Date/Time: Sun, 22 Dec 2024 08:23:35 +0000
Line Tool
View Count: 770
[2015-04-26 14:42:26]
JRA - Posts: 97
When I am using the line tool in a diagonal direction, after the charts progress and new bars are printed it loose its second anchor point, unless I lock it. When I am doing the same thing with the ray line tool it doesn't have that problem. Is this the way that tool behaves or am I doing something wrong?
[2015-04-26 22:30:36]
Are you talking about when you are actively using the Line tool or after it has already been drawn on the chart and new bars are added?
[2015-04-27 00:01:44]
Also refer to this help topic:
https://www.sierrachart.com/index.php?page=doc/helpdetails34.html
