Date/Time: Sun, 22 Dec 2024 13:33:08 +0000
txt size
View Count: 957
[2015-04-29 05:34:14] |
EuropeanTrader - Posts: 290 |
hi how can I increase the font size in chart value window? thx |
sierraaa.png / V - Attached On 2015-04-29 05:33:56 UTC - Size: 16.08 KB - 337 views |
[2015-04-29 08:04:08] |
You can set this through: Global Settings >> Graphics Settings >> Fonts >> Text Windows >> Select Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
