Date/Time: Sat, 23 Nov 2024 00:08:15 +0000
historical high /low on MACD
View Count: 1877
[2013-06-03 06:13:43] |
User45578 - Posts: 49 |
When i chose high/low or hh/ll on studies and when applyin on MACD chart i get srached! Why ?How to do in getting historical high and low lines upon a determined period on MACD charts Thanks
[2013-06-03 06:17:02] |
is it possible to get "rotation factor"(of DALTON) upon TPO charts?
[2013-06-03 17:27:51] |
vegasfoster - Posts: 444 |
In response to your first post, it works fine on my system. Maybe post a few pics of what you are trying to do.
[2013-06-03 19:13:14] |
We are not familiar with "rotation factor". For what period of time do you want to get the historical high/low of on the MACD? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-03 20:31:02] |
thanks for answers,for MACD i want the lowest low of the 120 lasts periodes
[2013-06-06 00:14:24] |
This is not a common request. Probably you should have a look at the Highest High/Lowest Low Over N Bars study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s54 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
