Date/Time: Sun, 22 Dec 2024 08:34:25 +0000
Edit Functions Failure
View Count: 836
[2015-04-24 11:34:47]
User94740 - Posts: 333
Hi SC, version 1249 edit command fails to execute the following functions:
-export intraday data to text file
-export and edit intraday data
-import and load intraday data
[2015-04-24 19:07:39]
Make sure first to select File >> Disconnect because some or all of these will require that you are disconnected from the data feed.
[2015-04-24 19:29:56]
gracias!
