Date/Time: Fri, 22 Nov 2024 20:10:13 +0000
Contiguous Delta Bars with same timestamp..
View Count: 1723
[2013-06-03 01:29:49]
maxpi - Posts: 181
Can this be? NQM13 symbol, data from Barchart, settings are intraday, delta bars[444], starting at 00:00:00, ending 23:59:59. On May 31 I see two bars next to each other, each with timestamp 06:42:00. I'm not used to thinking in terms of delta bars but this just doesn't seem right.
[2013-06-03 03:48:15]
When you use 1 minute bars, do you see any repeating timestamps?
[2013-06-03 04:40:44]
maxpi - Posts: 181
no repeating timestamps with 1 minute bars. No log messages about out of order timestamps or any irregularities either.
[2013-06-03 04:47:31]
maxpi - Posts: 181
I changed the bar interval to 100 and I get twelve contiguous bars timestamped 6:42:00.. I guess this could actually be the case if there was one big order at the ask or bid.. it would be split into a lot of bars.. probably nothing wrong at all. It just wasn't something I was used to seeing...
[2013-06-04 01:59:19]
Yes, this does make sense.
