday chart data for AMZN to the file AMZN.scid. Service: dtn | 2015-04-29 03:46:18
HD Request # 155 | Download start Date-Time: 2015-04-28 19:29:10.0 | 2015-04-29 03:46:18
HD Request # 155 | Requesting Tick data beginning at 2015-04-28 19:29:10 US Eastern Time. | 2015-04-29 03:46:18
HD Request # 155 | Receiving historical Intraday Tick data for AMZN | 2015-04-29 03:46:18
HD Request # 155 | Receiving Intraday data for AMZN starting at 2015-04-28 19:29:10 | 2015-04-29 03:46:18
HD Request # 155 | Received 1 record from 2015-04-28 19:29:10 to 2015-04-28 19:29:10 (0.0 seconds) and wrote 0 records for AMZN | 2015-04-29 03:46:18
HD Request # 155 | Intraday download COMPLETE for AMZN. Completion time: 0s. Unique request ID: 157 | 2015-04-29 03:46:18
Removed historical data download ID 157 | 2015-04-29 03:46:18
Real-time Intraday chart data file updates started for AMZN | 2015-04-29 03:46:18
HD Request # 156 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: dtn | 2015-04-29 03:46:18
HD Request # 156 | Download start Date-Time: 2015-04-28 19:59:48.0 | 2015-04-29 03:46:18
HD Request # 156 | Requesting Tick data beginning at 2015-04-28 19:59:48 US Eastern Time. | 2015-04-29 03:46:18
HD Request # 156 | Receiving historical Intraday Tick data for AAPL | 2015-04-29 03:46:19
HD Request # 156 | Receiving Intraday data for AAPL starting at 2015-04-28 19:59:48 | 2015-04-29 03:46:19
HD Request # 156 | Received 1 record from 2015-04-28 19:59:48 to 2015-04-28 19:59:48 (0.0 seconds) and wrote 0 records for AAPL | 2015-04-29 03:46:19
HD Request # 156 | Intraday download COMPLETE for AAPL. Completion time: 1s. Unique request ID: 158 | 2015-04-29 03:46:19
Removed historical data download ID 158 | 2015-04-29 03:46:19
Real-time Intraday chart data file updates started for AAPL | 2015-04-29 03:46:19
HD Request # 157 | Downloading Intraday chart data for XOm to the file XOm.scid. Service: dtn | 2015-04-29 03:46:19
HD Request # 157 | Download start Date-Time: 2015-04-28 19:59:49.0 | 2015-04-29 03:46:19
HD Request # 157 | Requesting Tick data beginning at 2015-04-28 19:59:49 US Eastern Time. | 2015-04-29 03:46:19
HD Request # 157 | Receiving historical Intraday Tick data for XOM | 2015-04-29 03:46:19
HD Request # 157 | Receiving Intraday data for XOm starting at 2015-04-28 19:59:49 | 2015-04-29 03:46:19
HD Request # 157 | Received 1 record from 2015-04-28 19:59:49 to 2015-04-28 19:59:49 (0.0 seconds) and wrote 0 records for XOm | 2015-04-29 03:46:19
HD Request # 157 | Intraday download COMPLETE for XOm. Completion time: 0s. Unique request ID: 159 | 2015-04-29 03:46:19
Removed historical data download ID 159 | 2015-04-29 03:46:19
Real-time Intraday chart data file updates started for XOm | 2015-04-29 03:46:19
HD Request # 158 | Downloading Intraday chart data for @ym#C to the file @ym#C.scid. Service: dtn | 2015-04-29 03:46:19
HD Request # 158 | Download start Date-Time: 2015-04-29 03:35:55.0 | 2015-04-29 03:46:19
HD Request # 158 | Requesting Tick data beginning at 2015-04-29 03:35:55 US Eastern Time. | 2015-04-29 03:46:19
HD Request # 158 | Receiving historical Intraday Tick data for @YM#C | 2015-04-29 03:46:20
HD Request # 158 | Receiving Intraday data for @ym#C starting at 2015-04-29 03:35:55 | 2015-04-29 03:46:20
HD Request # 158 | Timestamp of first Intraday data file record written: 2015-04-29 03:36:09 | 2015-04-29 03:46:20
HD Request # 158 | Received 19 records from 2015-04-29 03:35:55 to 2015-04-29 03:36:20 (25.0 seconds) and wrote 18 records for @ym#C | 2015-04-29 03:46:20
HD Request # 158 | Intraday download COMPLETE for @ym#C. Completion time: 1s. Unique request ID: 160 | 2015-04-29 03:46:20
Removed historical data download ID 160 | 2015-04-29 03:46:20
Real-time Intraday chart data file updates started for @ym#C | 2015-04-29 03:46:20
HD Request # 159 | Downloading Intraday chart data for BRK.B to the file BRK.B.scid. Service: dtn | 2015-04-29 03:46:20
HD Request # 159 | Download start Date-Time: 2015-04-28 17:01:29.0 | 2015-04-29 03:46:20
HD Request # 159 | Requesting Tick data beginning at 2015-04-28 17:01:29 US Eastern Time. | 2015-04-29 03:46:20
HD Request # 159 | Receiving historical Intraday Tick data for BRK.B | 2015-04-29 03:46:20
HD Request # 159 | Receiving Intraday data for BRK.B starting at 2015-04-28 17:01:29 | 2015-04-29 03:46:20
HD Request # 159 | Received 1 record from 2015-04-28 17:01:29 to 2015-04-28 17:01:29 (0.0 seconds) and wrote 0 records for BRK.B | 2015-04-29 03:46:20
HD Request # 159 | Intraday download COMPLETE for BRK.B. Completion time: 0s. Unique request ID: 161 | 2015-04-29 03:46:20
Removed historical data download ID 161 | 2015-04-29 03:46:20
Real-time Intraday chart data file updates started for BRK.B | 2015-04-29 03:46:20
HD Request # 160 | Downloading Intraday chart data for V to the file V.scid. Service: dtn | 2015-04-29 03:46:20
HD Request # 160 | Download start Date-Time: 2015-04-28 19:57:15.0 | 2015-04-29 03:46:20
HD Request # 160 | Requesting Tick data beginning at 2015-04-28 19:57:15 US Eastern Time. | 2015-04-29 03:46:20
HD Request # 160 | Receiving historical Intraday Tick data for V | 2015-04-29 03:46:21
HD Request # 160 | Receiving Intraday data for V starting at 2015-04-28 19:57:15 | 2015-04-29 03:46:21
HD Request # 160 | Received 1 record from 2015-04-28 19:57:15 to 2015-04-28 19:57:15 (0.0 seconds) and wrote 0 records for V | 2015-04-29 03:46:21
HD Request # 160 | Intraday download COMPLETE for V. Completion time: 0s. Unique request ID: 162 | 2015-04-29 03:46:21
Removed historical data download ID 162 | 2015-04-29 03:46:21
Real-time Intraday chart data file updates started for V | 2015-04-29 03:46:21
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2015-04-29 03:46:48
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2015-04-29 03:46:48
Connection to the external service has been lost. | 2015-04-29 03:46:48
Socket (37) | Shutdown and closed. | 2015-04-29 03:46:48
IQFeed | Disconnected from Level 2 port. | 2015-04-29 03:46:48
Socket (36) | Shutdown and closed. | 2015-04-29 03:46:48
IQFeed | Disconnected from Lookup port. | 2015-04-29 03:46:48
Socket (35) | Shutdown and closed. | 2015-04-29 03:46:48
IQFeed | Disconnected from Level 1 port. | 2015-04-29 03:46:48
Socket (34) | Shutdown and closed. | 2015-04-29 03:46:48
IQFeed | Disconnected from Admin port. | 2015-04-29 03:46:48
IQFeed | Fully disconnected. | 2015-04-29 03:46:48
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-29 03:46:48
IQFeed | Connecting. | 2015-04-29 03:46:53
Starting DTN IQ Feed interface software. | 2015-04-29 03:46:53
IQFeed | Connecting to Admin port 9300 | 2015-04-29 03:46:53
Socket (38) | Connected. | 2015-04-29 03:46:53
IQFeed | Connected to Admin port. | 2015-04-29 03:46:53
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2015-04-29 03:46:53
AdminMessage: S,STATS,66.112.156.221,60002,500,0,19,1,22,0,Apr 29 3:46AM,Apr 29 3:46AM,Connected,5.1.1.3,423970,445.26,0.02,222.63,4138.75,0.04,2069.38, | 2015-04-29 03:46:54
IQFeed | Connecting to Level 1 port 5009 | 2015-04-29 03:46:54
Socket (39) | Connected. | 2015-04-29 03:46:54
IQFeed | Connected to Level 1 port. | 2015-04-29 03:46:54
IQFeed | Connecting to Lookup port 9100 | 2015-04-29 03:46:54
IQFeed | Connecting to Level 2 port (9200)... | 2015-04-29 03:46:54
Socket (40) | Connected. | 2015-04-29 03:46:54
IQFeed | Connected to Historical Data port. | 2015-04-29 03:46:54
IQFeed | Fully connected. | 2015-04-29 03:46:54
Socket (41) | Connected. | 2015-04-29 03:46:54
IQFeed | Connected to Level 2 port. | 2015-04-29 03:46:54
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:46:54
IQFeed | Level 1 system message: KEY | 2015-04-29 03:46:54
IQFeed | Level 1 system message: SERVER CONNECTED | 2015-04-29 03:46:54
IQFeed | Level 1 system message: IP | 2015-04-29 03:46:54
IQFeed | Level 1 system message: CUST | 2015-04-29 03:46:54
IQFeed | Level 2 protocol is 5.0. | 2015-04-29 03:46:54
IQFeed | Starting real-time market data updates for: LNKD. ID: 1 | 2015-04-29 03:46:54
Intraday data recording state for symbol LNKD is set to download pending. | 2015-04-29 03:46:54
HD Request # 161 | Downloading Intraday chart data for LNKD to the file LNKD.scid. Service: dtn | 2015-04-29 03:46:54
HD Request # 161 | Download start Date-Time: 2015-04-28 19:46:00.0 | 2015-04-29 03:46:54
HD Request # 161 | Requesting Tick data beginning at 2015-04-28 19:46:00 US Eastern Time. | 2015-04-29 03:46:54
IQFeed | Starting real-time market data updates for: TSLA. ID: 2 | 2015-04-29 03:46:54
Intraday data recording state for symbol TSLA is set to download pending. | 2015-04-29 03:46:54
IQFeed | Starting real-time market data updates for: @ES#C. ID: 3 | 2015-04-29 03:46:54
Intraday data recording state for symbol @ES#C is set to download pending. | 2015-04-29 03:46:54
IQFeed | Starting real-time market data updates for: TWTR. ID: 4 | 2015-04-29 03:46:54
Intraday data recording state for symbol TWTR is set to download pending. | 2015-04-29 03:46:54
IQFeed | Starting real-time market data updates for: BABA. ID: 5 | 2015-04-29 03:46:54
Intraday data recording state for symbol BABA is set to download pending. | 2015-04-29 03:46:54
IQFeed | Starting real-time market data updates for: SPY. ID: 6 | 2015-04-29 03:46:54
Intraday data recording state for symbol SPY is set to download pending. | 2015-04-29 03:46:54
IQFeed | Starting real-time market data updates for: NKE. ID: 7 | 2015-04-29 03:46:54
Intraday data recording state for symbol NKE is set to download pending. | 2015-04-29 03:46:54
IQFeed | Starting real-time market data updates for: @NQ#C. ID: 8 | 2015-04-29 03:46:54
Intraday data recording state for symbol @NQ#C is set to download pending. | 2015-04-29 03:46:54
IQFeed | Starting real-time market data updates for: QQQ. ID: 9 | 2015-04-29 03:46:54
Intraday data recording state for symbol QQQ is set to download pending. | 2015-04-29 03:46:54
IQFeed | Starting real-time market data updates for: UAL. ID: 10 | 2015-04-29 03:46:54
Intraday data recording state for symbol UAL is set to download pending. | 2015-04-29 03:46:54
IQFeed | Starting real-time market data updates for: VXX. ID: 11 | 2015-04-29 03:46:54
Intraday data recording state for symbol VXX is set to download pending. | 2015-04-29 03:46:54
IQFeed | Starting real-time market data updates for: FB. ID: 12 | 2015-04-29 03:46:54
Intraday data recording state for symbol FB is set to download pending. | 2015-04-29 03:46:54
IQFeed | Starting real-time market data updates for: AMZN. ID: 13 | 2015-04-29 03:46:54
Intraday data recording state for symbol AMZN is set to download pending. | 2015-04-29 03:46:54
HD Request # 161 | Receiving historical Intraday Tick data for LNKD | 2015-04-29 03:46:54
HD Request # 161 | Receiving Intraday data for LNKD starting at 2015-04-28 19:46:00 | 2015-04-29 03:46:54
HD Request # 161 | Received 1 record from 2015-04-28 19:46:00 to 2015-04-28 19:46:00 (0.0 seconds) and wrote 0 records for LNKD | 2015-04-29 03:46:54
HD Request # 161 | Intraday download COMPLETE for LNKD. Completion time: 0s. Unique request ID: 163 | 2015-04-29 03:46:54
Removed historical data download ID 163 | 2015-04-29 03:46:54
Real-time Intraday chart data file updates started for LNKD | 2015-04-29 03:46:54
HD Request # 162 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: dtn | 2015-04-29 03:46:55
HD Request # 162 | Download start Date-Time: 2015-04-28 19:59:10.0 | 2015-04-29 03:46:55
HD Request # 162 | Requesting Tick data beginning at 2015-04-28 19:59:10 US Eastern Time. | 2015-04-29 03:46:55
IQFeed | Starting real-time market data updates for: AAPL. ID: 14 | 2015-04-29 03:46:55
Intraday data recording state for symbol AAPL is set to download pending. | 2015-04-29 03:46:55
IQFeed | Starting real-time market data updates for: XOm. ID: 15 | 2015-04-29 03:46:55
Intraday data recording state for symbol XOm is set to download pending. | 2015-04-29 03:46:55
IQFeed | Starting real-time market data updates for: @ym#C. ID: 16 | 2015-04-29 03:46:55
Intraday data recording state for symbol @ym#C is set to download pending. | 2015-04-29 03:46:55
IQFeed | Starting real-time market data updates for: BRK.B. ID: 17 | 2015-04-29 03:46:55
Intraday data recording state for symbol BRK.B is set to download pending. | 2015-04-29 03:46:55
IQFeed | Starting real-time market data updates for: V. ID: 18 | 2015-04-29 03:46:55
Intraday data recording state for symbol V is set to download pending. | 2015-04-29 03:46:55
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:46:55
HD Request # 162 | Receiving historical Intraday Tick data for TSLA | 2015-04-29 03:46:55
HD Request # 162 | Receiving Intraday data for TSLA starting at 2015-04-28 19:59:10 | 2015-04-29 03:46:55
HD Request # 162 | Received 1 record from 2015-04-28 19:59:10 to 2015-04-28 19:59:10 (0.0 seconds) and wrote 0 records for TSLA | 2015-04-29 03:46:55
HD Request # 162 | Intraday download COMPLETE for TSLA. Completion time: 0s. Unique request ID: 164 | 2015-04-29 03:46:55
Removed historical data download ID 164 | 2015-04-29 03:46:55
Real-time Intraday chart data file updates started for TSLA | 2015-04-29 03:46:55
HD Request # 163 | Downloading Intraday chart data for @ES#C to the file @ES#C.scid. Service: dtn | 2015-04-29 03:46:55
HD Request # 163 | Download start Date-Time: 2015-04-29 03:36:42.0 | 2015-04-29 03:46:55
HD Request # 163 | Requesting Tick data beginning at 2015-04-29 03:36:42 US Eastern Time. | 2015-04-29 03:46:55
HD Request # 163 | Receiving historical Intraday Tick data for @ES#C | 2015-04-29 03:46:56
HD Request # 163 | Receiving Intraday data for @ES#C starting at 2015-04-29 03:36:42 | 2015-04-29 03:46:56
HD Request # 163 | Timestamp of first Intraday data file record written: 2015-04-29 03:36:56 | 2015-04-29 03:46:56
HD Request # 163 | Received 20 records from 2015-04-29 03:36:42 to 2015-04-29 03:36:56 (14.0 seconds) and wrote 6 records for @ES#C | 2015-04-29 03:46:56
HD Request # 163 | Intraday download COMPLETE for @ES#C. Completion time: 0s. Unique request ID: 165 | 2015-04-29 03:46:56
Removed historical data download ID 165 | 2015-04-29 03:46:56
Real-time Intraday chart data file updates started for @ES#C | 2015-04-29 03:46:56
HD Request # 164 | Downloading Intraday chart data for TWTR to the file TWTR.scid. Service: dtn | 2015-04-29 03:46:56
HD Request # 164 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:46:56
HD Request # 164 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:46:56
HD Request # 164 | Receiving historical Intraday Tick data for TWTR | 2015-04-29 03:46:56
HD Request # 164 | Receiving Intraday data for TWTR starting at 2015-04-28 19:59:58 | 2015-04-29 03:46:56
HD Request # 164 | Received 3 records from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for TWTR | 2015-04-29 03:46:56
HD Request # 164 | Intraday download COMPLETE for TWTR. Completion time: 0s. Unique request ID: 166 | 2015-04-29 03:46:56
Removed historical data download ID 166 | 2015-04-29 03:46:56
Real-time Intraday chart data file updates started for TWTR | 2015-04-29 03:46:56
HD Request # 165 | Downloading Intraday chart data for BABA to the file BABA.scid. Service: dtn | 2015-04-29 03:46:56
HD Request # 165 | Download start Date-Time: 2015-04-28 19:58:41.0 | 2015-04-29 03:46:56
HD Request # 165 | Requesting Tick data beginning at 2015-04-28 19:58:41 US Eastern Time. | 2015-04-29 03:46:56
HD Request # 165 | Receiving historical Intraday Tick data for BABA | 2015-04-29 03:46:57
HD Request # 165 | Receiving Intraday data for BABA starting at 2015-04-28 19:58:41 | 2015-04-29 03:46:57
HD Request # 165 | Received 1 record from 2015-04-28 19:58:41 to 2015-04-28 19:58:41 (0.0 seconds) and wrote 0 records for BABA | 2015-04-29 03:46:57
HD Request # 165 | Intraday download COMPLETE for BABA. Completion time: 1s. Unique request ID: 167 | 2015-04-29 03:46:57
Removed historical data download ID 167 | 2015-04-29 03:46:57
Real-time Intraday chart data file updates started for BABA | 2015-04-29 03:46:57
HD Request # 166 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: dtn | 2015-04-29 03:46:57
HD Request # 166 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:46:57
HD Request # 166 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:46:57
HD Request # 166 | Receiving historical Intraday Tick data for SPY | 2015-04-29 03:46:57
HD Request # 166 | Receiving Intraday data for SPY starting at 2015-04-28 19:59:58 | 2015-04-29 03:46:57
HD Request # 166 | Received 1 record from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for SPY | 2015-04-29 03:46:57
HD Request # 166 | Intraday download COMPLETE for SPY. Completion time: 0s. Unique request ID: 168 | 2015-04-29 03:46:57
Removed historical data download ID 168 | 2015-04-29 03:46:57
Real-time Intraday chart data file updates started for SPY | 2015-04-29 03:46:57
HD Request # 167 | Downloading Intraday chart data for NKE to the file NKE.scid. Service: dtn | 2015-04-29 03:46:57
HD Request # 167 | Download start Date-Time: 2015-04-28 16:32:54.0 | 2015-04-29 03:46:57
HD Request # 167 | Requesting Tick data beginning at 2015-04-28 16:32:54 US Eastern Time. | 2015-04-29 03:46:57
HD Request # 167 | Receiving historical Intraday Tick data for NKE | 2015-04-29 03:46:58
HD Request # 167 | Receiving Intraday data for NKE starting at 2015-04-28 16:32:54 | 2015-04-29 03:46:58
HD Request # 167 | Received 1 record from 2015-04-28 16:32:54 to 2015-04-28 16:32:54 (0.0 seconds) and wrote 0 records for NKE | 2015-04-29 03:46:58
HD Request # 167 | Intraday download COMPLETE for NKE. Completion time: 0s. Unique request ID: 169 | 2015-04-29 03:46:58
Removed historical data download ID 169 | 2015-04-29 03:46:58
Real-time Intraday chart data file updates started for NKE | 2015-04-29 03:46:58
HD Request # 168 | Downloading Intraday chart data for @NQ#C to the file @NQ#C.scid. Service: dtn | 2015-04-29 03:46:58
HD Request # 168 | Download start Date-Time: 2015-04-29 03:36:42.0 | 2015-04-29 03:46:58
HD Request # 168 | Requesting Tick data beginning at 2015-04-29 03:36:42 US Eastern Time. | 2015-04-29 03:46:58
HD Request # 168 | Receiving historical Intraday Tick data for @NQ#C | 2015-04-29 03:46:58
HD Request # 168 | Receiving Intraday data for @NQ#C starting at 2015-04-29 03:36:42 | 2015-04-29 03:46:58
HD Request # 168 | Timestamp of first Intraday data file record written: 2015-04-29 03:36:59 | 2015-04-29 03:46:58
HD Request # 168 | Received 5 records from 2015-04-29 03:36:42 to 2015-04-29 03:36:59 (17.0 seconds) and wrote 1 record for @NQ#C | 2015-04-29 03:46:58
HD Request # 168 | Intraday download COMPLETE for @NQ#C. Completion time: 0s. Unique request ID: 170 | 2015-04-29 03:46:58
Removed historical data download ID 170 | 2015-04-29 03:46:58
Real-time Intraday chart data file updates started for @NQ#C | 2015-04-29 03:46:58
HD Request # 169 | Downloading Intraday chart data for QQQ to the file QQQ.scid. Service: dtn | 2015-04-29 03:46:58
HD Request # 169 | Download start Date-Time: 2015-04-28 19:44:40.0 | 2015-04-29 03:46:58
HD Request # 169 | Requesting Tick data beginning at 2015-04-28 19:44:40 US Eastern Time. | 2015-04-29 03:46:58
HD Request # 169 | Receiving historical Intraday Tick data for QQQ | 2015-04-29 03:46:59
HD Request # 169 | Receiving Intraday data for QQQ starting at 2015-04-28 19:44:40 | 2015-04-29 03:46:59
HD Request # 169 | Received 4 records from 2015-04-28 19:44:40 to 2015-04-28 19:44:40 (0.0 seconds) and wrote 0 records for QQQ | 2015-04-29 03:46:59
HD Request # 169 | Intraday download COMPLETE for QQQ. Completion time: 1s. Unique request ID: 171 | 2015-04-29 03:46:59
Removed historical data download ID 171 | 2015-04-29 03:46:59
Real-time Intraday chart data file updates started for QQQ | 2015-04-29 03:46:59
HD Request # 170 | Downloading Intraday chart data for UAL to the file UAL.scid. Service: dtn | 2015-04-29 03:46:59
HD Request # 170 | Download start Date-Time: 2015-04-28 17:14:23.0 | 2015-04-29 03:46:59
HD Request # 170 | Requesting Tick data beginning at 2015-04-28 17:14:23 US Eastern Time. | 2015-04-29 03:46:59
HD Request # 170 | Receiving historical Intraday Tick data for UAL | 2015-04-29 03:46:59
HD Request # 170 | Receiving Intraday data for UAL starting at 2015-04-28 17:14:23 | 2015-04-29 03:46:59
HD Request # 170 | Received 1 record from 2015-04-28 17:14:23 to 2015-04-28 17:14:23 (0.0 seconds) and wrote 0 records for UAL | 2015-04-29 03:46:59
HD Request # 170 | Intraday download COMPLETE for UAL. Completion time: 0s. Unique request ID: 172 | 2015-04-29 03:46:59
Removed historical data download ID 172 | 2015-04-29 03:46:59
Real-time Intraday chart data file updates started for UAL | 2015-04-29 03:46:59
HD Request # 171 | Downloading Intraday chart data for VXX to the file VXX.scid. Service: dtn | 2015-04-29 03:46:59
HD Request # 171 | Download start Date-Time: 2015-04-28 19:59:39.0 | 2015-04-29 03:46:59
HD Request # 171 | Requesting Tick data beginning at 2015-04-28 19:59:39 US Eastern Time. | 2015-04-29 03:46:59
HD Request # 171 | Receiving historical Intraday Tick data for VXX | 2015-04-29 03:47:00
HD Request # 171 | Receiving Intraday data for VXX starting at 2015-04-28 19:59:39 | 2015-04-29 03:47:00
HD Request # 171 | Received 2 records from 2015-04-28 19:59:39 to 2015-04-28 19:59:39 (0.0 seconds) and wrote 0 records for VXX | 2015-04-29 03:47:00
HD Request # 171 | Intraday download COMPLETE for VXX. Completion time: 1s. Unique request ID: 173 | 2015-04-29 03:47:00
Removed historical data download ID 173 | 2015-04-29 03:47:00
Real-time Intraday chart data file updates started for VXX | 2015-04-29 03:47:00
HD Request # 172 | Downloading Intraday chart data for FB to the file FB.scid. Service: dtn | 2015-04-29 03:47:00
HD Request # 172 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:47:00
HD Request # 172 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:47:00
HD Request # 172 | Receiving historical Intraday Tick data for FB | 2015-04-29 03:47:00
HD Request # 172 | Receiving Intraday data for FB starting at 2015-04-28 19:59:58 | 2015-04-29 03:47:00
HD Request # 172 | Received 1 record from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for FB | 2015-04-29 03:47:00
HD Request # 172 | Intraday download COMPLETE for FB. Completion time: 0s. Unique request ID: 174 | 2015-04-29 03:47:00
Removed historical data download ID 174 | 2015-04-29 03:47:00
Real-time Intraday chart data file updates started for FB | 2015-04-29 03:47:00
HD Request # 173 | Downloading Intraday chart data for AMZN to the file AMZN.scid. Service: dtn | 2015-04-29 03:47:01
HD Request # 173 | Download start Date-Time: 2015-04-28 19:29:10.0 | 2015-04-29 03:47:01
HD Request # 173 | Requesting Tick data beginning at 2015-04-28 19:29:10 US Eastern Time. | 2015-04-29 03:47:01
HD Request # 173 | Receiving historical Intraday Tick data for AMZN | 2015-04-29 03:47:01
HD Request # 173 | Receiving Intraday data for AMZN starting at 2015-04-28 19:29:10 | 2015-04-29 03:47:01
HD Request # 173 | Received 1 record from 2015-04-28 19:29:10 to 2015-04-28 19:29:10 (0.0 seconds) and wrote 0 records for AMZN | 2015-04-29 03:47:01
HD Request # 173 | Intraday download COMPLETE for AMZN. Completion time: 0s. Unique request ID: 175 | 2015-04-29 03:47:01
Removed historical data download ID 175 | 2015-04-29 03:47:01
Real-time Intraday chart data file updates started for AMZN | 2015-04-29 03:47:01
HD Request # 174 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: dtn | 2015-04-29 03:47:01
HD Request # 174 | Download start Date-Time: 2015-04-28 19:59:48.0 | 2015-04-29 03:47:01
HD Request # 174 | Requesting Tick data beginning at 2015-04-28 19:59:48 US Eastern Time. | 2015-04-29 03:47:01
HD Request # 174 | Receiving historical Intraday Tick data for AAPL | 2015-04-29 03:47:02
HD Request # 174 | Receiving Intraday data for AAPL starting at 2015-04-28 19:59:48 | 2015-04-29 03:47:02
HD Request # 174 | Received 1 record from 2015-04-28 19:59:48 to 2015-04-28 19:59:48 (0.0 seconds) and wrote 0 records for AAPL | 2015-04-29 03:47:02
HD Request # 174 | Intraday download COMPLETE for AAPL. Completion time: 1s. Unique request ID: 176 | 2015-04-29 03:47:02
Removed historical data download ID 176 | 2015-04-29 03:47:02
Real-time Intraday chart data file updates started for AAPL | 2015-04-29 03:47:02
HD Request # 175 | Downloading Intraday chart data for XOm to the file XOm.scid. Service: dtn | 2015-04-29 03:47:02
HD Request # 175 | Download start Date-Time: 2015-04-28 19:59:49.0 | 2015-04-29 03:47:02
HD Request # 175 | Requesting Tick data beginning at 2015-04-28 19:59:49 US Eastern Time. | 2015-04-29 03:47:02
HD Request # 175 | Receiving historical Intraday Tick data for XOM | 2015-04-29 03:47:02
HD Request # 175 | Receiving Intraday data for XOm starting at 2015-04-28 19:59:49 | 2015-04-29 03:47:02
HD Request # 175 | Received 1 record from 2015-04-28 19:59:49 to 2015-04-28 19:59:49 (0.0 seconds) and wrote 0 records for XOm | 2015-04-29 03:47:02
HD Request # 175 | Intraday download COMPLETE for XOm. Completion time: 0s. Unique request ID: 177 | 2015-04-29 03:47:02
Removed historical data download ID 177 | 2015-04-29 03:47:02
Real-time Intraday chart data file updates started for XOm | 2015-04-29 03:47:02
HD Request # 176 | Downloading Intraday chart data for @ym#C to the file @ym#C.scid. Service: dtn | 2015-04-29 03:47:02
HD Request # 176 | Download start Date-Time: 2015-04-29 03:36:39.0 | 2015-04-29 03:47:02
HD Request # 176 | Requesting Tick data beginning at 2015-04-29 03:36:39 US Eastern Time. | 2015-04-29 03:47:02
HD Request # 176 | Receiving historical Intraday Tick data for @YM#C | 2015-04-29 03:47:03
HD Request # 176 | Receiving Intraday data for @ym#C starting at 2015-04-29 03:36:39 | 2015-04-29 03:47:03
HD Request # 176 | Timestamp of first Intraday data file record written: 2015-04-29 03:36:47 | 2015-04-29 03:47:03
HD Request # 176 | Received 8 records from 2015-04-29 03:36:39 to 2015-04-29 03:37:04 (25.0 seconds) and wrote 7 records for @ym#C | 2015-04-29 03:47:03
HD Request # 176 | Intraday download COMPLETE for @ym#C. Completion time: 1s. Unique request ID: 178 | 2015-04-29 03:47:03
Removed historical data download ID 178 | 2015-04-29 03:47:03
Real-time Intraday chart data file updates started for @ym#C | 2015-04-29 03:47:03
HD Request # 177 | Downloading Intraday chart data for BRK.B to the file BRK.B.scid. Service: dtn | 2015-04-29 03:47:03
HD Request # 177 | Download start Date-Time: 2015-04-28 17:01:29.0 | 2015-04-29 03:47:03
HD Request # 177 | Requesting Tick data beginning at 2015-04-28 17:01:29 US Eastern Time. | 2015-04-29 03:47:03
HD Request # 177 | Receiving historical Intraday Tick data for BRK.B | 2015-04-29 03:47:03
HD Request # 177 | Receiving Intraday data for BRK.B starting at 2015-04-28 17:01:29 | 2015-04-29 03:47:03
HD Request # 177 | Received 1 record from 2015-04-28 17:01:29 to 2015-04-28 17:01:29 (0.0 seconds) and wrote 0 records for BRK.B | 2015-04-29 03:47:03
HD Request # 177 | Intraday download COMPLETE for BRK.B. Completion time: 0s. Unique request ID: 179 | 2015-04-29 03:47:03
Removed historical data download ID 179 | 2015-04-29 03:47:03
Real-time Intraday chart data file updates started for BRK.B | 2015-04-29 03:47:03
HD Request # 178 | Downloading Intraday chart data for V to the file V.scid. Service: dtn | 2015-04-29 03:47:03
HD Request # 178 | Download start Date-Time: 2015-04-28 19:57:15.0 | 2015-04-29 03:47:03
HD Request # 178 | Requesting Tick data beginning at 2015-04-28 19:57:15 US Eastern Time. | 2015-04-29 03:47:03
HD Request # 178 | Receiving historical Intraday Tick data for V | 2015-04-29 03:47:04
HD Request # 178 | Receiving Intraday data for V starting at 2015-04-28 19:57:15 | 2015-04-29 03:47:04
HD Request # 178 | Received 1 record from 2015-04-28 19:57:15 to 2015-04-28 19:57:15 (0.0 seconds) and wrote 0 records for V | 2015-04-29 03:47:04
HD Request # 178 | Intraday download COMPLETE for V. Completion time: 0s. Unique request ID: 180 | 2015-04-29 03:47:04
Removed historical data download ID 180 | 2015-04-29 03:47:04
Real-time Intraday chart data file updates started for V | 2015-04-29 03:47:04
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2015-04-29 03:49:37
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2015-04-29 03:49:37
Connection to the external service has been lost. | 2015-04-29 03:49:37
Socket (41) | Shutdown and closed. | 2015-04-29 03:49:37
IQFeed | Disconnected from Level 2 port. | 2015-04-29 03:49:37
Socket (40) | Shutdown and closed. | 2015-04-29 03:49:37
IQFeed | Disconnected from Lookup port. | 2015-04-29 03:49:37
Socket (39) | Shutdown and closed. | 2015-04-29 03:49:37
IQFeed | Disconnected from Level 1 port. | 2015-04-29 03:49:37
Socket (38) | Shutdown and closed. | 2015-04-29 03:49:37
IQFeed | Disconnected from Admin port. | 2015-04-29 03:49:37
IQFeed | Fully disconnected. | 2015-04-29 03:49:37
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-29 03:49:37
IQFeed | Connecting. | 2015-04-29 03:49:42
Starting DTN IQ Feed interface software. | 2015-04-29 03:49:42
IQFeed | Connecting to Admin port 9300 | 2015-04-29 03:49:42
Socket (42) | Connected. | 2015-04-29 03:49:42
IQFeed | Connected to Admin port. | 2015-04-29 03:49:42
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2015-04-29 03:49:42
AdminMessage: S,STATS,66.112.148.223,60003,500,0,20,1,23,0,Apr 29 3:49AM,Apr 29 3:49AM,Connected,5.1.1.3,423970,558.17,0.02,279.08,5385.43,0.04,2692.72, | 2015-04-29 03:49:43
IQFeed | Connecting to Level 1 port 5009 | 2015-04-29 03:49:43
Socket (43) | Connected. | 2015-04-29 03:49:43
IQFeed | Connected to Level 1 port. | 2015-04-29 03:49:43
IQFeed | Connecting to Lookup port 9100 | 2015-04-29 03:49:43
IQFeed | Connecting to Level 2 port (9200)... | 2015-04-29 03:49:43
Socket (44) | Connected. | 2015-04-29 03:49:43
IQFeed | Connected to Historical Data port. | 2015-04-29 03:49:43
IQFeed | Fully connected. | 2015-04-29 03:49:43
Socket (45) | Connected. | 2015-04-29 03:49:43
IQFeed | Connected to Level 2 port. | 2015-04-29 03:49:43
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:49:43
IQFeed | Level 2 protocol is 5.0. | 2015-04-29 03:49:43
IQFeed | Level 1 system message: KEY | 2015-04-29 03:49:43
IQFeed | Level 1 system message: SERVER CONNECTED | 2015-04-29 03:49:43
IQFeed | Level 1 system message: IP | 2015-04-29 03:49:43
IQFeed | Level 1 system message: CUST | 2015-04-29 03:49:43
IQFeed | Starting real-time market data updates for: V. ID: 1 | 2015-04-29 03:49:43
Intraday data recording state for symbol V is set to download pending. | 2015-04-29 03:49:43
HD Request # 179 | Downloading Intraday chart data for V to the file V.scid. Service: dtn | 2015-04-29 03:49:43
HD Request # 179 | Download start Date-Time: 2015-04-28 19:57:15.0 | 2015-04-29 03:49:43
HD Request # 179 | Requesting Tick data beginning at 2015-04-28 19:57:15 US Eastern Time. | 2015-04-29 03:49:43
IQFeed | Starting real-time market data updates for: QQQ. ID: 2 | 2015-04-29 03:49:43
Intraday data recording state for symbol QQQ is set to download pending. | 2015-04-29 03:49:43
IQFeed | Starting real-time market data updates for: @YM#C. ID: 3 | 2015-04-29 03:49:43
Intraday data recording state for symbol @YM#C is set to download pending. | 2015-04-29 03:49:43
IQFeed | Starting real-time market data updates for: LNKD. ID: 4 | 2015-04-29 03:49:43
Intraday data recording state for symbol LNKD is set to download pending. | 2015-04-29 03:49:43
IQFeed | Starting real-time market data updates for: TSLA. ID: 5 | 2015-04-29 03:49:43
Intraday data recording state for symbol TSLA is set to download pending. | 2015-04-29 03:49:43
IQFeed | Starting real-time market data updates for: @ES#C. ID: 6 | 2015-04-29 03:49:43
Intraday data recording state for symbol @ES#C is set to download pending. | 2015-04-29 03:49:43
IQFeed | Starting real-time market data updates for: TWTR. ID: 7 | 2015-04-29 03:49:43
Intraday data recording state for symbol TWTR is set to download pending. | 2015-04-29 03:49:43
HD Request # 179 | Receiving historical Intraday Tick data for V | 2015-04-29 03:49:43
HD Request # 179 | Receiving Intraday data for V starting at 2015-04-28 19:57:15 | 2015-04-29 03:49:43
HD Request # 179 | Received 1 record from 2015-04-28 19:57:15 to 2015-04-28 19:57:15 (0.0 seconds) and wrote 0 records for V | 2015-04-29 03:49:43
HD Request # 179 | Intraday download COMPLETE for V. Completion time: 0s. Unique request ID: 181 | 2015-04-29 03:49:43
Removed historical data download ID 181 | 2015-04-29 03:49:43
Real-time Intraday chart data file updates started for V | 2015-04-29 03:49:43
HD Request # 180 | Downloading Intraday chart data for QQQ to the file QQQ.scid. Service: dtn | 2015-04-29 03:49:43
HD Request # 180 | Download start Date-Time: 2015-04-28 19:44:40.0 | 2015-04-29 03:49:43
HD Request # 180 | Requesting Tick data beginning at 2015-04-28 19:44:40 US Eastern Time. | 2015-04-29 03:49:43
IQFeed | Starting real-time market data updates for: BABA. ID: 8 | 2015-04-29 03:49:43
Intraday data recording state for symbol BABA is set to download pending. | 2015-04-29 03:49:43
IQFeed | Starting real-time market data updates for: SPY. ID: 9 | 2015-04-29 03:49:43
Intraday data recording state for symbol SPY is set to download pending. | 2015-04-29 03:49:43
IQFeed | Starting real-time market data updates for: NKE. ID: 10 | 2015-04-29 03:49:43
Intraday data recording state for symbol NKE is set to download pending. | 2015-04-29 03:49:43
IQFeed | Starting real-time market data updates for: @NQ#C. ID: 11 | 2015-04-29 03:49:43
Intraday data recording state for symbol @NQ#C is set to download pending. | 2015-04-29 03:49:43
IQFeed | Starting real-time market data updates for: UAL. ID: 12 | 2015-04-29 03:49:43
Intraday data recording state for symbol UAL is set to download pending. | 2015-04-29 03:49:43
IQFeed | Starting real-time market data updates for: VXX. ID: 13 | 2015-04-29 03:49:43
Intraday data recording state for symbol VXX is set to download pending. | 2015-04-29 03:49:43
IQFeed | Starting real-time market data updates for: FB. ID: 14 | 2015-04-29 03:49:43
Intraday data recording state for symbol FB is set to download pending. | 2015-04-29 03:49:43
IQFeed | Starting real-time market data updates for: AMZN. ID: 15 | 2015-04-29 03:49:43
Intraday data recording state for symbol AMZN is set to download pending. | 2015-04-29 03:49:43
IQFeed | Starting real-time market data updates for: AAPL. ID: 16 | 2015-04-29 03:49:43
Intraday data recording state for symbol AAPL is set to download pending. | 2015-04-29 03:49:43
IQFeed | Starting real-time market data updates for: XOm. ID: 17 | 2015-04-29 03:49:43
Intraday data recording state for symbol XOm is set to download pending. | 2015-04-29 03:49:43
IQFeed | Starting real-time market data updates for: BRK.B. ID: 18 | 2015-04-29 03:49:43
Intraday data recording state for symbol BRK.B is set to download pending. | 2015-04-29 03:49:43
HD Request # 180 | Receiving historical Intraday Tick data for QQQ | 2015-04-29 03:49:43
HD Request # 180 | Receiving Intraday data for QQQ starting at 2015-04-28 19:44:40 | 2015-04-29 03:49:43
HD Request # 180 | Received 4 records from 2015-04-28 19:44:40 to 2015-04-28 19:44:40 (0.0 seconds) and wrote 0 records for QQQ | 2015-04-29 03:49:43
HD Request # 180 | Intraday download COMPLETE for QQQ. Completion time: 1s. Unique request ID: 182 | 2015-04-29 03:49:44
Removed historical data download ID 182 | 2015-04-29 03:49:44
Real-time Intraday chart data file updates started for QQQ | 2015-04-29 03:49:44
HD Request # 181 | Downloading Intraday chart data for @YM#C to the file @YM#C.scid. Service: dtn | 2015-04-29 03:49:44
HD Request # 181 | Download start Date-Time: 2015-04-29 03:39:32.0 | 2015-04-29 03:49:44
HD Request # 181 | Requesting Tick data beginning at 2015-04-29 03:39:32 US Eastern Time. | 2015-04-29 03:49:44
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:49:44
HD Request # 181 | Receiving historical Intraday Tick data for @YM#C | 2015-04-29 03:49:44
HD Request # 181 | Receiving Intraday data for @YM#C starting at 2015-04-29 03:39:32 | 2015-04-29 03:49:44
HD Request # 181 | Timestamp of first Intraday data file record written: 2015-04-29 03:39:45 | 2015-04-29 03:49:44
HD Request # 181 | Received 17 records from 2015-04-29 03:39:32 to 2015-04-29 03:39:46 (14.0 seconds) and wrote 15 records for @YM#C | 2015-04-29 03:49:44
HD Request # 181 | Intraday download COMPLETE for @YM#C. Completion time: 0s. Unique request ID: 183 | 2015-04-29 03:49:44
Removed historical data download ID 183 | 2015-04-29 03:49:44
Real-time Intraday chart data file updates started for @YM#C | 2015-04-29 03:49:44
HD Request # 182 | Downloading Intraday chart data for LNKD to the file LNKD.scid. Service: dtn | 2015-04-29 03:49:44
HD Request # 182 | Download start Date-Time: 2015-04-28 19:46:00.0 | 2015-04-29 03:49:44
HD Request # 182 | Requesting Tick data beginning at 2015-04-28 19:46:00 US Eastern Time. | 2015-04-29 03:49:44
HD Request # 182 | Receiving historical Intraday Tick data for LNKD | 2015-04-29 03:49:45
HD Request # 182 | Receiving Intraday data for LNKD starting at 2015-04-28 19:46:00 | 2015-04-29 03:49:45
HD Request # 182 | Received 1 record from 2015-04-28 19:46:00 to 2015-04-28 19:46:00 (0.0 seconds) and wrote 0 records for LNKD | 2015-04-29 03:49:45
HD Request # 182 | Intraday download COMPLETE for LNKD. Completion time: 0s. Unique request ID: 184 | 2015-04-29 03:49:45
Removed historical data download ID 184 | 2015-04-29 03:49:45
Real-time Intraday chart data file updates started for LNKD | 2015-04-29 03:49:45
HD Request # 183 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: dtn | 2015-04-29 03:49:45
HD Request # 183 | Download start Date-Time: 2015-04-28 19:59:10.0 | 2015-04-29 03:49:45
HD Request # 183 | Requesting Tick data beginning at 2015-04-28 19:59:10 US Eastern Time. | 2015-04-29 03:49:45
HD Request # 183 | Receiving historical Intraday Tick data for TSLA | 2015-04-29 03:49:45
HD Request # 183 | Receiving Intraday data for TSLA starting at 2015-04-28 19:59:10 | 2015-04-29 03:49:45
HD Request # 183 | Received 1 record from 2015-04-28 19:59:10 to 2015-04-28 19:59:10 (0.0 seconds) and wrote 0 records for TSLA | 2015-04-29 03:49:45
HD Request # 183 | Intraday download COMPLETE for TSLA. Completion time: 0s. Unique request ID: 185 | 2015-04-29 03:49:45
Removed historical data download ID 185 | 2015-04-29 03:49:45
Real-time Intraday chart data file updates started for TSLA | 2015-04-29 03:49:45
HD Request # 184 | Downloading Intraday chart data for @ES#C to the file @ES#C.scid. Service: dtn | 2015-04-29 03:49:45
HD Request # 184 | Download start Date-Time: 2015-04-29 03:39:29.0 | 2015-04-29 03:49:45
HD Request # 184 | Requesting Tick data beginning at 2015-04-29 03:39:29 US Eastern Time. | 2015-04-29 03:49:45
HD Request # 184 | Receiving historical Intraday Tick data for @ES#C | 2015-04-29 03:49:46
HD Request # 184 | Receiving Intraday data for @ES#C starting at 2015-04-29 03:39:29 | 2015-04-29 03:49:46
HD Request # 184 | Timestamp of first Intraday data file record written: 2015-04-29 03:39:39 | 2015-04-29 03:49:46
HD Request # 184 | Received 44 records from 2015-04-29 03:39:29 to 2015-04-29 03:39:46 (17.0 seconds) and wrote 40 records for @ES#C | 2015-04-29 03:49:46
HD Request # 184 | Intraday download COMPLETE for @ES#C. Completion time: 1s. Unique request ID: 186 | 2015-04-29 03:49:46
Removed historical data download ID 186 | 2015-04-29 03:49:46
Real-time Intraday chart data file updates started for @ES#C | 2015-04-29 03:49:46
HD Request # 185 | Downloading Intraday chart data for TWTR to the file TWTR.scid. Service: dtn | 2015-04-29 03:49:46
HD Request # 185 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:49:46
HD Request # 185 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:49:46
HD Request # 185 | Receiving historical Intraday Tick data for TWTR | 2015-04-29 03:49:46
HD Request # 185 | Receiving Intraday data for TWTR starting at 2015-04-28 19:59:58 | 2015-04-29 03:49:46
HD Request # 185 | Received 3 records from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for TWTR | 2015-04-29 03:49:46
HD Request # 185 | Intraday download COMPLETE for TWTR. Completion time: 0s. Unique request ID: 187 | 2015-04-29 03:49:46
Removed historical data download ID 187 | 2015-04-29 03:49:46
Real-time Intraday chart data file updates started for TWTR | 2015-04-29 03:49:46
HD Request # 186 | Downloading Intraday chart data for BABA to the file BABA.scid. Service: dtn | 2015-04-29 03:49:46
HD Request # 186 | Download start Date-Time: 2015-04-28 19:58:41.0 | 2015-04-29 03:49:46
HD Request # 186 | Requesting Tick data beginning at 2015-04-28 19:58:41 US Eastern Time. | 2015-04-29 03:49:46
HD Request # 186 | Receiving historical Intraday Tick data for BABA | 2015-04-29 03:49:47
HD Request # 186 | Receiving Intraday data for BABA starting at 2015-04-28 19:58:41 | 2015-04-29 03:49:47
HD Request # 186 | Received 1 record from 2015-04-28 19:58:41 to 2015-04-28 19:58:41 (0.0 seconds) and wrote 0 records for BABA | 2015-04-29 03:49:47
HD Request # 186 | Intraday download COMPLETE for BABA. Completion time: 1s. Unique request ID: 188 | 2015-04-29 03:49:47
Removed historical data download ID 188 | 2015-04-29 03:49:47
Real-time Intraday chart data file updates started for BABA | 2015-04-29 03:49:47
HD Request # 187 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: dtn | 2015-04-29 03:49:47
HD Request # 187 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:49:47
HD Request # 187 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:49:47
HD Request # 187 | Receiving historical Intraday Tick data for SPY | 2015-04-29 03:49:47
HD Request # 187 | Receiving Intraday data for SPY starting at 2015-04-28 19:59:58 | 2015-04-29 03:49:47
HD Request # 187 | Received 1 record from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for SPY | 2015-04-29 03:49:47
HD Request # 187 | Intraday download COMPLETE for SPY. Completion time: 0s. Unique request ID: 189 | 2015-04-29 03:49:47
Removed historical data download ID 189 | 2015-04-29 03:49:47
Real-time Intraday chart data file updates started for SPY | 2015-04-29 03:49:47
HD Request # 188 | Downloading Intraday chart data for NKE to the file NKE.scid. Service: dtn | 2015-04-29 03:49:47
HD Request # 188 | Download start Date-Time: 2015-04-28 16:32:54.0 | 2015-04-29 03:49:47
HD Request # 188 | Requesting Tick data beginning at 2015-04-28 16:32:54 US Eastern Time. | 2015-04-29 03:49:47
HD Request # 188 | Receiving historical Intraday Tick data for NKE | 2015-04-29 03:49:48
HD Request # 188 | Receiving Intraday data for NKE starting at 2015-04-28 16:32:54 | 2015-04-29 03:49:48
HD Request # 188 | Received 1 record from 2015-04-28 16:32:54 to 2015-04-28 16:32:54 (0.0 seconds) and wrote 0 records for NKE | 2015-04-29 03:49:48
HD Request # 188 | Intraday download COMPLETE for NKE. Completion time: 0s. Unique request ID: 190 | 2015-04-29 03:49:48
Removed historical data download ID 190 | 2015-04-29 03:49:48
Real-time Intraday chart data file updates started for NKE | 2015-04-29 03:49:48
HD Request # 189 | Downloading Intraday chart data for @NQ#C to the file @NQ#C.scid. Service: dtn | 2015-04-29 03:49:48
HD Request # 189 | Download start Date-Time: 2015-04-29 03:39:29.0 | 2015-04-29 03:49:48
HD Request # 189 | Requesting Tick data beginning at 2015-04-29 03:39:29 US Eastern Time. | 2015-04-29 03:49:48
HD Request # 189 | Receiving historical Intraday Tick data for @NQ#C | 2015-04-29 03:49:48
HD Request # 189 | Receiving Intraday data for @NQ#C starting at 2015-04-29 03:39:29 | 2015-04-29 03:49:48
HD Request # 189 | Timestamp of first Intraday data file record written: 2015-04-29 03:39:39 | 2015-04-29 03:49:48
HD Request # 189 | Received 11 records from 2015-04-29 03:39:29 to 2015-04-29 03:39:46 (17.0 seconds) and wrote 10 records for @NQ#C | 2015-04-29 03:49:48
HD Request # 189 | Intraday download COMPLETE for @NQ#C. Completion time: 0s. Unique request ID: 191 | 2015-04-29 03:49:48
Removed historical data download ID 191 | 2015-04-29 03:49:48
Real-time Intraday chart data file updates started for @NQ#C | 2015-04-29 03:49:48
HD Request # 190 | Downloading Intraday chart data for UAL to the file UAL.scid. Service: dtn | 2015-04-29 03:49:48
HD Request # 190 | Download start Date-Time: 2015-04-28 17:14:23.0 | 2015-04-29 03:49:48
HD Request # 190 | Requesting Tick data beginning at 2015-04-28 17:14:23 US Eastern Time. | 2015-04-29 03:49:48
HD Request # 190 | Receiving historical Intraday Tick data for UAL | 2015-04-29 03:49:48
HD Request # 190 | Receiving Intraday data for UAL starting at 2015-04-28 17:14:23 | 2015-04-29 03:49:48
HD Request # 190 | Received 1 record from 2015-04-28 17:14:23 to 2015-04-28 17:14:23 (0.0 seconds) and wrote 0 records for UAL | 2015-04-29 03:49:48
HD Request # 190 | Intraday download COMPLETE for UAL. Completion time: 0s. Unique request ID: 192 | 2015-04-29 03:49:48
Removed historical data download ID 192 | 2015-04-29 03:49:48
Real-time Intraday chart data file updates started for UAL | 2015-04-29 03:49:48
HD Request # 191 | Downloading Intraday chart data for VXX to the file VXX.scid. Service: dtn | 2015-04-29 03:49:48
HD Request # 191 | Download start Date-Time: 2015-04-28 19:59:39.0 | 2015-04-29 03:49:48
HD Request # 191 | Requesting Tick data beginning at 2015-04-28 19:59:39 US Eastern Time. | 2015-04-29 03:49:48
HD Request # 191 | Receiving historical Intraday Tick data for VXX | 2015-04-29 03:49:49
HD Request # 191 | Receiving Intraday data for VXX starting at 2015-04-28 19:59:39 | 2015-04-29 03:49:49
HD Request # 191 | Received 2 records from 2015-04-28 19:59:39 to 2015-04-28 19:59:39 (0.0 seconds) and wrote 0 records for VXX | 2015-04-29 03:49:49
HD Request # 191 | Intraday download COMPLETE for VXX. Completion time: 1s. Unique request ID: 193 | 2015-04-29 03:49:49
Removed historical data download ID 193 | 2015-04-29 03:49:49
Real-time Intraday chart data file updates started for VXX | 2015-04-29 03:49:49
HD Request # 192 | Downloading Intraday chart data for FB to the file FB.scid. Service: dtn | 2015-04-29 03:49:49
HD Request # 192 | Download start Date-Time: 2015-04-28 19:59:58.0 | 2015-04-29 03:49:49
HD Request # 192 | Requesting Tick data beginning at 2015-04-28 19:59:58 US Eastern Time. | 2015-04-29 03:49:49
HD Request # 192 | Receiving historical Intraday Tick data for FB | 2015-04-29 03:49:49
HD Request # 192 | Receiving Intraday data for FB starting at 2015-04-28 19:59:58 | 2015-04-29 03:49:49
HD Request # 192 | Received 1 record from 2015-04-28 19:59:58 to 2015-04-28 19:59:58 (0.0 seconds) and wrote 0 records for FB | 2015-04-29 03:49:49
HD Request # 192 | Intraday download COMPLETE for FB. Completion time: 0s. Unique request ID: 194 | 2015-04-29 03:49:49
Removed historical data download ID 194 | 2015-04-29 03:49:49
Real-time Intraday chart data file updates started for FB | 2015-04-29 03:49:49
HD Request # 193 | Downloading Intraday chart data for AMZN to the file AMZN.scid. Service: dtn | 2015-04-29 03:49:49
HD Request # 193 | Download start Date-Time: 2015-04-28 19:29:10.0 | 2015-04-29 03:49:49
HD Request # 193 | Requesting Tick data beginning at 2015-04-28 19:29:10 US Eastern Time. | 2015-04-29 03:49:49
HD Request # 193 | Receiving historical Intraday Tick data for AMZN | 2015-04-29 03:49:50
HD Request # 193 | Receiving Intraday data for AMZN starting at 2015-04-28 19:29:10 | 2015-04-29 03:49:50
HD Request # 193 | Received 1 record from 2015-04-28 19:29:10 to 2015-04-28 19:29:10 (0.0 seconds) and wrote 0 records for AMZN | 2015-04-29 03:49:50
HD Request # 193 | Intraday download COMPLETE for AMZN. Completion time: 0s. Unique request ID: 195 | 2015-04-29 03:49:50
Removed historical data download ID 195 | 2015-04-29 03:49:50
Real-time Intraday chart data file updates started for AMZN | 2015-04-29 03:49:50
HD Request # 194 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: dtn | 2015-04-29 03:49:50
HD Request # 194 | Download start Date-Time: 2015-04-28 19:59:48.0 | 2015-04-29 03:49:50
HD Request # 194 | Requesting Tick data beginning at 2015-04-28 19:59:48 US Eastern Time. | 2015-04-29 03:49:50
HD Request # 194 | Receiving historical Intraday Tick data for AAPL | 2015-04-29 03:49:50
HD Request # 194 | Receiving Intraday data for AAPL starting at 2015-04-28 19:59:48 | 2015-04-29 03:49:50
HD Request # 194 | Received 1 record from 2015-04-28 19:59:48 to 2015-04-28 19:59:48 (0.0 seconds) and wrote 0 records for AAPL | 2015-04-29 03:49:50
HD Request # 194 | Intraday download COMPLETE for AAPL. Completion time: 0s. Unique request ID: 196 | 2015-04-29 03:49:50
Removed historical data download ID 196 | 2015-04-29 03:49:50
Real-time Intraday chart data file updates started for AAPL | 2015-04-29 03:49:50
HD Request # 195 | Downloading Intraday chart data for XOm to the file XOm.scid. Service: dtn | 2015-04-29 03:49:50
HD Request # 195 | Download start Date-Time: 2015-04-28 19:59:49.0 | 2015-04-29 03:49:50
HD Request # 195 | Requesting Tick data beginning at 2015-04-28 19:59:49 US Eastern Time. | 2015-04-29 03:49:50
HD Request # 195 | Receiving historical Intraday Tick data for XOM | 2015-04-29 03:49:51
HD Request # 195 | Receiving Intraday data for XOm starting at 2015-04-28 19:59:49 | 2015-04-29 03:49:51
HD Request # 195 | Received 1 record from 2015-04-28 19:59:49 to 2015-04-28 19:59:49 (0.0 seconds) and wrote 0 records for XOm | 2015-04-29 03:49:51
HD Request # 195 | Intraday download COMPLETE for XOm. Completion time: 1s. Unique request ID: 197 | 2015-04-29 03:49:51
Removed historical data download ID 197 | 2015-04-29 03:49:51
Real-time Intraday chart data file updates started for XOm | 2015-04-29 03:49:51
HD Request # 196 | Downloading Intraday chart data for BRK.B to the file BRK.B.scid. Service: dtn | 2015-04-29 03:49:51
HD Request # 196 | Download start Date-Time: 2015-04-28 17:01:29.0 | 2015-04-29 03:49:51
HD Request # 196 | Requesting Tick data beginning at 2015-04-28 17:01:29 US Eastern Time. | 2015-04-29 03:49:51
HD Request # 196 | Receiving historical Intraday Tick data for BRK.B | 2015-04-29 03:49:51
HD Request # 196 | Receiving Intraday data for BRK.B starting at 2015-04-28 17:01:29 | 2015-04-29 03:49:51
HD Request # 196 | Received 1 record from 2015-04-28 17:01:29 to 2015-04-28 17:01:29 (0.0 seconds) and wrote 0 records for BRK.B | 2015-04-29 03:49:51
HD Request # 196 | Intraday download COMPLETE for BRK.B. Completion time: 0s. Unique request ID: 198 | 2015-04-29 03:49:51
Removed historical data download ID 198 | 2015-04-29 03:49:51
Real-time Intraday chart data file updates started for BRK.B | 2015-04-29 03:49:51
IQFeed | Level 1 system message: SERVER DISCONNECTED | 2015-04-29 03:51:00
IQFeed | Level 1 connection to data server disconnected. Reconnecting. | 2015-04-29 03:51:00
Connection to the external service has been lost. | 2015-04-29 03:51:00
Socket (45) | Shutdown and closed. | 2015-04-29 03:51:00
IQFeed | Disconnected from Level 2 port. | 2015-04-29 03:51:00
Socket (44) | Shutdown and closed. | 2015-04-29 03:51:00
IQFeed | Disconnected from Lookup port. | 2015-04-29 03:51:00
Socket (43) | Shutdown and closed. | 2015-04-29 03:51:00
IQFeed | Disconnected from Level 1 port. | 2015-04-29 03:51:00
Socket (42) | Shutdown and closed. | 2015-04-29 03:51:00
IQFeed | Disconnected from Admin port. | 2015-04-29 03:51:00
IQFeed | Fully disconnected. | 2015-04-29 03:51:00
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-29 03:51:00
IQFeed | Connecting. | 2015-04-29 03:51:05
Starting DTN IQ Feed interface software. | 2015-04-29 03:51:05
IQFeed | Connecting to Admin port 9300 | 2015-04-29 03:51:05
Socket (46) | Connected. | 2015-04-29 03:51:05
IQFeed | Connected to Admin port. | 2015-04-29 03:51:05
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2015-04-29 03:51:05
AdminMessage: S,STATS,66.112.156.227,60004,500,0,21,1,24,0,Apr 29 3:51AM,Apr 29 3:51AM,Connected,5.1.1.3,423970,630.36,0.02,315.18,6105.15,0.04,3052.57, | 2015-04-29 03:51:06
IQFeed | Connecting to Level 1 port 5009 | 2015-04-29 03:51:06
Socket (47) | Connected. | 2015-04-29 03:51:06
IQFeed | Connected to Level 1 port. | 2015-04-29 03:51:06
IQFeed | Connecting to Lookup port 9100 | 2015-04-29 03:51:06
IQFeed | Connecting to Level 2 port (9200)... | 2015-04-29 03:51:06
Socket (48) | Connected. | 2015-04-29 03:51:06
IQFeed | Connected to Historical Data port. | 2015-04-29 03:51:06
IQFeed | Fully connected. | 2015-04-29 03:51:06
Socket (49) | Connected. | 2015-04-29 03:51:06
IQFeed | Connected to Level 2 port. | 2015-04-29 03:51:06
IQFeed Level 2 error: Account not authorized for Level II | 2015-04-29 03:51:06
IQFeed | Level 2 protocol is 5.0. | 2015-04-29 03:51:06
IQFeed | Level 1 system message: KEY | 2015-04-29 03:51:06
IQFeed | Level 1 system message: SERVER CONNECTED | 2015-04-29 03:51:06
IQFeed | Level 1 system message: IP | 2015-04-29 03:51:06
IQFeed | Level 1 system message: CUST | 2015-04-29 03:51:06
IQFeed | Starting real-time market data updates for: @YM#C. ID: 1 | 2015-04-29 03:51:06
Intraday data recording state for symbol @YM#C is set to download pending. | 2015-04-29 03:51:06
HD Request # 197 | Downloading Intraday chart data for @YM#C to the file @YM#C.scid. Service: dtn | 2015-04-29 03:51:06
HD Request # 197 | Download start Date-Time: 2015-04-29 03:40:53.0 | 2015-04-29 03:51:06
HD Request # 197 | Requesting Tick data beginning at 2015-04-29 03:40:53 US Eastern Time. | 2015-04-29 03:51:06
IQFeed | Starting real-time market data updates for: TSLA. ID: 2 | 2015-04-29 03:51:06
Intraday data recording state for symbol TSLA is set to download pending. | 2015-04-29 03:51:06
IQFeed | Starting real-time market data updates for: LNKD. ID: 3 | 2015-04-29 03:51:06
Intraday data recording state for symbol LNKD is set to download pending. | 2015-04-29 03:51:06
IQFeed | Starting real-time market data updates for: @ES#C. ID: 4 | 2015-04-29 03:51:06
Intraday data recording state for symbol @ES#C is set to download pending. | 2015-04-29 03:51:06
IQFeed | Starting real-time market data updates for: TWTR. ID: 5 | 2015-04-29 03:51:06
Intraday data recording state for symbol TWTR is set to download pending. | 2015-04-29 03:51:06
HD Request # 197 | Receiving historical Intraday Tick data for @YM#C | 2015-04-29 03:51:06
HD Request # 197 | Receiving Intraday data for @YM#C starting at 2015-04-29 03:40:53 | 2015-04-29 03:51:06
HD Request # 197 | Timestamp of first Intraday data file record written: 2015-04-29 03:40:58 | 2015-04-29 03:51:06
HD Request # 197 | Received 7 records from 2015-04-29 03:40:53 to 2015-04-29 03:41:02 (9.0 seconds) and wrote 6 records for @YM#C | 2015-04-29 03:51:06
HD Request # 197 | Intraday download COMPLETE for @YM#C. Completion time: 0s. Unique request ID: 199 | 2015-04-29 03:51:06
Removed historical data download ID 199 | 2015-04-29 03:51:06
[2015-04-29 10:18:14]
This is the reason why:
The connection to the DTN IQ Feed system is controlled by the IQ Feed software. Therefore, please contact IQ Feed about this.
