Date/Time: Sun, 22 Dec 2024 13:56:01 +0000
TPO
View Count: 1427
[2015-04-29 00:37:41] |
User705641 - Posts: 38 |
Hello I have set up a chart with TPO and I have 4 green lines and 4 red lines above and below the distribution blocks. So far I have not found reference to explain these lines. Can you help please |
[2015-04-29 05:33:21] |
These are the Initial Balance Range Extension Lines. They are documented here: https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#ReadingTPOCharts There are the IBR 1-4 Extension Percentage inputs. These set the percentage for each of the 4 Initial Balance Range extension lines. For any extension line that you do not want to display, set the corresponding Percentage input to 0. If you do not want to see any of the Initial Balance Range Extension lines, then set the IBR Extension Display Mode input to None. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-29 05:34:46
