Date/Time: Sun, 22 Dec 2024 08:17:17 +0000
chicago
View Count: 856
[2015-04-24 15:06:51] |
ichimoku - Posts: 4 |
Whether volume of forward exchange contracts being real time from Chicago Stock Exchange is available on sierrachart? (eur, jpy, gbp, aud, nzd, gold, us500, crude oil) |
[2015-04-24 18:27:07] |
If you are referring to the Chicago Mercantile Exchange, Sierra Chart supports real-time futures data from the CME for all of these markets. You can use the Sierra Chart Exchange Data Feed: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php Or use one of the supported trading services: http://www.sierrachart.com/index.php?page=doc/data.php#Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
