Date/Time: Sun, 22 Dec 2024 13:21:59 +0000
spreadsheet: need CLOSE stat for current bar
View Count: 1148
[2015-04-28 19:12:57] |
jivetrader - Posts: 410 |
spreadsheet only shows Open, High, Low, Last. how do i get the Close value for the bar?
[2015-04-28 19:14:19] |
This is the same as Last.
[2015-04-28 19:20:29] |
no, there are discrepencies between LAST and CLOSE on 4tick range chart (open=close). i am comparing the chart candle's close to LAST and they are sometimes different. |
[2015-04-29 00:34:03] |
do you need me to show pictures of this or are you already looking into it?
[2015-04-29 00:42:17] |
No, we do not need pictures. We are checking on this today. Update: We do not see any problems with this. The OHLC values for the Range bar type you specified matches exactly what is outputted to the corresponding Sheet when using the Spreadsheet Study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-29 09:52:30
[2015-04-30 16:20:20] |
please explain the discrepencies attached.
sc last does not equal close.png / V - Attached On 2015-04-30 16:20:16 UTC - Size: 129.28 KB - 298 views |
[2015-04-30 17:16:41] |
You are misinterpreting what are the open and close values of the bar.
[2015-04-30 17:21:01] |
thank you i see now. i must be working too hard. also i have the bars colored by studies which are further complicating this thanks for your help. |
