Date/Time: Sun, 22 Dec 2024 08:22:45 +0000
Emailed Questions
View Count: 823
[2015-04-24 21:26:25] |
Sierra Chart - Max - Posts: 5756 |
I'm still trying to figure it out. I am so confused. I can't get Ray's moving averages to appear correctly. He has them for the different time frames. For instance, the 200 sma (simply moving average) would be 200 sma on the 5 minute, but on the 15, it would be 67, the 30 minute 34, etc. When I put on the 200 sma, it just shows 200 sma on all time frames.So I have no clue how to adjust time frames to make my charts functional--not sure I ever will. I will keep trying. Hopefully someone will explain to me how to do my charts correctly. Sierra Chart Support |
[2015-04-25 06:07:18] |
The only way to accomplish this is to set up a separate chart for each chart bar time frame you want. And then apply the correct moving average to that chart. Here are instructions to open a chart: http://www.sierrachart.com/index.php?page=doc/doc_GettingStarted.php#ConnectingtoData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
