Date/Time: Sun, 22 Dec 2024 12:46:43 +0000
sc.BaseDateTimeIn question
View Count: 970
[2015-04-27 05:04:02] |
enemyspy - Posts: 306 |
I am wondering if anyone can help me with this small chunk of code...see the line with a bunch of asterisks beside it. The time value that shows up on the subgraph/spreadsheet, returns a date value with time 0:00:00. Would it have anything to do with trying to place it in a float array? else if(bkt[j] >0 && (zclass[j] ==3 || zclass[j] == 4)) //if we have an downside breakout { for (int k = i+1; k < sc.ArraySize; k++) //find stuff { if(hi[k]>Patthi[j]) { dead[j] =1; deadx[j] = sc.BaseDateTimeIn.TimeAt(j);//************ } } if(dead[j] == 0) { d1[j] = d1[i-1]+1; } else { d1[j] =d1[j-1]; } } Date Time Of Last Edit: 2015-04-27 05:15:41
[2015-04-27 07:07:30] |
For more information, refer to this page here: https://www.sierrachart.com/index.php?page=doc/doc_SCDateTime.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-27 18:58:56] |
is there an indicator in the source code that exemplifies how you get the date time at the current index and pass it into a subgraph?
[2015-04-27 19:52:47] |
This will not work accurately and once the Date and Time are in the Subgraph, they could not be displayed since there is no support for that.
[2015-04-27 20:30:10] |
Ok so without using a subgraph is it possible to store the accurate value using a nested for loop where: for (int j = sc.Index; j >0; j--) { if() //something happens { for (int k = i+1; k < sc.ArraySize; k++) { if()//something happens some_kind_of_array_that_is_not_a_subgraph[j] = thetimestamp[k]) without printing the time stamp in a Subgraph, is it possible to compare the |
[2015-04-28 18:22:37] |
You could use persistent SCDateTime variables. The function for this is documented here: https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#scGetPersistentInt Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
