Date/Time: Fri, 22 Nov 2024 19:26:51 +0000
New spread sheet studies are blank
View Count: 1996
[2013-06-02 21:00:50]
enemyspy - Posts: 306
When I add a spreadsheet study to the list of indicators on a chart and name it to something new it comes up blank with no information in it at all.
What could be causing this and how do I fix it?
Date Time Of Last Edit: 2013-06-02 21:01:25
[2013-06-03 01:23:57]
Sawtooth - Posts: 4118
It will be blank if it's new. What information are you expecting to be in it?
Are you trying to rename an existing spreadsheet and retain the formulas?
[2013-06-04 00:36:10]
Normally the data from the indicators on the chart populate the spread sheet...but in this case they are not. There is nothing there.
[2013-06-04 00:47:03]
Make sure you are looking at the correct Sheet# within the Spreadsheet window.
[2013-06-04 04:09:17]
Yes...That was the first thing I did before positing this...and just did it again to verify that every sheet is completely blank with nothing on it.
[2013-06-04 05:31:42]
Are you running the non-CLR version of Sierra Chart?
