Date/Time: Sun, 22 Dec 2024 07:49:31 +0000
Time Range Highlight - Transparent?
View Count: 1042
[2015-04-25 20:22:50] |
User93103 - Posts: 48 |
Hello: Is it possible to set the Time Range Highlight - Transparent to a multiple time period within 24 hours? For example, set it to every other hour. Vertical Grids does help, but coloring is more useful. Thank you God Bless Ben |
[2015-04-26 09:28:56] |
You can add another instance of that study to the chart.
