Date/Time: Sun, 22 Dec 2024 12:00:18 +0000
historical data as CSV
View Count: 904
[2015-04-27 16:36:03]
User22153 - Posts: 46
Hello Support,
Can I download historical data as a CSV file?
[2015-04-28 03:45:15]
Are you referring to historical Daily data or historical Intraday data?
Historical Daily data is already in a CSV format which is documented here:
https://www.sierrachart.com/index.php?page=doc/doc_TextCSVDataFormat.html
In the case of Intraday data, it can be exported to a CSV format which is documented here:
https://www.sierrachart.com/index.php?page=doc/doc_ImportExport.html
