Date/Time: Sun, 22 Dec 2024 13:24:49 +0000
Saving data to a txt/csv or scid.
View Count: 1873
[2015-04-28 16:48:21]
bskogz12 - Posts: 38
I want to be able to store the data from sierra chart to a txt/csv or scid file so i can store volume on some etfs. If possible how can I go about doing this.
[2015-04-28 17:00:40]
Sierra Chart - Max - Posts: 5756
Are you referring to historical Daily data or historical Intraday data?
Historical Daily data is already in a CSV format which is documented here:
https://www.sierrachart.com/index.php?page=doc/doc_TextCSVDataFormat.html
In the case of Intraday data, it can be exported to a CSV format which is documented here:
https://www.sierrachart.com/index.php?page=doc/doc_ImportExport.html
Sierra Chart Support
[2015-04-28 18:38:54]
I'm asking if it's possible to save from Sierra charts to the txt file so i can store historical data.
[2015-04-28 18:53:38]
Our answer is the same.
[2015-04-28 23:08:38]
Intraday data.
[2015-04-28 23:28:40]
All data that Sierra Chart downloads and receives in real-time is stored and can be exported.
