Date/Time: Sun, 22 Dec 2024 07:56:58 +0000
Fonts installed
View Count: 891
[2015-04-27 02:03:18] |
User764269 - Posts: 5 |
Here is what I have so far. Sierra Charts is telling me I have no fonts installed. I went to my control panel on my computer and I do have a Fonts program, so I don't know what else they want me to do. Just to let you know, I went to Global Setting, clicked on graphic settings. Then I saw Chart text and clicked on the fonts tab. When I do that there is a button that says select and next to it there is another box that says sample 1234 but when I look at your instructions and the pictures that I see, I do not have another box naming certain types of fonts like your instructions shows. Therefore when I click on the select box it tells me that I do not have any fonts loaded and to go to my control panel. This I've already done, but I'm not having any progress yet. Thank you |
[2015-04-27 02:35:41] |
Can you provide us a screenshot where it says there are no fonts loaded on the computer. Here are instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
