Date/Time: Sun, 22 Dec 2024 13:53:40 +0000
Font issues
View Count: 883
[2015-04-28 23:43:28]
User764269 - Posts: 5
It seems like the only way I could send you a screenshot of my issue was to send you the chart. The problem is that when I go to global settings and then graphics, and then the font tab, it will not let me change any font as a window pops up that says fonts have not been uploaded. go to the control panel and the fonts folder.
However, while I do have fonts folder in my control panel on my computer, there is nothing that I see about uploading and fonts.
Like I said I could only send you my chart and not the little window that pops up as the system wouldn't let me do it.
I hope as you try to change the fonts from my charts, it will do for you what it has been doing for me and we can get this resolved.
http://www.sierrachart.com/image.php?l=1430264191601.png
Thank you very much.
[2015-04-29 04:47:34]
We cannot reproduce the problem and it is an operating system level problem.
However we suspect a small change we made might be triggering it although have no idea why. We are going to make another small change which might solve it.
