Date/Time: Sun, 22 Dec 2024 08:04:40 +0000
[User Discussion] - Volume by Price with , calc devPOC and VA together with Draw Peaks & Valleys
View Count: 778
[2015-04-24 09:21:54]
User465208 - Posts: 7
i am new to SC and its great. but usability and finding setting is quite a task ....
It does not work to have dev.POC and drawing Peaks & Valleys at the same time in one chart.
I have enabled the setting but only one of the selected work at a time.
I need to set calc. dev.POC to "no" that draw P&V work.
I want both the same time on the same chart running. What am I doing wrong ?
Thx
MK
