Date/Time: Sun, 22 Dec 2024 12:02:08 +0000
calculating Double Stochastic in ACSIL
View Count: 908
[2015-04-28 10:11:48]
User36750 - Posts: 14
Good morning,
Is it possible to calculate a Double stochastic by using sc.DoubleStochastic in ACSIL but based on a different Close/Last than the in the DataBaseIn. I want to use another Close/Last so i can see what the DS will be when a certain price is hit.
I hope you can help me out. Thanks!
Kind regards Bram
[2015-04-28 10:39:09]
This is not straightforward to do. We recommend taking the code for double stochastic and modifying it to meet your requirements.
You can find the source code in the /ACS_Source folder where Sierra Chart is installed to on your system.
[2015-04-28 14:14:45]
Okay thanks so far! What i will try now is to make a normal Double Stochastic calculation with the source code in order to understand better what is happening in the calculation before i change the Close/Last input into the Close of a previous closed bar of another time frame. Can you please see my attached file to see if i am on the right track for the normal DS calculation?
Kind regards Bram
attachmentDSzelfgemaakt.cpp - Attached On 2015-04-28 14:14:29 UTC - Size: 3.32 KB - 488 views
