Date/Time: Sun, 22 Dec 2024 08:22:04 +0000
Display a selected date chart
View Count: 831
[2015-04-25 01:14:05] |
User78439 - Posts: 21 |
I am using SC for a back testing with 1m chart. I choose for a period of 60 day. But with so many date implied, it is possible to type SOMEWHERE for a selected date so that only this date chart display on screen ? Currently, I use scrollbar at chart bottom to find a specific date but it is really time-consuming.
[2015-04-25 06:26:21] |
Yes this can be done. Refer to these Chart Settings: http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#LastDatetoDisplay Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
