Date/Time: Mon, 21 Sep 2026 23:29:21 +0000
How does one create a Breakout Bracket order?
View Count: 2457
[2015-04-28 20:03:34]
Netz - Posts: 19
Is it possible for an one click order at current market price to create a buy and sell order that is offset by a certain amount?
If possible, then to add OCO to that fill?
Thanks!
[2015-04-28 22:55:28]
Yes. These are called Attached Orders and are documented here:
Attached Orders
[2015-04-29 00:36:22]
Netz - Posts: 19
I went through the document before posting for help. Having troubles constructing it. Can you provide an example?
Here is a video explaining what I mean by breakout bracket order: https://www.youtube.com/watch?v=iv3QwfjQyNQ
I understand that I can place 2 OCO entry orders manually a few ticks below the bid and above the ask. Just wondering how to do it with 1 click like in the video.
Thanks much for the info.
[2015-04-29 05:22:36]
It sounds like you just want to enter a Stop order with 2 Attached Orders. Is this correct?
[2015-04-29 05:27:26]
Netz - Posts: 19
Sure, with one click of the button, order to buy above and sell below the current market. Each offset by like 4 ticks, as an example.
Thanks again.
[2015-04-29 16:19:01]
What you are looking for is OCO Buy Stop Sell Stop:
http://www.sierrachart.com/index.php?page=doc/doc_OrderTypes.html#OCOBuyStopSellStop
The documentation also explains how to submit this with one click and have the prices automatically set.
