Date/Time: Fri, 11 Sep 2026 12:06:15 +0000
Iqfeed
View Count: 1701
| [2015-04-24 19:20:32] |
| User25116 - Posts: 27 |
I am not using sierra feed any more and I am using iQfeed I need to disable the rhimatic sierra log in and have iQfeed. I cant make a trade because of this
| [2015-04-25 00:55:05] |
It looks like you are currently using IQ Feed. Here are the set up instructions if you need them: http://www.sierrachart.com/index.php?page=doc/DTNIQFeed.html#Setup Are you having any trouble with IQ Feed currently? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-04-26 23:01:46] |
I am not having problem with IQ feed. I talked with Optimus and they said that Rithmic is logging at the same time as IQ feed and I need to disable SC data because I cant take a live trade and it jumps me into "Sim" even though I disable it. Optimus said there is a process to disable SC data. I have all the log in infor mation set up with IQ feed and I am able to use their feed and it reads their symbols, but I just cant take a live trade. Can you send me the how to disable the multiple feeds and just to one.
| [2015-04-27 00:26:45] |
You cannot submit an order while connected to the IQ Feed Data service. Install another copy of Sierra Chart and set it to use your Rithmic account. Here are the instructions to install another copy of Sierra Chart: Using Multiple Data and Trading Services at the Same Time Here are instructions to set that new copy of Sierra Chart to use Rithmic: http://www.sierrachart.com/index.php?page=doc/Rithmic.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-04-27 15:32:05] |
I was able to install a copy of Sierrachart2 and I believe I was able to succeed in following the instructions but I don't see the "R" on the copy chart what I do have is this "@ES#/ES-201203-GLOBEX" but I don't see the "R"
| [2015-04-27 15:36:16] |
I don't know but if the "R" isn't showing up does that mean I cant take a trade still because I tried and it jumped me into SIM
| [2015-04-27 17:07:37] |
The first thing we want you to do is set up one of your copies of Sierra Chart to use Rithmic, and we want to make sure you are receiving market data from Rithmic and you can trade from that instance. Here are the Rithmic set up instructions: Rithmic Trading Platform Service: Setup Instructions Is the objective that you want to use IQ Feed for market data and trade through Rithmic? If so, Rithmic data is already good and we do not see any advantage with using IQ Feed in your case especially being you are using Optimus. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-04-27 18:39:21] |
I went through the steps and I happened to delete the chart in the edit and I am having trouble trying to bring it up
| [2015-04-27 18:39:55] |
is there a way you guys can just do all this for me ill pay if I have to
| [2015-04-27 19:50:50] |
Yes we can help you. But we can only help you get connected to Rithmic.
| [2015-04-28 00:53:01] |
I have a snapshot of the chart on the left which is from IQfeed on advance decline NYSE and the chart on the left is from Sierra feed I want to have the Sierra chart to read like the one on the left, that is why I wanted to have IQfeed but your team said you can make so the chart or feed can replicate the chart on left so if you can make that work I wont have to use IQfeed.
| [2015-04-28 03:25:56] |
If you want to use IQ Feed for market statistics, then continue to use it for that. The Sierra Chart market statistics will always be a little different than IQ Feed because the source stock data feed is different and there are probably slight differences with the calculations also. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
