Date/Time: Sun, 22 Dec 2024 13:54:28 +0000
Drawing lines from x1,y1 to x2,y2
View Count: 1198
[2015-04-24 10:50:00] |
marcovth - Posts: 61 |
Hello ... Before I am making an attempt using something like FreeGlut ... Is it possible with ACSIL to have precise line drawing control with x1,y1 to x2,y2 coordinates? http://www.transmissionzero.co.uk/computing/using-glut-with-mingw/ |
[2015-04-24 12:24:15] |
Another question ... I am located in the New York EST time zone. For some of my code, I programmed the NYSE market to start at 9:30:00. How do I code that for someone in London the NYSE market is also starting at 9:30:00 EST and not at 9:30:00 local time? Also, for the serious coders, could the number of ints and floats be doubled in struct s_PersistentVariables ? Date Time Of Last Edit: 2015-04-24 12:29:05
[2015-04-24 14:57:56] |
Other than with a time and sales study, is there another way with ACSIL to obtain the very latest Bid and Ask volume per Price? Is there something like sc.LastAskVolume and sc.LastAskPrice? Thanks. |
[2015-05-01 16:54:34] |
Is there an option some where in SC to turn off the screen saver while SC is being actively used. When you watch video's, the screen saver doesn't turn on as well. |
[2015-05-01 19:37:09] |
In response to post #1, refer to: https://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#CustomFreeFormDrawing In response to post #2, we do not fully understand the question or exactly what you want to do, to answer the question about Session Times. You should be able to determine this on your own. Refer to these new functions for persistent variables: https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#scGetPersistentInt The other questions are not within the scope of our support. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
