Date/Time: Thu, 12 Nov 2026 23:28:12 +0000
sc.GetStudyArrayFromChartUsingID
View Count: 1353
| [2015-04-24 22:34:55] |
| CustomIndicators - Posts: 126 |
I'm trying to make a manual loop that checks conditions on every chart I have up. For this, it would be easier if I could just specify the chart number outside of the defaults. Instead of this: SCInputRef StudySubgraphReference = sc.Input[0];
if (sc.SetDefaults) { StudySubgraphReference.Name = "Study And Subgraph To Display"; StudySubgraphReference.SetChartStudySubgraphValues(1,1, 0); return; } SCFloatArray StudyReference; sc.GetStudyArrayFromChartUsingID(StudySubgraphReference.GetChartStudySubgraphValues(), StudyReference); Can I just use this?: SCFloatArray StudyReference;
int chartNumber = 1; sc.GetStudyArrayFromChartUsingID(chartNumber, 1, 0, StudyReference); |
| [2015-04-25 06:16:32] |
We see what you want to do. This function will be added to the next release: void sc.GetStudyArrayFromChartUsingID(int ChartNumber, int StudyID , int SubgraphIndex, SCFloatArrayRef SubgraphArray)
We will try to have this out in one or two more days. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-04-25 21:23:48] |
Thank you! That should help me out a lot. I appreciate it. :)
| [2015-04-28 16:10:38] |
I've been watching for new updates on the change log, but haven't seen one yet. When will the update be coming out?
| [2015-04-28 18:44:07] |
There is a new version out now.
