Date/Time: Sun, 22 Dec 2024 12:11:32 +0000
Broadband speed
View Count: 951
[2015-04-27 22:32:42] |
User41512 - Posts: 58 |
Hi, what is the minimum, and also the optimal, internet connection speeds, required to run multiple charts at the same time. Thks |
[2015-04-28 04:43:35] |
This is not possible for us to answer the question but we do have this documentation here which might be helpful: https://www.sierrachart.com/index.php?page=doc/doc_DataSourceSettings.html#BandwidthUsage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
