Date/Time: Sun, 22 Dec 2024 08:28:23 +0000
Price Column Width After Font Change
View Count: 859
[2015-04-27 11:54:52] |
Ez - Posts: 53 |
Hi, Sorry for these dumb questions but I'm having trouble restoring the price column width after experimenting with larger Global fonts. Initially I had this phenomenon in the Trading Dom and now I'm getting it with other charts as well. Once I auditioned a larger font it expanded the column and upon returning to a smaller font the column width remains expanded. Is there a way to reset the column width? thx |
[2015-04-27 11:57:24] |
Chart >> Reload
