Date/Time: Sun, 22 Dec 2024 12:51:39 +0000
2 feeds
View Count: 837
[2015-04-27 14:42:27] |
EuropeanTrader - Posts: 290 |
Hi, if I connect TopStepTrader's data feed and trade through them, is it still possible that I have couple of charts powered from FXCM data feed at the same time in one SC instance? thanks |
[2015-04-27 17:10:21] |
No, this is not supported. You need to install an additional copy of Sierra Chart. Here are the instructions: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
