Date/Time: Sun, 22 Dec 2024 12:09:33 +0000
POC color
View Count: 901
[2015-04-27 13:39:18] |
EuropeanTrader - Posts: 290 |
Hi why is POC not colored as pink, as the middle one should be, please? It works on other markets thank you http://www.sierrachart.com/image.php?l=1430141654665.png |
[2015-04-28 04:41:51] |
We do not have an explanation for this. We have no idea whether this would matter or not, but right-click before that volume Profile and select Delete Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
