Date/Time: Sun, 22 Dec 2024 12:00:47 +0000
[User Discussion] - Column # Compare Thresholds alert
View Count: 885
[2015-04-24 15:25:27] |
User277546 - Posts: 8 |
Hi, Column # Compare Thresholds colors the number bar but i would like to put an alarm on it. Is it possible and if yes how? thanks |
[2015-04-28 19:45:29] |
So you are preparing it for the next update...
[2015-04-28 23:06:02] |
This is not currently planned.
